  • 1 Post By Project_dog
 Old 12-05-2015, 05:56 PM   #1
clivingston's Avatar
Posts: 23   (View Stats)
clivingston is an unknown quantity at this point
Default Engine Noises and wouldn't start on 1st try
Hey Guys,
after reading a ton of problems people have with their mazda cx-7s in terms of timing chains and VVTs I thought I would post two videos in hopes my car is not having the problem I think it is.
Background:
2007 Mazda CX7 milage 95300
I recently graduated with my Masters and so the whole time I have had this car I have not had the money to address these issues. Now I have a job the engine noises started at least 3 years ago. (was not notified of the extended 70k warranty) check engine light never comes on. It just sounds like a diesel engine and I want to get it fixed. I also recently (today) changed the spark plugs, and I use seafoam every now and again and did the brake line seafoam intake in hopes that might solve the problem.
Any ideas on the problems?
First video:
This happens about once a month where when I turn the key it fails to start, second turn always starts with no troubles any ideas?
Second Video:
This is the dreaded sound I hate!
My guess is the worst case scenario and I need to drop ~$1500 for the timing chain and parts. Will that fix the problem in the long term? I am hoping that reading all of the other posts has just made me over think the problem.
Thanks
clivingston is offline   Reply With Quote
 Old 12-06-2015, 07:33 PM   #2
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
Groaned at 7 Times in 6 Posts
I've never heard a timing chain slap a timing cover before but I imagine it would sound like that. I can't believe the mechanics you took it to couldn't figure this out.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 12-07-2015, 09:49 AM   #3
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Yes that is your timing chain hitting your vc. Thats what mine sounded like. Please get it done.
clivingston likes this.
Project_dog is offline   Reply With Quote
 Old 12-07-2015, 02:26 PM   #4
Dang
Did you take it to the dealer? Any idea how the cost was broken down? Has everything been fine since, how many miles ago did you get it done?
I see full kits OEM labeled Mazda for like $425 online, and then take it to the dealership if they're going to try and charge more. It really sucks I just spent $80 on an oil change last weekend, I believe it has to be drained for this procedure.
 Old 12-07-2015, 02:36 PM   #5
robbspeed's Avatar
Groans: 50
Have you really been driving it around like this for 3 years?
Just curious
Totaled/ R.I.P.
 Old 12-07-2015, 02:38 PM   #6
Just curious
Yes..... 3 years and a lot of driving minus the occasional wont start on the first turn and the noise it seems to run fine 18mpg (used to be higher but I think my roof rack brought it down)
 Old 12-07-2015, 02:44 PM   #7
robbspeed's Avatar
Groans: 50
My god, that poor engine. Its been out of time for so long. You need to do some serious reading and buy a lot of tools and start doing your own work. It'll save you money.
Totaled/ R.I.P.
 Old 12-07-2015, 02:50 PM   #8
Yeah, like I said I was broke in college so I didnt want to fix anything that wasnt causing a check engine light to come on.
Do you think the timing is also what is causing the occasional starting problems?
Mazda dealership wants about $1700......
Last edited by clivingston; 12-07-2015 at 02:50 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-07-2015, 02:53 PM   #9
robbspeed's Avatar
Groans: 50
Yeah I would say so. If it skips a tooth you'll have bigger problems than a CEL.
It must run rough, no?
Totaled/ R.I.P.
Last edited by robbspeed; 12-07-2015 at 02:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-07-2015, 02:56 PM   #10
What would you describe running rough as? I feel like it runs fine
 Old 12-07-2015, 03:01 PM   #11
robbspeed's Avatar
Groans: 50
Engine shaking and poor acceleration. If the timing chain is that loose I would think it wouldn't run well
Totaled/ R.I.P.
 Old 12-07-2015, 03:08 PM   #12
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
ALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the world
Groaned at 8 Times in 3 Posts
The CEL won't pop on for a VVT unless its more than 14 deg off timing. P0340 sets.
Buy your parts online, and get a labor quote for a VVT job. Should not be any more than 5.5 hours. Which equates @ 95/hr depending on the labor rate of the shop.
I've heard worse.
2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30
ALPINEST4RS is offline   Reply With Quote
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
robbspeed (12-07-2015)
 Old 12-07-2015, 03:12 PM   #13
I'd say the engine shakes a little, acceleration seems normal. I was test driving some 4 cylinder Jeeps this weekend and found my CX-7 has much better acceleration. I just dont know if its worth spending $1.7k on this fix, $200 for a transmission flush, probably 700-800 on new tires for a car thats probably worth 5k? The jeep dealership was going to offer me 3k for it as a trade in.
A NAPA mechanic quoted me $700 for labor if I brought in the parts, but I have read on here that its not a good idea to do it with someone who hasnt done it before.
I've heard worse.
The dealership I called was quoting me for 7.8-8 hours
Last edited by clivingston; 12-07-2015 at 03:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-07-2015, 03:13 PM   #14
robbspeed's Avatar
Groans: 50
Fuck a jeep. Fix your shit or buy a speed.
Totaled/ R.I.P.
 Old 12-07-2015, 03:13 PM   #15
Yeah that was my opinion after test driving some jeeps lol
 Old 12-07-2015, 05:16 PM   #16
Does anyone have a recommendation for a place to buy the whole kit of parts? If so how much and where?
I'm just going to get the car fixed and hope nothing else major fails.
 Old 12-08-2015, 12:40 AM   #17
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
Edge Autosport has VVT kits.
sent from my Nexus 6P
The Following User Says Thank You to MS3Shadow For This Useful Post:
ALPINEST4RS (12-08-2015)
 Old 12-08-2015, 06:59 AM   #18
I didnt see a VVT kit for the CX-7 is it the same as the Mazda OEM VVT Replacement Kit Mazdaspeed 3 2007-2013 / Mazdaspeed 6 2006-2007?
Mazda OEM VVT Replacement Kit Mazdaspeed 3 2007-2013 / Mazdaspeed 6 2006-2007 - EdgeAutosport.com
 Old 12-08-2015, 07:03 AM   #19
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
The engine should be the same, I think.
get in contact with them, to make sure or they can tell you where you might need to go.
Sent from my Nexus 6P
 Old 12-08-2015, 07:13 AM   #20
Anyone used the VVT from DCR? I would hate to put a new faulty Mazda part in.
VVT Actuator
 Old 12-08-2015, 07:57 AM   #21
I got all my parts from Tasca. They are out of Rhode Island. Cheaper than anyone.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
 Old 12-08-2015, 08:13 AM   #22
VVT kit is the same for a c-x7.
If the NAPA guy is a ford tech, then more than likely he's done a keyless L3,LF,L5, ect.
As for it being worth it... Some people love the car, some don't. If you're thinking of getting a new car then I'd make that decision before even repairing anything.
 Old 12-08-2015, 10:59 AM   #23
You are quite right! thanks!!
Here is my shopping list
Am I missing anything??
I am thinking about spending the extra $$ and getting the DCR actuator, any comments?
Thank you all for being so helpful!
 Old 12-08-2015, 11:21 AM   #24
Police - Grammarhead
Vansquish's Avatar
Groans: 1,854
If memory serves, Mazda revised the design later in the MZR DISI production run.
 Old 12-09-2015, 06:42 PM   #25
By far the cheapest, I tried to get my local Mazda dealership to price match and they said these parts were less than whole sale so they could not match them.
 Old 12-09-2015, 09:33 PM   #26
It seems like there are so many lists and kits with different parts
My list right now based on kits from eBay and people posting here is:
Variable Valve Timing Actuator
Timing Chain
Valve cover gasket
Serpentine belt??
The cam sprocket bolts x2
The cam friction washers: x2
Timing chain tensioner
bolt lock-c shaft
washer lock x3
chain guide
lever
RR Gasket
rtv silico
FRONT CRANK SEAL
Plug Blind
WASHER SEALING-HEAD COVER x 14
RING O
total 480 from Taska
Any thoughts?
engine does not start czbo CX-7 > Issues & Troubleshooting 5 05-09-2015 05:43 PM
Blocked off egr pipe and car wouldn't start? minger 2010 MS3 - Engine, Transmission & Driveline 18 06-04-2012 10:14 PM
New engine noises soaringeagle129 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-01-2011 12:10 PM
Engine Wont Start What So Ever BGofMD MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-18-2010 04:31 PM
engine build to start soon austin102085 MazdaSpeed 3 - Engine, Transmission & Driveline 25 09-25-2009 12:11 PM
Page generated in 0.45674 seconds with 25 queries
