Notices
Like Tree3Likes
  • 2 Post By Keko
  • 1 Post By speedms6
 Old 10-17-2012, 04:20 PM   #1
dale_gribble's Avatar
Posts: 1,048   (View Stats)
Groaned at 7 Times in 4 Posts
Default Why does my WOT AFR always dip @ 4,900RPMs?
From as long as I have been logging with my AP and during my time with Lex e-tuning, I have always seen my AFRs dip from ~11.0:1 to ~10.5:1 between 4800-5200. The AFR always stabilizes after 5200 back to the previous levels.
I have stacked every logged variable against the dip across multiple logs and there isn't a single event that happens that coincides with the dip. I have checked every single log field against the dip. No KR, no boost changes, nothing.
I see others' WOT runs where the AFR is a perfectly straight line past 4,000.
Maybe this is inline with others' experiences. It doesn't seem to impact power; my power/torque curves are always very smooth. I am just curious as to why I see this dip.
dale_gribble is online now   Reply With Quote
 Old 10-17-2012, 04:34 PM   #2
Actually, I did find one thing that coincides with each dip. The calculated load appears to spike very slightly during the AFR dip. Is that what does it?
The calculated load changed during this dip on each run:
1.81-1.85
1.77-1.81
1.62-1.66
1.68-1.71
 Old 10-17-2012, 04:56 PM   #3
I can't find anything in the load tables that would command this little load bump at these RPMs...
 Old 10-17-2012, 05:33 PM   #4
Keko's Avatar
Posts: 1,336   (View Stats)
Groans: 97
Do you have a speed6? I was reading a post earlier today that was talking exactly about this. I think it had to do with VVT changing to 0 at this load or something?
2012 MS3
Stratified 91
Aeroforce Interceptor | Pennzoil Plat 10W-30 | FoMoCo XT-M5-QS
15% Tint
Keko is online now   Reply With Quote
The Following User Says Thank You to Keko For This Useful Post:
dale_gribble (10-17-2012)
 Old 10-17-2012, 05:36 PM   #5
I do have a speed6... Interesting...
2006 MS6 WWP Sport
Autotech guts | Sure Aeros Full 3" CAI mod | CS race pipe | 18x8 TR C2 | 235/40
Turbosmart BPV | AP | Stratified | 3" dual catback | SU tmic | Autoexe springs
Do Stage 2 WMI D07 50/50 | Derale 190F fan controller
Next: NATOR down pipe
 Old 10-17-2012, 05:38 PM   #6
Keko's Avatar
Groans: 97
Graph your VVT on that also, it should intersect where the load peak/afr dip is
2012 MS3
Stratified 91
15% Tint
 Old 10-17-2012, 05:48 PM   #7
Keko's Avatar
Groans: 97
Finally found it. That was bugging me. This is quoted directly from Phate:
You also have a spike in calc'd load when VVT -> 0°. It's an MS6 thing that started with one of the last few releases of ATR. If you keep VVT just above 0 through the top end rev range, it won't spike. Ghetto work around, but it works and you won't lose power. That (the spike) will put you in higher load cells, where you will run less timing = less power.
his post has an image
rfinkle2 and dale_gribble like this.
2012 MS3
Stratified 91
15% Tint
The Following 3 Users Say Thank You to Keko For This Useful Post:
dale_gribble (10-17-2012), phate (11-01-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 07:55 PM   #8
speedms6's Avatar
Posts: 816   (View Stats)
dale_gribble i have been having the absolute same exact problem, only started happening a couple atr releases ago, what vvt are you gonna run to red line, is 2 good enough to keep it from spiking?
 Old 10-17-2012, 09:16 PM   #9
I am literally about to make a run with 1 degree vvt and will report back soon.
2006 MS6 WWP Sport
 Old 10-17-2012, 10:46 PM   #10
I still see the dip with +1 on VVT FYI. Plus, now I have KR and my power dipped a bit...
 Old 10-18-2012, 05:34 AM   #11
speedms6's Avatar
i made up a map with 2* last night, havent had a chance to run it yet, but drove ti to work this morning, also retarded the timing a bit, gonna figure this out first then get back to tuning the timing
 Old 10-18-2012, 05:59 AM   #12
rfinkle2's Avatar
Posts: 12,548   (View Stats)
Groans: 235
Lex would probably want to know about this, as I know he is particular and thorough.
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
rfinkle2 is online now   Reply With Quote
phate (11-01-2012)
 Old 10-18-2012, 06:35 AM   #13
highest hp speed6 in cali
Joe Isuzu's Avatar
Posts: 4,793   (View Stats)
Joe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the worldJoe Isuzu is the leader of the world
Groans: 192
Groaned at 326 Times in 194 Posts
vvt kickin in bro
Joe Isuzu is offline   Reply With Quote
The Following 4 Users Say Thank You to Joe Isuzu For This Useful Post:
Caveman4684 (11-27-2012), djuosnteisn (11-15-2012), Pointless (11-02-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 09:33 AM   #14
speedms6's Avatar
just went out and took some logs, i dont have a screen print of my vvt table but from where it would usually be 0 i had 3 for a coupl columns then down to 2 deg for the last few, its seemed like it may have worked, felt smoother, but when i get home and have atr i'll post some logs
The Following 2 Users Say Thank You to speedms6 For This Useful Post:
dale_gribble (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 07:01 PM   #15
speedms6's Avatar
it worked. thank god now i can get my afr's back in order, btw the reason the afrs are so low is because i have the 2150 psi rail valve and im trying to see if i can get the pressure to not hit 2073 and give me fuel cut, no luck yet though, always happens around 6000 rpm
anyway, attached first is a print screen of my vvt table, second a random old log that shows the dip and spike in load when the vvt goes to zero, and third is the log from today showing no dip and spike in load, i retarded my timing alot, gonna get my afr's all straight then up the timing some more, may also check out if i get any increases with vvt increase before i do timing, in know its been found on small turbos you dont, but i do have the reworked k04 so maybe a little up top could help
dale_gribble rfinkle2
dale_gribble (11-01-2012), rfinkle2 (10-19-2012)
 Old 11-01-2012, 02:45 PM   #16
speedms6 - hows your work been going with this? Any updates? I would love to know where your VVT and timing tables ended up relative to when you started.
I still haven't decided to trade my AFR dip with another set of problems until I got your feedback.
 Old 11-02-2012, 05:51 AM   #17
speedms6's Avatar
dale_gribble well i pretty much have the same vvt table i believe, i played around a little bit, but i really dont have time to get logs at consistent temps and where i live i have to drive like 10 mins to find a perfectly flat road thats good for a solid 4th gear pull
that being said i really dont think vvt adjustments up top will net much gain on a k04, i barely saw any differences that would lead me to think otherwise.
i think i ran 8 vvt out to 5000 rpms like the cobb maps(or maybe 5 i cant remember) and then two from there on out, the main thing is it cured the load dip and spike, no more of that, feels much smoother.
i also upped ignition i tihnk maybe a degree or 2 and the only kr i ever get is like .35 on spool up, so i tihnk i still have some more room, last vd i took, was consistent 290's for hp, no eth. so i dont think thats too bad, temps were somewhere between 60-65 degs.
ohhh and forgot to mention, i havent been on atr, since last thursday, and my comp at home is dead and i have no power. so until i get power back from this storm(which i dont think will be till friday the 9th, probably wont be doing much tuning.
 Old 11-02-2012, 10:54 AM   #18
86azms3's Avatar
Posts: 2,991   (View Stats)
86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world
Groans: 237
Groaned at 70 Times in 36 Posts
Load is calculated off of airflow....so you're getting a bit of an anomaly at that certain rpm in the maf tube. Me thinks.
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP,
Turbosmart Hybrid bpv, SURE TIG's + coolant bypass,
ITV24's, CP-E 75d RMM, Medefail Tranny mount,
DDM 35W 6000K HID's, SURE Counterweight,
18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's
390whp/400wtq
86azms3 is offline   Reply With Quote
 Old 11-02-2012, 11:06 AM   #19
Eth Fiend
phate's Avatar
Posts: 4,254   (View Stats)
phate has disabled reputation
you should be able to move where vvt goes to zero, and watch a corresponding shift in the load spike. VVT is definitely in the calc.
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
 Old 11-02-2012, 11:44 AM   #20
speedms6's Avatar
its 100% by vvt, when my vvt previously went to zero there was a spike, at the exact point in the log where it went to 0, changed it to two across the board, zero dip or spike and only thing i changed was vvt
The Following User Says Thank You to speedms6 For This Useful Post:
phate (11-02-2012)
 Old 11-15-2012, 02:56 PM   #21
Captain
djuosnteisn's Avatar
Posts: 11,163   (View Stats)
Groans: 79
Very weird VVT is affecting the ecu perceived load. I haven't looked at any of the maps, but is it safe to assume the spark advance simply drops a bit due to the higher calc load, not just mysteriously on it's own, right?
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
djuosnteisn is online now   Reply With Quote
 Old 11-15-2012, 02:59 PM   #22
Eth Fiend
phate's Avatar
Yep, totally correct. It just seems to change the load calc and everything else follows the new load curve at that point.
 Old 11-15-2012, 03:55 PM   #23
speedms6's Avatar
in my log(the first one before i changed the vvt) the only thing that changes is the vvt, the ign adv. stays exactly the same, well not the same but it just continues rising steadily as it should via my tune, i can post my tune from that if you would like, just gotta do some searching, but as soon as i changed the vvt just to target 2 instead of zero it completely fixed it
djuosnteisn (11-16-2012)
 Old 11-15-2012, 05:03 PM   #24
Eth Fiend
phate's Avatar
It depends on how you have the timing tables set up and what the conditions were like. I've now seen a few cars do this and the ignition tables follow the altered load curve. Would be interesting to see yours.
 Old 11-15-2012, 06:32 PM   #25
speedms6's Avatar
phate; now that i think about it you're right, i have my timing the same for the bottom 5-ish rows, since in the upper rpms im not going over 2.0 load i didnt want variations in timing due to different temps since im running a boost tune, one sec let me find an older map and a corresponding log
phate (11-15-2012)
 Old 11-15-2012, 06:38 PM   #26
speedms6's Avatar
attached are an old log and the map i was running and a newer log from a couple days ago and my most recent map, still working on upper rpm timing i think i had a loose bracket on the intake mani that was giving me a little false kr, before i did that most recent log so i lowered timing there and now i get none, also have the ptp hprv so i get fuel cut around 6000k so i cant rev real high, still lose power anyway past there, and my ap(old dongle) logs slow as shit, still good for 290 on the VD with no e85
dale_gribble (11-26-2012), phate (11-15-2012)
 Old 11-15-2012, 07:54 PM   #27
Eth Fiend
phate's Avatar
phate now that i think about it you're right, i have my timing the same for the bottom 5-ish rows, since in the upper rpms im not going over 2.0 load i didnt want variations in timing due to different temps since im running a boost tune, one sec let me find an older map and a corresponding log
Thanks for posting those. Yours is a bit tough to see with the slow logging rate, but I think we still get a good idea of what's occurring. If you look at calc'd load vs MAF, you can see the load increases pretty dramatically whereas MAF is just a steady increase in the same region (just north of 4500 rpm). You're also well above the load level where you have static ignition values.
PS - Since you're hitting such high loads, why not scale the load axis?
dale_gribble (11-26-2012), rfinkle2 (11-27-2012)
 Old 11-15-2012, 08:10 PM   #28
speedms6's Avatar
you can scale the load axis in atr? must have missed the boat on that one, if i'm getting this right, you mean i can scale the load axis like you scale a maf, just so say when i get 2.5 load i can scale it to read 1.8 in atr or something?
also once xmas is over and i presents and shit im gonna call cobb and see about getting a replacement ap the log rate is absurdly slow on mine
 Old 11-15-2012, 08:23 PM   #29
Eth Fiend
phate's Avatar
Yes, scaling the load axis in the ATR tables. Beware the Ign 'max' tables don't automatically change like the rest of them...just go play with it and check it out, it's one of the best features we've gotten recently
dale_gribble (11-26-2012), rfinkle2 (11-27-2012), speedms6 (11-15-2012)
 Old 11-26-2012, 08:58 PM   #30
speedms6, have you scaled your load axis yet? That makes perfect sense. I would love to get your feedback on this.
 Old 11-27-2012, 04:33 AM   #31
speedms6's Avatar
nope havent been in atr for a while, had a lot going on with thanksgiving and stuff, i am also not really sure how to 100% go about the scaling, like i get the idea of it and all, but the only time i go over 2.0 load is really when i go wot, and things are running find now, i'lll have to take some time and look into it and see what works
HTML code is On
Page generated in 0.52537 seconds with 27 queries
