Like Tree2Likes
 Old 03-08-2011, 08:22 AM   #1
RiceBurn2.3T's Avatar
Posts: 74   (View Stats)
RiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to behold
Default Knocking sound w/ video...
Hey guys, been having this problem for a while but been getting worse/louder. It will go away (barley audible) SOMETIMES after a long warm up, or driving for a few miles or so. Its louder when driving then it is in neutral. Now the sound is there more then not... Opposite of a month or so ago.
Couldnt really find the exact issue on here...Sorry if Ive missed it.
THANKS!!!
http://s219.photobucket.com/albums/c...8-10-35-15.mp4
RiceBurn2.3T is offline   Reply With Quote
 Old 03-08-2011, 08:48 AM   #2
Novej's Avatar
Posts: 353   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Dude if you can feel the engine vibrating, and your hearing it make a knocking noise, don't rev it OR EVEN RUN IT anymore (i understand you did that to create your video).......and get it towed to your dealership ASAP........At first I thought maybe that was just your tensioner making that sound (mine did the same thing) HOWEVER, you said you feel the engine vibrating too....yeah shut it down and get it towed in immediately!!!! DO NOT RUN IT ANYMORE!!!!
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
The Following 3 Users Say Thank You to Novej For This Useful Post:
ELiTeNeSs (03-08-2011), Raider (03-08-2011), RiceBurn2.3T (03-08-2011)
 Old 03-08-2011, 09:15 AM   #3
edwhayes's Avatar
Posts: 157   (View Stats)
edwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to all
Agreed
edwhayes is offline   Reply With Quote
 Old 03-08-2011, 10:52 AM   #4
Thanks. Does anybody know what the problem could be exactly?
 Old 03-08-2011, 11:01 AM   #5
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I bet its your tensioner. If you car has sat for a long time, and developed a warp in the accessory belt, it can pull the tensioner in and out each time it passes. Try watching it while it makes the noise.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 03-08-2011, 11:15 AM   #6
qtrmile beast's Avatar
Posts: 2,417   (View Stats)
take you oil cap off and stick your finger in there and see if you can feel slack in the chain. I bet that is were your noise is. This is the TIMING CHAIN tensioner not to mistaken for the belt tensioner. you can also look inside of your valve cover just above where the chain is and see where it was hitting the cover..
If you were to pull your valve cover off it may look like this
VIDEO....
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
 Old 03-08-2011, 12:09 PM   #7
Captain
Groans: 79
^^^ Also a good possibility
For the accessory belt, you could put a mark on it with a mark, and if that mark is in rhythm with the noise, it's the belt tensioner. If not, try the chain tensioner.
lvdukerider likes this.
www.permtuning.com
 Old 03-08-2011, 12:49 PM   #8
Wow, you guys are awesome!! Way better then other forums!
Ill deff. check that out. What might explain the vibrating? I can really feel it most of the time its idling.
The Following 2 Users Say Thank You to RiceBurn2.3T For This Useful Post:
Alpha (05-17-2011), BrianZX10R (03-08-2011)
 Old 03-08-2011, 12:54 PM   #9
Captain
Groans: 79
Well... like others before charles and i posted suggested.... it could be a bent rod.
Does your clutch pedal pulsate / vibrate when you just barely push it in (right when it begins to engage)? If so, turn the car off and do like the others suggested... tow it to the dealer.
www.permtuning.com
 Old 03-08-2011, 12:57 PM   #10
i have multiple mounts on my car so my car vibrates to hell so if you are one those that can FEEL the slightest vibration then i could not help you with that one sorry.... do you have an aftermarket mount? maybe your car is idling low? not sure?
track weight 3220
street weight 3370
 Old 03-08-2011, 03:22 PM   #11
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
I think there is something wrong with this car
RiceBurn2.3T likes this.
Amazon is offline   Reply With Quote
The Following 2 Users Say Thank You to Amazon For This Useful Post:
RiceBurn2.3T (03-08-2011), ScarMS3 (03-08-2011)
 Old 03-08-2011, 03:26 PM   #12
ScarMS3's Avatar
Posts: 2,088   (View Stats)
ScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the world
Groans: 97
Groaned at 31 Times in 25 Posts
You hit the proverbial nail on the head with that comment amazon
ScarMS3 is offline   Reply With Quote
The Following User Says Thank You to ScarMS3 For This Useful Post:
Amazon (03-09-2011)
 Old 03-08-2011, 06:06 PM   #13
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Vibes, motor mounts. Passenger Sid have brown shit on the frame below it? It so it's bad. Rear might be torn too. The rest, chain is what I heard.
RiceBurn2.3T (03-09-2011)
 Old 03-08-2011, 06:26 PM   #14
A rod was my first thought but I kinda decided to go 'selective thinking' on that one till we eliminate ALL other possibilities
My trans is auto...
 Old 03-08-2011, 06:42 PM   #15
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
So my car sounds exactly like this. I didn't notice it until I put in my TRZ tranny mount so I didn't really think much of it at first, but it has been getting louder. I just went out into the garage and stuck my finger in the oil cap and there is quite a bit of slack on the chain. Maybe just shy of the amount of slack in the video, but still a noticeable amount.
I'll take it in to the dealer if it needs looked at. How tight should it be?
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
 Old 03-08-2011, 06:48 PM   #16
ScarMS3's Avatar
Groans: 97
Originally Posted by kabobulate View Post
I didn't notice it until I put it in my trannyI just went out into the garage and stuck my finger In.How tight should it be?
Fixed it for you
The Following 3 Users Say Thank You to ScarMS3 For This Useful Post:
2007speed3 (03-28-2011), asall667 (08-03-2011), kabobulate (03-08-2011)
 Old 03-09-2011, 05:58 AM   #17
I dont think I have any after market mounts. It might be idling a bit low, Ill check.
A bit, thanks.
Last edited by RiceBurn2.3T; 03-09-2011 at 05:59 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-09-2011, 08:24 AM   #18
Captain
Groans: 79
The chain tensioner uses oil pressure to tighten. So it's best to check it when the car is warm. If it's still loose, then you have a problem.
My trans is auto...
Oh snaps... didn't even know what forum i was in lol. GL and keep us posted with what you find.
www.permtuning.com
4G63 (03-19-2011), kabobulate (03-09-2011)
 Old 03-09-2011, 09:13 AM   #19
Sorry for the rotated video....but no oil in the motor and the chain stays tight.. But DJ is right when the VVT changes timing with oil pressure also the tensioner uses oil to push the pin out to keep the tension on the chain.. when the vvt rotates to advance or retard timing this is when the chain is loosening and tightening but the deflection is very minimal..
This is freshly built motor with all new parts that i was about to install...
track weight 3220
street weight 3370
djuosnteisn (03-09-2011), kabobulate (03-09-2011)
 Old 03-09-2011, 04:09 PM   #20
kabobulate's Avatar
I checked when it was warm and it is tight. Thanks for the info. OP can have the thread back.
 Old 03-09-2011, 04:31 PM   #21
What you might want to do is take the valve cover off and check to see if the chain was hitting the cover or not this will let you know that the chain is tooo loose or not. The chain will get loose and tight due to oil pressure and also the VVT rotating to change timing. You just want to check the deflection of the chain to see if that looseness is tooo loose or not..
track weight 3220
street weight 3370
 Old 03-09-2011, 05:56 PM   #22
edwhayes's Avatar
The chain should NOT get looser & tighter because of the VVT. The tensioner will or is supposed to keep a constant tension to the chain and has nothing to do with the VVt mechanism.
 Old 03-19-2011, 08:17 AM   #23
Ascend's Avatar
Posts: 20   (View Stats)
Ascend can only hope to improve
Groaned at 20 Times in 4 Posts
When my motor mounts went it started sounding like this, but my AC went at the same time so I don't know which was actually making the noise.
Ascend is offline   Reply With Quote
 Old 03-19-2011, 02:28 PM   #24
mikomi's Avatar
Posts: 148   (View Stats)
mikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to behold
I got some engine vibration too. The timing chain tension was fine, turns out it was a the bearings on the crankshaft and a crankshaft walk.
FYHN
mikomi is offline   Reply With Quote
 Old 03-19-2011, 02:56 PM   #25
kmac's Avatar
Posts: 1,792   (View Stats)
The noise could be the belt pensioners as dj and others said and the vibration can be the elastometer balancer is separating which will damage the tensioner and vibrate the veh as well.
 Old 03-26-2011, 06:48 AM   #26
Hey guys, sorry took so long. I've been super busy.
I pulled the valve cover and found that the timing chain IS loose. The funny thing is, I cant find a mark where the chain should be hitting the cover, creating the knocking sound. Is that the only spot it would hit to make that knocking sound? I really hope this is the only problem. Thanks guys!
Sorry, my friend kept talking during the video and I got a text lol.
http://s219.photobucket.com/albums/c...imingchain.mp4
 Old 03-28-2011, 01:47 PM   #27
Im shopping around for parts. Wont be able to buy them till maybe Wednesday. Found a chain for $30 and a tensioner for around the same. Do you guys recommend any brand, or somewhere to get it?
Tensioner...
2010 MAZDA CX-7 SPORT Engine Timing Chain Tensioner
Timing chain...
http://www.partswebsite.com/mazdapar...magecallout=16
Do you guys approve?!
THANKS!!
 Old 03-31-2011, 01:06 PM   #28
aaahh...Anyone home?
Gotta order the parts but I want to know if these are good reliable stuff.
Thanks guys!
 Old 04-16-2011, 08:00 PM   #29
 Old 04-20-2011, 04:53 PM   #30
 Old 04-20-2011, 06:20 PM   #31
Raider's Avatar
Groans: 856
Dude, I am so sorry! I thought i posted. There is a thread in the ms3 section where someone replaced the chain. There is a specific tool needed to keep shot lined up. Search for that thread and I will also check in the morning.
Did you ever look at the passenger side motor mount? $10 donation to the forum will get you access to the tech manuals for the speed 3 which crosses over.
I just watched your video, and that is loose!!!
Last edited by Raider; 04-20-2011 at 06:20 PM. Reason: MSF Database - Automerged Doublepost
RiceBurn2.3T (04-23-2011)
 Old 04-21-2011, 06:17 AM   #32
Raider's Avatar
Groans: 856
Found the thread:
Replacing timing chain
Full of info for you!
 Old 04-23-2011, 05:08 PM   #33
Thanks man! I thought you guys where ignoring me because I never donated yet, haha. I will donate but we are seriously tight with money right now. This car is draining me. On top of the timing chain issue, the ac went out and its getting hot, and the suspension is being weird. But I will definitely donate at least the minimum asap.
So what do you think of the parts Ive found?
 Old 04-23-2011, 06:48 PM   #34
Raider's Avatar
Groans: 856
I buy my oem parts from onlinemazdaparts.com. Check them out!
 Old 05-03-2011, 10:28 AM   #35
I dont know if I trust the OE parts after experiencing and hearing about so many problems so soon with them.
 Old 05-03-2011, 10:31 AM   #36
Raider's Avatar
Groans: 856
aftermarket can be sketchy though. Some cheap parts sites might be as trusting as the ebay turbonator.
 Old 05-10-2011, 03:40 AM   #37
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Looks like I might be dealing with this sooner than later!
I have to do some more investigating later.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
 Old 05-10-2011, 05:05 AM   #38
Raider's Avatar
Groans: 856
I would be taking the valve cover off ASAP before driving it again, then. Otherwise, I expect a how-to on CX-7 motor replacement if it blows.
 Old 05-10-2011, 07:56 PM   #39
The Angry Goose
Hectik1's Avatar
Right now I am leaning torwards something else. Don't hear it while cruising, etc. Time for more investigation.
Hector
2014 Mazda 3
1979 Mazda Rx7
 Old 05-11-2011, 02:57 AM   #40
Raider's Avatar
Groans: 856
Passenger motor mount is always suspect. Look for signs it crapped itself. Brown liquid all around and below it.
Rotareez (02-27-2018)
knocking sound on acceleration, not ABS bzwyatt CX-7 > Issues & Troubleshooting 5 12-15-2010 06:05 AM
Knocking sound coming from rear differential on acceleration volodya84 MazdaSpeed 6 - Engine, Transmission & Driveline 3 04-23-2010 06:31 AM
VIDEO: Mythbusters annihilate a car near the speed of sound Haltech Automotive News 0 12-06-2009 05:10 PM
VIDEO: Toyota FT-86 sure doesn't sound like a boxer Haltech Automotive News 0 11-05-2009 04:50 PM
Custom CBE part 2 Video and sound clip Greyspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 12 04-13-2009 09:05 AM
Page generated in 0.56200 seconds with 32 queries
