| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #281 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
| The Following User Says Thank You to dantes5823 For This Useful Post: | helmetface (09-16-2012) |
![]() | | #282 | ![]() |
![]() Join Date: Jun 2011 Location: Conroe, TX
Rep Power: 1102 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,659
Groaned at 42 Times in 15 Posts
Did you have any issue with your wg not seating onto the housing to where the vband won't go over. It's like that Lil insert into the eh is to thick.... Gonna have to shave it I think.. Sent from my Galaxy Nexus using Tapatalk 2
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! |
![]() | | #283 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have a v band off the hot side. Then the ewg and it sits fine.
![]() | | #284 | ![]() |
| Not Ranked : 0 score I know you do but there's to much of a gap so the clamp won't go over.. It's like that insert is to thick. Even tried it with their supplied flange if you needed to weld it into something and it doesn't seat there either. Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #285 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think mines fine. The last time I took it off it does look like it leaked. Where I forgot but I think it was the elbow to the housing
![]() | | #286 | ![]() |
![]() Join Date: Sep 2011 Location: Lexington Park, MD
Rep Power: 524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,207
Groans: 156
With all due respect fuck yo numbers
__________________ 2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit | |
| The Following User Says Thank You to uncorked11 For This Useful Post: | dantes5823 (09-16-2012) |
![]() | | #287 | ![]() |
![]() Join Date: Dec 2010 Location: Virginia Beach
Rep Power: 83 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score You have to push the wg pretty hard on the seat so that you push the wg valve in enough to get the clamp on.
__________________ 2008.5 cwp ms3-sold 2014 Black Mustang GT Premium w/track package |
![]() | | #288 | ![]() |
Yea how did you get that damn drain line to fit properly n my damn way no room for Shit. Fuck atp their kits are bs it seems nothing was tested right... Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #289 | ![]() |
| Not Ranked : 0 score I had to grind a good amount of material away on the fitting that hits the clamp. I agree, atp needs to do some more r&d.
__________________ 2008.5 cwp ms3-sold 2014 Black Mustang GT Premium w/track package Last edited by paulwalll; 09-16-2012 at 05:38 PM. |
![]() | | #290 | ![]() |
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! | |
![]() | | #291 | ![]() |
![]() | | #292 | ![]() |
![]() | | #293 | ![]() |
Can you get a picture for me of your wg n where the drain Line comes down from the turbo to the block Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #294 | ![]() |
Groans: 156
I did not have much of an issue with either I took care of the WG first while allowing the tightened oil line hand from the turbo, next I looped it around and installed to the fitting already installed on the block. InFeXIoN
![]() | | #295 | ![]() |
| The Following User Says Thank You to InFeXIoN For This Useful Post: | uncorked11 (09-16-2012) |
![]() | | #296 | ![]() |
Groans: 156
| Not Ranked : 0 score No problem, this pic should help, but this was the shit internal WG housing I had first. none the lees the line is routed the same.
![]() | | #297 | ![]() |
![]() | | #298 | ![]() |
Groans: 156
| Not Ranked : 0 score I did no modifcation. I did try to coil it while it was out of the car. As it sits there are no kinks and the entry point to the block is the lowest point of the line.
![]() | | #299 | ![]() |
Anyone having boost creep issues on this setup? Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #300 | ![]() |
| Needs GHES ![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 401 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 293
Groaned at 6 Times in 3 Posts
I did a little bit but nothing that couldn't be tuned out. I have the 14psi spring setup. Running 26 psi with no issues now. I'm at like 40-50% WG duty.
__________________ Needs to install the GHES. |
| The Following User Says Thank You to Etipp98 For This Useful Post: | rfinkle2 (09-19-2012) |
![]() | | #301 | ![]() |
No creep.
![]() | | #302 | ![]() |
Are yall catted or catless? Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #303 | ![]() |
Catless, along with DNP manifold. How do you have your EBCS setup? Per grimmspeeds or perrins instructions?
![]() | | #304 | ![]() |
![]() | | #305 | ![]() |
![]() | | #306 | ![]() |
| Not Ranked : 0 score Yes my hotside, dnp ex mani and in mani is 2000 Deg ceramic coated. Ex mani is also titanium heat wrapped.
![]() | | #307 | ![]() |
| Tripple OG ![]() ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 7256 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,338
Groans: 110
Groaned at 41 Times in 35 Posts
| Not Ranked : 0 score Its scary how good I am. Take it away john.
__________________ 8:5:1CP pistons...Pauter rods...NJSPEED P&P cyl head...ACT 6 puck...T3 HTA3586...CPE Big maf...Custom inlet....Hks Bov....44mm Tial ewg vta..... T3 SCH40 ARdesign Tubular Manifold...3" Vband dp....Greddy TI-c...custom fmic...Hallman MBC...CPE HPFP...JBR dogbone...SU sidemounts...Occ w/t MD checkvalve...SILVERDEMONS Injector Seals...Perm tuned..Sixth Port powered. 445whp 397wtq 4/12 478whp 470ishwtq 10/12 Killah Built Perm tuned ![]() |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | atvfreek (09-27-2012) |
![]() | | #308 | ![]() |
| Not Ranked : 0 score ?? Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #309 | ![]() |
(Thread Starter) | Not Ranked : 0 score As per njspeed 3 we have come to conclude that your coating is what is giving you trouble. You probably need to file away around the v band to get it to sit properly. It's the coating that is making it thicker and giving you issues.
![]() | | #310 | ![]() |
![]() | | #311 | ![]() |
![]() | | #312 | ![]() |
Groans: 110
Gl
__________________ 8:5:1CP pistons...Pauter rods...NJSPEED P&P cyl head...ACT 6 puck...T3 HTA3586...CPE Big maf...Custom inlet....Hks Bov....44mm Tial ewg vta..... T3 SCH40 ARdesign Tubular Manifold...3" Vband dp....Greddy TI-c...custom fmic...Hallman MBC...CPE HPFP...JBR dogbone...SU sidemounts...Occ w/t MD checkvalve...SILVERDEMONS Injector Seals...Perm tuned..Sixth Port powered. 445whp 397wtq 4/12 478whp 470ishwtq 10/12 Killah Built Perm tuned ![]() | |
| The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post: | dantes5823 (09-19-2012), rfinkle2 (09-19-2012) |
![]() | | #313 | ![]() |
![]() | | #314 | ![]() |
| The Following User Says Thank You to dantes5823 For This Useful Post: | NJSPEED3 (09-19-2012) |
![]() | | #315 | ![]() |
| Not Ranked : 0 score Could it be I'm using a 10psi spring and it's not strong enough? Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #316 | ![]() |
OK so another little update. Tweaked the map a bit cause i was getting consistent 400+ torque numbers on vd so i lowered timing there and played with boost. And this is what it yielded. atvfreek its gonna be one hell of a close run. I took the gear out longer but for some reason after this point i guess something with the road i used, the lines just darted up to like 540whp lol. Maybe once its dry out ill take it to my usual spot and hopefully vd plot looks better. Ignore the afr, i hadnt done a log since my new meth controller.
| The Following User Says Thank You to dantes5823 For This Useful Post: | atvfreek (10-04-2012) |
![]() | | #317 | ![]() |
Rep Power: 8498 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,085
Groans: 31
Groaned at 19 Times in 16 Posts
__________________ 2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS Perm Tune by the Freek ![]() 417hp/395tq 12.903@117.33 Street tires and shitty 2.25 60ft | |
| The Following User Says Thank You to atvfreek For This Useful Post: | dantes5823 (10-04-2012) |
![]() | | #318 | ![]() |
(Thread Starter) | Not Ranked : 0 score Its gonna be lol. Im trying to do what you did and get on the dyno and actually be able to see what actually nets me gains and what not. And play with it to get a hair bit more whp and keep torque low. If i could get 415whp with like 380 torque i would be a happy man.
![]() | | #319 | ![]() |
Groans: 31
Its def worth it, and also adds peace of mind.
![]() | | #320 | ![]() |
| JerzyJetJr ![]() Join Date: Apr 2011 Location: Boynton Beach FL/Flanders, NJ
Rep Power: 2032 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,103
Groans: 82
Sent from my GS3
__________________ Hypnotic Tuning ftw Coming Soon: Terminator Cobra NJ NATOR FOR LIFE Shitty Unreliable Retarded Engineering | |
| Nap Time to Lap Time: 74-year-old James Hylton to race at Daytona | Haltech | Automotive News | 0 | 11-27-2008 03:40 PM |
