> 2010 MS3 - Big Turbo Builds
Like Tree8Likes
 Old 08-29-2017, 01:09 PM   #81
andale927's Avatar
Posts: 157   (View Stats)
andale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud ofandale927 has much to be proud of
Originally Posted by flyhigh View Post
What kind of pads are you using? I know "Track-use only" pads can run through rotors fairly quickly, but daaaaamn! My OEM rotors lasted 40k miles and I hope the Centrics will do better. I'm running the red stuffs because DD. I'm definitely going to me monitoring more closely now with that piece of info.
Yeah, I'm beginning to think it might be hub/bearing related because it seems crazy how quickly they warp. I run EBC yellows which are a little more aggressive but not quite track only or anything. I'll shut up now, don't want to derail your thread.
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
 Old 08-29-2017, 01:20 PM   #82
flyhigh's Avatar
Posts: 218   (View Stats)
flyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond repute
Originally Posted by mituc View Post
Next step: add meth.
That was the plan, but my CM system needs work. I'll be doing E-30 first, then adding the meth once its wired properly.
12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery
Rice--CorkSport interior lights and carbon fiber hood scoop
ETH/METH tune by Stratified in progress
flyhigh is offline   Reply With Quote
 Old 08-30-2017, 10:03 AM   #83
Jeff23spl's Avatar
Posts: 1,696   (View Stats)
I run HP+ race pads, (noisy, dusty but agressive) And it seem my rotor wear out quicker than the pad itself....Not warped at all after few years of abuse on the street. Sometimes i even hold the brakes to make a longer log in third gear until it smell lol.
Only bad side, watch your rear end in traffic, i got bumped yesterday but my hitch protected the car
All that to say, you probably have something wrong to warp yours.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
andale927 (08-30-2017)
 Old 09-18-2017, 06:37 PM   #84
flyhigh's Avatar
So the 93 octane tune is now complete. WMI is still inop, so it's on to Ethanol for now. I'm going with a E-30 per Stratified's recommendations. I couldn't get any grip on the wet roads today and can't wait to get it out on a dry road tomorrow.
 Old 09-19-2017, 06:23 AM   #85
Jeff23spl's Avatar
Btw how much is your fuel at this time? Was the price affected by Harvey/Irma?
Wife drive 2010 CX7
 Old 09-19-2017, 07:15 AM   #86
flyhigh's Avatar
IRMA-GERD YES. E was $1.99 pre-Harvey and now after Irma it's $2.59. 93 was $2.3x and now $3.2x
 Old 09-19-2017, 10:15 AM   #87
Jeff23spl's Avatar
Ok thanks, About the same increase up here.
1.0x/liter to 1.3-1.4/liter for 87 and now settle down to 1.2/l...
Sorry to be offtopic but as you pictured a gaz pump i was curious!...
Wife drive 2010 CX7
 Old 09-19-2017, 10:48 AM   #88
flyhigh's Avatar
Here's a log of a 4th gear WOT run on just the base map for E-30.
 Old 09-19-2017, 11:29 AM   #89
Jeff23spl's Avatar
Is it fine to have injector duty above 100% ?
Wife drive 2010 CX7
 Old 09-19-2017, 12:06 PM   #90
mituc's Avatar
Posts: 3,507   (View Stats)
Groans: 111
Yeah, as long as it's not too much above 100%, like 108-110%. Above 100% it means that they injectors are spraying during the power cycle as well after staying on during the intake and compression stroke.
By looking at the logs I see how much more efficient WMI is. However, pairing an E mix with an additional port injector (or 2) will result in a lot of awesome stuff.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 2 Users Say Thank You to mituc For This Useful Post:
flyhigh (09-19-2017), Jeff23spl (09-20-2017)
 Old 09-16-2018, 11:14 AM   #91
flyhigh's Avatar
At 400 crank HP even with meth injection the ringlands of the factory pistons are on borrowed time. You can run the factory engine until you crack ringlands and rebuild from there, but don't aim for 400hp and hope for the best simply because these pistons cannot handle the heat of 400cp for too long. of course it also depends on how often you ask for those 400hp and for how long.
It seems this may have happened...
93, E30, 93 w/WMI tunes are done. Working on E48 w/ WMI currently.
After a few WOTs to complete the 93 WMI tune there was oil comming from the vent of the OCC. Oil level looked low, so I added some to get it back in the correct range. After this, the exhaust started smoking, not terribly, but smoking. When the A/C cycled on, the smoke was bad. I took it in to the mechanic and could not duplicate the issue. He did a test on the coolant and said everything looked as it should, no bubbles, no carbon. Coolant temps even at idle for 20 minutes in 88* never got over 206*
Everything seemed fine for a couple weeks. I moved on to the E48 WMI tune and after a couple WOTs the oil was back under the OCC the next morning. Took the car to work carefully and let it run in the parking lot for a bit. There was a little bit of smoke at idle (blue). When the A/C kicked on it blew a ton of smoke. A/C off and smoke all but stopped. Took it back to the mechanic who now thinks it's either valve seals, piston rings, or the turbo. There is a lot of pressure in the crankcase as evidenced by the oil blowing out of the OCC and an oily VVT plug thingy.
I should note that I did not pay for the mechanic to look at the car. I just caught him before work to demonstrate the smoking and ask some questions. He's cool like that.
Besides the smoking, the car runs great. No noticeable power loss at all, but v-dyno shows me making more power on the E30 tune than I'm making now on E48 and WMI (that tune was back in March, so it was much cooler temps). The tuner looked back through my logs and found nothing wrong. I've asked around and not even the Mazda mechanic has seen pluming exhaust smoke caused by A/C.
I'll be doing a compression test and attempting a leak down test tomorrow.
 Old 09-16-2018, 08:56 PM   #92
mituc's Avatar
Groans: 111
I'm sorry to hear what you're going through, but at this point based on the symptoms hopefully it's just the turbo which started spewing oil because it gets it in excess and can't handle it any more. We'll see...
 Old 09-17-2018, 12:30 AM   #93
Solarsurge's Avatar
Posts: 570   (View Stats)
I was pluming smoke out the back, too. Three different mechanics told me I blew a head gasket. It turned out to be a clogged OCC hose. I pulled it off, blew into it, shot out a bunch of garbage, and it was fine after that. I went dual OCC after that due to the crank case pressure issues I was seeing and the hose I was using (Corksport silicone hose) was utter shit and just flexed too much. I will only ever use reinforced rubber hose after that. Good luck on your issues.
 Old 09-17-2018, 08:15 AM   #94
torquemaniac's Avatar
Posts: 727   (View Stats)
From my experience, that look like ringland failure...a compression test will validate this
I had to rebuild my engine 2 times because of ringland failure of the OEM pistons...I was running 32-33psi of boost with 1060cc/min of meth and 17 degree timing at redline (with Eagles rods of course)
Even with no crazy KR, the OEM pistons dont live long with this kind of power
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler // Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
Coming soon : Composite ram-air intake // Hood with heat extraction vent
 Old 09-17-2018, 01:21 PM   #95
flyhigh's Avatar
https://photos.app.goo.gl/2oerkpUpbWq9XJdq6
Compresion #'s
145
148
150
149
Leak down gauge seems busted, but all cylinders leak in to other cylinders. no leaks at exhaust or dip stick.
Pulling the TIP now to inspect the turbo.
 Old 09-17-2018, 02:12 PM   #96
flyhigh's Avatar
turbo looks okay, right?? Way more oil everywhere else...
https://photos.app.goo.gl/mJTrq2GQEMXAUi9x8
 Old 09-17-2018, 02:17 PM   #97
Solarsurge's Avatar
Compresion #'s
145
148
150
149
Um... cylinders leaking into other cylinders would be a head gasket failure.
 Old 09-17-2018, 11:38 PM   #98
mituc's Avatar
Groans: 111
A major one actually.
How's the coolant? Does it have any traces of oil or soot/exhaust stuff in it?
 Old 09-18-2018, 08:37 AM   #99
Jeff23spl's Avatar
can it have valves opens or leaking in more than 1 cylinders at time of test and air return by manifolds ? Leaking gasket isn't common for these engines.
Wife drive 2010 CX7
 Old 09-18-2018, 08:50 AM   #100
Solarsurge's Avatar
^This. Are you sure you tested at TDC for all the cylinders? Easy way to tell is to pull the spark plugs and put the longest screwdriver you have into the spark plug hole and rotate the engine by hand with a 21mm socket until it rises all the way up and stops. Cyls 1 and 4 should be at TDC when the hole in the crank pulley is directly below the pulley bolt and aligns with the bolt hole in the timing cover, Cyls 2 and 3 should be at TDC when the bolt hole is directly above the pulley bolt at 180 degrees from the other spot.
 Old 09-18-2018, 12:39 PM   #101
flyhigh's Avatar
Thanks guys.
Coolant looks good, no carbon or bubbles in the tank.
I did my best to make sure each cylinder was TDC for the leak down. Even cycled through twice to ensure it was on the compression stroke (same results for each test on each cylinder)
Tuner and some others think the smoke could be a PCV issue, so just ordered one from DM. Oil on the plug is likely from a leaky valve seal. OCC being fully vented could also be a problem. One step at a time, as I was kindly reminded.
The Following User Says Thank You to flyhigh For This Useful Post:
JSmith (09-18-2018)
 Old 10-01-2018, 03:17 PM   #102
flyhigh's Avatar
I thought maybe, just maybe, my car doesn't like E48 so I ran it out and put in straight 93 and re-flashed the tune. Took it to work yesterday (15 miles stop and go) no A/C. No problem, not much smoke, still stank though. Drove fine, stayed off the boost.
Today, still on 93 tune, took it out again. Same distance. No A/C, no problems.
Coming back home I ran the A/C the whole way. Left it running when I pulled in the garage and stepped out to witness the driveway full of smoke.
Turned off A/C and smoke all but stopped. Sat back in the car and gave her 3k RPM for a minute with A/C off and nothing but fresh exhaust to blow the residual smoke away. Turned the A/C back on and smoke poured out the exhaust again.
 Old 10-02-2018, 12:23 AM   #103
mituc's Avatar
Groans: 111
How's your PCV?
flyhigh (10-08-2018)
 Old 10-03-2018, 03:00 PM   #104
Jeff23spl's Avatar
i don't get the link between A/C and smoke.....especially if you raise rpm by yourself and it is ok...
Do you have some kind of hand made turbo cooler with the A/C system that leaks lol.
Do you see anything special with the radiator fan turned on cycling the a/c ? air pushed into the occ or anything weird about it ?
Wife drive 2010 CX7
 Old 10-03-2018, 06:33 PM   #105
andale927's Avatar
When you turn on AC intake manifold vacuum drops, which can mean increased crankcase pressure. Not sure if this is the case here, though. A really simple way to check would be to hook up a pressure gauge to the crankcase haha...
Sent from my Pixel XL using Tapatalk
Power:
Handling:
Other:
The Following User Says Thank You to andale927 For This Useful Post:
 Old 10-03-2018, 07:32 PM   #106
Solarsurge's Avatar
How's your PCV?
^This. Sounds like PCV/OCC routing issue. The A/C raises idle speed with throttle plate closed, which increases both the pressure in the block and vacuum in the intake manifold. That’s why there’s a vacuum port on the back side of the manifold connected directly to the PCV valve. If the valve is bad or there is not enough suction pulling excess air out of the block, that pressure pushes air up the turbo oil return and oil has nowhere to go, so it goes out the seals.
Jeff23spl likes this.
 Old 10-06-2018, 06:31 PM   #107
flyhigh's Avatar
How's your PCV?
PCV valve was fine. Replaced it anyway as well as leaky VC seals and added PCV plate. New seals are holding for now it seems. Still plenty of smoke from the OCC when engine is at operating temp. Haven't run the A/C at temp yet.
I have ordered a closed off OCC and check valves to add to the system and will plumb as DM suggests which should provide the necessary vac the block needs. Will report results when complete.
https://photos.app.goo.gl/kd9fWo4a8pdwhKbR8
Anyone ever seen 47* below ambient BAT before with a 50/50 mix and 1 nozzle?
 Old 10-07-2018, 03:51 PM   #108
mituc's Avatar
Groans: 111
Not sure if this is even possible unless the alcohol condenses on the boost temp sensor and then evaporates.
 Old 10-09-2018, 08:48 AM   #109
Jeff23spl's Avatar
Humm it would be hard to drop below ambiant unless you shoot at the sensor itself with cold juice or your ambiant reference is heated by engine heat or something....
Mine never do that but like Mituc, we live up north, i don't see ambiant above 90f often and the more hot it is, the more drop you will get....
It is even hard to say by how much mine drop because we get intake heated by the engine and the air surrounding the sensor will almost reach the engine temperature while cruising, So if i floor it at this time. it drop very fast regardless of meth just by moving air.
For exemple, if we do, wot log back to back without meth, BAT get higher on the second pull but when i do it with meth and heated engine bay, bat get better on the second pull because the meth do cool more than just the surrounding air....The 2th pull start lower and end lower too....I cannot keep it wot for a long while in my area without being cop charged so i would need a long dyno run to give accurate numbers but air flow won't be real in the ic....So...i prefer to say i see it drop but i don't know by exactly how much...probably 20-40f....
mituc likes this.
Wife drive 2010 CX7
Page generated in 0.48172 seconds with 25 queries
