 Old 12-24-2010, 09:01 AM   #1
ottoblotto's Avatar
Posts: 266   (View Stats)
ottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond repute
Default strange trans shifting pattern
for the past few weeks, post mods, i have noticed that the transmissions shifts in an odd way. it goes normal through the first four gears and then when it goes into fifth, it bogs then sounds like it goes back into fourth, revs high for a sec and once it speeds up, sounds like it drops back into fifth the entire time showing 5 on the display. i may have to vid it so you get a better idea, but it is annoying as hell. doesnt do it when im in manual, but i normally drive auto in the morning on the way to work so i can enjoy my coffee and such. is it possible the ecu and tcm are tied together and for some reason after mods and ecu reset something got jacked up??? how are they tied together if they are? any input would be great...
EDIT:
i have attached some vids so you see the pattern. one you can hear it well. this is just getting agitating and im finding myself driving in manual more and more often. is this what the tcm flash is for? i swear i got that resolved in Georgia, but the dealer couldve been blowing smoke...
2011.75 BMW E90 M3
El-Superbeast-O
ottoblotto is offline   Reply With Quote
 Old 12-28-2010, 06:42 AM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
There is a tsb for that, tcm reflash needed. Sucks, as you are going to run into issues getting it done there. Also, check levels. Flush every 40k miles, too.
 Old 12-28-2010, 07:08 AM   #3
ottoblotto's Avatar
ya im only at 27k-ish. but i had that done back in savannah prior to moving overseas. im thinking its tied into the ecu and i may have to disconnect and do a reset again... maybe i forgot to do the pedal push last time... ill try that tonight.
2011.75 BMW E90 M3
El-Superbeast-O
 Old 02-18-2011, 10:08 AM   #4
ottoblotto's Avatar
added videos.
2011.75 BMW E90 M3
El-Superbeast-O
 Old 02-18-2011, 08:27 PM   #5
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
car is probably scared from all the death metal
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
 Old 02-18-2011, 10:08 PM   #6
ottoblotto's Avatar
WHAT?!? fuck no, just makes her go faster...
2011.75 BMW E90 M3
El-Superbeast-O
E4 Shift Knob with no pattern now shipping E4Performance Mazdaspeed3/6 General Discussion 3 02-17-2010 09:07 AM
Ford needs 'pattern' contract with UAW, Mulally says Haltech Automotive News 0 10-31-2009 08:20 AM
Ford needs 'pattern' contract with UAW, Mulally says Haltech Automotive News 0 10-30-2009 03:20 PM
shifting problems.. loose trans mount on an 08? 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 41 04-08-2009 08:11 PM
downpipe bolt pattern MTuning MazdaSpeed 3/6 - Turbo Induction 2 08-16-2008 10:58 PM
Page generated in 0.45705 seconds with 22 queries
