Go Back   Mazdaspeed Forums > Mazdaspeed Forums Sponsors > EdgeAutosport.com
EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help!
Like Tree2Likes
  • 1 Post By EdgeAutosport.com
 Old 07-09-2014, 03:00 PM   #1
EdgeAutosport.com's Avatar
Posts: 6,206   (View Stats)
Default Precision Turbo's at EdgeAutosport!
You guys have seen the Precision Turbo kits, but thats not all we carry. If it is made by precision, we can get it for you.
Precision Turbo At EdgeAutosport
So let us know if you need anything precision and we'll be happy to get you taken care of!
LumberJack likes this.
The Following 5 Users Say Thank You to EdgeAutosport.com For This Useful Post:
cshunter (07-09-2014), ItsNox (07-10-2014), kbz0129 (07-11-2014), SpeedRebirth (07-09-2014), speedtoz (07-10-2014)
 Old 07-11-2014, 10:20 AM   #2
kbz0129's Avatar
Posts: 986   (View Stats)
kbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the worldkbz0129 is the leader of the world
I just got an email from David at Kozmic motorsports. He says they are just weeks away from releasing the Mazdaspeed 6 V-band down pipe and dump tube! I was just wondering if you guys will throw a Precision turbo kit together like you did for the Speed3's? If so I will definitely be a buyer!
2010 Ms3 PD Tuned
GTX3076 EWG Forged Engine Built By Yours Truly
2006 Ms6 GT-Stock
kbz0129 is offline   Reply With Quote
The Following 3 Users Say Thank You to kbz0129 For This Useful Post:
Code Monkey (07-11-2014), EdgeAutosport.com (07-15-2014), Hargarbl (07-15-2014)
 Old 07-11-2014, 10:25 AM   #3
Code Monkey's Avatar
Posts: 7,623   (View Stats)
Two weeks?
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
MCS coilovers|Brembo BBK|6UL 17x9|Nitto NT01
2000 E39 M5
2001 MR2 2ZZ
 Old 07-11-2014, 10:28 AM   #4
kbz0129's Avatar
Not exactly two weeks. This is what the email says "the downpipes are a few weeks out from the design being completed before a run is produced for sale."
Had to edit my first post, for some reason I had 2 weeks in my head. My bad.
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
Last edited by kbz0129; 07-11-2014 at 10:28 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-11-2014, 10:39 AM   #5
@EdgeAutosport.com; are PTE ball bearing turbos watercooled?
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
 Old 07-11-2014, 11:09 AM   #6
shadesofgray19's Avatar
Posts: 794   (View Stats)
From PTE website
Available with either a Hydrodynamic 360° thrust bearing system, or an Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
2006 Black Mica MS6 - Sold 10/15
shadesofgray19 is offline   Reply With Quote
The Following 3 Users Say Thank You to shadesofgray19 For This Useful Post:
Code Monkey (07-11-2014), EdgeAutosport.com (07-15-2014), kbz0129 (07-11-2014)
 Old 07-11-2014, 11:14 AM   #7
Originally Posted by shadesofgray19 View Post
From PTE website
So I assume the hydrodynamic one is watercooled? If so, is Edge offering this one for sale?
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
 Old 07-11-2014, 11:30 AM   #8
No, that is the journal bearing. Copied from another site - The journal bearing system is the most common type of turbo bearing system because it is cheap and it works. The journal bearing system typically consists of two types of plain bearings: cylindrical bearings to contain radial loads and a flat thrust bearing to manage thrust loads. Plain bearings in turbos use oil to keep parts from rubbing each other based on the hydrodynamic principle. In hydrodynamic lubrication, the fluid (oil in a turbo) stays between the moving surfaces and prevents metal-to-metal contact.
To my knowledge PTE turbo's are not water cooled. I'm sure someone will correct me if I am wrong on this.
The Following 4 Users Say Thank You to shadesofgray19 For This Useful Post:
Code Monkey (07-11-2014), Darth_Nuruodo (07-11-2014), EdgeAutosport.com (07-15-2014), kbz0129 (07-11-2014)
 Old 07-11-2014, 12:23 PM   #9
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
No, I think you got it right. Every water cooled PTE I've seen has been a conversion kit.
Bone stock so far
 Old 07-15-2014, 09:02 AM   #10
There will definitely be an MS6 Kit put together as soon as Kozmic releases the parts necessary to complete it.
No, PTE turbos are oil cooled only.
kbz0129 likes this.
The Following 3 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Code Monkey (07-15-2014), kbz0129 (07-19-2014), Micha (07-24-2014)
 Old 07-19-2014, 05:31 AM   #11
kbz0129's Avatar
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
 Old 07-20-2014, 09:27 PM   #12
blackstar's Avatar
Posts: 520   (View Stats)
blackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the world
Very excited to hear this.
blackstar is offline   Reply With Quote
 Old 07-20-2014, 09:35 PM   #13
LumberJack's Avatar
LumberJack has disabled reputation
Groans: 57
Groaned at 21 Times in 13 Posts
You would be correct. The difference between them is just the size of oil feed line used. Ball bearing use a -3 feed line and the chra already has the built in restricter where as the journal beating use an unrestricted -4 feed line.
2018.... Doing even more freeky things!
10.36@148 Fastest Gen 2
LumberJack is offline   Reply With Quote
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
EdgeAutosport.com (07-21-2014), PUGENE (07-21-2014), shadesofgray19 (07-21-2014)
Precision Turbo Kits at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 601 07-03-2015 09:53 AM
Kozmic Motorsports Precision V-band Downpipe at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 22 02-17-2014 04:36 PM
Anyone running a precision turbo on MS3 origjdm3 MazdaSpeed 3/6 - Big Turbo Builds 37 07-08-2010 04:04 PM
Page generated in 0.35915 seconds with 26 queries
