> Cobb Tuning
 Old 09-11-2014, 10:07 PM   #1
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
Default V233 Maps
Anything been changed in these maps? I also notice they added a Stage 3 set of maps. Anyone seen any differences between these and stage 2? I just noticed boost targets were raised to 18.5.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
 Old 09-12-2014, 01:44 PM   #2
GabbyChaves's Avatar
Posts: 128   (View Stats)
GabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the world
Was wondering the same thing with no luck on finding any answers
GabbyChaves is offline   Reply With Quote
 Old 01-12-2015, 01:37 PM   #3
cyber-ms3's Avatar
Posts: 196   (View Stats)
cyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond repute
Groaned at 6 Times in 2 Posts
What changed between this and v231 on any of the maps?
cyber-ms3 is offline   Reply With Quote
 Old 01-12-2015, 04:09 PM   #4
ihasmazda's Avatar
Posts: 1,011   (View Stats)
ihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the world
if you select "Download Map Notes" you can see:
 v233 – Revised map names for staged package support.
 v232 - World Market 2009 - 2012 MAZDASPEED3 / Mazda3 MPS /MAZDASPEED Axela only. Corrected a small fueling error in the WOTfueling tables.
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
ihasmazda is offline   Reply With Quote
The Following User Says Thank You to ihasmazda For This Useful Post:
SarcasticOne (01-12-2015)
 Old 01-12-2015, 04:25 PM   #5
Bujwazay's Avatar
Posts: 486   (View Stats)
Bujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the world
https://cobb.app.box.com/mazdaspeed-map-notes
this link has all the details
Go Fast Parts: ETS 3.25" TMIC, Cobb TIP, COBB SF Intake, Racing Beat CBE, Cobb AP, Ultimate Racing Resonated TP, AT Internals, COBB XLE BPV
Other Stuff: Denso ITV22, CS LED Kit, DDM 35w HID kit w/ TRS Lenses, Cobb shift weight, CS Urethane exhaust hangers, Bilstein sports, CP-e stage II RMM, Whiteline F/R Endlinks, Rays Forged Mazdaspeed Wheels, TWM Big Type R Knob, CS AL skid plate, CS shifter bushings, CS RSB
Bujwazay is offline   Reply With Quote
The Following User Says Thank You to Bujwazay For This Useful Post:
 Old 01-13-2015, 02:35 PM   #6
cyber-ms3's Avatar
I checked out that pdf and it seems like cobb only states the difference between Base map, 91 octane map, and stage 3. It just so happens to be that the OTS maps are v233. I don't think that pdf is illustrating what's new for v233.
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 10:03 PM
FFS and v 101 maps cm-jp1 MazdaSpeed 3/6 - ECU Computer Tuning 1 10-05-2009 10:31 AM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 05:48 AM
New v.102 maps are available now! 94jedi
148 08-20-2008 01:05 PM
Page generated in 0.26694 seconds with 24 queries
