> Cobb Tuning
Like Tree2Likes
  • 2 Post By avesfan101
 Old 06-27-2015, 11:01 AM   #1
SPEEDO90's Avatar
Posts: 79   (View Stats)
SPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the rough
Groaned at 9 Times in 5 Posts
Default base map needed!
Hey guys! I need A base map or a map tweak. I have the AP v2 and my mods are as followed. cobb sf intake, cobb tih, autotech hpfp and ebay catless dp. I want to know if anyone hear can help me with a base make for my dp mode till I can get a full tune PLEASE! I can pay up..
SPEEDO90 is offline   Reply With Quote
The Following User Says NO Thank You to SPEEDO90 For This Un-useful Post:
Vansquish (07-13-2015)
 Old 06-27-2015, 11:40 AM   #2
ms6mil's Avatar
Posts: 4,972   (View Stats)
ms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the world
Groans: 307
Groaned at 6 Times in 6 Posts
What "tweak" do you need that the COBB OTS maps w/DP don't have?
COBB Tuning - Maps
"Here am I. Send me!"
____________________________________________
Columbus, GA 2006 MazdaSpeed 6
EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel
GT3076 - 393/380 3/9 e85
GT3076 - 426/400 E85/DO10 Meth
PTE5862 - TBD
ms6mil is offline   Reply With Quote
 Old 06-27-2015, 11:54 AM   #3
SPEEDO90's Avatar
COBB Tuning - Maps
Cobb ots stage 2 is for catted dp and I have at catless! Or does it not matter?
Sent from my SM-G920T using Tapatalk
 Old 06-27-2015, 11:59 AM   #4
acousticdefbot's Avatar
Posts: 319   (View Stats)
acousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the world
the downpipe has no cat so he needs his wasted gas downpipe closer adjusted.
if you're willing to pay, you might as well go through one of the e-tuners that offer an ots/flash map. all cobb offers is the tool for you to do it. i believe they will dyno tune as well but you're looking at a needless expenditure for what you need. cobb also offers atr free of charge if you're willing to make the adjustments yourself, but i don't want to see you blow up your car.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
 Old 06-27-2015, 12:01 PM   #5
SPEEDO90's Avatar
Okay so basically you're saying that the OTS map I'm using now is no good
 Old 06-27-2015, 12:11 PM   #6
ms6mil's Avatar
Groans: 307
Download ATR and reduce the WGDC tables yourself. pretty simple to do or can walk you through it.
LMAO.... WGDC = Wasted Gas Downpipe Closer... that's a new one.
Seems like over the last couple of days you are being brought up to speed with everything you need, reading your other posts...
Download ATR....
Stay out of Boost until your internals come in
Add a signature of all your mods to include what year vehicle
....report back and me or someone will get you sorted out...
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
chaser27 (07-13-2015)
 Old 06-27-2015, 12:12 PM   #7
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
Are you just concerned with over boosting? It's fairly easy to adjust limits and WGDC so that doesn't happen. OTS maps are pretty conservative. I had similar mods on an OTS map for a while with no problem before I learned how to use ATR. Just monitor so you know if you need to back off. I would suggest you look up a tuning guide and tweak it yourself or just run OTS until you can get the full e-tune.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 06-27-2015, 12:16 PM   #8
OCspeed's Avatar
Posts: 168   (View Stats)
OCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond repute
Groaned at 7 Times in 5 Posts
I think I read something on here that for a catless "starting point" you should lower WG by like 10-15%? Not completely sure..I could be wrong lol. Good luck
Self Tuned: 310 HP / 355 TQ on E85 50/50
2012 black speed3 - AP - CxRacing FMIC - COBB SF - COBB TIP - Ebay catless long DP - XS Power Exhaust Manifold - ARK CBE - AutoTech internals - Rotella T6 - JBR 88 Duro RMM - JBR MudFlaps - DevilsOwn M.I. - GFB Respons 50/50 - AEM DryFlow - NGK Step Colder
Instagram @ mpodboj
www.matiaspodbojracing.yolasite.com
OCspeed is offline   Reply With Quote
 Old 06-27-2015, 12:17 PM   #9
SPEEDO90's Avatar
Thank you so much man preciate it. I just got referred to a local guy here who claims to be a Mazdaspeed enthusiast and tuner he said he will charge me $150 to do 93 and e85 tune he also said that he will do free revisions for me and he will also do the log in for me while I'm in the car! What do yall think?
 Old 06-27-2015, 12:23 PM   #10
ms6mil's Avatar
Groans: 307
Just make sure the guy knows what he's doing, check with other cars that have been tuned by him, check results and compare to other options out there.
learn to log your pulls yourself..
PTE5862 - TBD
The Following 2 Users Say Thank You to ms6mil For This Useful Post:
chaser27 (07-13-2015), Raider (07-13-2015)
 Old 06-27-2015, 12:26 PM   #11
SPEEDO90's Avatar
He tunes his own car and has tuned my friends car too.
 Old 06-27-2015, 12:29 PM   #12
superman's Avatar
That's a great price assuming he knows his stuff. If you trust him with your car go for it! A good tune makes a huge difference with these cars. Let us know how it goes.
 Old 06-27-2015, 12:32 PM   #13
SPEEDO90's Avatar
I'll update next week when it starts. Thanks guys!
 Old 06-29-2015, 11:24 AM   #14
EnixStorm's Avatar
Posts: 108   (View Stats)
EnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond repute
Groaned at 3 Times in 1 Post
Good luck!
Cobb SRI :|: Cobb TIP :|: CPE Stg 2 RMM :|: JBR 70 PMM :|: AutoTech Internals :|: AP V3
EnixStorm is offline   Reply With Quote
 Old 07-13-2015, 05:43 AM   #15
SPEEDO90's Avatar
Originally Posted by g00s3y View Post
I never said anything about I would do the logging for you while you're in the car, that's on you. I said we can meet up to discuss things in person since you are local. Free revisions means while you have the same parts on the car, you won't need to pay anything extra until we finalize the tune.
And while I'm no Freek/Nishan/tuning god... I know how to safely get more power out of these cars very well also.
I Must have misunderstood the logging part, I apologize. But that's fine you don't need to be a God lol couple ppl in town have said your awesome and that's cool with me. I should be ready next week!
I knew iv seen the car on your profile pic somewhere lol
Last edited by SPEEDO90; 07-13-2015 at 05:43 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-13-2015, 07:08 AM   #16
avesfan101's Avatar
Posts: 442   (View Stats)
avesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the world
No offense to the "tuner" here but spend the extra $100 and go with someone reputable who has tuned more than 3 cars. Someone like the aforementioned tuners who know both the limits and nuances of this platform.
Just because a tune isnt super aggressive doesn't mean it's safe. You can still end up with a hole in your block.
Scare Dem and FSUMazdaSpeed like this.
Fuck MSF
avesfan101 is offline   Reply With Quote
The Following 3 Users Say Thank You to avesfan101 For This Useful Post:
Nel Mazdaspeed (07-13-2015), Scare Dem (07-13-2015), Shampu (07-13-2015)
 Old 07-13-2015, 08:42 AM   #17
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
And anyone using MSF to conduct business MUST be an approved vendor. Getting caught using PMs and posts to do business while not approved is subject to permaban.
 Old 07-13-2015, 09:09 AM   #18
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
Guy is local, talked to him on facebook and text. No business was conducted on here.
I love how people automatically assume if you aren't an "MSF approved tuner", you don't know what you're doing. I never once called myself a tuner. And since I'm not "reputable" apparently, it must mean I don't know the "limits and nuances" of this platform. 25,000+ tuned miles on my car, 20,000+ tuned on my friend's who I've tuned and worked on, both still running strong, among the couple others in the area I've also tuned and worked on. Not to mention the hundreds of hours of reading/research I've done to understand what I am doing. Not to only do it, but to feel confident enough to actually charge others for my work.
I already said I wasn't on a level of the MSF tuning gods. But with a k04 powered Mazdaspeed, I know what I'm doing. Now if he had a BT, I would have told him to come here and get a tune from Freek/Nishan/etc. Because I haven't tuned any BT Mazdaspeed, and someone else's motor won't be the guinea pig for me to try it first. The same reason I never offered to tune anyone else I know before I was confident enough with what I was doing with my own car with just the k04.
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
Gr8Speed (07-13-2015), Raider (07-13-2015)
 Old 07-13-2015, 09:14 AM   #19
SPEEDO90's Avatar
I was just going to say that we did not conduct business on here you couldn't say it any better.
The Following 2 Users Say Thank You to SPEEDO90 For This Useful Post:
Raider (07-13-2015), Vansquish (07-13-2015)
 Old 07-13-2015, 09:31 AM   #20
Raider's Avatar
Groans: 856
I agree on many points. My tuner is not approved here either. That said, 400 so called tuners are out there and many are great. Some are sketchy. Few have been banned or outed as dangerous.
I have to take the stand of protecting msf members and figured you knew better than to do business here lol. You know me, I trust nobody and have to make tough calls as a result.
g00s3y (07-13-2015)
 Old 07-13-2015, 09:32 AM   #21
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Gr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the world
Groaned at 123 Times in 84 Posts
Couldn't agree more. You don't even need to know what you're doing with how stupid simple ATR is set up. It's not like you're building a map on a standalone. Cobb's software makes it so easy I could (and have) teach my 11 year old brother the basics of it.
https://www.youtube.com/user/JustinBieberVEVO
Gr8Speed is offline   Reply With Quote
The Following User Says Thank You to Gr8Speed For This Useful Post:
g00s3y (07-13-2015)
 Old 07-13-2015, 09:46 AM   #22
Raider's Avatar
Groans: 856
Not true. Many have tried, and blew up engines of poor unsuspecting owners. There are variables that some asshat with a dated abilors guide and a copy of ATR and a nickname to use can call themselves a tuner.
And because of that, the list of legit tuners is small. And bad ones can blow your motor.
 Old 07-13-2015, 09:50 AM   #23
Gr8Speed's Avatar
Maybe I exaggerated a bit, but it is pretty damn easy if you have a little guidance and some common sense. Yes many have tried and failed, but they were lacking in either one or both of those departments.
 Old 07-13-2015, 10:03 AM   #24
Raider's Avatar
Groans: 856
Their lacking was masked until motors stated detonating left and right.
 Old 07-13-2015, 10:37 AM   #25
g00s3y's Avatar
Groans: 439
Oh yes lol, I've already got a couple infractions for things I've forgotten in the For Sale section. Don't need to get banned from here, I still need this website for it's knowledge.
ATR is simple in it's setup (especially boost tuning), but only after you understand the tables, what they do, and how they work in conjunction with each other. When I first opened up ATR about 2 years ago, I looked and said "fuck that, too much to deal with", and started looking around for a tune. I decided the price to pay someone else to look at a spreadsheet, and edit cells in another program based upon that data, wasn't worth it for me. Especially when I know I could learn it myself, because there is this amazing thing called the internet, and this website comes along with it.
I decided I needed to learn myself when I kept getting fuel cut (because Cobb OTS & catless DP), and didn't want to pay for a tune, just to basically stop that. So started reading and making revisions to a Cobb OTS tune. I also was able to get some good help from this guy Anthony (Drunkmann Tuning, big in the Subie world, had an MS3 for a while) in understanding ATR and how it works. Also helped me understand how the 2.3 we have is quite different from other motors out there. From there it was just more reading every time I came into an issue, or if there was something I didn't understand.
Like I said before, I recently decided I was at the point where I am confident enough with what I do, to be able to actually charge people. I still try to get anyone who asks me about it, to learn themselves first, because I also agree that ATR makes it easy to do, once you understand it all. It's especially easy and safe (imo) with a k04 (on 93) if you have internals, and aren't an idiot who knows how to use google.
The Following User Says Thank You to g00s3y For This Useful Post:
Raider (07-13-2015)
Base map for BT shawn. MazdaSpeed 3/6 - ECU Computer Tuning 9 10-16-2012 05:53 AM
right base map for me trioskater
Cobb ATR Support
4 05-08-2010 03:05 PM
What should I use as my base map GQ_WhiteMS3
Cobb ATR Support
32 05-16-2009 04:25 PM
Page generated in 0.87311 seconds with 29 queries
