> Cobb Tuning
 Old 02-23-2016, 07:18 AM   #1
dinoxor's Avatar
Posts: 346   (View Stats)
dinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the world
Default Cobb Rear Sway bar help
Recently installed a used Rear Sway bar a week ago and was a bit concerned with a few things.
Emailed customer service last week but still no response. Called them but they told me to send them an email...
1) Did I installed these correctly? (Despite the upside down logo)
Note how the ends curve on this stock photo
2) Is this bracket still good to use? There's a minor crack at the weld on the right
3) Bushings looks worn, does anyone know where I can find replacement (1.25 or 32mm) bushings?
Found some Energy Suspension bushings but they don't seems like they're able to handle the abuse
Thanks!
Black Mica 2008.5
CS SRI+TIP • AT HPFP • TP
dinoxor is offline   Reply With Quote
 Old 02-23-2016, 09:13 AM   #2
shamie's Avatar
Posts: 936   (View Stats)
That's got to be the correct way or it would hit. The decal must be flipped. If it were me I'd get a new bracket. JBR has them with bushings. It doesn't look like COBB sells any of their own suspension stuff anymore.
 Old 02-23-2016, 05:28 PM   #3
sheston's Avatar
Posts: 1,847   (View Stats)
Doesn't JBR make some heavy duty sway bar brackets that are really close to the right size?
Just an FYI, your photos are missing some bolts (and brackets) :-)
 Old 02-23-2016, 06:50 PM   #4
dinoxor's Avatar
I know, I like to live dangerously
But yeah Jbr does make brackets but I'm looking for cheaper more temporary solutions at the moment
Black Mica 2008.5
 Old 03-03-2016, 04:53 PM   #5
macdiesel's Avatar
Posts: 824   (View Stats)
macdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the world
If your looking at a cheaper temporary solution have the bracket welded.
2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts//
Coming up: Corksport injector seals
macdiesel is offline   Reply With Quote
 Old 03-03-2016, 05:51 PM   #6
blue speed's Avatar
Posts: 237   (View Stats)
blue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond repute
Groaned at 4 Times in 1 Post
I have the same rear sway bar (but my COBB is right side up) it looks fine just get the bracket wielded. And grease the snot out of the bushings.
Cobb shifter weight, CBE, RSB, knob Corksport BPV, boost tubes, SRI, TIP ,Ex hangers,80 Duro RMM & TMM insert CP-E TMIC, UR test pipe & catted DP, Hypertech, Autotechs. JBR Coolant bypass, intake gasket, air filter & BP hose.Konig wheels. Sure, FSB bushings.
blue speed is offline   Reply With Quote
Page generated in 0.27532 seconds with 24 queries
