> 2010 MS3 - Big Turbo Builds
 Old 11-11-2018, 03:47 PM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default Help Choosing Internals
Today I got the spare motor torn down, will need some crank polishing and undersized bearings but other than that itís good for a rebuild.
Iíve been reading up a lot on connecting rods, but Im just not sure which is the most proven and cost effective rod. My aim with this motor is 550-600WHP with a Precision 6062. This will be running 93 in the stock fuel tank along with a port injection manifold and separate fuel cell with E85 or 100% methanol (havenít decided yet but my current meth setup has got me hooked).
Iím between K1 H-Beam rods and Manley H-Beam rods, also donít know if the 625 rod bolts are necessary at this power level. Iím trying to keep the build somewhat economical, otherwise I would just go with Carrillo rods lol
I know for a fact Iím using L19 head and main studs, Iíve been told by multiple people to skip the ARP2000 studs. With such a large turbo I should be running considerably less boost but better safe than sorry.
Another thing is pistons, Iím not sure how much power the stock pistons can handle, but if I should replace these then I was thinking of Manley Platinum pistons? Or is there something else a lot of people go with?
Other than that I think Iím pretty set, I know the turbo is very large for this HP level but I want plenty of overhead, I canít tell you how many times Iíve blown up these smaller turbos simply because they were working so hard.
achulz is offline   Reply With Quote
Choosing coilovers Steezyms3 MazdaSpeed 3/6 - Suspension & Brakes 53 04-19-2014 01:44 PM
Help with choosing first MODS!?!? KILLER_VIZ Gen2 MS3 General Discussion 36 02-13-2012 02:34 AM
Need help choosing an OTS map... flz33
Cobb Access Port/Maps
2 08-12-2009 06:11 PM
need help choosing 06speed MazdaSpeed 3/6 - Turbo Induction 4 03-15-2009 08:59 AM
Help choosing a new ap map. tburton101 MazdaSpeed 3/6 - ECU Computer Tuning 0 12-28-2008 01:40 PM
Page generated in 0.23978 seconds with 20 queries
