![]() | ![]() | #1 | ![]() |
![]() Join Date: May 2018
Rep Power: 10 ![]() Thanks: 0
(Thread Starter) | ![]() ![]() ![]() My co workers suggested checking the spark plugs and the Recirculation valve/Bypass valve - Not sure what these are officially called, but its the Blow-off valve that recirculates back into the intake. |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Jun 2015 Location: Santa Cruz, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 984
Groans: 203
But yeah, replace the plugs since you have them and make damn sure you gap them correctly. They are NOT pre gapped. What gap you ask? Well, its important and you can find that by searching too. Good luck!
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3357 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| ![]() ![]() ![]() Ah, "The Bog"... Have fun with fixing that. Also, check to make sure your temp sensor on the throttle body inlet isn't torn. They like to rip, causing a boost leak. This rubber piece from the factory expands anyway, and should be replaced with a metal piece, that will not expand or tear. BEGi made one back in the day that worked with the stock ECBS/Recirc-valve setup.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
The Following User Says Thank You to Neverlift For This Useful Post: | mr_mazda329 (09-03-2018) |
![]() | ![]() | #4 | ![]() |
(Thread Starter) | ![]() ![]() ![]() I searched around the miata section but I probably wasnt using the right keywords. I pulled the spark plugs yesterday, they looked OK, kind of crusty but also looked like they had been in there a while. Gaps were around .044-.048, NGK Iridium plugs. The plugs that were in the glove box were not the right plugs, they were the platinum plugs for an N/A car, gaps measured .040-.042. Not having an immediate solution, I adjusted the gaps on the platinum plugs down to .035 (only combination I had in gauges). From what I read, the turbo engines are supposed to be around .032. I have the correct set of NGK iridium plugs on order, should have them this weekend. |
![]() | ![]() | #5 | ![]() |
Out of curiosity, are these turbos normally quite loud when boosting? My MS3 makes next to zero noise when it boosts but the MSM is very noticeable. Wondering if I do have a boost leak or even an exhaust leak somewhere under the hood. | |
![]() | ![]() | #6 | ![]() |
Groans: 1,143
| ![]() ![]() ![]() Post a quality landscape photo of your entire engine bay, and lets go from there. It has been forever since I have heard a stock MSM, but I remember my GF's reaction to it when I drove it off the lot, "You have to buy this." She was bored to death in a AP2 moments before. So yeah, it's definitely noticeable stock. An aftermarket intake will increase that sound, as will an aftermarket recirc valve. You can check the downpipe & exhaust fittings for any build up from a leak. There are a few stupid little tricks to getting those MSM's to cross 200whp on the stock tune & turbo. My favorite was unplugging the TPS to keep the ECU in open loop 24/7 (the switch you feel at 5k), and porting the wastegate inlet to alleviate boost creep after cutting the cat out. You can add larger injectors, a manual boost controller to increase the boost a couple lbs, and add some resistors to remove the fuel cut when it goes over 12psi. They have issues with the OE intake and catch can system, so look to correct that ASAP with a check valve on the feed line to the oil pan. What intercooler is on the car? Are the fittings and rubber hoses coated in oil?
![]() | ![]() | #7 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Wow man, thats a ton of great info, going to have to donate after work now ![]() Yeah my GF went from driving a 2007 mazda 6 sedan that got totaled. She was pissed that she lost her car right up until I found this thing at a dealer. It is spotless, cant find any leaks on any connections but I havent gotten too far under it to check exhaust. I'll get some pictures uploaded later this evening. |
![]() | ![]() | #8 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Havent had the time to check the fuel filter and that solenoid valve. I checked a few other things, air filter is brand spankin new, installed the new properly gapped laser cut iridium plugs. Previously, the engine felt like it was studdering around 35-40 and 70-75, CEL was on for codes P0037 and P0300, no signal from O2 sensor heater wire and random missfire detected. The motor also felt kind of chattery (I chalked this up to it being such a light car, lacking insulation). After installing the iridium plugs (gapped to .030 +/-.001), the CEL stayed off for a while, engine felt more smooth, the studdering went away, engine definitely has more pep right around when the turbos hits. I noticed that the spark plugs in cylinder 1 and 2 came out with almost no force required, while the rear two were somewhat tighter. I am going to check the new plugs at the end of this week and see if they loosened up at all. The CEL came back on, got my scan tool in the mail and it read code P0037, heater wire from O2 sensor no signal. Here is a shot of the engine bay. |
The Following User Says Thank You to ISPKI For This Useful Post: | Neverlift (06-26-2018) |
![]() | ![]() | #9 | ![]() |
Groans: 1,143
| ![]() ![]() ![]() Completely stock. Get that check valve for the oil drain to pan. Check the inside of the intercooler piping & rubber connectors for oil. Also look for options to replace that throttle body inlet piece. I found a tear on mine at <60k miles, took me almost a month to track it down iirc. ![]() GL w/ the o2 sensor code, might be time to replace it.
![]() | ![]() | #10 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Yeah I am just going to replace the O2 sensor, 110k miles on them, im sure it would help to have new ones. The IC looks like it has eaten a ton of rocks over the years of not having a grille in front of it so I was looking at putting in a new IC, maybe a slightly larger one for better cooling. As far as the throttle body inlet piece. Should I be looking at the fittings that are circled in the attached photo? Im pretty sure this is what you are referencing but just want to make sure I am looking in the right spot. |
![]() | ![]() | #11 | ![]() |
![]() Join Date: Jan 2009 Location: Vegas, NV.
Rep Power: 777 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,245
Groans: 55
| ![]() ![]() ![]() Yup. You want to look the whole thing over actually. have you cleaned the bog solenoid out yet? Have you done the o2 sensor? I also recommend finding a Joe's Intake when you upgrade. It improves the car's drivability a ton. Ebay FMIC is enough. You can make easy power for little money on this car. Anything over 200wh start to cost ya tho.
__________________ 09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals 97 Miata Daily Driver 04' Mazdaspeed Miata Track Car Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing ![]() |
Display Modes | |
Troubleshooting the VVT | mituc | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 02-28-2014 02:30 PM |
FYI O2 troubleshooting | car46999 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 06-08-2012 09:10 PM |
need some help/troubleshooting | Nefarion | 2010 MS3 - Troubleshoot/Diagnostics | 15 | 08-30-2011 06:32 AM |
