> 2010 MS3 - Big Turbo Builds
Like Tree35Likes
 Old 10-18-2012, 07:08 AM   #1
robry's Avatar
Posts: 862   (View Stats)
robry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the world
Groans: 27
Groaned at 9 Times in 7 Posts
Default robry's BT build GT3076R
I bought @Captain KR 's GT3076 and PG manifold. We're installing it this Fri/Sat 19th and 20th. In preparation I have already done the following mods to the car:
Cobb SRI (will be for sale)
Cobb TIP (will be for sale)
ebay DP
Autotech FP internals
Cobb AP
ATP FMIC with Garrett 600hp core
JBR 88A RMM
JBR Stage2 SST & Knob
Nitto NT05s
KSport KontrolPro coilovers
SPC Camber Arms
Bought the following for the BT build:
Will's ATP GT3076R with mazda exhaust housing/IWG welded closed.
PG v3 Speed3 manifold with customized 44mm EWG
ebay 44mm EWG (could replace but Will has had good luck)
screamer pipe
Will's intake with 3.5" maf
brand new support items:
ATP oil/coolant line kit which includes:
-Oil drain fittings/gaskets and -10AN line for GT turbo
-Coolant return line with new banjo bolts and crush washers
-45 degree 2" silicone coupler
-Oil feed banjo and crush washers (also have 1 extra one too just in case)
-easy boost source clip for silicone couplers (I won't need this, ATP's charge piping has a boost source nipple already)
Cobb EBCS
Bosch 3 bar map sensor
Matt's PnP adapter harness
SSP Oil feed kit (not going to attempt this at Will's, will save for another day when I have time to remove the tensioner and do it properly, perhaps the spring)
I'm not going to do seals yet, I need to get an OCC and do the EGR stuff. I'll probably delete VTCS as well all at once. I'm only going to run 20-22psi on the 30R until the spring when I can afford to drop pistons and rods in the car like @chimmike recently did.
I'm sure I'll need a clutch then as well. Any comments/suggests are welcome I should be posting some photos and video this weekend.
rfinkle2 and scgomez911 like this.
2014 Mustang GT Premium 6MT - GT Track Pack/Leather Recaros/Glass roof in Sterling Grey Metallic | Barton SS/2 Post | J&M LCA | Steeda Street UCA | JBA 3" O/R X | GT500 ABs | JLT plastic CAI | SCT xcal with AED HP custom tune
SOLD2011 Mazdaspeed3 Celestial Blue Mica
robry is offline   Reply With Quote
The Following 13 Users Say Thank You to robry For This Useful Post:
atvfreek (10-18-2012), bstover17 (10-18-2012), Chimmike (10-18-2012), CWP_MS3 (10-18-2012), DISIindahead (10-18-2012), doubleflusher (10-24-2012), EdgeAutosport.com (10-18-2012), h0ckeyman (10-22-2012), helmetface (10-18-2012), leon78 (10-20-2012), ms3blackmica (04-02-2013), rfinkle2 (10-18-2012), Voltron (11-26-2012)
 Old 10-18-2012, 07:09 AM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
First! GLWB.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
robry (10-18-2012)
 Old 10-18-2012, 08:19 AM   #3
Captain KR's Avatar
Posts: 2,320   (View Stats)
Groans: 391
I'm going to post some pics to this soon
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
 Old 10-18-2012, 08:51 AM   #4
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
GLWB..I bought the seals first before OCC since I'm still low on miles just for warm and fuzzies. What clutch setup you looking to go with. I have the ACT 6 puck and still have yet to install it. Probably will sometime this winter since my stock clutch is still good. Can't wait to see your car when it's done.
Sent from your girlfriends cellphone using Tapatalk 2
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following User Says Thank You to DISIindahead For This Useful Post:
 Old 10-18-2012, 09:53 AM   #5
robry's Avatar
Groans: 27
probably the same one you have, ACT 6 puck, I've had a CC 6puck in my RSX before, not exactly looking forward to running it but oh well.
I'll do ALL the intake/seals/egr/occ crap at once in the spring.
The Following 2 Users Say Thank You to robry For This Useful Post:
DISIindahead (10-20-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 10:46 AM   #6
manila's Avatar
Posts: 1,767   (View Stats)
manila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the worldmanila is the leader of the world
Groaned at 30 Times in 17 Posts
GLWB man! Everyone going BT makes me want to join the club
'12 MS3 Black Mica w/ Tech
COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >>
JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >>
HYPNOTIC TUNED: tehmadscientist & senor finkle
manila is offline   Reply With Quote
 Old 10-18-2012, 10:53 AM   #7
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
God damn, I need some money for my BT build... Gonna be getting the GTX3076R instead though, with 38mm EWG.
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline   Reply With Quote
 Old 10-18-2012, 11:01 AM   #8
robry's Avatar
Groans: 27
I've wanted to BT all along, this deal came along and I jumped on it.
EdgeAutosport.com (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 11:13 AM   #9
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Robry, how does the ATP FMIC piping kit fit?
Do you have corn sauce in your area?
In any case, I don't think I have to say it, best of luck with your build.
 Old 10-18-2012, 11:17 AM   #10
robry's Avatar
Groans: 27
I really like the fitment, I have 0 issues, no problems with the dipstick etc. It does hang down a little low but other than that it's fine and made a major improvement overall.
and yes I have e85 about 50 miles away so I bring home 15-25 gallons and mix it with 93.
 Old 10-18-2012, 11:19 AM   #11
rfinkle2's Avatar
Groans: 298
Ahh. Easy 400 hp for you then.
You are the only one I know of to have the ATP piping.
Thanks again for your Virtual machine help btw.
 Old 10-18-2012, 11:21 AM   #12
robry's Avatar
Groans: 27
haha I hope
I got a good deal on the ATP piping kit, it was really well made/laid out, would highly recommend that over the corksport setup.
anytime, if you need any more help let me know.
The Following User Says Thank You to robry For This Useful Post:
 Old 10-18-2012, 11:25 AM   #13
rfinkle2's Avatar
Groans: 298
haha I hope
Just keep the tq early low and 400 hp is a walk in the park on cornsauce with that turbo.
Payne Racing 67 (10-22-2012)
 Old 10-18-2012, 11:28 AM   #14
trf5000's Avatar
Posts: 2,290   (View Stats)
I need a bigger turbo. Subbed for results and GL with the build.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 10-18-2012, 12:19 PM   #15
robry's Avatar
Groans: 27
I'm ready to get 'er.
 Old 10-19-2012, 07:52 PM   #16
robry's Avatar
Groans: 27
at Will's tonight, woohoo, can't wait to get into this tomorrow.
 Old 10-20-2012, 02:13 AM   #17
Captain KR's Avatar
Groans: 391
I know this nigga/ginga @BlueDmnSpeed ain't sleep
Always use plenty of protection
Mad turbos nikka
simply_pandora likes this.
Killah Built
 Old 10-20-2012, 08:00 AM   #18
robry's Avatar
Groans: 27
last night's progress lulz
Last edited by robry; 10-20-2012 at 08:00 AM. Reason: MSF Database - Automerged Doublepost
simply_pandora (12-03-2012)
 Old 10-20-2012, 08:17 AM   #19
ms3rick's Avatar
Posts: 2,959   (View Stats)
FAPPING
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
 Old 10-20-2012, 03:47 PM   #20
robry's Avatar
Groans: 27
car is running, need to fix the maf cal and shit. Wastegate is leaking but we'll get it figured out.
 Old 10-20-2012, 04:00 PM   #21
robry's Avatar
Groans: 27
@Bucker @rfinkle2 @phate
can one of you guys get ahold of me to help me with this maf cal so I can drive the car home? I'd really appreciate it!
thanks!
 Old 10-20-2012, 05:00 PM   #22
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
yo @Captain KR fuck yo couch bitch! lol. i am a sleeping fool i love my sleep
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline   Reply With Quote
 Old 10-21-2012, 04:22 PM   #23
robry's Avatar
Groans: 27
managed to brick my ecu/immobilizer 35 miles from home. just got the car back to the house off the flat bed.
fucking junk. guess I'll call cobb tomorrow.
Monotonous ONE (10-21-2012)
 Old 10-21-2012, 05:12 PM   #24
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
fuck
that is some serious faggot shit
sorry to hear that...looking forward to the build
Monotonous ONE is offline   Reply With Quote
 Old 10-21-2012, 05:14 PM   #25
robry's Avatar
Groans: 27
sounds like a combo of a bad flash + some other electrical issue. I have some theories so I'm gonna crack into it tomorrow after work and see what I can find.
if you unplug the maf sensor, the car will sometimes start, and will also show a battery light.
it seems like something is shorted or not getting proper connection.
 Old 10-22-2012, 05:45 AM   #26
trf5000's Avatar
Sucks to hear man. Hope you get it figured out.
2010 MS3 - Sold
 Old 10-22-2012, 11:10 AM   #27
robry's Avatar
Groans: 27
http://www.mazdaspeedforums.org/foru...-start-128082/
 Old 10-22-2012, 05:03 PM   #28
robry's Avatar
Groans: 27
flash the car again after rechecking all connectors and it works now. just took a maf cal for bucker after about 30 miles of driving. woot.
Captain KR likes this.
The Following 4 Users Say Thank You to robry For This Useful Post:
Captain KR (10-22-2012), Monotonous ONE (10-22-2012), rfinkle2 (10-23-2012), tddvrrn (11-12-2012)
 Old 10-22-2012, 06:40 PM   #29
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
I'm about to do the same turbo instal. just waiting for parts to come in. any tips or tricks you could share with us?
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
 Old 10-22-2012, 07:14 PM   #30
robry's Avatar
Groans: 27
just take your time, are you running an IWG turbo? if so it'll go much easier. Plan on removing the manifold then remove the k04 from the downpipe, reinstall the 30R clocked correctly, then install the manifold again. easiest way to do it. @Captain KR is the one who helped and led me through the install with knowledge.
The Following 3 Users Say Thank You to robry For This Useful Post:
Andjo (10-22-2012), rfinkle2 (10-23-2012), simply_pandora (12-03-2012)
 Old 10-22-2012, 07:33 PM   #31
Andjo's Avatar
running an iwg. I'm hoping to do it sometime this weekend or next.
 Old 10-22-2012, 07:36 PM   #32
robry's Avatar
Groans: 27
soak and remove the DP bolts first. then you can remove the intake and tip and FMIC/TMIC piping to the turbo. Then it's matter of removing the OEM manifold and then coolant and oil lines, then yank the stock turbo.
reverse operation on the new turbo. make sure you have coolant as you will lose a bunch.
@Captain KR is uploading all the photos that @BlueDmnSpeed took of the install. So I'll update the thread when I have them!
Last edited by robry; 10-22-2012 at 07:37 PM. Reason: MSF Database - Automerged Doublepost
Andjo (10-22-2012), dr_banano (10-23-2012), rfinkle2 (10-23-2012)
 Old 10-22-2012, 08:03 PM   #33
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Groaned at 64 Times in 49 Posts
This...as soon as we went to 2 gallons of meth in tank my car made nasty progress. Good luck with the new snailyyy
Sent from my GS3
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following User Says Thank You to Payne Racing 67 For This Useful Post:
robry (10-23-2012)
 Old 10-23-2012, 04:54 AM   #34
robry's Avatar
Groans: 27
dr_banano (10-23-2012), Payne Racing 67 (10-23-2012)
 Old 10-24-2012, 10:47 AM   #35
Captain KR's Avatar
Groans: 391
@robry
priming
and the start
Fail_6 likes this.
Killah Built
 Old 10-24-2012, 11:11 AM   #36
Ryguy's Avatar
Posts: 546   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
Me so jelli
Ryguy is offline   Reply With Quote
 Old 10-24-2012, 03:35 PM   #37
Captain KR's Avatar
Groans: 391
Originally Posted by Ryguy View Post
Me so jelli
you are next
Killah Built
The Following User Says Thank You to Captain KR For This Useful Post:
danieldolina70 (10-24-2012)
 Old 10-24-2012, 04:05 PM   #38
danieldolina70's Avatar
Posts: 366   (View Stats)
danieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the world
I'm next,, shoul be less than 2 weeks....gtx3071 r
[SIGPIC][/SIGPIC]//GT3076r EWG///GUARDIAN ANGEL///JMF INTAKE MANI///COBB EBC///LONG TUBE MANI///RICH TUNE///CPE PRE FILTER///CPE INTAKE and TIP COMBO///CPE TMM AND RMM///TURBO SMART BPV///CPE BIG ASS FMIC WITH CRASH BAR///COOLANT BYPASS///NGK-1 PLUGS///CPE HPFP/// LONG TUBE DP///CPE TRITON CBE///SURE PMM///SURE RSB///AEROFORCE GUAGES///JBR OCC///RALLY ARMOR FLAPS///6000 k HID LOWS AND FOGS///YELLOW-SPEED COILOVERS///KONIG WHEELS WITH 245/40/18 MICHELIN PS2 TIRES /KILLER BUILT TRANS WITH ACT 6 PUCK AND PRO LIGHT FLYWHEEL ////////// NATOR DELAWARE///////////////////////
STICKERS WON'T MAKE YOUR CAR FASTER .BUT HANGING WITH GUYS WITH NATOR STICKERS WILL
321 hp 359 tq Nator Pa. DYNO DAY 10/13/12 WITH KO4 TURBO
369 hp 368 tq NO meth or e85 ... MNM dyno day ......
danieldolina70 is offline   Reply With Quote
 Old 10-24-2012, 04:33 PM   #39
StayBroke's Avatar
Posts: 2,075   (View Stats)
Need to leave this site........im going to miss my 3076r
The Following User Says Thank You to StayBroke For This Useful Post:
Payne Racing 67 (10-24-2012)
 Old 10-25-2012, 05:51 AM   #40
robry's Avatar
Groans: 27
lol, I can't wait til we actually start tuning.
running a rev of the basemap bucker sent me because of the wastegate issue. hopefully that shit shows up tomorrow and I can actually enjoy the car without a massive exhaust leak. Might get the dump tube made longer Saturday.
Payne Racing 67 (10-25-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f540/robry-s-bt-build-gt3076r-127741/
Motor und Anbauteile - [ALLE] Gerissene Laufbuchse ohne Tuning - Seite 3 This thread Refback 02-19-2013 10:32 AM
Starting a GT3076R build looking for suggestions MurrySpeed MazdaSpeed 3 - How-To's 14 07-11-2012 10:16 AM
GT3076R Build Begins This Weekend! Payne Racing 67 2010 MS3 - Big Turbo Builds 42 05-16-2012 08:58 AM
GT3076r Build chadgermano MazdaSpeed 3/6 - Big Turbo Builds 12 04-26-2012 03:03 PM
Page generated in 0.59998 seconds with 36 queries
