> 2010 MS3 - Big Turbo Builds
Like Tree5Likes
 Old 11-13-2014, 10:39 AM   #41
JSmith's Avatar
Posts: 701   (View Stats)
Groans: 104
Groaned at 6 Times in 6 Posts
Hope none of those DP studs are seized. Dont forget to properly bleed the coolant system afterwards either.
 Old 11-13-2014, 11:17 AM   #42
tbutts333's Avatar
Posts: 9   (View Stats)
tbutts333 is an unknown quantity at this point
All the studs looked okay, and thanks for the advice ill look more into that also.
tbutts333 is offline   Reply With Quote
 Old 11-13-2014, 11:29 AM   #43
BlackFlag's Avatar
Posts: 596   (View Stats)
BlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the worldBlackFlag is the leader of the world
Great writeup!
This will definitely come in handy.
Slow for now...
Cobb ApV3///Cobb SRI+TIP///JBR Solid Shift Bushings///JBR 88 RMM///JBR SSP///
JBR Shift Knob///Cobb EBCM///MSR 045 18x8 +35///Nitto Nt05 235/40/18///CS Batt Box///CS Catted DP///ITV22's///Autotech Internals///TR8 FMIC///Koni FSD's/// CS springs
Freek Tuning Meow
BlackFlag is offline   Reply With Quote
 Old 11-13-2014, 08:02 PM   #44
sheston's Avatar
Posts: 1,847   (View Stats)
How much fueling headroom do you have? Just wondering why you stopped at 21psi?
 Old 11-13-2014, 08:10 PM   #45
econman's Avatar
Posts: 355   (View Stats)
econman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the worldeconman is the leader of the world
90-95% IDC at around 350whp w/ 21PSI. I had a bit left but didn't want to push it
econman is offline   Reply With Quote
 Old 11-15-2014, 02:32 PM   #46
tbutts333's Avatar
Default Turbo help
okay so I got the turbo in just wanna know if there are and torque specs for the manifold bolts?
 Old 11-15-2014, 03:38 PM   #47
Code Monkey's Avatar
Posts: 7,671   (View Stats)
I think it was about 55 ft/lbs. Not that it matters much as you will not be able to access most of the nuts with a torque wrench, just make sure the nuts are tight but not monkey tight.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 11-15-2014, 03:46 PM   #48
tbutts333's Avatar
Awesome thanks. And one more thing how do you drain the colent? I'm not seeing a line and the cel light came on. The car at idle blows out cold air. But when it's being driven the car blows hot air I think that has to do with the coolent. Thanks
 Old 11-15-2014, 03:52 PM   #49
ShadowHunter117's Avatar
Posts: 55   (View Stats)
ShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to behold
It sounds like the intake and exhaust manifold changes on my setup do make a difference then. I have a very similar set up to yours with the same turbo and intake, but I have a stock intake mani that is PnP and has VTC delete, as well as a Steedspeed exhaust mani. It has been a while since I have looked at some logs, but I am pushing 23.5-24 PSI and don't think I was reaching 90+ WGDC yet. The intake mani mods aren't to expensive to get done, but a different exhaust mani costs a bit.
Great write up on the install btw. I had some members of our local MazdaSpeed group who had already done some turbo upgrades to help out with mine.
2011 Black Mica MS3
Engine: HTP 3.5" Intake, HTP Small Battery Box, GTX2867R Turbo, TR6 Intercooler w/CX Racing Pipe, PNP Stock Intake Mani w/ VTC Delete, Steadspeed Exhaust Mani, CNT Catted DP, 3" Magnaflow Exhaust, Autotech HPFP Internals, JBR OCC, JBR EGR Delete, 3-bar MAP Sensor, Grimmspeed EBCS, Forge BPV V2, Stratified Tuned
Handling: CS Lowering Springs, JBR Rear Swaybar, JBR PMM/TMM(70 duro) RMM(88 duro), GTSPEC Chassis Braces(Except trunk), Front Strut Tower Bar, 17x9 TRMotorsports C3 Wheels w/ 245/40ZR17 Michelin Pilot Sport A/S 3
Waiting to Install: Stratified Guardian Angel, Snow Performance Stage 2 Meth Kit w/Failsafe and Trunk Mount Tank
ShadowHunter117 is offline   Reply With Quote
 Old 11-15-2014, 03:54 PM   #50
No need to drain the coolant, just make sure to replace the coolant you lost when you were installing the turbo, and make sure to burp the system so you do not have any air bubbles trapped in there.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 09-23-2018, 04:30 PM   #51
Tomumass06's Avatar
Posts: 18   (View Stats)
Tomumass06 has a little shameless behaviour in the past
Thanks for the post. I have been working on this the past weekend and it has been a bitch so far. My car is a stock 2011with 120k on it now. The heat shields most likely will not be usable again. My last engine build made 7300 shp just sayin.
Tomumass06 is offline   Reply With Quote
 Old 11-08-2018, 06:39 PM   #52
Zozr's Avatar
Posts: 5   (View Stats)
Zozr will become famous soon enoughZozr will become famous soon enough
Thanks, great pictures
Last edited by Zozr; 11-10-2018 at 10:06 AM. Reason: Pictures started showing for me again....weird
Zozr is offline   Reply With Quote
alexryan's GTX2867r Build alexryan 2010 MS3 - Big Turbo Builds 95 11-07-2014 05:14 PM
Page generated in 0.31382 seconds with 29 queries
