> Cobb Tuning
 Old 08-31-2013, 11:30 AM   #1
Mr Wilson's Avatar
Posts: 120   (View Stats)
Mr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the world
Default With V3 car starts, but dies right away
Apologies if I have aids and it's all my fault.
Removed AccessTuner and Manager from the computer keeping my current map.
Installed Tuner with V3 id and downloaded manager.
Opened my map in Tuner and re-saved, loaded onto V3
Uninstalled V2 from car
Installed V3 on car, saved stock ecu info
Uploaded my map.
Car starts, but stalls immediately. Tried installing OTS map and same result.
What can I do next?....Cheers for any help.
Edit: Would help if I match maps to the parts in my car. CPe choon does not work with Whale Penis....I have aids.
2008.5 CWP SPEED3
MODS TO DATE: KW V3 Cobb AP V3, RSB, STS TWM Shifter Extender Sure Shortcut, Countershift CP-e Tow Plate, FMIC, HPFP, DP, Exhaust Manifold, HeliHose, PMM/TMM, Nexus CBE, Injector Seals TiAL bpv JBR WP, Solid Shifter Bushings, TB/IM Gasket, RMM Celestspeed3 Coolant Bypass DBA 4300 T3 Hawk HP+ Denso itv22 Saikou Michi OCC DGM Lip HTP Slim Battery Tray SilverDemon EGR Block Off Rays Volk TE37 SL 18x9.5 +22, Formula Lugs Bridgestone RE-11 265/35-18 SilverDemon EGR Delete Kit Stratified ECBS, 3-Bar Map Sensor Intake Manifold PnP
Mr Wilson is offline   Reply With Quote
 Old 08-31-2013, 11:36 AM   #2
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Uninstall the ap, see if car starts.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Spoofmastafly is offline   Reply With Quote
The Following User Says Thank You to Spoofmastafly For This Useful Post:
Mr Wilson (08-31-2013)
 Old 08-31-2013, 11:44 AM   #3
Mr Wilson's Avatar
Uninstalled, still does the same thing.
2008.5 CWP SPEED3
 Old 08-31-2013, 11:56 AM   #4
Mr Wilson's Avatar
And I'm a fucking knob.....
Car works....I'm a tool.
Thanks @Spoofmastafly;
2008.5 CWP SPEED3
 Old 08-31-2013, 12:13 PM   #5
What was it?
 Old 08-31-2013, 07:12 PM   #6
Mr Wilson's Avatar
Wrong map for intake. Stalling out as map was for cpe nano, not jbr peen.
2008.5 CWP SPEED3
Car starts, then dies, then runs fine cm-jp1 Mazdaspeed3/6 General Discussion 6 10-30-2013 03:01 PM
Valves cleaned, car starts, dies after rough idle. Thoughts? slixx 2010 MS3 - Troubleshoot/Diagnostics 5 05-28-2013 04:00 PM
Engine starts and then dies Revyspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-28-2011 06:16 PM
Starts then dies bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 9 01-06-2010 07:24 AM
Page generated in 0.26300 seconds with 21 queries
