| MazdaSpeed 3/6 - Build Diaries MazdaSpeed 3/6 - General Build Threads/Diaries |
![]() | | #601 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Until then, might as well post vdyno updates to here too. Attached is OTS Stg 2 on spring pressure and without VVT; slow as balls with an 8.5 second 60-100.
__________________ |
| The Following 6 Users Say Thank You to Enki For This Useful Post: | Code Monkey (04-30-2014), ItsNox (04-20-2014), littleloogy (04-20-2014), Mauro_Penguin (04-21-2014), Micha (04-20-2014), wolly6973 (04-21-2014) |
![]() | | #602 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score OK I'm officially at a loss here guys. I've been told that I should be able to go past 2.5 load without having to use supplemental fueling, but every time I breach 2.5 load my AFR tanks and I get a misfire or sputter frequently. I just regapped the plugs to .024 and the issue persists; any input would be appreciated.
![]() | | #603 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score What's your afr target? It wanders quite a bit in that log. What happens if you bring boost down? You are approaching 120% IDC. Oh, and that turbo flows some air!
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
![]() | | #604 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score AFR target is 11.6; I previously calibrated for 11.4 so it's off a bit and leaning it out on the MAF only resulted in yet more strangeness... I leaned the curve out from 3 volts to 5 volts by 6%, which resulted in near perfect 3rd gear AFR targets, but now my fuel pressure is dropping for apparently no reason at all, and BATs are killing my airflow.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Boost_creep (04-30-2014), littleloogy (04-30-2014) |
![]() | | #605 | ![]() |
| Not Ranked : 0 score Are you running an e-mix on this setup?
![]() | | #606 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Make your commanded AFR tables (knocking) same as the rest. Never mind I think you already did this...
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
| The Following User Says Thank You to Etipp98 For This Useful Post: | udntknw (04-30-2014) |
![]() | | #607 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score E29 I have not done this yet, nor have I ever done this. Issue only happens past 2.5 load, but I'm going to try some other things here soon after work and see if they help.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #608 | ![]() |
| Not Ranked : 0 score Are you using the injector control tables for E29, or maf scaling? I think etipp is asking in reference to this thread: AFR targets at loads higher than 2.50 ATR/ATP fix
| The Following 3 Users Say Thank You to Boost_creep For This Useful Post: |
![]() | | #609 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Well shit. I'll give this a shot and see if my new changes on top of this have any impact.
| The Following User Says Thank You to Enki For This Useful Post: | Mauro_Penguin (05-09-2014) |
![]() | | #610 | ![]() |
| Not Ranked : 0 score Oh so now you listen...... Yeah, using the injector scalars to adjust for E85 mixes doesn't work well on big turbo cars for some reason. Sent from my SAMSUNG-SGH-I747 using Tapatalk
| The Following 3 Users Say Thank You to Ziggo For This Useful Post: |
![]() | | #611 | ![]() |
Groans: 189
So I'll be doing that, probably getting back on the map/wiki from where I left off maybe Sunday.
__________________ | |
![]() | | #612 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Half a day off work, a 5 hour "nap" and 10 minutes of backtracing my maps for the wiki and I figured out where I went wrong. Thanks to @Ziggo; and @Captain KR; for screwing my head back on straight and helping me find my fuckup.
| The Following 5 Users Say Thank You to Enki For This Useful Post: | btstarcher (05-02-2014), Captain KR (05-02-2014), littleloogy (05-01-2014), Mauro_Penguin (05-09-2014), wolly6973 (05-02-2014) |
![]() | | #613 | ![]() |
| Not Ranked : 0 score Things to do when going above 2.50 load. Some or all may fix the issue: - Rescale your MAF table as the WOT fuel scaling parameters stop working past 2.50 load - Do not use injector scalars - Set all fuel tables the same Finally, going above 112 IDCs has shown to start destabilizing combustion and cause it to go lean and misfire.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 10 Users Say Thank You to Lex For This Useful Post: | Boost_creep (05-02-2014), BrianB6 (05-16-2014), Enki (05-02-2014), JgamB (05-02-2014), littleloogy (05-02-2014), Mauro_Penguin (05-09-2014), Nitr0EngiE (05-08-2014), udntknw (05-02-2014), wolly6973 (05-02-2014), Ziggo (05-02-2014) |
![]() | | #614 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score So minor update time. Hitting a peak of 2.4 load and >4.07 volts with only 75% WGDC on a 10 PSI spring (peaking 19 PSI, leveling to 18 by redline). Not flowing as much as I thought I was, but I guess that means what I thought was wrong (when I realized my mistake) was the answer after all. I've pulled another 2% MAF flow on the next map from 4v on and re-smoothed the transition to compensate for the tapering richness, but it's running a LOT better now. Also, this map had only 6 degrees timing up top; the next log/dyno will have double timing and 20 PSI boost to see what I get from it.
| The Following 5 Users Say Thank You to Enki For This Useful Post: | Boost_creep (05-02-2014), Easter Bunny (05-02-2014), JgamB (05-02-2014), littleloogy (05-02-2014), Mauro_Penguin (05-09-2014) |
![]() | | #615 | ![]() |
Groans: 793
| Not Ranked : 0 score That's got to be getting pretty hot in the egt department.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | Enki (05-03-2014), Mauro_Penguin (05-09-2014) |
![]() | | #616 | ![]() |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score 270 whp with 6 degrees. lol. Tappin'
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
| The Following 2 Users Say Thank You to Dimenus For This Useful Post: | Enki (05-03-2014), Mauro_Penguin (05-09-2014) |
![]() | | #617 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Not sure if I can call this progress or not; you guys can be the judge. 12 deg timing @ 6500 (about half my last known MBT) AFR dipping 11 flat Fuel pressure tanking to 1300s 20.8 PSI peak 2.58 load peak 4.21 MAF volts peak 412 g/s flow peak (on new MAFCAL) Still missing/misfiring but not as bad. Vdyno was with passenger ( @johnnyboy05gt; ) so fat driver + passenger mod accounts for the weight. Gonna try leaning it out to 11.75 tomorrow and see if that helps fuel pressure a bit. Stay tuned.
![]() | | #618 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score 6 degrees comes in at 6500. Peak power only had 4.5.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Dimenus (05-03-2014), Mauro_Penguin (05-09-2014) |
![]() | | #619 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Update time! Leaned out fueling targets to 12:1 with no other changes; hit similar voltages/flows and very little sputter (single misfire or so) in 4th gear uphill pull. Map still has 12 degrees timing @ 6500 RPM peak, but the numbers look MUCH better. Fuel pressure looks to be dropping off past 2.45 or so load between 4.01 and 4.08 volts so I probably need to lean that range a bit in the calibration. Thoughts on this log @Ziggo; @Lex; @phate;? Is this an actual out of fuel scenario or is there something wrong mechanically?
![]() | | #620 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Guessing I do have a hardware issue, and I think I might know what it is. I'm thinking my HPFP return spring might be getting soft as it seems the hotter the car is the more pronounced my fueling issues are; the following is a snippet of a log that was taken after cruising around town running errands and doing a third gear pull (AC was used but turned off for the pull): ![]() Here is the analysis from attempted reproduction; note that the log was taken from the same logging location both times with only time spent letting everything heat up real good (mid RPM driving w/ AC on): Mid-Temp Run: Oil Temp (gauge): ~177 First Sub-1600 cell AFR: 11.76 BAT: 133 Boost: 20.24 MAF Flow: 327.94 Load: 2.35 HPFP PSI: 1497 RPM: 5308 Lowest Sub-1600 cell Same as above High Temp Run: Oil temp (gauge): ~210 First Sub-1600 cell: AFR: 11.76 BAT: 115 Boost: 19.3 MAF Flow: 225.17 Load: 2.32 HPFP PSI: 1574 RPM: 3850 Lowest Sub-1600 cell AFR: 11.47 BAT: 117 Boost: 20.02 MAF Flow: 351.92 Load: 2.47 HPFP PSI: 1204 RPM: 5411 Third log was taken on the return trip going uphill after oil temps dropped back down to the 180s from non-AC driving a short distance. Anyone have a line on a package deal for new HPFP + new internals + new hardline + new rail valve?
![]() | | #621 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score I wonder if you can buy Corksports spring for their internals? They offer a stiffer return spring. I am wondering if you are floating your pump. I had to get stiffer springs for my Briggs Flathead. I could not go passed 6,000 RPMs without floating my valves down the straightaways. A spring can only return so fast... Sent from my SAMSUNG-SGH-I747 using Tapatalk |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Enki (05-04-2014), Mauro_Penguin (05-09-2014) |
![]() | | #622 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score That's a great idea, but it might also be tolerances. I'll contact @CorkSport; tomorrow and see if they will sell me a spring.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | littleloogy (05-04-2014), Mauro_Penguin (05-09-2014) |
![]() | | #623 | ![]() |
| Not Ranked : 0 score Might just want to test a couple stock springs for their rate against yours. If the spring is compromised, a good stocker would probably fix it. I turn a couple more rpm than you and haven't seen issues, yet.
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() | | #624 | ![]() |
Groans: 189
Are we at the point where we can buy individual parts for the pump finally?
![]() | | #625 | ![]() |
| Not Ranked : 0 score I have a few stock springs here if you want to compare them to your spring. I have been searching everywhere, even the UK for replacement parts for our pumps. Whoever decided not to allow parts to be sold individually should be branded an asshole. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #626 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score UOA came back; engine is apparently in great shape. Despite the sample from this oil change being done at the more than 6 month mark, Blackstone recommends I extend the interval further. Guess I'll do my next oil change in December or January.
| The Following 5 Users Say Thank You to Enki For This Useful Post: | btstarcher (05-05-2014), CorkSport (05-08-2014), littleloogy (05-05-2014), Mauro_Penguin (05-09-2014), Realgib3 (05-05-2014) |
![]() | | #627 | ![]() |
| Not Ranked : 0 score This is excellent news. I was really worried I was going to see a "Enki's engine rebuild Ordeal" pop up. Sent from my SAMSUNG-SGH-I747 using Tapatalk |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Enki (05-05-2014), Mauro_Penguin (05-09-2014) |
![]() | | #628 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score So, I've heard back from both companies, and here are the results: Autotech states that they make all their internals to the same tolerance, so they won't be able to sell me a "loose" set. They would, however, check out the internals to make sure they are to spec with no issues if I could survive on a set of stock or otherwise internals for the time being. @CorkSport; told me they didn't have any "spare" upgraded springs but that they would happily send me a stocker or two at no charge. Of course, I took them up on that offer. Thanks guys!
| The Following 6 Users Say Thank You to Enki For This Useful Post: | Boost_creep (05-07-2014), Code Monkey (05-12-2014), Easter Bunny (05-08-2014), himurax13 (05-09-2014), ItsNox (05-07-2014), Mauro_Penguin (05-09-2014) |
![]() | | #629 | ![]() |
| Not Ranked : 0 score Just going back on what you already determined but losing pressure at that flow rate and engine RPM does point to a hardware issue. The pump should flow plenty at that RPM to support that flow rate.
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #630 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
Groans: 52
| Not Ranked : 0 score Yeah I had this issue way back when and it was just my KMD's going bad. The heat just caused them to bind more so pressure loss got worse and worse and I ran it harder. |
| The Following 3 Users Say Thank You to Realgib3 For This Useful Post: |
![]() | | #631 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Well if my spring isn't bad compared to one of the ones I'm getting from CorkSport, I may be buying a new set of internals and having my existing Autotechs shipped back for analysis. I'm weary of trying the CorkSport internals as they are inclined to build pressure more aggressively, but I'm running an aftermarket 2075 relief valve so that results in fuel cuts when out of boost on a stock fuel pressure table....Which I already know how to tune around, so I guess that makes the issue moot.
![]() | | #632 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Looks like I'm going to need new HPFP internals; I'm going to contact Autotech with the attached pictures to see how they want to handle this issue or if I'm up shit creek. No clue how this happened or why, or even why it's only an issue at higher temperatures. Also, I need a hard line as mine started to twist (but doesn't appear damaged) when I was taking it off, so car is out of commission for a bit while I get that all sorted as well. If anyone knows where I can get a brand new hardline (sans pump), please let me know. If the only way to get a hardline is with the pump, then I guess I'll have to go that route. Side note: when I took the spring off the pump, it was > 1mm compressed compared to the one @CorkSport; sent (thanks again!), though it's currently sitting at .4 MM shorter. Unfortunately, I can't really tell if one is stronger than the other due to girly typist hands, so that's still up in the air.
| The Following 6 Users Say Thank You to Enki For This Useful Post: | btstarcher (05-12-2014), cocoanton (05-12-2014), ItsNox (05-15-2014), littleloogy (05-12-2014), Mauro_Penguin (05-19-2014), Realgib3 (05-12-2014) |
![]() | | #633 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Hard line orderd. Thanks @Etipp98;! Pending purchase of new pump and word back from Autotech on my current internals.
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #634 | ![]() |
![]() Join Date: Feb 2012 Location: Atlanta, GA
Rep Power: 5063 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,719
| Not Ranked : 0 score I am in a similar situation as yours except I get random drops in fuel pressure as heat builds up. I also think it is a hardware issue. I just got a new ITFP installed and got a used stock HPFP and installed CS internals, will head to the track this weekend and report back if I still have misfires.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 05-12-2014 at 10:39 PM. |
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Enki (05-12-2014), Mauro_Penguin (05-19-2014) |
![]() | | #635 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Pump ordered/paid for. Just waiting on Autotech's response. If I don't hear back from them by noon ish tomorrow, I'll probably just order a set from Edge or something.
![]() | | #636 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Stock HPFP probably shipped yesterday, and new internals from Edge are shipping today. Still no word from Autotech.
| The Following 6 Users Say Thank You to Enki For This Useful Post: | Code Monkey (05-14-2014), ItsNox (05-15-2014), JgamB (05-14-2014), littleloogy (05-14-2014), Mauro_Penguin (05-19-2014), SarcasticOne (05-14-2014) |
![]() | | #637 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Thanks to @Etipp98; for the brand new hardline! Still no word from Autotech even after a second email. I'll have to try to contact someone else in the company I guess. Pump and internals should be here tomorrow sometime; I'm going to try to get the hardline installed today though, work permitting.
![]() | | #638 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Autotechs just arrived (Thanks, @EdgeAutosport.com;!) and I've finally heard back from Autotech themselves. They are more than willing to send me a new set, or send that set to Edge for a refund (which is what I'll be doing). Hopefully that replacement stock pump arrives today sometime soon...I've been itching to get back out on the road.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Mauro_Penguin (05-19-2014), Ziggo (05-16-2014) |
![]() | | #639 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score ![]() VDyno and 3rd gear log attached; oil temps ~214. Might be time to put the bigger WGA back in.
| The Following 6 Users Say Thank You to Enki For This Useful Post: | CorkSport (05-20-2014), Darth_Nuruodo (05-17-2014), littleloogy (05-16-2014), Mauro_Penguin (05-19-2014), Snyeed (05-16-2014), udntknw (05-16-2014) |
![]() | | #640 | ![]() |
| Not Ranked : 0 score Woot woot! Sent from my SAMSUNG-SGH-I747 using Tapatalk |
| The Following User Says Thank You to littleloogy For This Useful Post: | Enki (05-16-2014) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f541/enki-s-efr-ordeal-157429/ | ||||
| borgwener turbos ? Mazda MPS Owners Club | This thread | Refback | 04-13-2015 04:01 PM | |
| turbo fitment ? Mazda MPS Owners Club | This thread | Refback | 02-14-2015 02:19 PM | |
| Turbo ? Mazda MPS Owners Club | This thread | Refback | 02-12-2015 08:41 AM | |
| BT path help | This thread | Refback | 12-27-2013 05:04 PM | |
| Video: Washington State bridge collapse victim talks about his ordeal | Haltech | Automotive News | 2 | 05-24-2013 10:00 AM |
| Report: Good Samaritan motorists box in man driving with girlfriend on hood, end ordeal safely | Haltech | Automotive News | 0 | 09-26-2012 06:20 AM |
