Like Tree6Likes
  • 1 Post By Raider
  • 2 Post By Project_dog
  • 1 Post By robbspeed
  • 1 Post By kdxracer
 Old 11-16-2015, 02:20 AM   #1
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Default Running issues
I dont know where to start. i did mine vvt. fucked up my valves. replaced all the bad parts. went and replaced the all the bad parts. upgraded my turbo, made my own dp, went to a grimmspeed 3 port, jbr 3.5 intake, 3 bar Tmap. got rid of the butterflies in the IM and went with a custom FMIC.
I got everything all back together today. I Tried starting it. It would start up. Then die right a way. Finally got it to run and idle at 2000 RPM. idle wouldnt come down. So I throttled up. 3000k. Then the it would surge from 3000 to 2500 rpm. and wouldnt stop. so I shut it off.
I rechecked all my clamps everything is tight.
Project_dog is offline   Reply With Quote
 Old 11-16-2015, 02:36 AM   #2
Oh I'm not done with my dp yet. So I don't have my 2nd O2 sensor in yet.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
 Old 11-16-2015, 03:05 AM   #3
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Probably the tune.
Project_dog likes this.
 Old 11-16-2015, 03:09 AM   #4
Have you messed with versa tuner ?
 Old 11-16-2015, 07:51 AM   #5
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
2nd O2 sensor is not really necessary. it's only there to monitor the first cat.
 Old 11-16-2015, 10:37 AM   #6
I don't have a first cat
 Old 11-17-2015, 01:13 PM   #7
well I went and changed my MAF tables. Still doing the same problem.
 Old 11-17-2015, 05:13 PM   #8
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Spary carb cleaner on all gasket areas and vac lines. Do idle change? If so thats ur leak
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 11-25-2015, 02:53 AM   #9
well with a couple of days off. going to work on the car.
 Old 11-25-2015, 05:18 PM   #10
torquemaniac's Avatar
Posts: 727   (View Stats)
@Project_dog; record a log of the start-up and idle (start the log before you crank the engine)
Record : LTFT, STFT, MAF, load, rpm, ignition timing, MAP, actual lambda, desired lambda, relative throttle position, valve timing
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler // Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
Coming soon : Composite ram-air intake // Hood with heat extraction vent
 Old 11-25-2015, 09:40 PM   #11
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
mr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the world
Can we get @Vansquish to make some grammatical corrections here? Jesus.
Did you check your timing after 'putting it back together'?
Who changed your valves?
Sounds like you have a giant leak at the least.. Pull a log for us.
Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet!
mr.speedy3 is offline   Reply With Quote
The Following User Says Thank You to mr.speedy3 For This Useful Post:
Vansquish (11-27-2015)
 Old 11-26-2015, 01:05 AM   #12
I will tomorrow.
 Old 11-26-2015, 05:03 PM   #13
well I have some logs. I noticed on part of my fmic pipe is hot, and the next pipe after it was not. i disconnected the fmic. Started right up.
 Old 11-26-2015, 05:50 PM   #14
Open it up. Maybe a rag or something stuffed inside.
 Old 11-26-2015, 07:54 PM   #15
Going too. I changed my map settings too.
 Old 11-27-2015, 10:10 PM   #16
Hoping tomorrow I'll get my dp done. 2nd o2 sensor put in.
 Old 12-02-2015, 01:43 PM   #17
I got it all back together. still having a problem and i noticed when the car is idle (2000 rpm) my map is reading 11 psi. normal?
and P2188 code.
Last edited by Project_dog; 12-02-2015 at 01:43 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-05-2015, 08:09 PM   #18
Well still no luck. A little better. I have attached a log file using versa tune.
File Type: zip VersaTuner Logs trying to start and idle.zip (13.6 KB, 5 views)
 Old 12-06-2015, 09:58 PM   #19
worked on her today. I feel like a dumbass. But lesson learned. Well Found my PCV tube was not connected. I went ahead installed a new pcv valve and ran my OCC tubes. cleared codes, started right up. Idle at 1800 rpm then went down to 800 rpm. Took around the block. Ran like a rape ape. happy thats over. Thanks for all the advise and help.
lildisco and robbspeed like this.
The Following User Says Thank You to Project_dog For This Useful Post:
robbspeed (12-07-2015)
 Old 12-07-2015, 06:07 AM   #20
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
Groaned at 7 Times in 6 Posts
Lol congrats man
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 12-07-2015, 07:06 AM   #21
Any noticeable boost lag with the 3'' piping?
 Old 12-07-2015, 10:05 AM   #22
no i dont feel the lag. I drove it around for 10 mins.
 Old 01-15-2016, 05:37 PM   #23
kdxracer's Avatar
Posts: 10   (View Stats)
kdxracer is an unknown quantity at this point
What are you using to pull logs? I just got a cheap code reader device that syncs to 'OBD Car Doctor' (free version) app on my phone. I can see most of the standard info real time but honestly don't really know what some of the readings are supposed to be. I just cleaned the throttle body and intake, replaced pcv valve and hose to intake, and replaced thermostat (180 degree). The coolant temp is running between 200 and 210, which seems high to me. Does anyone know what is standard?
kdxracer is offline   Reply With Quote
 Old 01-15-2016, 05:50 PM   #24
robbspeed's Avatar
Groans: 50
I'm guessing he uses Versatuner since it says Versatuner.
Totaled/ R.I.P.
 Old 01-15-2016, 05:56 PM   #25
kdxracer's Avatar
Never heard of that. Obviously, I don't do a lot of tuning and changing codes...lol
 Old 01-15-2016, 06:24 PM   #26
robbspeed's Avatar
Groans: 50
I don't know of any other options for a cx7. Can I ask what made you clean your throttle body? And how/why did u clean your intake?
As far as your coolant temp goes, is it 200° - 210° while cruising?
I just wanna add this isn't your or my thread so if you're having a problem you should create a new thread. I don't wanna be an accessory to thread jacking.
Totaled/ R.I.P.
 Old 01-15-2016, 06:53 PM   #27
kdxracer's Avatar
I was getting codes indicating not warming up to operating temp so suspected the thermostat. As for the throttle body and intake, it would barely idle and it would die shifting from reverse to drive and sometimes when stopping at the top of a small incline. The tb was terribly dirty as well as the inside of the intake. It was caked with oily carbon type deposits severely restricting airflow from vacuums. I had to take the intake off anyways to get to the hose between the pvc and intake as it had a 2" gash in it. While it was off I cleaned the blades on the block side. I pulled the cover the pcv goes into and cleaned similar debris out replacing the pcv when putting it back together.
It idles beautifully now!
Yes, it is running 200 - 210 while cruising.
 Old 01-15-2016, 07:08 PM   #28
kdxracer's Avatar
Here is a pic of the throttle body...and intake
 Old 01-15-2016, 07:10 PM   #29
robbspeed's Avatar
Groans: 50
Good shit. Maybe there's some air trapped in there from when you replaced your thermostat. How's your coolant level? Is there any shit or debris obstructing the radiators air flow? What type of coolant and what concentration did you use?
Gross
Totaled/ R.I.P.
Last edited by robbspeed; 01-15-2016 at 07:11 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-15-2016, 07:15 PM   #30
kdxracer's Avatar
hose...
 Old 01-15-2016, 07:25 PM   #31
kdxracer's Avatar
There is good air flow through radiator. I think there may still be an air bubble in the system. I tried a burping procedure but it didn't seem to drop yet. Level is good and I will keep an eye on it because if it does burp the air out it'll suck it in from the reservoir. I used the Asian formula coolant 50/50 diluted.
Clean parts!
 Old 01-15-2016, 07:42 PM   #32
robbspeed's Avatar
Groans: 50
How long has it been since you replaced it? You can try squeezing the radiator hose while its running when your burping it.
If all else fails it's possible but unlikely you got a bad new thermostat.
Totaled/ R.I.P.
 Old 01-15-2016, 07:45 PM   #33
kdxracer's Avatar
Yeah, I know that can happen. I'll watch it real close for a while before going and replacing it again, or trade it off...lol I'll have to let my wife drive the Mustang, she won't mind...lol
robbspeed likes this.
Running mixed series tires - alignment issues? Flitzr951 Mazdaspeed3/6 General Discussion 4 07-02-2015 08:25 AM
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 12:50 PM
AMR CO's..anyone running them shifter48 Auto-X / Road Racing / Time Attack 9 12-06-2012 10:24 AM
Who's running an occ? pwned 2010 MS3 - Engine, Transmission & Driveline 62 11-27-2012 05:01 PM
MS3's running VTA IshiKage MazdaSpeed 3/6 - Turbo Induction 32 01-23-2009 02:28 PM
Page generated in 0.49267 seconds with 28 queries
