> Cobb Tuning
 Old 03-17-2013, 09:01 AM   #41
alex_speed13's Avatar
Posts: 162   (View Stats)
alex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond repute
so far, an amazing add, vibes are ok, had a swapped urethane from sure and well that brings other vibes than of the RMM, though meanwhile i had only the pmm oem and the RMM was doing an amazing job with minimal noise and vibrations. as far as it concerns, a great product, i would recommend it to anyone.
GenPu:
Cobb AP (Freek tuned ) RMM // AutoTech int. // Jamies 3"cher/ JB TIG's// JB's shortcut// Stratified 3port ebcs// MAttdamond OCC kit// // CPE DP/Triton // ETS TMIC // HKS ssqv IV //Sure s3 track grade (surprisingly good so far)
Someday, i will just get drunk and randomly order a GTX2867 or even a ewg GTX3071, when the bill comes ill shit my pants, but when i'll install it, ill go nuts...
alex_speed13 is offline   Reply With Quote
 Old 04-08-2013, 07:56 AM   #42
Ssvtecsol's Avatar
Posts: 39   (View Stats)
Ssvtecsol is a name known to allSsvtecsol is a name known to allSsvtecsol is a name known to allSsvtecsol is a name known to allSsvtecsol is a name known to allSsvtecsol is a name known to all
I am def thinking of getting this. Anyone have any reviews on how bad the vibrations are at idle? I think this is the only mount I am going to change. I am not going crazy with my MS3 but def want it to shift better than stock. I miss my SI shifting....
Current: 2012 MS3 (Cobb SRI, Magnaflow CBE)
Current: 2006 Yamaha R1
09 Si Civic
07 Del Sol (B16)
Ssvtecsol is offline   Reply With Quote
 Old 04-08-2013, 07:52 PM   #43
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
@COBB: I got my COBB RMM in the mail today and I wonder if it's not damaged (or I'm retarded, or both). I can't screw in the large bolt into the recessed nut all the way. I can maybe get it 25% in. Is this normal? It seems like something is not aligned properly. Threads look ok.
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
 Old 04-09-2013, 12:48 PM   #44
Ryguy's Avatar
Posts: 546   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
Thats as tight as i could get with my hands but its all the way through
Ryguy is offline   Reply With Quote
 Old 04-09-2013, 12:56 PM   #45
XLT_66's Avatar
Posts: 850   (View Stats)
Hey there @moonrider_99;
Could you screw the bolt in with the mount out of the car? I suppose there is a possibility that the nut was pressed in a bit crooked. Usually you can straighten it out by torquing the bolt down to draw the nut in straight.
If it wont' do that, let me know via PM and I'll get a new mount out to you ASAP.
So sorry for the issue!
Edit: Sorry! I thought I was logged in with my Evan@COBB account. Please send a PM to Evan@COBB if you can't get the nut drawn in straight. If it won't, I'll throw the bad mount at the warehouse clerk's head for screwing it up!
2009 CWP MS3 Sport
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
 Old 04-09-2013, 03:28 PM   #46
Thank you for the follow up. I did not try to torque it because I did not want to ruin the threads. Here are the pics. The strange thing is that from the "opposite/wrong" side it goes through the nut no problem so it looks like either the nut or the other hole is not aligned when bolt is inserted the correct way.
Won't go more than this, barely catching the nut on the other side.
Can't see very well but the bolt is barely in
Uploaded with ImageShack.us
Screw it directly into the bolt from the opposite side, no problemo.
2004 MSM
 Old 04-11-2013, 04:42 PM   #47
jrotaryb's Avatar
Posts: 416   (View Stats)
jrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the worldjrotaryb is the leader of the world
Groaned at 17 Times in 5 Posts
I had mine installed today. You can really feel the mount while the car is cranking on a cold start but I'm sure it will break in a bit and calm down. I remember a similar feeling when I had an Ingalls engine torque damper on my last car.
You can also feel the mount when blipping the throttle at a stop but once on the move and the mount has some load on it, there aren't really any vibrations. Past maybe 1200-1500 rpm it's not noticeable.
Wheel hop and torque steer are much improved too...right now I have about 22,300 miles on the car so we'll see how long the break in takes. This weekend I'm goin to NY for a few days so that will be an easy 400 mile round trip.
One note, my installer told me that the vertical bolt was a bit cross threaded and he didn't like how it came out. Possibly a factory error? Or maybe from the dealer last year when I was chasing a small knock over bumps? They told me they tightened everything up (ugh dealers).
So, he re-tapped the threads and put in a new bolt, torqued to spec and assures me all is well. I suppose if they made a mistake, he wouldn't have said anything...
pedal2plastic.wordpress.com
The driving game blog
Liquid Silver 2011 Mazdaspeed 3 w/ Tech Package
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
jrotaryb is offline   Reply With Quote
 Old 04-15-2013, 07:30 PM   #48
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
I would get a torque wrench down there and check it yourself. Mine stripped out and I had to install a helical because the threads were destroyed.
Sent via stocked out for a while ...
Pickles Tune in progress
 Old 04-17-2013, 08:23 AM   #49
jrotaryb's Avatar
I put 600 miles on the mount with our little trip and its definitely calmed down since the first drive. Other than this trip, I really don't drive much...I will have them double check the torque on my next oil change in a couple of months or if I hear any noise. Again, they could have said nothing to me so I think all is fine.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 07-30-2013, 01:56 AM   #50
Dablin's Avatar
Posts: 10   (View Stats)
Dablin is a name known to allDablin is a name known to allDablin is a name known to allDablin is a name known to allDablin is a name known to all
picked mine up saturday at cobb-socal, installed mines on sunday. so far the vibe that initially were present at the beginning are gone now only after 3ish days. I did my 1st launch/pull, fukin tits lol. took a couple turns, almost no wheel hop, I also noticed my clutch got stiffer?
great product cobb!
Dablin is offline   Reply With Quote
 Old 10-22-2013, 08:12 AM   #51
jrotaryb's Avatar
Update - 6 months and about 5000 miles on the mount with no problems to speak of. I've had one oil change since installation (late July) and asked the shop to inspect/check torque...all was ok.
Vibration is non-existent now and still no wheel hop. Another oil change is coming up so I'll have it checked again...
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
The Following 3 Users Say Thank You to jrotaryb For This Useful Post:
atvfreek (10-22-2013), KCi (10-24-2013), wishmaster (10-23-2013)
 Old 11-24-2013, 09:02 PM   #52
darkstar5440's Avatar
Posts: 477   (View Stats)
darkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the world
Groaned at 13 Times in 3 Posts
Sorry to revive a somewhat old thread. But has anyone had problems with the top bushing seperating from the mount? It happened to me about a month ago after a few hard launches at the drag strip. I took it out smacked the bushing back into the mount flush and reinstalled. I was under my car last night and noticed it seperated again. I got about 8,500 miles on the mount and I got a heavy foot. Ive torqued the mount to 75ftlbs and used blue loctite.
OMWTFYB
darkstar5440 is offline   Reply With Quote
 Old 11-24-2013, 09:19 PM   #53
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
Can you snap me a picture? How far is it separated? The mount should be sandwiched in the subframe so I'm thinking the amount is very small? Thanks!
Sent from my HTC One using Tapatalk
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
 Old 11-24-2013, 10:09 PM   #54
I just took it out and smacked it flush again, it seems like the center piece is raised a tad higher than the outer bushing and it works its way out
OMWTFYB
 Old 11-25-2013, 08:24 PM   #55
So is this normal @Evan@COBB; ?
OMWTFYB
 Old 11-25-2013, 09:08 PM   #56
Evan@COBB's Avatar
This is the first I've seen a vehicle that has that kind of room for it to dislodge like that. Let me see it tomorrow when I'm back at a computer.
The Following User Says Thank You to Evan@COBB For This Useful Post:
darkstar5440 (11-25-2013)
 Old 11-25-2013, 09:54 PM   #57
The center bushing is taller than the outer bushing. The center bushing fits snug when I slide the mount into the subframe, after I drive the car the outer bushing seems to work it's way out to the height of the center bushing. I would think both bushings should be the same height? @Evan@COBB;
I'm going to take it out again tomorrow and take a look at it, something is def wrong...this shouldnt be happening. Hopefully its a faulty part and not my subframe fucked up.
OMWTFYB
 Old 11-25-2013, 10:03 PM   #58
Although this is what it looked like when I first got it and the center bushing is taller than the outer one so something went wrong...like I said I'm gonna take it out again tomorrow and investigate
OMWTFYB
 Old 11-27-2013, 08:34 AM   #59
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Me tinks u haz shrinkage....
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
 Old 11-27-2013, 08:36 AM   #60
Elaborate please...me and Evan are trying to figure out why this would possibly happen.
OMWTFYB
 Old 11-27-2013, 08:50 AM   #61
El_Diablo's Avatar
Groans: 769
Temps are getting colder. Different materials or even durometers of the same material will expand and contract at different rates. Think of what happens to your pee-pee when it gets cold. It braves it at first while the boys run and hide.
The Following User Says Thank You to El_Diablo For This Useful Post:
WetzMS3 (11-30-2013)
 Old 11-27-2013, 08:54 AM   #62
@Evan@COBB; what you think? It has been in the 20's here in NJ and that night I was at the track it was in the 40's. This would be the first test in cold weather for this mount right? It was released in the spring?
OMWTFYB
The Following 2 Users Say Thank You to darkstar5440 For This Useful Post:
Koke382 (11-27-2013), WetzMS3 (11-30-2013)
 Old 11-30-2013, 11:04 AM   #63
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
I did an oil change amoung other things today and decided to take a look at my Cobb RMM. I have the same issue it looks like. I didn't remove it, so the pictures are kinda shitty.
It has also been fairly cold here lately. I have also notice more vibrations than a month or two ago.
Is there any word on a resolution or the cause of this?
@Evan@COBB?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
darkstar5440 (11-30-2013)
 Old 11-30-2013, 11:22 AM   #64
Well that's comforting knowing I'm not the only one this has happened to. I'm debating wether or not I should make the switch to jbr. Cobbs customer service has always been outstanding, I have to say that.
@Evan@COBB; what are your thoughts on the bushing wearing out prematurely?
OMWTFYB
The Following User Says Thank You to darkstar5440 For This Useful Post:
 Old 11-30-2013, 02:06 PM   #65
WetzMS3's Avatar
Groans: 430
You're not the only one @darkstar5440. And thanks for addressing it here. I may not have paid much attention to it without your heads up. I really liked the mount until a few weeks ago when it got rougher in some conditions, and this likely happened. I am hoping we got bad apples, and this will not be a common issue. But I'm not sure where my confidence in that is yet.
I know John, @Chuthor, runs the same mount, in similar weather to me. I'd be curious if he has taken a look at his recently and seen any issues. I do drive it really aggressively, and it's seen a lot of pulls in the few months its been in.
Any word from Cobb about a resolution? I'm not sure if it's better to run this mount like this, or the stock until I replace it, and I would rather not have to buy a new one.
2013 MS3 Black Mica
 Old 11-30-2013, 02:12 PM   #66
Me and @Evan@COBB; have exchanged several private messages. I had supplied him with detailed pictures of the mount installed, disassembled, just the pin in the subframe housing, and the pin with the bushings in the housing. My pin fits nice and snug there def is no excessive room like he thought there was.
He told me out of the 850+ mounts they have sold I am the only person to have this problem and he has never seen anything like it. He told me he thinks it doesn't interfere with the way the mount was designed to work, even though the top bushing has become dislodged significantly. He asked for my thoughts and I am curious if the mount will fail later on down the road. He also offered me a full refund and no exchange he seems to think mine is not defective.....I have yet to hear back from him
OMWTFYB
 Old 11-30-2013, 02:20 PM   #67
WetzMS3's Avatar
Groans: 430
Interesting. I sent him a pm before that last post.
I have noticed a difference in feel. So it is not working the way it was intended to, or did for a few months prior in the very least.
I'm glad to hear that so many have been sold with so few issues. I would prefer to run this mount over a rougher similar preforming mount.
Maybe others with the mount can check theirs and chime in. If the separation is as rare as it sounds, seems like our mounts are failing, or will fail.
2013 MS3 Black Mica
 Old 11-30-2013, 02:40 PM   #68
Default Sneak Peek: COBB Tuning Rear Motor Mount
I would imagine we can't be the only ones, I'm always checking over everything on my car. I first noticed it in October after like 20 pulls at the drag strip. On one of the pulls I had a rough launch and popped the hood, assuming my intercooler hit the hood and popped it.
That prompted me to jack the car up the next day and check everything out. That's when I noticed the mount dislodged. I smacked it back flushed and thought nothing of it. I got back underneath the car about a month later and it was dislodged again. That's when I brought this issue to cobbs attention. I once again pulled it out and smacked it flush, drove it for a day and got underneath the car again to find out it dislodged yet again within a very short period of time. I also drive my shit wreckless on a daily basis
Although its very hard for me to say I've noticed a difference in drive ability since I really have no clue when the mount initially dislodged itself.
OMWTFYB
 Old 11-30-2013, 02:51 PM   #69
Chuthor's Avatar
Posts: 435   (View Stats)
Chuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the world
Hmmm I thought mine got a little rougher, but not enough to bother me to actually go look. I don't have a garage or anything so popping it up to take a look isn't the easiest for me, but I'll try to take a look at mine the next opportunity I get.
2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC
Chuthor is offline   Reply With Quote
The Following 2 Users Say Thank You to Chuthor For This Useful Post:
darkstar5440 (11-30-2013), WetzMS3 (11-30-2013)
 Old 11-30-2013, 03:20 PM   #70
WetzMS3's Avatar
Groans: 430
Thanks @Chuthor
Perhaps we need to start another thread to get this the proper attention.
I don't expect much response during the weekend, but the thread title is not relevant to this issue. There may be other people with the problem, who won;t read this thread because of it's title.
2013 MS3 Black Mica
The Following 2 Users Say Thank You to WetzMS3 For This Useful Post:
Chuthor (11-30-2013), darkstar5440 (11-30-2013)
 Old 11-30-2013, 03:53 PM   #71
@WetzMS3; good idea, don't ask me I has the worst grammar. Lol I will contribute tho
OMWTFYB
 Old 11-30-2013, 04:45 PM   #72
WetzMS3's Avatar
Groans: 430
Cobb RMM Problems
@darkstar5440 Please throw your .02 in!
2013 MS3 Black Mica
 Old 12-01-2013, 08:25 AM   #73
Evan@COBB's Avatar
No worries, guys! You have my attention! I'll be working to come up with something for you guys to test out for me.
The test mule for this mount has been my own personal car. Built motor and a GT35R put more stress on this mount than must can make happen but I also don't do 20 pulls at the strip.
Do you guys have any other of the mounts upgraded as well? In all reality, if your dragging your car, you'll need more than just the one mount.
Stay tuned while I come up with something.
The Following 4 Users Say Thank You to Evan@COBB For This Useful Post:
Agent_Orange (12-01-2013), darkstar5440 (12-01-2013), El_Diablo (12-02-2013), WetzMS3 (12-01-2013)
 Old 12-01-2013, 09:23 AM   #74
Awesome!
I wasn't fully mounted when I ran at the strip last month. Three weeks ago I installed jbr TMM and PMM and the bushing is still pushing out.
Sub'd
Thanks, @Evan@COBB;
OMWTFYB
 Old 12-01-2013, 09:53 AM   #75
WetzMS3's Avatar
Groans: 430
I am not fully mounted either. But I also am not running from a dig at the strip yet.
2013 MS3 Black Mica
 Old 04-21-2014, 12:29 PM   #76
RedMS3's Avatar
Posts: 46   (View Stats)
RedMS3 will become famous soon enoughRedMS3 will become famous soon enough
I like it...!
RedMS3 is offline   Reply With Quote
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 07:47 AM
A sneak peek at Motor Trend Classic Haltech Automotive News 0 06-04-2010 04:00 PM
Take a sneak peek at Top Gear Australia Haltech Automotive News 0 09-13-2008 08:10 AM
GM gives very early sneak peek at next-gen Astra Haltech Automotive News 0 09-08-2008 09:00 AM
RS5 Stopgap? Audi gives sneak peek at S5 Evo Haltech Automotive News 0 08-25-2008 07:40 AM
Page generated in 0.57396 seconds with 34 queries
