Notices
Like Tree3Likes
  • 2 Post By bcmurphy87
  • 1 Post By djuosnteisn
 Old 04-25-2012, 06:42 PM   #1
bcmurphy87's Avatar
Posts: 1,294   (View Stats)
bcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the world
Default Blow thru + 5th port
Here is my current set up for blow thru. I have 15 inches of 3.5 with a honey comb right before the maf. Then i have 5 inches after the maf before we hit the TB. The meth taps right outside the coupler.
DJ i have plenty of space for it where i put the white stars......Plenty of vertical clearance and should have horizontal as well. As long as it isn't spraying during LC it should never hit the Maf. I have had no problems with the meth so far.
djuosnteisn
I added a few more pictures of the engine bay to show you the rest of the set up and the LACK of perm stickers......
ESB Jiu JItsu and weakdog85 like this.
06 Speed 6- Built, working on a PERM tune.
In progress dyno 476/410
just bang out the tight spots.
bcmurphy87 is offline   Reply With Quote
The Following 11 Users Say Thank You to bcmurphy87 For This Useful Post:
Bucker (04-26-2012), Chriscote (04-26-2012), dantes5823 (09-09-2012), djuosnteisn (04-26-2012), ESB Jiu JItsu (08-09-2012), helmetface (04-26-2012), MS3-a(sore)ASS-rex (04-26-2012), sallyspeed3 (04-27-2012), SPEED6 KILLAH (09-08-2012), Todd98SE (09-14-2012), uncorked11 (08-09-2012)
 Old 04-26-2012, 12:51 PM   #2
Captain
djuosnteisn's Avatar
Posts: 11,181   (View Stats)
Groans: 79
Looks plenty do-able.
And engine bay looks very sectsy good sir. Definitely lacking in terms of decals.... for shame.
I'll order some today
Bucker likes this.
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
djuosnteisn is online now   Reply With Quote
Alpha (04-26-2012), Bucker (04-26-2012), MS3-a(sore)ASS-rex (04-26-2012)
 Old 04-26-2012, 12:55 PM   #3
Bucker's Avatar
Posts: 2,740   (View Stats)
Groans: 418
Groaned at 88 Times in 44 Posts
Looks even better in person
380whp/428ft/lb Dry Shot(Current K04 record )
75 Shot Results soon. 400whp here I come!
Dyno Results
ATR Training
The Following User Says Thank You to Bucker For This Useful Post:
 Old 04-26-2012, 01:21 PM   #4
bcmurphy87's Avatar
thanks guys! i know it might have to add a red button like you Will.
The Following 4 Users Say Thank You to bcmurphy87 For This Useful Post:
Bucker (04-26-2012), Chriscote (04-26-2012), MS3-a(sore)ASS-rex (04-26-2012), rfinkle2 (11-15-2012)
 Old 04-26-2012, 02:21 PM   #5
MS3-a(sore)ASS-rex's Avatar
Posts: 6,266   (View Stats)
Groans: 193
Groaned at 75 Times in 63 Posts
You should have labeled the MAF in your drawing lol, now people are going to ask why you haz honeycomb in your IC piping.
Nice setup though man, best of luck!
MS3 has officially been retired to daily duty
Project 1G is officially under way; 1991 Eagle Talon TSi.
Stock Turbo & Stock Motor Grand Champion of the World!
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
bcmurphy87 (05-02-2012)
 Old 08-09-2012, 08:36 AM   #6
ESB Jiu JItsu's Avatar
Posts: 494   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
Groaned at 4 Times in 2 Posts
amazing setup! watching and learning!
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
The Following User Says Thank You to ESB Jiu JItsu For This Useful Post:
bcmurphy87 (08-09-2012)
 Old 09-14-2012, 12:13 PM   #7
Phoenix Speed3's Avatar
Posts: 640   (View Stats)
Phoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the world
bcmurphy87 how has this setup worked so far?
Phoenix Speed3 is offline   Reply With Quote
 Old 09-14-2012, 12:24 PM   #8
bcmurphy87's Avatar
Its great no issues at all. I have all my tuning done with Perm.
How much can the K04 blow? sallyspeed3 MazdaSpeed 3/6 - Turbo Induction 26 03-30-2012 11:15 AM
Grimmspeed 3 Port In 2 Port Mode on IWG? bewsted MazdaSpeed 3/6 - ECU Computer Tuning 1 12-21-2011 07:59 AM
Page generated in 0.30720 seconds with 26 queries
