 Old 12-05-2014, 11:40 AM   #41
blackbalts's Avatar
Posts: 23   (View Stats)
blackbalts is a splendid one to beholdblackbalts is a splendid one to beholdblackbalts is a splendid one to beholdblackbalts is a splendid one to beholdblackbalts is a splendid one to beholdblackbalts is a splendid one to behold
Yeah, when I placed it it seemed to rotate itself back. I could never get it to "lock" in.
Just left dealership. They only had one of the crank gear washers and gave me fords part number. They wont have more until Tuesday, fml. Lol so you say I need there of these friction washers, not two?
blackbalts is offline   Reply With Quote
 Old 12-05-2014, 11:41 AM   #42
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Gr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the world
Groaned at 123 Times in 84 Posts
2 of them to do timing chain. 3 if you remove the oil pump sprocket. You will also need 1 cam friction washer.
https://www.youtube.com/user/JustinBieberVEVO
Gr8Speed is offline   Reply With Quote
 Old 12-05-2014, 11:50 AM   #43
blackbalts's Avatar
This will be my go to mazda forum from now on. You guys are great! Not too many out there this friendly, helpful and responsive.
Ok. Got my hands on a second for the crank gear. I am not removing oil pump sprocket. I also got two for the vvt, but sounds like I will only need the one. I have a quick meet now, but will resume shortly. Hopefully no more questions!
Last edited by blackbalts; 12-05-2014 at 11:50 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to blackbalts For This Useful Post:
Gr8Speed (12-05-2014), jeopardy98 (12-05-2014), UnknownSuperhero (12-05-2014)
 Old 12-05-2014, 11:50 AM   #44
Gr8Speed's Avatar
We're normally assholes. You just seem like a decent guy that isn't pants on head retarded asking what BOV is the best so we're being nice haha. Also VVT is a bitch to do yourself so I commend your efforts.
The Following 4 Users Say Thank You to Gr8Speed For This Useful Post:
frothy (12-05-2014), jeopardy98 (12-05-2014), mr.speedy3 (12-06-2014), UnknownSuperhero (12-05-2014)
 Old 12-05-2014, 11:53 AM   #45
frothy's Avatar
Posts: 1,067   (View Stats)
The friction washer on the oil pump sprocket is a bitch to replace, so most skip it. You should be fine leaving it as is. Definitely replace the other two.
If you loosen JUST the intake camshaft, you'll be fine with the one camshaft washer. If you loosen the exhaust side as well, you'll need a second. I loosened the exhaust side when I did mine, so I needed 2.
 Old 12-05-2014, 01:48 PM   #46
blackbalts's Avatar
Lol, right on. Well I moderate a cobalt forum and frequent an evo one so I understand the issues with people on forums and what to and not to ask! Definitely not my first timing job, just new to the keyless timing craziness!
And a synapse bov is the only answer to that question lol.
The Following User Says Thank You to blackbalts For This Useful Post:
frothy (12-05-2014)
 Old 12-05-2014, 02:11 PM   #47
frothy's Avatar
The Following User Says Thank You to frothy For This Useful Post:
ALPINEST4RS (12-05-2014)
 Old 12-05-2014, 11:03 PM   #48
blackbalts's Avatar
Quick update. Everything went together easily and a couple cranks and no cylinder/valve connection. Serp belt wasnt right size so waiting until tomorrow to finish and start. My only criticism so far for the how to is removal of coolant tank and power steer fluid resivoir is an unecessary step as well as seperating fuel pump. I'll post results tomorrow when I start it up.
The Following 2 Users Say Thank You to blackbalts For This Useful Post:
Gr8Speed (12-06-2014), jeopardy98 (12-06-2014)
 Old 12-06-2014, 11:16 AM   #49
blackbalts's Avatar
Well, it hasn't blown up yet! TC light is flashing at me so I must not have connected one of the connectors, wife isnt cool with it staying like that but i am, more fun that way. Otherwise thank you all for your help!
 Old 12-06-2014, 11:40 AM   #50
blackbalts's Avatar
Ok, so TC OFF light will illuminate if the battery is replaced. After driving for three seconds it turns off. The TDC light is still illuminated and I heard there was a hard reset for this. I will update when I find it.
One more criticism of the how-to. It is unnecessary to remove the airbox. So that the PS resivoir and the coolant tank removal is unnecessary. Also, it doesn't refer to installing the 6mmx1.00 bolt when removing the crank pulley at first. Otherwise it's a great guide.
 Old 12-06-2014, 11:49 AM   #51
blackbalts's Avatar
Here is the fix after replacing the battery for windows (my passenger side needed this) and the DSC (what I referred to as TDC above).
Disconnected battery on your CX-7 and now the passenger window will not work? TCS land DSC lights on too? Read here!
 Old 12-06-2014, 12:19 PM   #52
Gr8Speed's Avatar
Ahhh the window problem. Yeah no biggie. Congrats on getting the job done.
Possible timing chain and vvt replacement. CX7Haley CX-7 > Issues & Troubleshooting 10 09-15-2014 06:25 PM
Timing Chain Replacement FluffySheepBoy MazdaSpeed 6 - Engine, Transmission & Driveline 2 01-26-2014 07:00 PM
timing chain and vvt replacement mikecrpntr MazdaSpeed 3 - Engine, Transmission & Driveline 2 11-15-2013 03:21 PM
Supply-chain chiefs fixated on cost cuts Haltech Automotive News 0 10-16-2009 10:40 AM
Page generated in 0.32410 seconds with 23 queries
