> Cobb Tuning
 Old 04-11-2014, 07:01 AM   #1
jucca's Avatar
Posts: 159   (View Stats)
jucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond repute
Default Cobb LC/FFS conversion problems
have done Stratified tune, and went to Cobb web to convert last @Lex; map with LC enabled at 2700 RPM, and FFS at default setting 6700RPM I beleive, LC/FFS default threshold at 6.21MPH, but have found when changing gears above 3000RPM I'm getting huge delay (at least 0.5 sec or even more) with adding gas.
Actually I don't want FFS, just LC, but conversion tool on Cobb site don't allow me without putting FFS and FFS/LC threshold parameters, is there solution of just adding LC and fix with delay I got. Thanks.
Cobb AP V3
Stratified tune
Autotech HPFP internals
M2 DP
JBR PowerPath stg II
Sure RMM
Sure Rear Diff Mount
TurboXS 50/50
Grimspeed EBCS
NGK Iridium step colder
Ebay OCC
EGR delete
3BAR MAP w/ Harness
3" CBE w/ high flow mufflers
Eibach -35mm
18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39
jucca is offline   Reply With Quote
 Old 04-11-2014, 08:53 AM   #2
Posts: 12,651   (View Stats)
Set the FFS rev limiter to the rev limiter of the car at 6700 RPM to not have FFS enabled.
 Old 04-11-2014, 08:56 AM   #3
jucca's Avatar
Thanks Lex, I've actually done that in first.
FFS is solved, but still have problems with gas pedal delay.
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 04-11-2014, 09:02 AM   #4
Do you have this problem with the unmodified map? It may not be related.
 Old 04-11-2014, 09:05 AM   #5
jucca's Avatar
No. But found on your last few maps that RPMs goes for 100-150 in up when changing gears, dont know if you have done that for purpose.
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 04-14-2014, 09:26 AM   #6
jucca's Avatar
Have checked lines, everything seems OK, ECBS is clicking so I supose it work well.
As I remember, we were three in car at that time in pretty inclined hill when it went 25PSI. Wonder how can I stop this happening.
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
Cobb RMM Problems WetzMS3 Cobb Tuning 31 05-08-2014 05:49 AM
Cobb Tuning and engine problems RWDAddict MazdaSpeed 3/6 - ECU Computer Tuning 14 11-17-2011 01:41 PM
anybody have problems with cobb sri and ap stage 1? bowlburner 2010 MS3 - Troubleshoot/Diagnostics 1 11-14-2011 06:15 PM
cobb SRI+TIP no problems??? IRONBAR Gen2 MS3 General Discussion 3 09-20-2011 01:03 PM
Camber problems with COBB/H&R springs? 08BLKMS3 MazdaSpeed 3/6 - Suspension & Brakes 6 05-28-2009 11:05 AM
Page generated in 0.29571 seconds with 21 queries
