Like Tree141Likes
 Old 01-26-2014, 09:57 PM   #561
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Have to post this... My prior attempts at soldering wound up being...well, abominations. They worked, but they didn't look like anything you'd want to be near.
This is the difference the right solder size and a good iron make; these are the two MOSFETs pictured earlier, now mounted to a board.
Enki is offline
littleloogy (01-26-2014), Mauro_Penguin (03-04-2014)
 Old 01-26-2014, 10:44 PM   #562
littleloogy's Avatar
Posts: 4,005   (View Stats)
Its amazing how having the right equipment can make all the difference in your work. At work with high end irons, my work looks factory. At home... Well not so much.
Sent while cleaning my spill valve again...
littleloogy is offline
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
Enki (01-26-2014), Mauro_Penguin (03-04-2014)
 Old 03-03-2014, 04:49 PM   #563
Enki's Avatar
Groans: 189
I know it's been quite a while since my last real update; unfortunately, it's probably going to get more sparse from here on out.
While I was out testing the capacitor bank, my pops noticed something I had not.
My dipstick popped out just a little bit, spraying a little oil over the intake manifold and some of the radiator hoses. Nothing major, but considering I'm running stock PCV setup on the intake mani and the valve cover is vented to the intake, this doesn't really bode well; especially considering my AFRs frequently shift pretty rapidly when cruising between 14.2 and 14.9, steady state.
With as much abuse as my car has seen, I wouldn't be surprised if it failed a leakdown test on cylinder 3 due to ringland issues.
At some point in the near future, I'll look into doing compression and leakdown testing to see where it stands. Unfortunately, the last test I did wasn't really conclusive, so I'll probably have to borrow one from a local.
Enki is offline
The Following 11 Users Say Thank You to Enki For This Useful Post:
atvfreek (03-03-2014), btstarcher (03-03-2014), Code Monkey (03-03-2014), Easter Bunny (03-03-2014), El_Diablo (03-06-2014), Hush (03-03-2014), littleloogy (03-06-2014), Mauro_Penguin (03-04-2014), timjs (03-03-2014), wolly6973 (03-04-2014), Ziggo (03-03-2014)
 Old 03-22-2014, 05:28 PM   #564
Enki's Avatar
Groans: 189
So some of you may know that there's been some testing going on with a potential fix for full E85 found by @littleloogy;; since his testing has gone rather well, I asked him to post up his findings so we can branch out the research/testing to other owners willing to participate. I have to admit, this prospect has me rather excited despite the fact that I can't really run full E85 and hope to hit stock boost levels.
That said, I went ahead and decided to test anyways. I picked up the last two bottles of this shit:
Amazon.com: Red Line (60103) Complete SI-1 Fuel System Cleaner - 15 Ounce: AutomotiveAmazon.com: Red Line (60103) Complete SI-1 Fuel System Cleaner - 15 Ounce: Automotive
Then I drove around to use up as much of the last quarter tank of E26 I had left would allow and put a full bottle of the cleaner in with 7.5 gallons of corn.
If I recall correctly, I've not cleaned my pump since the last time I tried full E and had the spillvalve stick on me, and I have not had any issues as of yet (but I've just started this test, so time will tell. IDCs are currenly in the low 90s on spring pressure (10.6 ish peak PSI), but airflow is fucking incredible. I'm about 6 G/S lower on the EFR with full E85 @ 10.6 PSI than I was on the K04 with 50/50 mix and 15.8 PSI and the same BATs.
I may try and get another PSI or two out of the turbo to kick airflow up a bit more and max out the fuel system just to see what it will do, but that might be tricky due to how the EBCS responds.
I realize this isn't exactly apples and oranges, but I was maxing the K04 out pretty hard to get the numbers below out of it.
As a side note, I ran into the super lean midrange issue again; 15:1 AFRs but with no KR until after 6k (when AFRs had stabilized already).
Enki is offline
The Following 9 Users Say Thank You to Enki For This Useful Post:
Constantin (03-22-2014), cshunter (03-23-2014), El_Diablo (04-01-2014), Hush (03-22-2014), killer-ms3 (03-22-2014), littleloogy (03-22-2014), Mauro_Penguin (03-23-2014), Tokay444 (03-22-2014), udntknw (03-22-2014)
 Old 03-23-2014, 01:14 AM   #565
Enki's Avatar
Groans: 189
Sad Christmas. Pressure went in and out multiple times, including having only ITFP pressure upon cold start. I'll pull and clean the pump, but if it goes out again after that I'm afraid I'm done with the testing; hopefully others will have better luck and my car is simply cursed.
Logs and vdyno attached.
Enki is offline
 Old 03-23-2014, 01:44 AM   #566
That's not what I wanted to hear. Yeah, clean the internals and see what happens. I am curious why your having pressure drop @ 50/50. Shit is working flawlessly for me.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
 Old 03-23-2014, 02:04 AM   #567
cshunter's Avatar
Posts: 1,312   (View Stats)
cshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the worldcshunter is the leader of the world
Groans: 28
Maybe your car got contaminated with some unicorn jizz when it was made...lol
Tho I hope enki get his straighten out.
Sent from my Evil Nexus 5
2013 CWP That's slow
2012 LSM Totaled by an asshole red light runner
Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )
Previous: MILTUNED E85 K04
cshunter is offline
 Old 03-23-2014, 02:08 AM   #568
Enki's Avatar
Groans: 189
I'm not on 50/50; 2 oz sauce to 1 gal e85 is what I have in the tank right now.
Enki is offline
btstarcher (03-23-2014), El_Diablo (04-01-2014), littleloogy (03-23-2014), PapaSmurf (03-23-2014)
 Old 03-23-2014, 09:05 PM   #569
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
Possibly it only works with redline oil? Or atleast not what your currently using.
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 03-23-2014, 09:54 PM   #570
Enki's Avatar
Groans: 189
There might be some truth in that. I'm on RP oil, but other oils are going to be (or currently are being) tested.
Enki is offline
El_Diablo (04-01-2014), littleloogy (03-23-2014), Mauro_Penguin (03-26-2014), PapaSmurf (03-24-2014)
 Old 03-23-2014, 11:11 PM   #571
What flavor E are you running? Do you think one brand can have a different effect on oil then another brand? I have not had sticky internals until I went on this road trip. Maybe my car got a STD form all the different pumps.
 Old 03-23-2014, 11:47 PM   #572
Enki's Avatar
Groans: 189
Shell pumps/store, Western Petroleum. Neighbor down the street says when he hydro tested (using the mix and shake cylinder tester thingy) one of the pumps I frequent (as early as 3 weeks ago) tested at 85% ethanol by volume.
Enki is offline
littleloogy (03-24-2014), Mauro_Penguin (03-26-2014)
 Old 03-24-2014, 01:58 PM   #573
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Houghton or Sahuarita?
Just tapa it in.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline
 Old 03-24-2014, 02:52 PM   #574
This makes me curious also. The ingredients could be different, sugar can also be used to make E. I'm wondering if certain brands make E differently, and with chemicals that react to oil better/worse with certain oils. Might have to put my chemistry lab coat back on...
Sent from a Galaxy far far away...
 Old 03-24-2014, 03:20 PM   #575
PapaSmurf's Avatar
Groans: 112
I am pretty sure there is a company in the US that does supply Sugarcane Ethanol. Most is said to be corn, but I have heard from people that sugarcane ethanol is also available in the US.
hard to find which companies distribute to what gas stations etc.
860whp/677wtq
2.7 V6 Ecoboost
 Old 03-24-2014, 03:39 PM   #576
Yes. Pacific Ethanol, Madera, CA http://www.pacificethanol.net/
 Old 03-24-2014, 03:42 PM   #577
Enki's Avatar
Groans: 189
Just tapa it in.
I think he got his last from Houghton, I got mine from Sahaurita. Pretty sure my pump is at least half the problem though.
Enki is offline
 Old 03-25-2014, 04:15 PM   #578
Enki's Avatar
Groans: 189
OK so, some interesting news.
First off, the spill valve was sticky as fuck; no real surprise there. What was surprising, however, is that the sticky came off without having to be actually cleaned out; simply handling the disassembled parts ended the sticking of the spill valve. Even more interesting is that normally, cleaning sticky death off of shit (using rags/paper towels) usually leaves your hands/fingers sticky as well. Not this time.
I did wind up actually cleaning the button valve retainer (the part you take out after the spill valve) just to be safe, since the sticky didn't rub off of that. I'm assuming it's because I let it dry, whereas the other parts still had corn on them.
As a result, my current observations/hypothesis about the Redline fuel injector cleaner are as follows:
1. It actually does a quantifiable "thing" to improve conditions that lead to the formations of at least the sticky death (long term testing needed for black death on the internals)
2. Your testing results *may* be skewed if you already have a pump full of sticky, since it can't seem to actually remove the sticky coating but can lubricate/prevent sticky interference from taking place (helps with already sticky cars)
I have to note that points 1 and 2, while carrying my personal thumbs up, may not be entirely accurate. The simple fact of the matter is we need more test data to either support or debunk both claims.
As a side note, I also did the spill valve spring mod v2, and it gave me some interesting results...It partially stuck in a position that forced maximum pressure development between shifts initially:
Yes, it felt as strange as it looks; like I had a new rev limit of 4k. It didn't do this every time, btw.
Enki is offline
The Following 8 Users Say Thank You to Enki For This Useful Post:
Code Monkey (03-25-2014), Dano (03-28-2014), El_Diablo (04-01-2014), littleloogy (03-25-2014), Mauro_Penguin (03-26-2014), PapaSmurf (03-25-2014), Realgib3 (03-27-2014), SpeedEngineer (03-26-2014)
 Old 03-28-2014, 12:00 AM   #579
Enki's Avatar
Groans: 189
Well shit. Go get fueled up for the monthly trip to Phoenix. No problem there.
Flash back to E26 map since I still don't fully trust full E85 in my car yet. So far so good.
Go to check tire pressure, get up to the driver's front tire and the area reeks of fuel. REEKS. Fuck.
Pop the hood, check things out, bottom of pump and hard line is covered in fuel diluted oil. COVERED. No clue what's up, but I'm sure it ain't good.
Probably time to get a new pump and hard line after all, but tomorrow will tell for sure.
Enki is offline
El_Diablo (04-01-2014), JgamB (03-28-2014), Mauro_Penguin (03-28-2014), Mochi (03-28-2014)
 Old 03-28-2014, 12:04 AM   #580
JgamB's Avatar
Posts: 2,566   (View Stats)
The only thing I can think of that would allow that much oil to pass would be the primary O-ring that slips into the valve cover. Those tiny little quad rings barely qualify as a barrier to oil. Hopefully that's all it is, sorry to hear the shitty news.
JgamB is offline
The Following User Says Thank You to JgamB For This Useful Post:
 Old 03-28-2014, 12:11 AM   #581
Enki's Avatar
Groans: 189
You mean around the valve cover itself? I don't think that's it as there's no oil above the bottom of the pump; there's a ton going down/on the hard line and a pool under the pump that I'll try to get pictures of tomorrow morning during some diagnostics.
Enki is offline
 Old 03-28-2014, 07:52 AM   #582
crutch77's Avatar
Posts: 493   (View Stats)
crutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the world
I think he may have been talking about this o-ring. It's the first thing I thought of:
2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it)
crutch77 is offline
The Following User Says Thank You to crutch77 For This Useful Post:
JgamB (03-28-2014)
 Old 03-28-2014, 08:19 AM   #583
I have another hpfp core if you need it, In case its fucked.
 Old 03-28-2014, 10:58 AM   #584
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
I have new and used hardlines if you end up wanting one.
Etipp98 is offline
The Following User Says Thank You to Etipp98 For This Useful Post:
 Old 03-28-2014, 11:17 AM   #585
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
hey stEnki. Why don't you have a check valve in the factory PCV system? That's why your crankcase is getting pressurized dude. Stock PCV can't handle the type of boost you're running, it's destroyed it.
07 MS3
The original Genpoo Hater
Chimmike is offline
himurax13 (03-29-2014)
 Old 03-28-2014, 08:39 PM   #586
Enki's Avatar
Groans: 189
Hey gingerbike, 20 psi is a lot? That's news to me, considering I was running that stock turbo (/sarcasm). I know what I need to fix that, but I don't want to spend the money or time to do it anytime soon.
On topic: Turns out it was the hardline nut (again). Torqued the fuck out of it and the area around the pump was dry after I got to phoenix; no new oil/residue or anything. Last time I tightened it, I was pretty sure I went too far and now I'm about a half turn past that. Gonna see how long it holds up though.
Enki is offline
 Old 03-28-2014, 08:45 PM   #587
Enki's Avatar
Groans: 189
Oh and btw, this is what it looked like at 8 AM this morning:
Enki is offline
btstarcher (03-28-2014), littleloogy (03-28-2014), Mauro_Penguin (03-31-2014)
 Old 03-29-2014, 01:45 AM   #588
Make sure the fuel does not splash on your BT, that would be no good. I'm glad you caught it! You could have had a bad time.
Enki (04-05-2014)
 Old 04-05-2014, 03:58 PM   #589
Enki's Avatar
Groans: 189
I'll be the first to admit that I'm complete shit when it comes to straight line racing, but I went out and did some spur of the moment today anyways.
Met up with a non-NATOR MS6 (Utah plates) belonging to a stepson of one of the SRT4 guys (former MS3 owner) that I've met since I started doing the whole car meet thing several years ago. Anywho, I gave him some basic advice on drag racing so he didn't break shit (he's almost completely stock, sans SRI and TIP) and he improved very rapidly. My second and fourth time slips have him in the right lane, for those that care; I'm left lane in every slip.
I've got logs and videos of the first three runs, but forgot to do the fourth as I was in a bit of a hurry. My goal was to get > 105 MPH and that's what I did; there's still a fair amount left in the car as far as power goes, and I'm confident that a *good* driver ( @udntknw; ) could easily abuse my car into the high 12s; though I'm not sure if that will ultimately require WMI (which I still need to finish installing).
At any rate, the car is running well, and even though drag strip shit ain't really my bag, it was entertaining.
Enki is offline
Code Monkey (04-05-2014), m.a.vega1 (04-13-2014), Mauro_Penguin (04-06-2014), OverBoosted (04-05-2014), wolly6973 (04-05-2014)
 Old 04-05-2014, 08:12 PM   #590
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Lol "drag isn't my thing" >> is building a drag Falcon. Admittedly auto doesn't need for it to be your thing to do it.
Bone stock so far
Darth_Nuruodo is offline
 Old 04-05-2014, 09:06 PM   #591
Enki's Avatar
Groans: 189
Uh, who said anything about me building a drag racing Falcon?
Enki is offline
Easter Bunny (04-08-2014), Mauro_Penguin (04-06-2014)
 Old 04-05-2014, 09:53 PM   #592
bmylez's Avatar
Posts: 3,197   (View Stats)
bmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the worldbmylez is the leader of the world
Groans: 31
Groaned at 36 Times in 28 Posts
Sorry, Enki can't hear you over the sound of his 400whp daily driver and soon-to-be 1200+ whp weekend car.
2007 CTS-V - Trying to sell
2009 CTS-V - Not getting a cam. Ever.
bmylez is offline
The Following 4 Users Say Thank You to bmylez For This Useful Post:
btstarcher (04-06-2014), Enki (04-05-2014), Mauro_Penguin (04-06-2014), udntknw (04-06-2014)
 Old 04-13-2014, 05:26 PM   #593
Enki's Avatar
Groans: 189
Should have the WMI install finished/wired and tested this upcoming week. Here's some pics of the BPV dissection from today; basically waiting for the RTV to set before I do anything else.
Nozzle will be mounted on the black blockoff plate in the first picture, which I'm aware isn't ideal but it will be sleeper with the stock BPV hiding it. I'll eventually get some hose on the outlet and probably finish the wiring before long.
I *do* need one of those vac blocks, though Full-Race wants $50 + another 30 ish in shipping so I'll probably see what I can get from Edge or another source.
Enki is offline
btstarcher (04-14-2014), Mauro_Penguin (04-14-2014), udntknw (04-14-2014), WetzMS3 (04-15-2014)
 Old 04-15-2014, 06:31 PM   #594
Enki's Avatar
Groans: 189
Pics of plumbed (but not wired) sleeper meth.
WetzMS3 likes this.
Enki is offline
btstarcher (04-15-2014), Code Monkey (04-20-2014), ItsNox (04-16-2014), littleloogy (04-15-2014), Mauro_Penguin (04-19-2014), Micha (04-20-2014), phate (04-15-2014), Realgib3 (04-16-2014), udntknw (04-15-2014), WetzMS3 (04-15-2014), wolly6973 (04-16-2014)
 Old 04-16-2014, 02:13 PM   #595
Enki's Avatar
Groans: 189
Chatted with @Ziggo; last night regarding load tuning, figured I'd give it another shot.
Didn't go so well.
The only thing I can think of is the .95 injector phasing that's set on this map that isn't elsewhere; if this test doesn't go well then I'm probably just going to go back to boost tuning.
Enki is offline
btstarcher (04-16-2014), littleloogy (04-16-2014), Mauro_Penguin (04-19-2014), Micha (04-20-2014), WetzMS3 (04-16-2014)
 Old 04-16-2014, 02:41 PM   #596
Enki's Avatar
Groans: 189
Made the change, tested it, still running low 14s AFR.
Compared MAF tables and realized that the load tune one was calibrated rich, likely to try to curb some of the leanness...replaced with MAFCAL from the destro tune, and tripled my boost overrun WGDC comp (underrun still zeroed).
Gonna give this one last shot...
Enki is offline
 Old 04-16-2014, 03:23 PM   #597
Enki's Avatar
Groans: 189
Little better...Going to try dropping load target to 1.5 and see how it responds/runs. Not sure if I'll have time to flash and run today or tomorrow; might have to be Friday.
I know that high bats are killing my ability to hit my 2.0 load target, so I may not be able to without the meth spraying.
Enki is offline
btstarcher (04-16-2014), littleloogy (04-16-2014), Mauro_Penguin (04-19-2014), Ziggo (04-16-2014)
 Old 04-16-2014, 06:40 PM   #598
Enki's Avatar
Groans: 189
Think I have this figured out. I converted all load targets to 1.5, including dropping the Calc Load Max A and B to the same; issue got worse, and peak load dropped to 1.23 @ 20 PSI/almost 4 volts and 320 g/s flow @ 5k rpm...way, way off from what it should be.
I then loaded up the boost map and it ran like a champ; no issues.
Started comparing tables and came across the max load table which I guess I didn't comprehend fully what it was for and realized I was setting my own personal load cap, nor did I realize that this is what the result would be from setting that table too low.
I've got it set the same as my boost tune now (5.0 load max) so that should take care of it if I'm not totally retarded. Still not sure why it won't go over 1.23 load when everything else is set for 1.5 though.
Hopefully I'll have a chance tomorrow to test it out.
Enki is offline
btstarcher (04-16-2014), Mauro_Penguin (04-19-2014), Micha (04-20-2014)
 Old 04-16-2014, 07:59 PM   #599
Enki's Avatar
Groans: 189
I'm still retarded, but this fixed it. Some more tweaking and I should be good to go.
Enki is offline
btstarcher (04-16-2014), ItsNox (04-16-2014), Mauro_Penguin (04-19-2014), Ziggo (04-17-2014)
 Old 04-16-2014, 10:24 PM   #600
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
Good stuff. I just started trying to load tune and everything is looking similar to my boost tune. Except I am not on E85 and things are heating up these days!
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f541/enki-s-efr-ordeal-157429/
borgwener turbos ? Mazda MPS Owners Club This thread Refback 04-13-2015 04:01 PM
turbo fitment ? Mazda MPS Owners Club This thread Refback 02-14-2015 02:19 PM
Turbo ? Mazda MPS Owners Club This thread Refback 02-12-2015 08:41 AM
BT path help This thread Refback 12-27-2013 05:04 PM
Video: Washington State bridge collapse victim talks about his ordeal Haltech Automotive News 2 05-24-2013 10:00 AM
Report: Good Samaritan motorists box in man driving with girlfriend on hood, end ordeal safely Haltech Automotive News 0 09-26-2012 06:20 AM
Page generated in 0.62985 seconds with 32 queries
