Like Tree30Likes
 Old 10-02-2015, 07:08 PM   #1
davychronic's Avatar
Posts: 1,154   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Default Davychronic's corksport/gtx build
So I guess im far enough along now to start a build thread.
Bought this car in February because I felt it was appropriate to have an awd grocery getter since the winters here tend to suck. Im not trying to acheive the highest hp or test the strength of the internals, im just trying to make this car how mazda should have from the factory for the most part.<---This may have slightly changed... My factory k04 never had any issues, im am just tired of such a weak powerband. I will be very happy with 350whp<---not happy anymore, I need moar, so that was kind of my goal. Just enough to shit on a minor bolt-on 5.0 or equivalent since thats what most people have around here.
So mods before this project started goes as follows...
jbr pp2 intake
corksport internals
cs rmm
3 bar map
ill post a dl with that shit on e30 tuned by myself...
So I bought a @CorkSport; turbo because I like the td05 ra since ive used them in the past with a lot of success and I really like what cs is doing for our platform and not giving up on us. I also picked up the turboxs v3 exhaust mani after reading the long ass thread by @Turbo_Steve; and I appreciate what he has done for us and I wanted to keep my tmic setup and a lot of toob manifolds dont allow for it. Also went with the divorced cs downpipe mainly because its a small exit out of the turbo and tapers to 3 inch (im guessing to help with any creep associated with an bellmouth dp).
Then I started searching for a tuner, I read a lot of threads about tuners and called a few and ended up choosing the guys over at Purple Drank. What made me choose was the conversation I had with Will on the phone about what my power goals were and what I could expect out of what I got. This was about a month before I started my install that I started inquiring about a tune. He also made a couple recommendations about how to squeeze a few extra ponies so I picked up a jbr 3.5" intake and took my intake manifold off to check my valves' condition.
After checking my valves they looked like shit so I pulled the head and had it built with all supertech hardware 1mm oversized with inconel exhaust valves and 55lb valvesprings (20lb over stock)..
I also used this opportunity to change the vvt, timing chain, tensioner, guides.
I also figured id ditch the vtcs so i cut that crap out and did a little port matching.
I decided on arp8740 studs, I read the thread after the fact but still not concerned. So I torqued mine to 80ft/lb on a cometic .01 thickness increase hg.
So it went together pretty easy in a day by myself, added a DamondMotorsports vented catch can, blocked off egr, painted the valvecover wrinkle black, got some cpe inj seals (i added permatex #2 ), jbr tig, and a cpe deltacore tmic. I wrapped the header and dp in dei titanium and used dei gold on the underside of the tmic and shroud, probably forgetting some stuff but you get the picture I did a lot of shit.
At first I wasn't all too impressed with the new sound coming from the exhaust, so I will probably pick up a resonated tp from corksport to quiet the tone down and hopefully take the "raspy" sound away.
The new 3.5" intake is nice and quiet until you get into boost, then you hear the turbo screaming to life.
I dont want to go through and post a bunch of datalogs unless some specific parts that are requested but once the tune is finished I will be taking it down to Karls Performance and see what the real dyno numbers are compared to vdyno.
So after a bunch of going back and forth with Ryan from PD, he is suggesting that I scale down to a 3 gallon (e24) mix instead of a 4 gallon (e30) mix because my engine is flowing a little better than expected and I am running out of fuel at 20psi on e30. Honestly the main reason I am wanting to run e30 is because it is very plentiful for me in my area, in fact more plentiful than 91 octane (I can buy e30 straight from the pump).
So now I just ordered the Aquamist HFS-4 methanol kit with two 1.2mm injectors and I plan to tap my cold pipe for both injectors as suggested by Ryan.
I really wanted to make good power on e30 without meth but running out of fuel at 20psi only got me to 330ish on vdyno.
So now im walking down a slippery slope with my stock internals once its addicted to meth and probably going to build it next summer but ill see how far I can go with this turbo.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
The Following 11 Users Say Thank You to davychronic For This Useful Post:
09speedaddict (10-02-2015), amoosenamedhank (11-02-2015), Barett@CorkSport (11-02-2015), dr0 (10-04-2015), ericrapp0507@gmail.com (01-01-2016), ItsNox (11-02-2015), Jackis (10-04-2015), nekret (10-03-2015), rolliepollie07 (10-02-2015), speedfreak44 (10-02-2015), Thepedigree13 (10-02-2015)
 Old 10-02-2015, 08:47 PM   #2
Here is last vdyno on k04
 Old 10-02-2015, 09:42 PM   #3
09speedaddict's Avatar
Posts: 223   (View Stats)
09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute
Groans: 28
Sweet setup. I'm really leaning towards this turbo in my speed3. Just a small note; worried about it being lean? or is that covered under the "base map"category?
09speedaddict is offline   Reply With Quote
 Old 10-02-2015, 09:46 PM   #4
There wasnt any knock, its on e30 and targets were 11.6 so the future revisions im sure will iron that out. It pulls strong up top, great turbo so far.
 Old 11-02-2015, 07:07 AM   #5
Here is my last e30 vdyno, we were barely started on this tune (2nd revision) before a 3 gallon mix was suggested
 Old 11-02-2015, 07:15 AM   #6
JakeMS3's Avatar
Posts: 1,139   (View Stats)
JakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the world
Groaned at 7 Times in 5 Posts
Nice numbers bet it's fun to take off from those stop lights!!
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
Corksport Catted DP/HPFP Internals
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
JakeMS3 is offline   Reply With Quote
 Old 11-02-2015, 07:18 AM   #7
Haha where I live the closest stoplight is like 40 miles away, but yea it is pretty fun to drive. Just looking for a little bit more, trying to shoot for 400whp with meth now. I would like to push 26-28 psi on e30 and meth and see what it'll do.
 Old 11-02-2015, 07:25 AM   #8
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Originally Posted by davychronic View Post
Im not trying to acheive the highest hp or test the strength of the internals, im just trying to make this car how mazda should have from the factory for the most part. So now im walking down a slippery slope with my stock internals once its addicted to meth and probably going to build it next summer
Quoted for lol
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post:
davychronic (11-02-2015), Gitcherex (05-09-2016)
 Old 11-02-2015, 07:38 AM   #9
Originally Posted by Mazdazilla6 View Post
Quoted for lol
Haha thanks...Just not happy with only 20psi so away I go with testing the integrity of the factory internals for a few months (which will be in the winter and we get a lot of snow so wot wont be a common occurrence). I thought I would be happy with it until a new corvette beat me on a roll.
The Following 2 Users Say Thank You to davychronic For This Useful Post:
Gitcherex (01-01-2016), Mazdazilla6 (11-02-2015)
 Old 01-01-2016, 09:26 AM   #10
Gitcherex's Avatar
Posts: 103   (View Stats)
Gitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud of
Has the final revision been completed yet? If so, what #'s are you hitting?
p.s. Did ya ever get another chance at the Corvette?
Gitcherex is offline   Reply With Quote
 Old 01-01-2016, 09:38 AM   #11
I tried to get some dyno time in before vacation to complete my tune and get some real numbers but weather wasnt cooperating. My last datalog put me at 367hp 373tq on e30 with 1.01cf
Nah no chance at the vette yet and i havent got any good races down here in Dallas et either, kind of surprising but there is also fuggin construction everywhere so its kind of hard to find a safe place to run
Last edited by davychronic; 01-01-2016 at 09:38 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to davychronic For This Useful Post:
 Old 01-01-2016, 09:42 AM   #12
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
This is our life
Race his ass in the snow !!
a win is a win
Gitcherex likes this.
ericrapp0507@gmail.com is offline   Reply With Quote
The Following User Says Thank You to ericrapp0507@gmail.com For This Useful Post:
 Old 01-01-2016, 09:43 AM   #13
Hahaha
 Old 01-01-2016, 09:45 AM   #14
Gitcherex's Avatar
very nice, thats roughly what my goal is (for now lol). But I know the feeling all too well, no matter how much I taunt em, people ignore me lol.
 Old 01-01-2016, 09:51 AM   #15
Its good power, im happy with it. I have an aquamist meth kit ready to be installed but ill probably wait til i build the motor. On 93 I can hit 27psi super fast (like 3700rpm) and hold it to about 5500rpm wher i need to taper it down to 25psi hitting fuel limits. I need to datalog one of my 93 runs and see where im at there. Ive started to play with running 12.0afr on my e30 tune to get more boost but i richen it to 11.8 at 5500 and up.
Mazdazilla6 (01-01-2016)
 Old 01-02-2016, 05:42 PM   #16
redgenpu's Avatar
Posts: 28   (View Stats)
redgenpu has a spectacular aura aboutredgenpu has a spectacular aura about
Would not feel bad losing to a Stingray. Any 'vette made in the last few years is very quick, plus you have AWD slowing you down at higher speeds. I am considering this turbo and can only hope to be competitive with a new vette. Congrats on the install - 27 psi seems insane
davychronic likes this.
redgenpu is offline   Reply With Quote
 Old 01-19-2016, 08:54 AM   #17
Just to add a few things to my bulid thread
Got a pair of Corbeau RRS seats with heaters and brackets all from Corbeau. Install was pretty straight forward, still waiting on resistors to come in to fix airbag lights. Passenger rail is missing a spot fot the lower seat belt anchor so i bolted it to the floor. The seats are great, they sit about 2 inches lower than stock so it takes a little getting used to the new driving position.
Also got a set of Enkei Raijin 18x8 +40 wheels that are maybe a pound lighter than stock. For now they are wrapped in the Goodyear Eagle sport all seasons that were on my stock wheels 225/45 but come summer they will get summer rubber 245/40.
I started tuning my e30 tune leaner, starting at 12 and working my way up. Reason being is that i am making more power without detonation and you know the old saying leaner is meaner. Also stepped boost up to 23 psi so ill get some good vdyno numbers and datalogs to post.
The Following 3 Users Say Thank You to davychronic For This Useful Post:
Code Monkey (01-22-2016), impossible (02-11-2017), Mazdazilla6 (01-20-2016)
 Old 03-19-2016, 05:00 PM   #18
Default Davychronic's corksport turbo build
So while doing a log tuning for 100% meth i bent a rod a couple weeks ago. 30 psi is too good to be true on these puny factory internals.
You can see third one down (cylinder 3) the rod is tweaked. So i went ahead and order Manley H beams and Manley pistons and rebuilt it in car.
You can see the spagetti factory rods compared to the beefy Manley rods.
So i bought a cylinder bore gauge and a couple other tools to make sure everything was within specs to do it without pulling it out and all went well. I honed it with 220 grit and finished it off with 320. I check flatness on the block and head (which i had built a couple months ago) and all was good. Installed everything without too many problems, Manley dis send me oversize pistons in a standard size box and they had a hell of a time believing me since "they are check sooo many times before they ship" but if they jad only paid attention to the weight on the box it could have been caught.
So after a bunch of bs with Manley, i finally got Edge to overnight me the right pistons and everything went smoothly from then on.
They look soooo pretty, shame ill never get to see them again, i hope.
Heres so in process pics
So now i got about 100 miles on it and all is well, ill check compression at 500 and see how its goin.
Ill post my log from when i bent the rod in a few hours, you can see where it happened.
zjnspeed3 likes this.
The Following 4 Users Say Thank You to davychronic For This Useful Post:
allo80 (03-20-2016), Code Monkey (03-19-2016), Poohster (03-19-2016), speedfreak44 (03-19-2016)
 Old 03-19-2016, 07:38 PM   #19
Here is the datalog vdyno of the rod bending action
 Old 03-19-2016, 08:03 PM   #20
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Looks like you were trying to have an excuse to go built with a curve like that.
Etipp98 is offline   Reply With Quote
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
Code Monkey (03-19-2016), impossible (02-11-2017)
 Old 03-19-2016, 08:27 PM   #21
Yea I was seeing how far i could push my luck. I was originally tapering boost up to redline but i missed the big torque shove so i said fuck it. Im trying to see how far this corksport turbo will go. Its clearly good for over 400hp.
 Old 04-02-2016, 07:02 PM   #22
So I guess to update this, i've passed my "break-in" period so I changed the oil with Royal Purple HPS 5w30. I turned the meth back on and got back to tuning. Im on my 4th revision and starting to wind down with my 91 and meth tune and numbers are looking pretty good. I dont expect to hit the dyno til i finish my e30 and meth tune. Im having a little trouble overboosting once the 2nd meth nozzle kicks on and I cant really get it to slow up so im tuning around it and making it work. It feels like the vdyno should be close, it pulls very strong all the way to 7k with no knock over .35 and im running 18.5* at 7k rpm so mild timing since i run a little more on my e30 tune without meth. I could flatten my torque curve out by tapering my boost up to redline but im happy with the big initial torque shove.
Jonb82 likes this.
Code Monkey (04-03-2016)
 Old 04-02-2016, 07:12 PM   #23
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
How much wgdc are you at?
Sent from my SM-G920P using Tapatalk
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 04-02-2016, 07:42 PM   #24
Pretty much 90s across like 95 up top
 Old 04-02-2016, 07:48 PM   #25
GEE1989's Avatar
Gotcha. May 2 I'm getting tuned with built motor, meth, and corksport turbo so I'm curious to see what this can do. How much meth are you running?
08 MS3
 Old 04-02-2016, 08:01 PM   #26
GEE1989's Avatar
And also how loud is that turbo at 28 psi lol. I know it screamed at 22 before the zoom zoom boom
08 MS3
 Old 04-02-2016, 09:05 PM   #27
I spray 9gph of 100% and get 85%idc at 7k rpm. This is about all the turbo can do i think. Even with meth boost temps come up to intake temps at high rpm so come summer time im sure ill have to back down a frw degrees of timing
Its a good turbo tho, you wont regret your purchase. It feels like the turbo that should have came on the car, excellent powerband.
Last edited by davychronic; 04-02-2016 at 09:05 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-02-2016, 09:36 PM   #28
GEE1989's Avatar
That's still solid power. Yea I'm gonna run 100% meth 10gph. I'm already impressed with this turbo
It's definately a perfect turbo for this car. It pulls hard to redline. I would say this is like a bnr s3.5 lol
08 MS3
 Old 04-03-2016, 05:41 AM   #29
Ive never had the bnr so I cant really compare but its a great turbo for its size. Ive started looking at a pte 5862 and water to air intercooler. I am well passed the efficiency range for this turbo and its just blowing hot air.
 Old 05-03-2016, 09:44 AM   #30
c_bye's Avatar
Posts: 67   (View Stats)
c_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to behold
I've been super impressed with this turbo so far too, been running 24psi on 93 and it pulls all the way to redline.
Awesome build, keep it up.
davychronic and Freefallin like this.
2008 Cosmic Blue MS3 GT // CS TD05-18G Turbo // Freektuned //Denso ITV22 // CS DP // CS 3.5" Full Intake // CS 3.5 Bar Map // CNT Catback // CS HPFP // JBR FMIC Piping // Treadstone TR8 FMIC // CS OCC // CS Heat Sheilds // CS boost hoses // CS ECU relocation // Cobb AP3 // Cobb RMM // HKS SSQV 4 // CS Short Shifter // CS Short Shift plate // Fifteen52 18x9 Tarmacs // Hankook RS3 235/40 // Koni Yellows // GC Coilovers // CS F&R Sway Bars // CS front Endlinks // Whiteline rear Endlinks // GC bump stops // CS mid chassis brace // Megan front H brace // CS rear strut tower bar // Stoptech rotors/pads/ss lines // DG carbon spoiler // DG carbon bumper cover // V2 Side Skirts // STi Lip // CS Antenna // CS Lisence plate relocator // CS LED Fogs // PIAA yellow high beams // Pioneer NEX-7100 // Prosport Premium gauges (Boost/OP/OT) // CP-E Gauge Pod // TWM Shift Knob // Sparco Pedals // Royal Purple 5w/30
c_bye is offline   Reply With Quote
 Old 05-03-2016, 11:06 AM   #31
Tommy_y0's Avatar
Posts: 302   (View Stats)
Tommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond reputeTommy_y0 has a reputation beyond repute
In for rest of build, been considering this turbo for my BT build, or maybe even going bigger lol. Always wanted a GTX3071R/GTX3076R (can't decide). That and quite a few people up here in MN have BNR's so I want to be different haha.
'14 CRF250R #Dirtscooter | 2001 Audi S4 and 2001 Audi S4 Avant |
SOLD | '07 Cosmic Blue Mica MS3 GT #Genjuan | Hypnotic Tuned | M2 Catless DP w/Titanium Header Wrap | Damond "Gold" RMM | AutoTech HPFP | HTP 3.5" Intake | Turbosmart 50/50 | RallyArmor Mud Flaps | JBR Weighted Knob | JBR Shift Weight | H&R Coilovers | Grimmspeed EBCS | Corksport FSB w/billet brackets | Sparco Pro Corsa's wrapped in Dunlop Direzza DZ102's |
Tommy_y0 is offline   Reply With Quote
 Old 05-03-2016, 12:42 PM   #32
Yea my build is changing direction, ive been meaning to update this.
Ill attach my last datalog it is on e30 and is about 10-15 more hp than my 91 map thanks to leaner afrs. The only way i could get decent control of boost was to taper it up to redline which killed peak torque but gave me a good flat curve. In my opinion this is the best turbo for the stock block. I have absolutely no gripes, it would be better with an ewg if you are trying to spool it up as fast as you can but on a stock block thats not recommended. I am at the limit of the turbo and my tmic at the moment and another build is under way. Im running 100% wgdc at redline and can only get 28-30 psi which is great and well beyond the efficiency range of the turbo.
Im starting a new build because i want 500-550 awhp that will take me the next several months to get everything together and this is how im going to get there:
sp63 stage 2 long block (the reason im going this route since im already biult is because the down time and cost would be very similar if i tore my motor apart, sent my crank and cams in to have them keyed and have my block machined and etc. it comes out to about the same cost but with much less downtime if i just buy the long block already keyed)
cp-e havoc intake mani and fuel rail
im exploring a few options on fuel controllers still, id like to have my aux injectors to be spraying all the time to keep my valves clean but im looking at 4 750cc injectors and a walbro 450lph pump
treadstone vertical flow fmic TRV1859 with a blow through maf and custom piping
i intend to keep the meth but ill be spraying only one nozzle and more for temp control and knock protection
cp-e atmosphere barebones kit, tial vband mani and dp
tial 44mm mvr ewg
and either a gtx3076r or gtx3582r
still staying self tuned
Im split on turbo choices because I still want to be able to track the car but I dont want to be pushing the turbo passed its efficiency range either. I dont think the gtx3582r would be so great on the track so im really just researching a lot of other guys with the 35r to see if i can make 26-28psi by like 3700-3800 rpm.
I am about to install my new 8 puck RD Motorsports clutch and act streetlite flywheel next weekend to make sure i get that broken in before the new motor goes in. Hard to break in a new motor with a new clutch. Ill try to post a pic of the clutch later today.
But yea i highly recommend the corksport turbo to anyone looking for good power on a stock block, i dont regret my purchase at all. I plan to have my new build finished by August or September if all goes well. Ill probably do it in phases when I have time. Id like to break the new motor in with the corksport turbo. Come Christmas time i'll have a ton of goodies to sell
CharlieD, Tommy_y0 and Freefallin like this.
SpeedRebirth (05-04-2016), Tommy_y0 (05-03-2016)
 Old 05-03-2016, 07:30 PM   #33
Tommy_y0's Avatar
......Come Christmas time i'll have a ton of goodies to sell
Hell yee in for that! Hahaha
 Old 05-03-2016, 09:24 PM   #34
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Whats up with that boost control. Geez
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 05-04-2016, 05:22 AM   #35
Yea its tough to slow spool down with meth especially when you are working at the upper limit of the map sensor. I debated getting an ewg to make it easier but im just changing it all so its about as smooth as i could get it. Took me a lot of logs just to get it where it is, ive tried so many different ways to slow it down once it hit 28. I tried load targeting, throttle closing, lowered boost targets and wgdc, wgdc correction, everything i could think of didnt work so i had to taper it slowly which is ok it still pulls hard. See the way i have my meth set up is one nozzle comes on at 15psi and a second one comes on at 25psi and its when that second one comes on that makes the turbo hard to slow down. This was the best method i think to keep it from bogging from coming on with too much too early. Two different size nozzles too.
 Old 05-08-2016, 09:39 PM   #36
Tommy_y0's Avatar
@herzloglover; @lasserudn;
The gnarly Corksport turbo build I was talking about at ENM-MN
herzloglover likes this.
 Old 08-25-2016, 07:43 AM   #37
Guess I should update this, never made it to the dyno to see what this ended up making but it felt strong and the corksport turbo is great. I highly recommend it for someone who is still stock block that wants a little more power for pretty cheap.
I have started a new build it probably needs a new thread but im going with a cpe precision vband mani with a pte5858 with a ported s compressor housing and .82 a/r exhaust housing turbo with a tial mv-r wg that i am going to build a custom recirc pipe into the kozmic dp.
I have a tr-10 intercooler on the way and a couple sets of universal intercooler piping kits, 2.5" hot side, 3" cold side with a tial qr bpv.
Waiting on Damond to release the intake mani adapter to run the focus manifold
Still need to make a custom oil drain line so im waiting on everything to show up before i start disassembling everything
Should have a ton of shit coming up for sale in the next couple months like the corksport turbo,xs v3 exhaust mani that is wrapped in dei titanium, corksport divorced downpipe also wrapped, cpe deltacore anodized in black, hks bov
So far all I have is the turbo but in the coming weeks the rest of the stuff should trickle in
impossible likes this.
DingoDave (08-25-2016), impossible (10-26-2016)
 Old 08-25-2016, 06:15 PM   #38
sheston's Avatar
Posts: 1,844   (View Stats)
Looking forward to see how you push this set up. Are your goals still only a little more than you got out of the Corksport, or have those changed also?
 Old 08-25-2016, 06:25 PM   #39
Id like a solid 500-550whp and id like to stick with a 3 bar map but we will see how it turns out when i start tuning
 Old 08-29-2016, 12:15 AM   #40
shaneski's Avatar
Posts: 471   (View Stats)
There's a good chance you will have to run a 3.5 bar map sensor to run the power you wan't, boost will possibly be out of range for the 3 bar, especially to catch head lifting boost spikes.
Gen 2 2012 - ATP GTX3076r IWG - Full Race exhaust mani - 2NV Industries built Forged bottom end - PNP Head - JMF Intake Mani- UR Turbo Back - JBR tru 3.5 intake - TR8 FMIC - Devils own stage 2 WM - Cobb 3 port EBC- Autotech internals - FREEKTUNED.
CorkSport's 2013 White MS3 Build CorkSport Vincent Mazda MZR DISI Engine Builds (2006-2013) 36 03-20-2015 08:09 PM
GTK-450 turbo build matgod MazdaSpeed 3/6 - Big Turbo Builds 18 09-09-2013 07:00 PM
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 01:16 PM
CorkSport Across the Pond – Dave Higson’s Gen2 Mazdaspeed 3 Build CorkSport CorkSport 0 08-17-2012 02:50 PM
Corksport Downpipe...Is this poor build quality? spedo3 Gen2 MS3 General Discussion 27 07-23-2012 04:13 PM
Page generated in 0.59792 seconds with 34 queries
