Like Tree6Likes
 Old 07-07-2015, 02:54 AM   #41
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Originally Posted by udntknw View Post
Are you concerned about the rod?
Ya. I did find a old vvt spring laying around the crank.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Originally Posted by torquemaniac View Post
Put back the timing chain cover and passenger side mount, then take of the pan...its no fun, but its the only way
Thanks man.
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
Last edited by Project_dog; 07-07-2015 at 02:54 AM. Reason: MSF Database - Automerged Doublepost
Project_dog is offline   Reply With Quote
 Old 07-12-2015, 05:24 PM   #42
 Old 07-12-2015, 05:33 PM   #43
Better picture.
 Old 07-12-2015, 06:38 PM   #44
torquemaniac's Avatar
Posts: 730   (View Stats)
What is it?
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
 Old 07-12-2015, 06:39 PM   #45
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Pin cover from vvt actuator?
Project_dog likes this.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline   Reply With Quote
 Old 07-13-2015, 03:03 AM   #46
Yep it is. The smaller piece I found in the oil pick up tube.
 Old 07-13-2015, 03:23 AM   #47
frothy's Avatar
Posts: 1,067   (View Stats)
These were fragments from that first VVT actuator that you had replaced and not the new one, right?
 Old 07-13-2015, 03:35 AM   #48
Ya. My new one is ok.
The Following User Says Thank You to Project_dog For This Useful Post:
frothy (07-13-2015)
 Old 07-15-2015, 01:18 AM   #49
Wrist pin on number 3
Last edited by Project_dog; 07-15-2015 at 01:18 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-15-2015, 01:21 PM   #50
Does anyone know if my pistons are good?
 Old 07-15-2015, 02:44 PM   #51
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Default my vvt issue
@Dano; @Tomas;, advice.
 Old 07-15-2015, 03:08 PM   #52
Im not the expert, but the piston looks OK from the angle you gave
How are the ring land on the pistons?
I would not worry about the #3 wrist pin hole on the piston if you cleaned everything well and the pin goes in with a minimum of resistance (and if the pins surface is not dented)
Some of my OEM wrist pins required some force to get in, even if they were free of scratches and put back in the same piston (even getting them out required some force)
Anxious to see what the experts have to say
 Old 07-15-2015, 03:11 PM   #53
I'll get better pictures Tonight
 Old 07-16-2015, 01:48 AM   #54
Number 1 piston
Number 2 piston
Number 3 piston
Number 4 piston. I noticed some of the coating is coming off the side of the piston. Should I be worried?
 Old 07-17-2015, 02:26 AM   #55
Everything looks fine...
 Old 07-17-2015, 03:51 AM   #56
Raider's Avatar
Groans: 856
Now the one thing that caught my attention is the lack of signs of any impact of piston by the valve.
Is it actually possible that the low compression is the result of timing being off, and the noise is of that shit bouncing around?
 Old 07-17-2015, 07:17 AM   #57
How are the rings...this may explain the low compression on cylinder 2...if not, the fact that you moved the VVT to tighten the chain may have offset the timing on cylinder 2 just enough to affect compression!?!?
 Old 07-17-2015, 07:22 AM   #58
Raider's Avatar
Groans: 856
And that would be a simple-ish fix. Reassemble, and redo timing and such. No new motor. Just time right.
 Old 07-17-2015, 09:36 AM   #59
When timing the motor, align the VVt to the cam with the mark you made initialy...and if you need to tighten the chain, loosen the exhaust cam
Dont forget to make sure piston 1 is at TDC (crankshaft sitting on the DTC pin)
Here is BlueStreak how-to as a reference : How To: Assemble A Forged Motor
 Old 07-18-2015, 05:00 PM   #60
Whats the progress?
 Old 07-18-2015, 05:38 PM   #61
Well. A lot of the parts are on their way to my house. I'm cleaning up parts. Also I'm taking my intake manifold apart and cleaning it. Painting things too.
The Following 2 Users Say Thank You to Project_dog For This Useful Post:
Raider (07-18-2015), torquemaniac (07-19-2015)
 Old 07-28-2015, 03:56 PM   #62
Whats the status...forged rods in the block
The Following User Says Thank You to torquemaniac For This Useful Post:
Raider (07-28-2015)
A/c issue USMCMAzda MazdaSpeed 3/6 - Troubleshoot/Diagnostics 29 06-08-2013 03:56 PM
DDM HID 35W Issue spoof3r Exterior 2 03-31-2011 12:53 PM
ECU/PCM issue 08ms3_spirit MazdaSpeed 3/6 - ECU Computer Tuning 2 05-26-2010 08:12 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 07:40 PM
AWD issue caseygt2 MazdaSpeed 6 - Engine, Transmission & Driveline 7 02-14-2010 01:38 PM
Page generated in 0.41370 seconds with 25 queries
