Like Tree2Likes
  • 1 Post By m4tic
  • 1 Post By taf0422
 Old 03-11-2011, 06:00 PM   #1
txmedic83's Avatar
Posts: 4   (View Stats)
txmedic83 is an unknown quantity at this point
Default P0300 Random / Multiple Cylinder Misfires
Hi everyone,
Glad to see folks migrated instead of disappearing from the other forums. I changed my sparkplugs the other day at 60,000 miles. Put in Autolite Extreme Iridiums, the part verified as for my vehicle by the guy at Oreilly's (who I actually do trust). The gap on the plug is at .051, which was what was specified. I know the plugs I removed from the motor were gapped at around .029.
I went pedal to the metal last night and the check-light came on. Got back to the house and plugged into the computer and pulled P0300 - Random / Multiple Cylinder Misfires. Any chance this is related to the plug change, or gap in particular?
I'm pretty sure I didn't screw up the firing order since we have coil caps and I only did one plug at a time.
Thanks for your thoughts.
txmedic83 is offline   Reply With Quote
 Old 03-11-2011, 06:06 PM   #2
m4tic's Avatar
Posts: 4,922   (View Stats)
Originally Posted by txmedic83 View Post
Hi everyone,
really?? you dont know whats wrong?
2007 MS6 w/ Cheez
The Following 4 Users Say Thank You to m4tic For This Useful Post:
kmac (03-11-2011), mikomi (03-21-2011), SLOWHATCH (08-13-2013), taf0422 (03-11-2011)
 Old 03-11-2011, 06:11 PM   #3
txmedic83's Avatar
I thought that might be it... But then I don't understand why the gap is being published as .051 for all the plugs you buy at any store? Was also told cannot re-gap iridium plugs.
 Old 03-11-2011, 06:23 PM   #4
m4tic's Avatar
yes what you are experiencing is spark blowout (cylinder pressure literally killing spark)
you can gap those carefully with feeler gauges; or get a set of denso itv20 or itv22 that are easier to gap since they are out of the box with a smaller gap.
speedcig likes this.
2007 MS6 w/ Cheez
The Following 3 Users Say Thank You to m4tic For This Useful Post:
kmac (03-11-2011), taf0422 (03-11-2011), txmedic83 (03-11-2011)
 Old 03-11-2011, 06:31 PM   #5
kmac's Avatar
Posts: 1,792   (View Stats)
You can re-gap the plugs, u just have to be careful .
The Following User Says Thank You to kmac For This Useful Post:
 Old 03-11-2011, 07:06 PM   #6
taf0422's Avatar
Posts: 4,688   (View Stats)
Groans: 192
holy shit...that a little more than twice the size of my gap
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 03-11-2011, 07:13 PM   #7
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I have totally hear that before! Pron
2008 MS3 gt
470hp/463tq on GT35r at 29psi
HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned
burn813 is offline   Reply With Quote
The Following User Says Thank You to burn813 For This Useful Post:
 Old 03-21-2011, 08:28 AM   #8
mikomi's Avatar
Posts: 148   (View Stats)
mikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to behold
Don't the ITV20s come in the correct gap already? I got some ITV22s and they were already gapped to what they needed to be (I bought them from Amazon without checking the gap).
FYHN
mikomi is offline   Reply With Quote
 Old 03-21-2011, 10:35 AM   #9
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
My itv22s did come gapped at .028 but you should have checked to make sure.
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
The Following User Says Thank You to DONOTBUGME For This Useful Post:
 Old 08-13-2013, 01:45 PM   #10
jerrodraven's Avatar
Posts: 7   (View Stats)
jerrodraven has a little shameless behaviour in the past
Default multiple cylinder missfire
Just changed my plugs started have the same problem going to regap my plugs and see what it does
jerrodraven is offline   Reply With Quote
p0300 r6yamajim MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 11-04-2010 02:01 AM
P0300 dny MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-07-2010 08:48 PM
P0300, then CEL goes away paulyg MazdaSpeed 3 - Engine, Transmission & Driveline 6 07-20-2009 01:18 PM
P0300, then CEL goes away paulyg MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-07-2009 07:53 AM
random cylinder misfire - p0300 p300 phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 17 09-26-2008 03:50 PM
Page generated in 0.32923 seconds with 27 queries
