 Old 07-21-2013, 06:32 PM   #1
rickyb24's Avatar
Posts: 2   (View Stats)
rickyb24 is an unknown quantity at this point
Default '08 CX& Power loss and holwing
I have an 08 CX7, the other day while cruising at about 75mph, I lost what felt like the turbo? I went to pass a car and stepped on it and it was like the car had an anchor. No power. The engine started making and intermittent "howling" sound within minutes. Now it " howls" from about 1800rpm to around 2200rpm all of the time, but still no power. I can ( probably shouldn't) drive it and get up to highway speed , but it has hardly no acceleration. It's a VERY slow climb to speed. I've had some say it's the belt tensioner making the noise, but it doesn't explain the drop in power. I'm looking for ideas. I'm stumped. I'm a motor head ... but I'm an old school motor head. Not a tuner....yet THANKS for any help!
rickyb24 is offline   Reply With Quote
 Old 07-21-2013, 06:44 PM   #2
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Groaned at 64 Times in 49 Posts
Sounds like a boost leak. Check either your intake, or tubes leading to the intercooler.
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
 Old 07-23-2013, 06:04 PM   #3
rickyb24's Avatar
Checked out both intercooler tubes, both OK. I used a buddies code reader and I got a P0101 for the MAF or VAF and then got a P0401 for the EGR valve. I guess I'll keep checking lines and clean the EGR. ANY other ideas would be great.
2008 CX7 Sport, BONE STOCK...for now.
 Old 07-23-2013, 06:15 PM   #4
m4tic's Avatar
Posts: 4,922   (View Stats)
does it howl only while on the gas?
does it how constantly with wheel speed?
either you missed a boost leak (wastegate, boost control solenoid).. or something like the pto took a dump.
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
Payne Racing 67 (07-25-2013)
 Old 07-25-2013, 12:33 PM   #5
Did you check your intake? Where it connects to the turbo? That will affect MAF, and because it throws everything off, could cause the egr code as well
Sent from your moms phone
 Old 10-07-2016, 11:42 PM   #6
MAZDAUSA's Avatar
Posts: 1   (View Stats)
MAZDAUSA is an unknown quantity at this point
I am having exactly the same issue. Dealer is asking to replace catalytic converter ..they are saying $2K for the replacement.
MAZDAUSA is offline   Reply With Quote
Loss of power at WOT Speeden6 MazdaSpeed 6 - Engine, Transmission & Driveline 49 04-09-2012 09:48 PM
WTF power loss and mpg loss ztnedman1 Gen2 MS3 General Discussion 10 11-07-2011 07:26 PM
Loss power kao_lor Mazdaspeed3/6 General Discussion 13 04-15-2011 01:43 PM
New to me MS3 08.5 Power Loss rtabagaboy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 31 10-17-2009 01:22 PM
Loss of Power mleblond MazdaSpeed 3 - Engine, Transmission & Driveline 11 09-03-2009 07:16 AM
Page generated in 0.30940 seconds with 23 queries
