> 2010 MS3 - Big Turbo Builds
Like Tree18Likes
 Old 09-02-2017, 07:00 AM   #41
Fstrnyou's Avatar
Posts: 2,231   (View Stats)
Originally Posted by VoodooJef View Post
No, no...please....turn my build thread into a junkyard find thread. LOL.
A unique way to keep a thread alive between updates. You mentioned getting a beater. The only person to blame for this debacle is you.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 09-02-2017, 07:04 AM   #42
VoodooJef's Avatar
Posts: 144   (View Stats)
VoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond repute
Carry on.....
Built motor w/ Manley rods & Mahle 4032 pistons,BNR S4v2, 3.5" JBR tru-wide, XS power V3 exhaust mani, ST intake mani, CNT catless dp, Magnaflow 3" exhaust, autotech hpfp, Coolingmist progressive (lots of methanol), Cobb FMIC, Cobb RMM, DM PMM, JBR shifter w/ Maisonvi knob, 255/35/18 Pilot Super Sports, Bilstein coilovers (f), Bilstein cartridges in (r) with BC linear spring conversion, GFB valve w/ a GA, Versatune so I can be a rebel, just a little north of 500whp.
And Yeah, that`s Steve Vai playing my arm in my avatar.
VoodooJef is offline   Reply With Quote
The Following User Says Thank You to VoodooJef For This Useful Post:
voodoo2crue (09-02-2017)
 Old 09-02-2017, 02:51 PM   #43
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Carry on.....
Back on topic, did you end up going with the 4032 mahles? And where did you get them. The only 4032s I'm seeing are the sp63 and supertechs from edge
Sent from my SAMSUNG-SM-G890A using Tapatalk
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 09-02-2017, 03:29 PM   #44
Fstrnyou's Avatar
According to Post #1 : indeed he did.
But I can see it could be read differently the way it was written.
Other rides:
History:
 Old 09-04-2017, 07:06 AM   #45
VoodooJef's Avatar
Mahle makes them for sp63. Like they might as well have been drop shipped. They showed up in a mahle box with all of the mahle paperwork, mahle shipping label.
voodoo2crue (09-04-2017)
 Old 09-04-2017, 08:26 AM   #46
Thanks for the clarification, I looked at the mahle website and see they offer a 4032 but couldn't find it anywhere other than the sp63 version. I'll be joining the 4032 gang real soon. I see supertech makes a version that edge is selling but haven't heard much about it.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 09-04-2017, 09:44 AM   #47
VoodooJef's Avatar
Like I have said all along, it`s not so much that either alloy is "better" than the other, they just have their own strengths and the 4032s are what I was looking for. If the engine is healthy they`ll both handle pretty well the same power numbers. 2816s have a higher resistance to detonation, which is good if you run shit gas or freakish amounts of boost and insufficient means of cooling the combustion charge. I run E85 and methanol on top of it so detonation really isn`t even in the equation so the drastically increased lifespan of 4032 was a high priority.
 Old 09-04-2017, 10:18 AM   #48
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
I would get the rings Pistons wrist pins and bearings epc treated when you do the Pistons
Sent from my SM-N930P using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 09-07-2017, 08:06 PM   #49
VoodooJef's Avatar
picked up my car today. Jesus that was a treat. I'm restricted to mobile posting so I'll save the details. The short version: hooray!
voodoo2crue likes this.
 Old 09-07-2017, 08:08 PM   #50
tmillner's Avatar
I meant WPC treated...
Congrats btw
Sent from my SM-N950U using Tapatalk
 Old 09-07-2017, 08:14 PM   #51
manu's Avatar
Posts: 76   (View Stats)
manu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of light
Groaned at 7 Times in 5 Posts
Oh yeah!! Can't wait to do mine. Enjoy!
Sent from my SM-G955U using Tapatalk
manu is offline   Reply With Quote
 Old 09-10-2017, 05:57 PM   #52
VoodooJef's Avatar
Ok: aside from some mafcal shenanigans it`s running extremely well. Build seems to be solid and I`ve given it the business a time or two just to wake up the hamsters under the hood. Nothing very dramatic as far as performance but it`s still on spring pressure until the maf gets sorted. The clutch is ridiculous. Grabby as f*** but not unruly.
 Old 09-10-2017, 06:04 PM   #53
tmillner's Avatar
Was the engine already broken in
 Old 09-10-2017, 06:33 PM   #54
VoodooJef's Avatar
Yep. A three hour dyno break in procedure that gets the motor ready for full tuning right away. Had I wanted them to tune it I could have gotten it back the same day fully dyno tuned but for several reasons I opted not to have them tune it. I did consider it, though. A local buddy had the same shop do his that way and it ripped from the day he picked it up.
The Following 2 Users Say Thank You to VoodooJef For This Useful Post:
andale927 (09-17-2017), Bexar (09-13-2017)
 Old 09-17-2017, 10:42 AM   #55
VoodooJef's Avatar
First oil change today. I was not ok with leaving the break in oil in there for long but the builder said give it 10 days or so. Not that I expected anything less, but the oil that came out was clean and clear (technically it's the second batch of oil as it was changed immediately after the break in) Took a sample to send to Blackstone just for baseline reference. Installed an oil pressure gauge while I was at it. After a short trip to the store she's getting about 25psi at idle and 60 under a bit of throttle, 80 if I'm leaning on it.
So far it's looking solid. 750 miles or so and nary a peep out of it.
 Old 09-17-2017, 12:14 PM   #56
Glad to hear it's running well. What oil are you going to run?
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 09-17-2017, 12:27 PM   #57
VoodooJef's Avatar
I put Valvoline dino 10w30 in this time. After this I'll run Mobile 1 extended protection and probably stick with 10w30. It's supposed to be a 15k mile oil, but I change it at 8k and have been getting great UOA results. The next oil analysis will tell me more but unless there's still excessive wear particles that's the plan.
 Old 09-17-2017, 02:10 PM   #58
For the coming break in, my builder wants to use valvoline vr1 20w50. I thought that was a little heavy but I'm going to go with it. It won't be in there long.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 09-17-2017, 03:27 PM   #59
VoodooJef's Avatar
It really comes down to bearing clearances. Mine is dead on oem spec so I could conceivably even run 5w30 again. The 10w isn't going to affect much of anything other than maybe cold start oil pressure.
 Old 09-17-2017, 04:29 PM   #60
Fstrnyou's Avatar
Out of curiosity, why would you want to run a heavy oil for break-in?
High weight makes higher oil pressures, but doesnt that mean the fluid is having issues flowing to where it's needed? The tightest tolerances, and quite frankly the only real restriction IMO, is getting into the bearings.
Other rides:
History:
 Old 09-18-2017, 06:42 AM   #61
VoodooJef's Avatar
I broke mine in on 10w30, not a heavy oil by any standard. The 20w50 Crue's builder recommended is a little curious. Heavy oils have a higher resistance to shearing forces but that's not really a big issue in a proper build. The only real shear points in there are rings on cylinder walls, and the single most important part of a break in is making sure the rings grind on the walls to seat them well. There has been a practice over the years of running a "loose" bottom end for high revving engines. It involves turning the crank an extra thousandth (give or take, not quoting actual numbers there) and running a thicker oil in those cases. Lots of subaru builders do it. I'm not a fan, especially on a DD.
 Old 09-18-2017, 06:55 AM   #62
Totally agree with you on the "curious" remark. Although I went ahead and provided the builder with the oil he recommended, I'll be dumping it after 100 miles and going with a 10w30. I'm kinda leaning toward the RP 10w30.
https://www.amazon.com/Royal-Purple-...sed+SAE+10W-30
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 09-18-2017, 07:23 AM   #63
VoodooJef's Avatar
We used Motul high zinc break in specific oil on mine. Builder said I could go a month on it and I thought "yeah, I trust that like a fart after mexican buffet". RP does seem to be popular for sure. Given how well the Mob 1 extended has done for me I'm inclined to keep using it until a UOA comes back with a reason not to. Blackstone as well as Bob the Oil Guy have gone on record to say that at the end of the day oil is oil and none of them test any better than another. I'm sure we all have our own favorites but I wonder how different they really are....
Bexar likes this.
voodoo2crue (09-18-2017)
 Old 09-21-2017, 04:02 PM   #64
VoodooJef's Avatar
So, the latest...
I said I was going to have some help from one of our established tuners. Didn't happen. Rather than sit on my ass, I set out to familiarize myself with the software and started tuning it my damn self. A couple of steps in the learning curve and a cautious approached has me sitting right under 400whp, mafcal is perfect and scaled for methanol, and only at 19psi or so. I'll start upping the load targets and bringing up boost until either (a) I hit my goal or (b) I run out of fuel. I should hit 460whp around 28psi. Load tuning was aggravating and foreign at first, seeming ridiculous and tedious to get anywhere but now that I am familiar with the process I see the value in it. Not to mention the pride in doing it myself. It's pretty quick already, easily handling a feisty M4 earlier (they're not very fast but I'm also hardly turned up the wick, too). I've got about a thousand miles on the motor now and she seems to be holding together like a champ.
andale927 and voodoo2crue like this.
 Old 09-23-2017, 07:53 AM   #65
VoodooJef's Avatar
Vdyno has since given me 440, 444, 471, and 457. Vdyno is by no means
gospel but the logs imply 440 is in the ballpark. I've got some minor tweaking to do then I'll get her on the rollers. I'm admittedly proud of myself for the way it's running. Very smooth and mild mannered while part throttle, turns into a fire breathing beast of fury at wot and still what could be considered a moderate tune, even mild considering the forged motor and head work (not ported, just new valve seats, guides, springs, etc).
manu, voodoo2crue and Bexar like this.
andale927 (09-29-2017), Thor Hammer (09-25-2017)
BNR S4v2 NJsean0 2010 MS3 - Big Turbo Builds 23 08-16-2017 08:25 PM
Voodoo's BNR S4 Tune in progress voodoo2crue 2010 MS3 - ECU Computer Tuning 36 06-18-2016 05:37 AM
LA 2010: 2011 Scion xB Release Series 8.0 dabbles in Voodoo Haltech Automotive News 0 11-18-2010 12:00 PM
Photoshop voodoo gives close-up view of Chevy Volt Haltech Automotive News 1 08-29-2008 10:09 AM
Page generated in 0.43828 seconds with 25 queries
