 Old 02-25-2015, 08:42 PM   #1
jtb2798's Avatar
Posts: 4   (View Stats)
jtb2798 is an unknown quantity at this point
Default 2008 CX-7 Timing chain repair gone wrong
This repair was in the interest of preventative maintenance and the car was running just fine with the exception a noisy timing chain. We have replaced the timing chain, tensioner, VVT actuator, cam position sensor, crank position sensor, plus the bolts and washers (all OEM parts). The chain is in time, we're getting oil pressure, the starter is turning, but the car will not crank. We've checked the grounds and every stupid thing we could think of. We took off bad parts and replaced them with good parts. The chain is in time using the timing tool kit that came with the VVT and there is no adverse sound that you would expect if the chain were not in time and the valves were being destroyed. Does anyone have any other ideas as to why the car will not start? Computer related? Safe mode? I'm open to any suggestions that will prevent me from towing this to the dealer and bending over.
jtb2798 is offline   Reply With Quote
 Old 02-26-2015, 05:10 AM   #2
xNonAmEx's Avatar
Posts: 10   (View Stats)
xNonAmEx is just really nicexNonAmEx is just really nicexNonAmEx is just really nicexNonAmEx is just really nice
Did you check the spark while cranking?
2007 Mazda 6 MPS, mostly stock
xNonAmEx is offline   Reply With Quote
 Old 02-26-2015, 06:27 AM   #3
RalliartRsX's Avatar
Posts: 366   (View Stats)
RalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the world
I second sounds like a spark issue
RalliartRsX is offline   Reply With Quote
 Old 02-26-2015, 06:57 AM   #4
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Any codes being thrown?
I'd third some kind of spark issue.
If you have some kind of torque application you can check the fuel pressure as well.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
 Old 02-26-2015, 07:33 AM   #5
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Check the motor mount ground, and the ground by the fuel pump. That ground by the HPFP has thwarted many people.
Is the motor turning "as it should?" Meaning, does it sound like it has compression, and isn't just free wheeling? It'll turn super fast if it's free wheeling.
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
Raider (02-26-2015)
 Old 02-26-2015, 07:41 AM   #6
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
If the starter is turning, the motor should be cranking. If it is turning over and not firing.
Check grounds as @xfeejayx; said. I think it is on the passenger mount on CX-7. Then that tiny little wire on the hpfp.
Then pull plugs out and connect to coils, crank it over and check for sparky.
 Old 02-26-2015, 08:35 AM   #7
xfeejayx's Avatar
Groans: 78
If you have the means, do a compression check. We've recently learned that the plastic timing tool leaves something to be desired, and your timing can actually be off if you didn't pay attention.
-Wetz
QFT
 Old 02-26-2015, 08:59 AM   #8
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
How are you getting oil pressure if the car is not cranking?
How is the starter turning without the engine cranking?
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 02-26-2015 at 08:59 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-26-2015, 03:39 PM   #9
jtb2798's Avatar
I am getting spark when attempting to crank and the grounds are connected properly. If the chain was out of time and anything in the engine was being damaged would it not be audible when I attempt to crank it?
 Old 02-26-2015, 03:44 PM   #10
SpencerC's Avatar
Posts: 2,159   (View Stats)
SpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the world
My guess is this guy:
Unless I am misunderstanding and the engine is literally not turning due to something blocking it.... Maybe you forgot to remove the TDC pin in the back of the engine?
SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount -
CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit
1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights
Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3?
Last edited by SpencerC; 02-26-2015 at 03:44 PM. Reason: MSF Database - Automerged Doublepost
SpencerC is offline   Reply With Quote
 Old 02-26-2015, 03:49 PM   #11
Yatta's Avatar
Posts: 1,862   (View Stats)
Has someone else done this? wondering what would go first or what it would sound like
 Old 02-26-2015, 04:07 PM   #12
SpencerC's Avatar
I've never heard of it. But what he wrote doesn't make that much sense either... starter cranking, getting spark, engine isn't cranking... we don't know if he can turn it by hand that I can see, but supposedly all ground and spark is good... so either it is physically blocked right.... or it isn't getting fuel.
 Old 02-26-2015, 05:09 PM   #13
Tokay444's Avatar
Groans: 793
So is it cranking or not?
Demodded.
The Seals
 Old 02-26-2015, 05:11 PM   #14
Spec's Avatar
Posts: 4,472   (View Stats)
Is it even possible to fuck up and have a cam turned 180* on an mzr?
 Old 02-26-2015, 05:48 PM   #15
jtb2798's Avatar
Sorry let me clarify, the engine is turning, there is spark, there is fuel pressure (at least I think so since the fuel pump spurts gas everywhere when I remove it), but its as if the fuel is not getting to the spark plugs for the engine to fire. Everything was functioning prior to this repair and all that was replaced was the timing chain and related components. Is it possible that the chain could still not be in time even though it is top dead center? When attempting to start the engine the engine seems to be turning at normal speed, there is no metal on metal clashing that I would expect to hear if the valves are being destroyed, and there is no gas smell in the spark plug wells after attempting to crank. This leads me to believe that something, be it a sensor, the computer, all 4 fuel injectors failing at the same time, or simply the chain is somehow not in time and not allowing the car to start. Am I under the wrong impression that the cam shaft can only be in two different positions, either the right way or 180 degrees the wrong way?
 Old 02-26-2015, 11:40 PM   #16
xNonAmEx's Avatar
Technically when using the timing plate you can put cams in 4 different positions: lobes facing each other, pointing in the opposite directions and a combination of those. I would check the compression just to be sure. Regarding fuel, did you check the relays and fuses? Also the ground on the hpfp that Spencer posted.
 Old 02-27-2015, 04:42 AM   #17
xfeejayx's Avatar
Groans: 78
Please Read. Every. Post. After reading, go through what you have and haven't done, and answer accordingly. Your car will run faster if you do this.
3 people have now told you to check your grounds, especially at the HPFP. Please start there if you haven't already.
Using the plastic timing tool you probably got with that kit, yes, you can accidentally install either cam 180*. If one cam is 180*, the engine will crank faster than normal because you don't have compression. This will not destroy your valves. You will hear nothing except a fast crank.
I don't know how good your ear is at hearing a fast crank, but to make sure this is right, put everything back to 0* and make sure the cam lobes at cylinder one are facing up and towards the center of the engine.
It's not your injectors. All 4 don't go at once.
-Wetz
QFT
 Old 03-04-2015, 12:17 PM   #18
jtb2798's Avatar
Wound up just taking the car to Mazda. Mazda saying that the car was put back together out of time and attempted to start and needs a new head. Is this even possible if the car never cranked?
 Old 03-04-2015, 12:28 PM   #19
Raider's Avatar
Groans: 856
It did crank if the engine turned over. You said starter moved, so engine moved, and engine is now busted.
The timing tools were not used properly or failed, and it came out of time. TDC was not verified after assembly, prior to starting, is my guess, as a way to check. Would have to know where cams are for TDC, as well as crank.
Most likely a valve got bent and caused damage. Its super-common for the non-dealer mechanic to do this. Like VERY common. Extremely common when it is a shade-tree mechanic in their garage who has not done this before.
Note that you can get an entire motor rebuilt longblock from @EdgeAutosport.com; probably cheaper than a Mazda dealer head. Of course, I would recommend getting the dealer to install it.
 Old 03-04-2015, 12:48 PM   #20
shamie's Avatar
Posts: 942   (View Stats)
I would be suspect of needing a new head. Sounds like the dealer knows he's going to be in this almost as much labor to swap a head, so why not charge you for one while he's in there.
 Old 10-14-2015, 05:50 PM   #21
CX-7Pilot's Avatar
Posts: 22   (View Stats)
CX-7Pilot will become famous soon enough
So what's the word? Did the dealer end up replacing the head? What did that set you back? I might be in the same boat, but hopefully I'm getting mine in before permanent damage is done.
CX-7Pilot is offline   Reply With Quote
 Old 10-14-2015, 06:11 PM   #22
Raider's Avatar
Groans: 856
The guy has not logged in for 7 months.
 Old 02-18-2016, 02:55 PM   #23
ace woodford's Avatar
Posts: 2   (View Stats)
ace woodford is an unknown quantity at this point
Default VERY similar problem with mine..can anyone help me?
Hello, I'm in desperate need of some mechanical advice for my 2007 CX-7 Grand Touring. Here's the story, I was driving my son home to his mother's last month in sub-zero temps and I blew a coolant hose...in the middle of nowhere...I foolishly made the decision to limp it to the next small town 4 miles away(it was -4deg and I was more afraid of being stuck with my 10yr old in the deathly cold than I was about the effects on my engine), We made it to safety but the car overheated and blew a headgasket as well as melted the coil boots on #'s 3 and 4. I got the car towed home and had my mechanic replaced the head gasket as well as machine the head, replace timing chain/vet etc.. He finally got everything together yesterday but now we can't get it to start. The timing was done right(all coil packs are sparking) but it still won't fire up.
Can anyone PLEASE give me some advice on where to begin? My wife's advice is to crush the car, but I've done soooo much work on this vehicle over the 175k miles I've owned it that it's become a war of attrition between the CX-7 and myself...and I'm not giving up... PLEASE HELP
ace woodford is offline   Reply With Quote
Page generated in 0.43179 seconds with 32 queries
