| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #41 | ![]() |
| NATOR Photog ![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 1831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,645
Groaned at 61 Times in 26 Posts
| Not Ranked : 0 score I was excited for a moment.
__________________ ![]() Anthony D. Christiano 2008 CosmicBlue Mazdaspeed3 - 294whp/335wtq on stock K04, new BNR Stage 3 numbers coming soon... BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, 3-bar map and connector, PTP injector seals and studs, Kritz 3-port boost solenoid, Sure Return, CP-E FMIC, TWM STS, AutoTech Fuel Pump Internals, James Barone 88-Duro RMM, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 ET48, Cobb Rear Sway Bar, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back. BF Goodrich g-Force Sport 235/40/18's, MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #42 | ![]() |
Rep Power: 8460 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,997
Groans: 31
| Not Ranked : 0 score With just 93 and stock compression ratio, you will be knock limited at about 330hp
__________________ 2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS Perm Tune by the Freek ![]() 417hp/395tq 12.903@117.33 Street tires and shitty 2.25 60ft |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2012 Location: pimpn' all over the world
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
So this might be a silly question, but I am really impressed with the S3 and want to adjust my parts list accordingly. Which the more necessary evil if installing an S3? Aftermarket manifold, or Meth? Again, I am pretty sure someone on planet earth has already answered this question, but right now all of these dyno graphs just have me so excited my logic is out of the windown
__________________ 2012 MS3 Black w/tech package. |
![]() | | #44 | ![]() |
Groans: 31
__________________ 2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS Perm Tune by the Freek ![]() 417hp/395tq 12.903@117.33 Street tires and shitty 2.25 60ft | |
| The Following User Says Thank You to atvfreek For This Useful Post: | dr_banano (08-11-2012) |
![]() | | #45 | ![]() |
![]() Join Date: Jan 2012 Location: COLUMBIA MISSOURI
Rep Power: 22 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score This is simply kickass check that out the torque up top it just doesn't go away. This is one of the nice things about race fuel it vaporizes much faster which in a direct injected engine i would think it would be even more noticable at the top of the rev range. That and yeah ignition timing can be ramped up nicely. I really like the turnout guys keep it up!!!
| The Following User Says Thank You to Matt H. For This Useful Post: | atvfreek (08-11-2012) |
![]() | | #46 | ![]() |
Alright so meth over manifold, and since this turbo is more efficient than the K04, is a FMIC simply overkill?
![]() | | #47 | ![]() |
![]() Join Date: Jul 2010 Location: Clarksville, Md
Rep Power: 676 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,173
| Not Ranked : 0 score A fmic Is not overkill at all, but an aftermarket tmic would certainly suffice with meth. That's what atvfreek is running. Tmic + meth =win.
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake |
![]() | | #48 | ![]() |
Yeah I mean you can and always want to obtain cooler air with running a turdblow, but from a price standpoint it seems that the TMIC would be the better choice over the FMIC. I have been looking at freeks mods list and I like his setup a lot. I just want to achieve the enough power to rocket a pu into the 11's, but have fun with it day to day. I think the S3 would make that happen
![]() | | #49 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8351 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,236
If you're stuck with regular fuel - especially 91, an FMIC is worth it. It just doesn't get heatsoaked like the TMIC does when moving slowly and resists heatsoak during extended pulls much better. I know the gen2 guys are more limited in terms of FMIC choices however. After having stock, TMIC, FMIC, I would have saved for a used FMIC instead of going through the aftermarket TMIC.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | lilred (08-12-2012), THE REAPER (08-12-2012) |
![]() | | #50 | ![]() |
Good input lex. I never really knew much about TMIC until this platform. I have only had FMIC experience. I am building a parts/price list as I speak, of course none of the prices take into account me going VIP and getting second hand parts for the cheap. I was impressed with the CS TMIC because you can put the MS3 cover back on so it looks stock. All about being sneeky lol
![]() | | #51 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 158 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
Groaned at 22 Times in 8 Posts
latest VD...
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- Nitto NT05 tires on stocker wheel - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- ptp studs/seals - JBR TB/IM Thermal ins - EGR block - pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car Last edited by dr_banano; 08-30-2012 at 09:36 AM. |
| The Following 4 Users Say Thank You to dr_banano For This Useful Post: |
![]() | | #52 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 575 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
Groaned at 53 Times in 26 Posts
god damn! We are talking about BT power ^ This is on race fuel, right?
__________________ *COBB: AP, shifter weight *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, 88TMM, EGR delete, WP *Grimmspeed: EBCS *TWM: Full Shifter *Tomei: Shift knob *KDM: HPFP internals *Ford: syn trans fluid *UR: TP, CBE *Bremmer Kraft:18x8 et45 BR05 (5mm rear spacers) *Dunlop: 245/40/18 Sport Maxx TT * Bilstein: B8 Sport *SWIFT: Spec-R springs *gtspec: 4point ladder brace, rear subframe brace * AC DELCO : Adj. camber arms *Denso:ITV22 *Stoptech: Performance pads *MORIMOTO: 5K HID elite *OEM: Gutted primary cat |
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | atvfreek (08-16-2012) |
![]() | | #53 | ![]() |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,386
| Not Ranked : 0 score Looking fantastic. Got the log you used for that. I am always curious to see the logs. Also, ambient temps? Nice power and very nice curves though.
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
![]() | | #54 | ![]() |
![]() | | #55 | ![]() |
| Used parts FTW ![]() Join Date: Jul 2012 Location: Caldwell, NJ
Rep Power: 661 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,421
Groaned at 8 Times in 7 Posts
Maybe a silly question, but is an E85 tune more limiting than the race gas tune used here? I ask because I plan on going BNR S3 w/ E85, and this power curve looks fantastic.
__________________ ----------2012 Red MS3---------- GTX3071r FreekPerm:in Progress |
![]() | | #56 | ![]() |
Rep Power: 4090 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,497
It is more limiting because you will run out of fuel faster but Oxygenated 110 unleaded fuel is very very expensive however. Zigatapatalka
| The Following User Says Thank You to Ziggo For This Useful Post: | atvfreek (09-05-2012) |
![]() | | #57 | ![]() |
Groans: 31
![]() | | #58 | ![]() |
![]() Join Date: Feb 2012 Location: Los Angeles, CA
Rep Power: 766 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 898
Groans: 34
| Not Ranked : 0 score Are you talking about the point where the coupler on the tip connects to? It is slightly wider than a regular K04. I believe I measured the diameter to be 2.310"
__________________ "Stockish" Black Mica 2010 MS3 Genpu
![]() | | #59 | ![]() |
![]() Join Date: Feb 2011 Location: Germany
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
its definately wider. The stock tip doesnt fit. But most of us who go BNR S3 already have TIP with silicone coupler. My Corksport fits, its tight but it fits! Also you get less space to the battery tray because the BNR S3 is pushing the TIP more out. I had to push my tip into the coupler till it touches the compressor housing and even yet its not perfect :-(
| The Following User Says Thank You to MPS_Fan For This Useful Post: | atvfreek (09-06-2012) |
![]() | | #60 | ![]() |
Groans: 34
![]() | | #61 | ![]() |
Done the same to my battery box. I'm not very happy with the TIP fitting. It looks like i have to make it shorter on the turbo side. Maybe i will get a HTP battery tray to get more room
![]() | | #62 | ![]() |
no problem with my cobb tip, fits same as stock....
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- Nitto NT05 tires on stocker wheel - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- ptp studs/seals - JBR TB/IM Thermal ins - EGR block - pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car |
![]() | | #63 | ![]() |
CS TIP gets pushed out in direction of the battery box. It rubs like a mofo!! But slotting out the battery box holes helped a lot.
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 06:20 AM |
| -cj-'s BT Build | -cj- | MazdaSpeed 3/6 - Big Turbo Builds | 30 | 07-24-2011 09:38 PM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 09:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 05:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 04:20 PM |
