Miata MX-5
> Miata - General Questions
 Old 01-15-2015, 11:13 AM   #1
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Default Miata v8 swap vs rx7 v8 swap
So far from what I have read the last few days the miata v8 swap costs quite a bit more and requires more work such as cutting and welding then an rx7 v8 swap. Is that right or am I am idiot. Some guy wants to sell me a 88 sport rx7 non running with a spare rotor assembly for 900 bucks. Good deal or no? Leaning rx7 route right now
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 01-15-2015, 11:19 AM   #2
SpencerC's Avatar
Posts: 2,159   (View Stats)
SpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the world
Depends on how much work you want to do yourself, and which you like more. I've seen both done and they both can be awesome. You can get a lot of kits or DIY from the ground up, cost will differ significantly depending on which route you go.
GRANNYSSPEEDSHOP.COM
https://www.hinsonsupercars.com/p-10...n-package.aspx
Flyin' Miata : Engine conversions : V8 conversions
Miata V8 Swap
V8 Monster Kit -
If it was me I would go the Miata route, but I'm a big Miata fan.
SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount -
CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit
1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights
Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3?
SpencerC is offline   Reply With Quote
 Old 01-15-2015, 11:21 AM   #3
blake0521's Avatar
I like the idea of an miata put I prices it and I will be 8 to 15k since I don't know how to weld and would have to get a shop to do it. Maybe it's easyier then I think?
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 01-15-2015, 02:23 PM   #4
SpencerC's Avatar
I doubt it's easier than you think. But if you don't weld or fab it could be more difficult for sure.
Just hand Flyin Miata $30k and a used Miata and they will do it all for you with an LS crate engine.
 Old 01-15-2015, 03:21 PM   #5
blake0521's Avatar
Don't have 30 k hahaha I found a rx7 shell for 700 bucks with a motor that needs apex seals and it comes with a spare rotor for 700 total. Might do that so the whole build shouldent be more then 11k
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 01-15-2015, 08:50 PM   #6
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Past Mazdas & Speeds
The Following 2 Users Say Thank You to Neverlift For This Useful Post:
h.h.sk1nny (01-23-2015), Manny (01-17-2015)
 Old 01-15-2015, 09:15 PM   #7
blake0521's Avatar
What should I have a spare 30k in my dresser? hahaha I am 21 and in college selling cars. I am too broke to drop that kind of money!
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 01-16-2015, 05:41 AM   #8
BLKSTIG's Avatar
Posts: 507   (View Stats)
BLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the worldBLKSTIG is the leader of the world
Groaned at 7 Times in 6 Posts
I tried to stay away from this thread...I'm a purists when it comes to the rotary powered vehicles. Anyways, I say go miata. I also say that it will be cheaper for you in the long run to pick u an already swapped rx7. If that still isn't an option, abandon ship.
This swap is well documented between both cars, but there is a lot more involved in the swap than most like to give credit for. Without fab skills this can get pricey. Good luck. cruise rx7club. hopefully a cheaper swap will come up for sale already done or someone who has given up will be unloading parts.
Originally Posted by Captain KR View Post
bitch you thieve these nuts in your mouth..... trying to say my stroke game is weak i stroke better than you dream of strokin..... frail ass lite brite
'06 Mazdaspeed 6|| Cobb SF & AP Stage 1 | RPM Street Springs | SPC Ball Joints | SU Rear MM | SURE Dread | Whiteline RSB |18x8 Enkei EKM3 w/ 225/40 | JBR SSP & SURE Anchors | Rotora Blanks w/ EBC Red Stuff | 6K HID lights/blown fog | V2 Pre-amp |
BLKSTIG is offline   Reply With Quote
The Following User Says Thank You to BLKSTIG For This Useful Post:
chaser27 (01-16-2015)
 Old 01-16-2015, 05:52 AM   #9
Code Monkey's Avatar
Posts: 7,671   (View Stats)
Cough, cough....
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
BLKSTIG (01-16-2015), Tyhackman15 (01-16-2015)
 Old 01-16-2015, 07:41 AM   #10
blake0521's Avatar
Thanks for the info. I have a guy that is going to inspect that shell to tell me if it's a good platform to start with. If it is not we are going miata. If it is then rx7 time! If I get the rx7 we are going to give the 13b-t a go and if that's not enough power then v8 time.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 01-16-2015, 07:46 AM   #11
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Mike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the worldMike@Stratified is the leader of the world
A friend of mine put an LS2 in his Miata and the entire build was very well documented. The car is bad ass.
Goodbye 4-Banger, Hello LS2 – Miata Build - LS1TECH
--- 2011 Black Mica MS3 Tech ---
Mike@Stratified is offline   Reply With Quote
 Old 01-16-2015, 07:47 AM   #12
BLKSTIG's Avatar
I'll check to see if I still have any FC rx7 parts lying around. I know I have a full T2 keg with miscellaneous accessories. Keg needs a rebuild though. Ran fine when pulled but It's been sitting for roughly 4years
 Old 01-21-2015, 05:19 PM   #13
blake0521's Avatar
So my guy is going to go check that shell hopefully this weekend. If it checks out it will be up to my house asap. Then time to find a turbo 2 rear end or some sort of upgrade. I hate to say it but it is for sure getting a 5.0 V8. Sorry rotary guys! It too hard to resist a motor and trany and some bbk parts with only 70k miles for 1,100. @BLKSTIG; do you have any rear end parts?
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 01-21-2015, 06:05 PM   #14
BLKSTIG's Avatar
sorry, no rear end parts. Good luck with the build. My buddy owned a cammed LT1 swapped FC. It was pretty quick. You'll have a lot of fun buying tires all the time haha
BNR S3 Swap How To Ziggo MazdaSpeed 3/6 - Big Turbo Builds 244 12-13-2016 08:07 PM
LSD Swap out Tomas MazdaSpeed 3 - How-To's 81 10-08-2012 08:16 PM
BNR S3 Swap How To Ziggo MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 152 09-20-2012 07:16 AM
BNR GTX Swap Possible? Kydizzle MazdaSpeed 3/6 - Turbo Induction 12 03-28-2012 11:24 AM
Page generated in 0.33642 seconds with 25 queries
