 Old 02-04-2017, 04:01 AM   #1
ruggeri5054's Avatar
Posts: 15   (View Stats)
ruggeri5054 is an unknown quantity at this point
Default 2008 cx7 issue
hello, I have a 2008 cx7 2.3 AWD turbo. The issue started at a small misfire, then a day later it turned into a bad miss. I noticed the timing chain was stretched and the vvt actuator pin was damaged. I changed all timing components, retimed the engine and checked for compression. Compression and leakdown were fine. ...Valves seem to be holding.
New Coils and ir plugs, all OEM...
back together and the misfire started small again, progressing worse to only being able to idle with no throttle response.
Double checked timing, spot on...
Live data was ...
287 to 300 fuel psi at 450 rpm
o2 reading normal
maf at 5 g
engine temp sensor was at -40 deg BUT second reading from sending unit was at 180 when warm.. closed loop
other data was recorded but this seemed to be the most important at the time..
so..
At first the CEL came on and was throwing p2088 so I checked the vvt solenoid.. it jumps fine but engine still runs rich or advanced.
The solenoid has 12 v power immediately with just the key on. No ground faults or shorts and no cross to power. we checked the wiring and it all seems to be ok with no shorts from PCM to Ground to Sensor/pigtail
We then tried the "relearn" process and it seemed to do nothing.
What am I missing here.. the engine seems to be running rich and fouling every plug out. What do you think I should do next I am at my whits end.. Please throw suggestions..
Key points, there is spark, there is fuel, not sure what psi should be at 450 rpm...
Fuel Regulator? could the VVT solenoid be not holding? Should the VVT solenoid have power immediately even when not running just key on? event timing is spot on right now so that is not it.Chain has no slop. Crank Sensor is lined up at 20th tooth TDC...
Please Help..
Could it be ECM.. please help
Could it be the coolant temp switch.. please help
Could it be a mazda... please help
Could it be that I am loosing my mind with this.. please help..
Please help!
ruggeri5054 is offline   Reply With Quote
 Old 02-04-2017, 03:37 PM   #2
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
Is it still throwing the P2088 code? Is it still misfiring?
 Old 02-04-2017, 03:39 PM   #3
As of now no for the code but idle misfire and still running rich
 Old 02-04-2017, 04:02 PM   #4
flapjack's Avatar
If the O2 sensor readings look normal, I would expect that the engine wouldn't be running rich. Maybe one or more of the injectors are clogged or bad? If that isn't the problem maybe try adjusting the crank sensor down a bit to retard it and see how it runs.
 Old 02-04-2017, 04:04 PM   #5
Good point, ill check adjust the ckps. All the plugs are still fouling though, dry carbon fouling..maybe not rich just bad ignition timing?
 Old 02-04-2017, 04:23 PM   #6
flapjack's Avatar
Cool, let me know what happens. Another thing I just thought of is the plug gaps. No plug I've bought has come properly gapped out of the box. I'd pull the plugs out and use a feeler guage and make sure they're gapped correctly. OEM plug gap should be 0.034" I believe.
The Following User Says Thank You to flapjack For This Useful Post:
torquemaniac (02-04-2017)
 Old 02-04-2017, 04:24 PM   #7
Awesome work thank you, i will double check.
 Old 02-04-2017, 04:46 PM   #8
torquemaniac's Avatar
Posts: 727   (View Stats)
Most here will suggest to gap the plug at 0.028!
Can you post a datalog of the car running?
First thing I would check is the MAF sensor, and then look for electrical connection problem (maybe a bad ground due to a rusted wire)
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler // Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
Coming soon : Composite ram-air intake // Hood with heat extraction vent
 Old 02-06-2017, 07:32 PM   #9
The maf seems ok, scan shows 5g ps, plugs are good-gapped. There is almost no vacuum and throttle does not respond 99 percent of the time. Plug 1 was covered in gas, plug 2 3 4 carbon fouled bad. All cylinders have spark and fuel.
 Old 02-06-2017, 08:11 PM   #10
flapjack's Avatar
When you say plug 1 are you referring to the plug farthest from the transmission? Just making sure we're on the same page.
Also the no vacuum part immediately makes me think its a faulty MAP sensor. This would explain why its running so rich and not idling properly.
 Old 02-07-2017, 09:44 AM   #11
yep number 1 cylinder. Just curious, how can the map sensor cause a physical condition of no vac? couldthe low vac be caused by such a low idle? I can't wrap my head around any of these shenanigans.
Quick question, should the vvt solenoid be powered at idle? we checked the power with key on to the vvt pigtail and it had 12.8 volts. However when plugged into the vvt solenoid it does nothing. When the vvt solenoid is jumped with 12v it jumps forward. Both the old and new VVT solenoid do the same thing.
 Old 02-07-2017, 10:01 AM   #12
What should the MAP read on the scanner? Also, no more codes are being thrown even when we mess with sensors while it is running. CEL stays off. Could the PCM really be worth replacing? Could it be tested? I am down for all the suggestions I just want to make sure I can understand the logic before spending more money.
I also appreciate all your input, thank you.
 Old 02-07-2017, 05:47 PM   #13
So this is where we are at MAP and MAF are good, confirmed good, all grounds are good. All injectors are good. The main issue is there is almost no vacuum. This seems to be causing the issue. Confirmed no leaks in manifold or anywhere that holds vac.
 Old 02-08-2017, 06:48 AM   #14
In the first post you said that the car is running rich, but then you say there is almost no vacuum at idle...with no vacuum at idle the car should be running lean (throtle open too much), unless the ECU is pulling a lot of timing to get the idle RPM on target
Did you monitor ignition timing ? (idle timing should be around 10 degree)
Maybe there is a problem with the throttle or its wiring!?
Did you log fuel trims (LTFT and STFT)?
The ECT reading are in degree C or F?
Is the car stuck in 3rd gear? (this would indicate the car is in fail-safe mode)
 Old 02-10-2017, 10:34 PM   #15
well well well.. stripped the manifold off and fuel rail.. found a broken injector on number 1. The tip was crooked and fuel was leaking past the crack. No impact marks or anything looks like it failed under pressure.
 Old 02-11-2017, 08:42 AM   #16
It was dumping fuel into the cylinder. No hyrolock though. The issue before was a timing error apparently. So after re-timing it it ran alot better just sputtered from the injector. Should be back and running soon.
 Old 02-11-2017, 02:33 PM   #17
flapjack's Avatar
Interesting and good to know. Thanks for posting what you found because information like this helps everyone. Hopefully you get back on the road with no other problems very soon.
 Old 02-11-2017, 06:08 PM   #18
No problem, seems that the high pressure these produce can cause some major wear and tear. I am just glad that nozzle did not eject into the head!!!
 Old 02-15-2017, 08:53 PM   #19
so the car is running great now! I have only one problem left, that is the brake light fuse keeps blowing, when it does (as soon as i hit the brakes) the ABS and ETC light comes on. The fuse blows when replaced as soon as the brakes are applied. After hooking it up on my scanner I got these codes...c1954 Chassis B1884 Body and U2064 Network. I tried unhooking all the tail lights and nothing changed. I inspected wiring to the ECU and it all seems to be fine. This only happened when I did the above repairs...what are your thoughts????
 Old 02-16-2017, 05:58 AM   #20
Dropen's Avatar
Posts: 38   (View Stats)
Dropen will become famous soon enough
Did you try removing all the brake bulbs? and disconecting the 3rd brake light and try?
The 3rd brake light works complete (all the led or bulbs)?
Try that and see if still burning the fuse.
Other thing... see if the fuse is "exploded" or just the filament is cutted. If its the 1st one its a shortcircuit and you have one wire to ground, if theres the 2nd option means that you overpass the amps of the fuse and you have some bulb or something consuming more than usual.
Dropen is offline   Reply With Quote
 Old 02-16-2017, 06:19 AM   #21
Yeah the fuse def. More than a small cut. I am going with a short, but i do not know where to begin or where on the harness to start at. The,rear lights were all disconnected bulbs and all, no difference. I can test the switch but i can only imagine that the switch will cause a non working issue, not draw more amps. The diagram i have is very plain, it does not show detail of where the actual wires travel to.
 Old 02-21-2017, 08:23 AM   #22
well fixed the brake light issue.. not quite sure what I did but I pulled the power plug to the fuse block and there was some oily substance on it. I cleaned all of it up and the brake lights were fine. NOW the car has no fuel supply what so ever. No start, has spark, has compression but no fuel. I have checked all fuses, replaced relays and still no fuel being delivered. This happened exactly after the brake lights started working.. What possibilities could this be related to??
 Old 02-22-2017, 04:05 PM   #23
update, the fuel pump is not being activated by the PCM. The PCM is only allowing 5.2 volts to the relay which is not enough to activate it.. Things I have tested so far...
The resistor is within spec, .3 ohms or less
The pump will activate and the car will run if the relay is shorted between power and pump (top two) The voltage between the fuel control relay and the speed control relay is 12v..
the only problem is terminal 1h (fuel control) is only outputting 5 volts which according to the workshop manual it is supposed to be b+ or 12.
I have no problem replacing the PCM but I want to make sure that the PCM is actually doing its job and something else is telling the PCM to kill the pump for some reason..
I also noticed that the ENGBAR1 fuse has both neg and pos continuity, is this normal? I checked most of the entire harness and found no opens/shorts. This is really pointing toward a PCM but I want to rule out other possibilities before flashing a new PCM. Someone please put some input in lol
Ultimately the problem is isolated between terminal 1h on the PCM being low voltage, not enough to activate the relay (I did change relays and nothing changed)
2008 Black Mica with Slight Steering Issue Rogejo321 Mazdaspeed3/6 General Discussion 9 04-12-2015 06:33 PM
2008 Mazdaspeed 3 Airbag issue Nitr0EngiE MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 03-04-2014 10:22 PM
Report: NHTSA probing 2005-2008 Ford Crown Victoria police cars over steering issue Haltech Automotive News 0 09-17-2012 11:20 AM
Small recall for big suspension issue on 2008 Honda Element Haltech Automotive News 0 08-19-2008 11:50 AM
2008.5 Bose issue NYpest MazdaSpeed 3/6 - Car Audio & Electronics 22 08-04-2008 10:19 PM
Page generated in 0.40283 seconds with 24 queries
