 Old 07-24-2017, 02:29 PM   #1
AboveAverageJoe's Avatar
Posts: 43   (View Stats)
AboveAverageJoe has a spectacular aura aboutAboveAverageJoe has a spectacular aura aboutAboveAverageJoe has a spectacular aura about
Default My engine light does not work is it supposed to light up when I insert the key?
My light doesn't come one when you insert the key like it did in my 3. I looked at the gauge cluster and it doesn't look like it's been tampered with. Is there another way the light could be disabled? It has an old stored P0300 code (Random multiple cylinder misfire) when I used a code reader. so I'm curious why the light isn't on. I let it run and even though the chain is loose and it has the 5 second start rattle it's not throwing a code. What the heck is going on??
AboveAverageJoe is offline   Reply With Quote
 Old 07-24-2017, 03:26 PM   #2
SaveMelMac's Avatar
Posts: 469   (View Stats)
SaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the world
It should turn on. Maybe the bulb or led burnt out?
SaveMelMac is offline   Reply With Quote
 Old 07-24-2017, 04:07 PM   #3
After looking at the cluster, I would have to pull the needles off the gauges to separate the boards. I think I'll break it if I do.
 Old 07-24-2017, 04:47 PM   #4
JSmith's Avatar
Posts: 697   (View Stats)
Groans: 102
Groaned at 6 Times in 6 Posts
Is that cluster in an automatic...?
 Old 07-24-2017, 05:15 PM   #5
Yes, it's an automatic.
Trunk light doesn't work? Bryce99 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 11-10-2016 09:02 AM
e-brake light, abs light, dsc light, and traction control light DarrenMon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-27-2016 08:44 PM
Check engine light came on after 7 months with light mods SwizzleSpd MazdaSpeed 3/6 - Turbo Induction 10 01-03-2013 05:15 PM
How does the Auto light work on gt models? hMg_Ms3 MazdaSpeed 3 - How-To's 7 08-02-2011 01:52 PM
Page generated in 0.30205 seconds with 22 queries
