 Old 10-29-2017, 05:42 AM   #1
liamfm's Avatar
Posts: 9   (View Stats)
liamfm is an unknown quantity at this point
Default Long crank when warm, not hot.
Hi all,
2010 CX-7 2.3 T with about 96K on it. Around 65K it developed a hard start when warm (not hot, not cold, but after sitting for 20-60 min). Never threw a CEL, and the problem eventually just went away. Fast forward and we've been having the same problem since about 85K. It is basically a long crank 4-5 sec, when warm. This morning it did it cold as well (42*F). Once started it will restart fine, unless you let it sit for 20-60 min, then you get a long crank again.
No CEL at all, took to local mechanic and no codes lurking. Plugs have been replaced, but nothing else yet.
Can anyone point me in the right direction? I've read about sticking EGR valves, dirty throttle plates, etc.
The only thing I've noticed is that when doing a long crank I get the evap/gascap light on on the dash. It goes off as soon as the car fires, but the orange light stays on while cranking. I'm not sure that it comes on when the car starts properly, though that could just be that it starts so quickly.
I don't want to just throw parts at it, but I'm lost as to where to start.
Thanks in advance!
Sent from my XT1575 using Tapatalk
liamfm is offline   Reply With Quote
 Old 10-29-2017, 09:44 AM   #2
SaveMelMac's Avatar
Posts: 469   (View Stats)
SaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the world
Is it a slow crank? By long crank you mean the engine just turns over a few more times before it starts up?
SaveMelMac is offline   Reply With Quote
 Old 10-29-2017, 09:49 AM   #3
liamfm's Avatar
Fast crank, plenty of battery power, just longer time
Sent from my iPad using Tapatalk
 Old 10-29-2017, 06:05 PM   #4
Bob-o's Avatar
Posts: 1,312   (View Stats)
Bob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the world
My 09 speed 3 does that too
EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah
Bob-o is offline   Reply With Quote
 Old 10-29-2017, 06:36 PM   #5
liamfm's Avatar
I took the egr out today, soaked it in purple power, followed by hot water to flush it. It didn't seem stuck, but it was carboned up a bit. So far, the engine seems quieter, and starts instantly. Time will tell. Total project time, 2 hrs and 8 oz of purple power. On my Dodge with a Cummins, this is a 67.5k service. Same basic setup, but gas vs diesel. Maybe Mazda should have considered it a 70k service item.
Long Crank, no CEL liamfm CX-7 > Issues & Troubleshooting 11 10-29-2017 05:46 AM
Hard Start, Long Crank, Rough Idle red ghost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 10-07-2014 11:24 PM
Long Crank at cold start maikell77 2010 MS3 - Troubleshoot/Diagnostics 4 03-13-2013 08:54 PM
Page generated in 0.28816 seconds with 22 queries
