 Old 06-15-2016, 10:07 PM   #1
brooklyncx7's Avatar
Posts: 13   (View Stats)
brooklyncx7 is an unknown quantity at this point
Default major jerking
Iv recently had the timing chain and vvt repair on my 2007 mazda cx7. 2 days later I started experiencing intense jerking when driving. The car would jerk as if its not getting enough gas or something. The jerking is intense, you could really feel it. This would happen for about 10 miles each time and then something would happen and it would run completely fine. The CEL is on and the code is p2187. (System too lean at idle) I went to the repair shop and we had the computer reflashed because I had the timing chain fix. However post reflash the problem remained. Has anyone experienced this? Mechanic is pretty confused as well at this point. We did a smoke test 2 times everything was fine. Can it be pcv valve? MAF? or fuel pump? Any input appreciated
brooklyncx7 is offline   Reply With Quote
 Old 06-15-2016, 10:19 PM   #2
Iv read through the forum and the people that have been getting the p2187 dont seem to report the jerking issue Im talking about. Unless if thats what rough idle means?
 Old 06-15-2016, 10:23 PM   #3
SpeedRebirth's Avatar
Posts: 685   (View Stats)
SpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the world
Groans: 33
Like this?
Mazdaspeed6 -06
Tuned with by Alex@Stratified
CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP
Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation
Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit
JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2
Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025
Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp
Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter
Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
Last edited by MS3Shadow; 06-16-2016 at 06:12 AM. Reason: removed the s for the video to embed
SpeedRebirth is offline   Reply With Quote
 Old 06-16-2016, 07:50 AM   #4
Originally Posted by SpeedRebirth View Post
Oh yes very similar! It would do that and then after a couple of miles something would change and would drive fine. Did you end up figuring out what the problem was?
 Old 06-16-2016, 08:08 AM   #5
Groans: 33
Tried to tune it out but nothing changed. I heard some say it could be a bad O2 sensor. It always happens between 1500-2400 rpm when barely accelerating, so sitting in traffic slowly going forward is a pita because it will buck suddenly which may look like I'm a terrible driver lol. Some day I'll swap out the sensor and see if anything changes
Mazdaspeed6 -06
290 AWHP / K04
 Old 06-16-2016, 08:12 AM   #6
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,443   (View Stats)
Groans: 890
The Following User Says Thank You to SofaKingAwesome For This Useful Post:
WetzMS3 (06-16-2016)
 Old 06-16-2016, 08:18 AM   #7
No check engine light?
 Old 06-16-2016, 08:18 AM   #8
Police - Grammarhead
Vansquish's Avatar
Groans: 1,854
Check your plugs. I've had similar symptoms when I had a fouled plug.
 Old 06-16-2016, 08:20 AM   #9
Did you have a check engine light with code p2187?
 Old 06-16-2016, 08:28 AM   #10
Vansquish's Avatar
Groans: 1,854
Nope. If you're getting a too lean at idle code, you've got a vacuum leak. Check your purge valve.
 Old 06-16-2016, 08:39 AM   #11
Thanks I'll take a look! I did 2 smoke tests but everything was fine though. Can a purge valve problem be revealed through a smoke test? I'm sorry I'm a noob this is my first ever car!
 Old 06-16-2016, 08:56 AM   #12
Vansquish's Avatar
Groans: 1,854
No. You'll have to pull the valve off and see if it is broken. There are a bunch of threads on here about this problem. Use the search tool in my signature to find them.
SofaKingAwesome (06-16-2016)
 Old 06-16-2016, 09:40 AM   #13
MikeBavaro's Avatar
Posts: 269   (View Stats)
MikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant future
Primary o2 sensor, It took forever for me to pinpoint it, next time it starts spitting stand on it for a second or so to blow out the extra fuel. it bucks because the primary o2 sensor says its lean AF and dumps extra fuel in. eventually it will throw a code for a bad 02 sensor but that may take a few months.
2007 MS3
True Red
HKS BOV-K&N CAI-APV3-CS TMIC
CS Short Throw-Whiteline Bushings-CS Rear Bar
1968 Mustang
Built 289 w/ factory heads
Built C4
Bulit 8" posi
Runs low 14's at 100 flat
MikeBavaro is offline   Reply With Quote
 Old 06-16-2016, 10:06 AM   #14
Can a bad 02 sensor throw a P2187 code? And is there a way to make sure it is the 02 sensor?
 Old 06-16-2016, 10:29 AM   #15
MikeBavaro's Avatar
You can disconnect the primary o2 and take it for a rip and if the condition goes away, its bad. I never did this test on my speed 3 so I cannot speak from personal experience on how easy/ it is. My car eventually threw p2187 as well as bank 1 sensor 2 too rich, but that was after chasing it for 2 months.
2007 MS3
True Red
1968 Mustang
Built C4
Bulit 8" posi
 Old 06-16-2016, 11:33 AM   #16
After the car warms up like after 5-10 miles the condition goes away and everything works completely fine except CEL is on. So everything is capable of working well.
 Old 06-16-2016, 11:35 AM   #17
MikeBavaro's Avatar
Mine only did it in 6th on the highway doing about 65-75, usually on throttle tip in like when going up a hill
2007 MS3
True Red
1968 Mustang
Built C4
Bulit 8" posi
 Old 06-16-2016, 11:48 AM   #18
PolishMs3's Avatar
Posts: 56   (View Stats)
PolishMs3 is just really nicePolishMs3 is just really nicePolishMs3 is just really nicePolishMs3 is just really nice
I'm having the exact same issue, I switched to an e30 tune a few months back so I was thinking it could be my hpfp but it's clean! I get the jerkiness right after shifting into second and 3rd gear with very light throttle but only during the first 10-15 mins of starting the car, after I drive for a little while it goes back to normal. I don't have a CEL coming on though.
PolishMs3 is offline   Reply With Quote
 Old 06-19-2016, 08:56 AM   #19
I'm going to my mechanic tomorrow. But is there a reason most people don't think it's a bad fuel pump?
 Old 06-19-2016, 09:10 AM   #20
PolishMs3's Avatar
I'm not sure but I was way wrong on my last post. After trying to start the car again my fuel pressure was around 200 and the car was not wanting to run correctly. I think my issues are due to a dirty spill valve. I'll be cleaning it this weekend and I'll post back if that was the issue
 Old 06-23-2016, 10:43 AM   #21
Here is a video of my issue. The jerking is much more relevant in person than it seems in the video.
Jerking under boost Mazda2012 Gen2 MS3 General Discussion 52 06-04-2018 04:51 PM
Mazdaspeed 6 jerking n hdzcarlos03 MazdaSpeed 3 - How-To's 7 07-08-2015 11:53 AM
Hesitation, jerking.. kish89 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 11-24-2012 02:59 PM
Car bucking/jerking with ECT less than 140* bmylez MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 03-13-2012 09:14 AM
jerking below turbo DCLXVI MazdaSpeed 3/6 - ECU Computer Tuning 3 08-25-2009 04:30 PM
Page generated in 0.39813 seconds with 25 queries
