| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #1 | ![]() |
![]() Join Date: Jun 2011 Location: Conroe, TX
Rep Power: 1103 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,659
Groaned at 42 Times in 15 Posts
(Thread Starter) | Not Ranked : 0 score GTX3071R EWG 2000 Deg Ceramic coated hotside DNP Ex mani 2000 Deg Ceramic coated inside/out and wrapped SSP Ported and VTCS deleted/coated Intake Manifold SSP Oil/Drain lines (which i will be reviewing for them for the forum since they are local) Deutchwerks 65c Sure Studs/Seals Bosch 3 bar map sensor w/ mattjackson PNP harness CNT Catless Full DP swapping out the Ultimate racing DP/TP. 38mm Tial WG In one of the pictures below i know you can see the ATP drain, its only going to be on the car for a few miles after i get everything in because after im going upto SSP so that way we can make and finalize the drain line for their kit on these turbos and this sort of set up for the kits. Sent from my Galaxy Nexus using Tapatalk 2
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! Last edited by InFeXIoN; 09-08-2012 at 06:06 AM. |
| The Following 12 Users Say Thank You to InFeXIoN For This Useful Post: | BigjohnB20 (09-10-2012), DingoDave (09-08-2012), GunGuru727 (09-18-2012), helmetface (09-08-2012), ktms3 (12-11-2012), Monotonous ONE (09-08-2012), MSFer87 (09-17-2012), speedms6 (09-10-2012), StayBroke (09-08-2012), Toymachinespeed (09-10-2012), uncorked11 (09-08-2012), Voltwings (09-10-2012) |
| MSF Leg Humper ![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 3848 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,108
Groans: 713
Groaned at 76 Times in 57 Posts
looks really awesome FIRST IN
__________________ |
![]() Join Date: Sep 2011 Location: Lexington Park, MD
Rep Power: 526 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,230
Groans: 156
looks good, def double check all conections before start up.
__________________ 2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit |
| The Following User Says Thank You to uncorked11 For This Useful Post: | InFeXIoN (09-08-2012) |
![]() | | #4 | ![]() |
![]() Join Date: Nov 2010 Location: Houston
Rep Power: 1140 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,588
Groaned at 32 Times in 13 Posts
i remember my first Big Turbo
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN |
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | InFeXIoN (09-10-2012), Toymachinespeed (09-10-2012) |
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score Bahaha I've been waiting for you to say that. You gonna come help Sat? Sent from my Galaxy Nexus using Tapatalk 2
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! |
![]() | | #6 | ![]() |
| Not Ranked : 0 score Yeah man just shoot me the time/address
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score send me your number on fb Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #8 | ![]() |
Hate your life yet Garrett haha? if not you're not installing a BT right! hope everything's going well, sorry i couldnt make it to the second day of instal. Looking forward to some good results and updates.
![]() | | #9 | ![]() |
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! | |
![]() | | #10 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 454 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 83
Good luck man let me know how much more you enjoy the BT.
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
![]() | | #11 | ![]() |
Well everything is back together and is at ssp getting a precise maf Cal done today on the dyno.. Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #12 | ![]() |
Rep Power: 11938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,968
Groans: 235
| Not Ranked : 0 score Are they going to tune it there as well?
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not sure yet. But David can get the maf Cal perfect compared to being on the street. Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #14 | ![]() |
Alright well its getting a daily tune on 93 about 370. Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #15 | ![]() |
![]() Join Date: Nov 2010 Location: spring/woodlands
Rep Power: 411 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
370 on their dyno? not just on 93. lol
__________________ ZZB way of life over with!!!built motor is in--PTE5858 w/4" full intake , TIAL EWG , TIAL BPV , GRIMMSPEED EBCS , 3" full TBE , CPE exh mani , DCR VVT , TR11 FMIC w/2.5" piping , ported and welded intake mani , 5/6th port -------tuning now and numbers soon-------- TEAM LBN BEERS -- FYCN TEAM MEAGHAN -- FYCN |
![]() | | #16 | ![]() |
(Thread Starter) | Not Ranked : 0 score 370 converted off their dyno. Sent from my Galaxy Nexus using Tapatalk 2
| The Following User Says Thank You to InFeXIoN For This Useful Post: | tooslow10 (09-18-2012) |
![]() | | #17 | ![]() |
so 370 dynojet power? right?
| The Following User Says Thank You to tooslow10 For This Useful Post: | InFeXIoN (09-18-2012) |
![]() | | #18 | ![]() |
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 913 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 648
Groans: 307
Groaned at 44 Times in 29 Posts
Is that the 90° dump elbow that comes from edge or did you get that someplace else?
__________________ 2007 Sunlight Silver MS3 GT CP-E SRI / CP-E TIP / Cobb AP Stage 1 slightly tweaked by me / JBR 88 RMM, SSP, SSB, Heavy Knob / Turbosmart Dual Port BOV 50/50 / Autotech internals _______________________________________________ Sitting in my garage: ...... To be ordered: CorkSport TBE |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score comes with the kit.
| The Following User Says Thank You to InFeXIoN For This Useful Post: | EdgeAutosport.com (09-18-2012) |
![]() | | #20 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 3802 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,914
Groaned at 9 Times in 7 Posts
__________________ ![]() Auto Tech Fuel pump internals #1 Source! PM Me for Details or call me 303-268-2140 | |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | InFeXIoN (09-18-2012) |
![]() | | #21 | ![]() |
Groans: 307
Cool. Didn't know it was that long. Good to know cuz im looking at the kit for after tax season.
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 06:20 AM |
| -cj-'s BT Build | -cj- | MazdaSpeed 3/6 - Big Turbo Builds | 30 | 07-24-2011 09:38 PM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 09:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 05:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 04:20 PM |
