Like Tree6Likes
 Old 06-29-2015, 01:02 AM   #1
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Default my vvt issue
Well I have reading and reading for the past two days. Trying to figure out what I did wrong. every time I started my cx 7 i could hear my vvt getting worse and worse. I order parts. Last Yesterday I did it. I use the cam tool and the crank pin. I marked the Crank pulley to the crank Position Sensor. Once I got the vva. I marked it to the cam. Transferred the mark to the new one. installed it. put the chain on. it was loose in the middle. I tried to move the intake cam to torse the exhaust cam it wouldnt. I still had the cam tool on. so we rotated the vva to the front of the car. To tighten the chain up. once I got to the crank pulley. I lined it up with the crank position sensor. torqued it and turned it 90 degrees. Started it. Ran like crap and a knocking noise too. I did removed the crank pin before I started it.
Need some idea. Please Help. This is my daily driver.
Project_dog is offline   Reply With Quote
 Old 06-29-2015, 10:07 AM   #2
Anyone?
 Old 06-29-2015, 08:21 PM   #3
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Sorry just saw this. Sounds like the timing is way off. And if off enough, valves got bent. The only think you can do is get to TDC on the bottom end, and line up the cams.
If you can't, tow to dealer to get it done.
 Old 06-29-2015, 08:50 PM   #4
That's my plan.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
The Following User Says Thank You to Project_dog For This Useful Post:
Raider (06-30-2015)
 Old 06-29-2015, 09:35 PM   #5
frothy's Avatar
Posts: 1,067   (View Stats)
The wording of the OP is a little convoluted, but this thread is essentially a continuation of something that started in Rokusek's HOW-TO VVT thread.
OP had a VVT that was all jingly jangly so he read up, bought some parts, and took a stab at some engine surgery this past Sunday.
Timing tools were used and supposedly everything lined up appropriately, but upon startup engine knock was prevalent and the vehicle ran like crap.
 Old 06-30-2015, 05:40 AM   #6
Raider's Avatar
Groans: 856
Ah. Well this could be really bad if it was that far off. Of course, the camp position sensor being loose can make the car run like ass too.
 Old 07-01-2015, 09:48 AM   #7
torquemaniac's Avatar
Posts: 727   (View Stats)
Did you make sure piston #1 was against the TDC pin when you torqued everything up?
If the cam tool was in place, and the crank position sensor is correctly aligned, the only thing that could have gone wrong IMO, is that piston #1 was not perfectly at TDC
One extra thing I did in my build to make sure everything align perfectly, is to mark the timing chain and the cam gears...see post #1 38 here : Big turbo build CX-7 :P
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler // Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
Coming soon : Composite ram-air intake // Hood with heat extraction vent
 Old 07-01-2015, 10:43 AM   #8
I did. I towed it to mazda yesterday.
 Old 07-01-2015, 11:48 AM   #9
well bad news. valve hit the piston. There goes my car.
 Old 07-01-2015, 11:52 AM   #10
Raider's Avatar
Groans: 856
Damn dude. That sucks.
You can get a rebuilt longblock for about $3500 though, with warranty.
 Old 07-01-2015, 12:20 PM   #11
Raider's Avatar
Groans: 856
@EdgeAutosport.com; can finance you, too.
 Old 07-01-2015, 12:38 PM   #12
Well I will look into that. Thanks raider.
 Old 07-01-2015, 12:41 PM   #13
Raider's Avatar
Groans: 856
No worries. Call and ask for Alan. Tell him you love his music and Raider says hi.
EdgeAutosport.com (07-14-2015)
 Old 07-01-2015, 12:47 PM   #14
frothy's Avatar
Posted earlier today, FYI:
Originally Posted by EdgeAutosport.com View Post
Hey guys, just wanted to let you know that I will be going on vacation tomorrow and I won't be back in the office till the 14th of July. You can still contact us by emailing sales@edgeautosport.com. But, response time on the forum will be down until I get back so if you need anything, just email, or call us at 303-268-2140.
Thanks,
Alan
 Old 07-01-2015, 01:30 PM   #15
SeeMeGovan's Avatar
Posts: 939   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
Oh man in sorry. I'm still a bit confused about your procedure when you were tightening the cams but it sounds like you didn't have even chain tension when you tightened the cams so that can actually put your timing slightly off if the tension is really uneven.
I hope you get it fixed up soon.
Sent from my SGH-T889 using Tapatalk
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
 Old 07-01-2015, 02:43 PM   #16
My pan is to pay the be diagnosed time. Get it towed to the house. Start tearing it down
 Old 07-01-2015, 03:05 PM   #17
Like I said. The chain was loose a little bit. So we turned the vva to tight the chain up. Then torq the vva to the cam
 Old 07-01-2015, 03:39 PM   #18
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
So how did you fuck up exactly?
Here's a video that shows fairly well how to time a similar motor.
https://www.youtube.com/watch?v=RqwnDmDkZrQ
I'm putting a 2.3 fusion motor in my daily and will have to swap intake cam and cranshaft pulley. I would like not to make the same mistake as you.
SeeMeGovan likes this.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
 Old 07-01-2015, 06:47 PM   #19
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Damn bro, I didn't see you had actually started your own thread.
Sorry to hear the outcome. I was really hoping this wasn't the problem. keep your head up and rebuild.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline   Reply With Quote
 Old 07-02-2015, 02:11 AM   #20
Ya me too man.
I went over to mazda today. looks like the valve did hit the piston. all 4 cylinders. by the looks of it its not a lot of damage to the piston. The tech did a compression test. 1,3,4 are good. around 180. number 2 was at 90. they quoted me 2 engines. new and used. I told them no. I dont have 8700
My plan is to get it home friday. Then start tearing it down. I really hope I can get the cylinder head fixed and call it good.
 Old 07-02-2015, 11:02 AM   #21
stockms3's Avatar
Groans: 74
@Project_dog; so how exactly did you fuck this up?
 Old 07-02-2015, 02:51 PM   #22
I don't know. Honestly
 Old 07-02-2015, 09:27 PM   #23
stockms3's Avatar
Groans: 74
Damn that sucks dude. After you timed it, did you rotate the crank and then insert all the tools again to see if everything is still lined up?
 Old 07-03-2015, 11:32 PM   #24
No.
Got her home today. Started to tear it down.
I have a lot to do. I am going to pull the oil pan. Check for metal. I did find a spring (little one) timing cover housing.
I'm not sure if I want to do upgrades or just get her back to stock. I don't know anything about what piston upgrades rods, valves, I have a lot to read.
I am looking for a how to in pulling the cylinder head. If anyone knows.
 Old 07-04-2015, 12:00 AM   #25
Don
Don's Avatar
Posts: 181   (View Stats)
Don has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond repute
you should be ok with a new head if the pistons and cylinder walls are ok. it sounds like you slightly bent a valve which isnt a huge deal. remove the head, check for damage, get new valves and guides in the original head.. enjoy
Don is offline   Reply With Quote
 Old 07-04-2015, 07:28 PM   #26
udntknw's Avatar
Honestly. Factory service manual is the best guide to removal.
**Old Motor**
**New Motor**
 Old 07-04-2015, 10:13 PM   #27
l4nc3r's Avatar
Posts: 153   (View Stats)
l4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the world
Where you messed up, you turned the VVT to fix the timing. That's very wrong.
Keep the timing tool in until you're fully done and everything is torqued correctly.
Bolt VVT up to Intake Cam. Torque it down.
Make sure Piston 1 is TDC. Install TDC pin in back of block to keep cylinder there.
Put chain on. No slack between Exhaust and VVT. Slack is allowed between VVT and crank, and back up to Exhaust.
Pull the pin on the chain tensioner. Chain will snap tight. Should be no slack anywhere on the line now.
Put everything back together. Car is timed.
Until you're done with the whole procedure, Do NOT remove timing tools and do NOT turn the camshafts. All the chain tightening should be done by the chain tensioner.
07 Red Speed3 - SHE'S ALIVE! SHE'S ALIVE!!!
GT3071R / HTP 4" Intake / Brentported Intake Manifold / CXRacing Piping with TR8L Core
DNP v2 Exhaust Manifold / Stainless Steelworks Downpipe/Test Pipe / HKS Hi-Power CatBack
FreekTuned E25 / HKS SSQV2 / JBR 88 Trio
Bilstein B8's / Eibach Prokit / Drag DR-34 18x8
Soon to be installed - Snow Performance Meth Kit with CM14 Nozzle
l4nc3r is offline   Reply With Quote
 Old 07-04-2015, 10:58 PM   #28
 Old 07-05-2015, 07:52 AM   #29
udntknw's Avatar
If I read his explanation correctly. Before he tightened the vvt to the cam, he rotated the vvt only with the timing tools still in place to remove the slack.
**Old Motor**
**New Motor**
 Old 07-05-2015, 08:41 PM   #30
stockms3's Avatar
Groans: 74
That's interesting in the video I watched they rotate both the exhaust and intake cam to get rid of the slack.
https://youtu.be/RqwnDmDkZrQ?t=2m49s
 Old 07-05-2015, 09:36 PM   #31
Pulled the head off today. Did find some marks on the pistons. A ton of carbon built up on the pistons. I cleaned up. I didn't find any cracks.
 Old 07-05-2015, 09:43 PM   #32
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
I put some brake clean in the exhaust ports too see if the valves are leaking. Number 2 is leaking. Later tonight I'm going to do the intake side.
Plus I'm going to send it out to tested.
torquemaniac (07-06-2015)
 Old 07-06-2015, 08:28 AM   #33
Lex2007's Avatar
Posts: 553   (View Stats)
For whatever its worth bro, I give you credit for trying and for struggling on. Successful people are never afraid to fail. This is a pain in the ass but you're gonna learn a lot in the process and become that much more confident.
Project_dog likes this.
The Following User Says Thank You to Lex2007 For This Useful Post:
Project_dog (07-06-2015)
 Old 07-06-2015, 10:05 AM   #34
Does the pistons have cut out for the intake valve. ?
 Old 07-06-2015, 10:45 AM   #35
udntknw's Avatar
Yes, they have reliefs for the valves
**Old Motor**
**New Motor**
 Old 07-06-2015, 11:11 AM   #36
Well next step. Is I'm going to remove. The pan. Check the rod.
 Old 07-06-2015, 04:17 PM   #37
Keep up the good work...now youre gonna the engine inside/out
 Old 07-06-2015, 05:03 PM   #38
I need to figure out how to support the engine while I take off the oil plan. Since I don't have the pass side motor mount.
 Old 07-06-2015, 05:04 PM   #39
udntknw's Avatar
Are you concerned about the rod?
**Old Motor**
**New Motor**
 Old 07-06-2015, 06:01 PM   #40
Put back the timing chain cover and passenger side mount, then take of the pan...its no fun, but its the only way
A/c issue USMCMAzda MazdaSpeed 3/6 - Troubleshoot/Diagnostics 29 06-08-2013 03:56 PM
DDM HID 35W Issue spoof3r Exterior 2 03-31-2011 12:53 PM
ECU/PCM issue 08ms3_spirit MazdaSpeed 3/6 - ECU Computer Tuning 2 05-26-2010 08:12 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 07:40 PM
AWD issue caseygt2 MazdaSpeed 6 - Engine, Transmission & Driveline 7 02-14-2010 01:38 PM
Page generated in 0.57010 seconds with 30 queries
