 Old 12-31-2008, 03:03 PM   #1
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Default When all else fails.... cut material away from it!
Testing is done with the stock AR housing. It took 3 times to the CNC and 2 AR housings but we got it.
Some of you know that the stock pre turbo pressures are close to 2.4 to 1. We have been able to drop these pressures and get additional flow out of the stock AR housing. How you ask? Simple, we CNC the scroll area and then finish it up by hand (polish). We have been doing this to the SRT4 Neon for about 3 years now and every manifold that we sell for the Neon seems to get 15 WHP and 20 WTQ.... we are expecting the same from the Mazdaspeed.
Pressure levels are down to a more controllable 1.8 to 1.9 to 1 and this is allowing for more air flow and reduction in EGT's. This unit will come with everyone of our SST for the Mazdaspeed and we will be offering them separate for $275 + shipping and core for those that are looking for that little extra from your stock turbo. Power gains are across the curve with the most gains be noticed at redline. We will be testing one on a SST turbo here very soon and should have dyno results of before and after on a stock turbo here very soon.
What we do to the units:
CNC the scroll area
port the whole feed into the scroll
open up the WGA flapper hole to keep boost creep in check (needed on the SST upgrade)
full porting of the area after the scroll disscharge (opened up to reduce aft turbo pressures)
Full Ceramic coatings of the AR housing
This allows for a huge increase in flow and better WGA controll for boosted on-off applications.
Pictures are as follows (left to right):
Side by side, stocker vs porte unit (we had not polished this unit yet, sorry)
Stock unit
Ported unit
Ported flapper
Stock flapper (opening)
Side by side ported vs stocker
Machined unit (2" disk just about falls through the scroll area)
Stock unit (2" disk had to be forced into the scroll area)
Finished port work after we hand finish the CNC work
I will be adding these to the site here in a bit so you guys can start ordering them up.
I hope you like what you see.
ptperformance is offline   Reply With Quote
The Following User Says Thank You to ptperformance For This Useful Post:
gsrtype1 (01-01-2009)
 Old 12-31-2008, 03:05 PM   #2
Forgot to mention that there is an additional 200 RPM worth of lag added to the turbo. The pay off is very much worth it due to the car pulling much harder to redline.
 Old 12-31-2008, 03:09 PM   #3
Posts: 12,651   (View Stats)
Looking forward to the back to back dyno.
 Old 12-31-2008, 03:21 PM   #4
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
Groans: 49
cant wait to see proof to back up the pic.Im looking for as superstocker
boosted3 is offline   Reply With Quote
 Old 12-31-2008, 03:25 PM   #5
yah this is def a viable option for me.
 Old 12-31-2008, 06:56 PM   #6
Dyno should be in 2 weeks if not sooner, thanks guys.
 Old 01-01-2009, 12:51 AM   #7
bf360's Avatar
Posts: 2,069   (View Stats)
seems like everyday your thinking of new ways to improve on the sst, thumbs up for that
i really like the added lag it should add, along with lowering egt's
i will definitely be watching the sst in 09 as a likely option
 Old 01-01-2009, 11:00 PM   #8
boosted3's Avatar
Groans: 49
Yea same here i got a big meet in june to attend and i m hoping to choose a sst before then.But want one thats gona give me the reliability and power.Cant wait for dynos.
 Old 01-01-2009, 11:56 PM   #9
bf360's Avatar
meet? que? which meet
 Old 01-02-2009, 02:54 PM   #10
Thanks guys, I am debating on doing the SST with the new manifold on the car or not, still have to figure out what I want to do. I will be on the dyno next week for sure for some base line testing then we will be getting the new AR housing installed. I have to see if we can install the ceramic coated DNP then or not and get this non coated unit off the car. Decisions decisions?
 Old 01-03-2009, 08:41 PM   #11
b-ron's Avatar
Posts: 470   (View Stats)
b-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud ofb-ron has much to be proud of
sent u a pm
2005 evo 8: mbc @ 25 psi,air filter,kelford 280 cams, tbe and tune 316awhp 297tq mustang dyno
b-ron is offline   Reply With Quote
 Old 02-07-2009, 04:00 PM   #12
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Update?
 Old 02-07-2009, 06:45 PM   #13
babcockxmx's Avatar
Posts: 539   (View Stats)
babcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the world
Groans: 52
john will be back in a month
2007 BM MS3
babcockxmx is offline   Reply With Quote
 Old 02-10-2009, 07:33 PM   #14
Originally Posted by b-ron View Post
sent u a pm
Thanks, got it.
Update?
We need the AP in order to get rid of this f'ing fuel cut. Working that angle now.
I'mmmm backkkk.
 Old 02-10-2009, 08:29 PM   #15
babcockxmx's Avatar
Groans: 52
^lol
2007 BM MS3
HTML code is On
Industry aid fails in the Senate Haltech Automotive News 0 12-11-2008 08:20 PM
UAW official: If GM fails, so will Ford Haltech Automotive News 0 11-20-2008 01:50 PM
Trans mount material is signed off on.... ptperformance Mazdaspeed3/6 General Discussion 6 10-30-2008 06:03 PM
An upside of the big slide: Raw material prices dip and#x2014; for now Haltech Automotive News 0 10-19-2008 10:00 PM
RENNTECH fails Copyright Infringement 101 Haltech Automotive News 0 05-22-2008 12:50 PM
Page generated in 0.58977 seconds with 28 queries
