 Old 04-23-2016, 01:20 PM   #1
rycher's Avatar
Posts: 4   (View Stats)
rycher is an unknown quantity at this point
Default White Smoke Issue
I have a 2010 cx-7 grand touring AWD that is blowing thick white smoke. I've done a lot of reading on this issue (especially mazdaspeedforum, thank you btw) and im curious what route to go to fix this issue..
I have purchased the https://damondmotorsports.com/produc...tor-banjo-bolt
bolt and installed it but still getting white smoke. man i was really hoping that fixed my issue. cheap and easy, but its still smoking after install.
So im curious what my next steps should be.! I did receive a p0139 error just prior to smoke. i read that could be caused by bad turbo seals allowing oil to run down and gunk up sensor.. is this true?
I've read i can do a list of the following before replacing the turbo..
replace pcv
change oil to 5-w40
do a seafoam treatment ( what is this and why would it fix a white smoke problem)
Id rather try everything possible before i replace the turbo.
Anyone have any advice on which route i should take.
rycher is offline   Reply With Quote
 Old 04-24-2016, 07:17 AM   #2
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
I doubt seafoam will help. Has your coolant level dropped at all?
Sent from my SM-N920P using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
Last edited by tmillner; 04-24-2016 at 07:17 AM. Reason: MSF Database - Automerged Doublepost
tmillner is offline   Reply With Quote
 Old 04-24-2016, 10:24 AM   #3
08speed's Avatar
Posts: 147   (View Stats)
08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of
White smoke is generally means coolant is being burned, not oil.
08speed is offline   Reply With Quote
The Following User Says Thank You to 08speed For This Useful Post:
Vansquish (04-24-2016)
 Old 04-24-2016, 02:59 PM   #4
rycher's Avatar
thanx for the replies..
the smoke looks just like the video's i've seen of a blown turbo.. like this one.. https://www.youtube.com/watch?v=c-CkSlZo31M
doesnt really smell like oil.
my water level has not changed.. it is right at the top of the radiator cap.
did compression tests on all 4 cylinders. all were around 120.
Im also going to ask this question here rather then start another thread.
I have the 2010 AWD verions of the cx7. When i replace the turbo do i have to drop/remove the transaxle??????
i've seen both answers, yes and no, but want to know from someone whose done the work before or knows for sure ..
Last edited by rycher; 04-24-2016 at 02:59 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-24-2016, 05:59 PM   #5
impossible's Avatar
Posts: 732   (View Stats)
Groans: 30
Pull off intake, check turbo for shaft play, maybe drain fluids as well. Turbo might be toast
2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning
white smoke after e85 mix bshotts422 2010 MS3 - Troubleshoot/Diagnostics 123 04-20-2014 08:44 PM
white smoke Dslatch4 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 11-12-2013 10:06 AM
White smoke aldekei 2010 MS3 - Troubleshoot/Diagnostics 7 07-22-2013 12:26 PM
White Smoke Soriku1489 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 07-08-2010 05:25 PM
White smoke? PLEASE HELP Fallenvoices MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 01-06-2010 03:39 PM
Page generated in 0.43021 seconds with 23 queries
