> Cobb Tuning
  • 1 Post By mituc
 Old 01-05-2016, 03:31 AM   #1
mituc's Avatar
Posts: 3,526   (View Stats)
Groans: 111
Default Gen1 Cat-Back muffler
The in-cabin noise is ok-ish even though even with the Cobb hangars the mid resonator wants to touch the chassis a little which has an unpleasant impact on the cabin comfort, but with that pretty much addressed (when it gets too close I adjust it) I'm now after lowering the outside noise levels a bit as well as the noise the rear passengers get.
So did anyone fit a muffler to the gen1 Cobb cat-back and can share the dimensions? I'm debating between either fitting a small muffler there (the largest that can fit) or even a catalytic converter which should also tame down the noise a bit. I'm open to suggestions as well, anything else than "leave it as is", simply because the regulations will become stricter over night, probably some politicians are tired of hearing their children complaints about being smashed in their lamborghinis and ferraris every day in night illegal races by small turbocharged hatchbacks.
robbspeed likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
robbspeed (01-05-2016)
GI: CP-E 3" Cat-back for Mazdaspeed 6, single-exit, offroad (no resonator/muffler) RPM Revolution Performance Motorsports 66 03-17-2014 02:08 PM
axel back muffler delete bmannn Gen2 MS3 General Discussion 1 07-21-2011 09:10 AM
Page generated in 0.22518 seconds with 20 queries
