Like Tree141Likes
 Old 07-12-2014, 07:32 AM   #681
ST_Fan's Avatar
Posts: 10   (View Stats)
ST_Fan has much to be proud ofST_Fan has much to be proud ofST_Fan has much to be proud ofST_Fan has much to be proud ofST_Fan has much to be proud ofST_Fan has much to be proud ofST_Fan has much to be proud ofST_Fan has much to be proud of
I'm new around here but thanks for posting this thread @Enki;
Just read all 68 pages(the testy exchanges were very entertaining, you don't get too much of that on the ST Forums)
You have a nice build going. I'm doing the same build on my ST and this gives me a little insight into what I'm up against next week.
I'm going with a Forge Actuator red spring I think, but you have me thinking about sticking with the MB canister that comes with the turbo to start even though BW recommends the high boost canister.
ATM I'm running a D05 nozzle 50/50 for cooling only on the k03. Plan to run a Stratified failsafe for boost cut once I run out of fueling on the 6758.
Just curious about the 7163 if you are running out of fueling now, how would you fuel the the bigger turbo if you went that route? Meth or 5th port(we don't have this yet) ?
Unleashed 93B(Awesome!) | Unleashed W/M I | E-Focus Roll Restrictor(RMM) | K&N Air Filter | JBR Solid Shifter Bushings | Eibach ProKit Springs | Cobb STS 40% | JBR BSD(waiting for next oil change) | Avant Garde M310 18x8.5 42OS | BFG KDW's | Levels FMIC | Redline Tuning Hood Struts | Ford Power Button | OCD Cold Side | CP-E Hot Side | FRPP CAI | Rallyarmor Flaps | AVS Rainguards | Boomba Black BOV | MBRP 304 XP Series 3" TB | Steeda Symposer Delete
ST_Fan is offline
The Following 4 Users Say Thank You to ST_Fan For This Useful Post:
btstarcher (07-13-2014), Easter Bunny (07-13-2014), Enki (07-12-2014), Mauro_Penguin (07-13-2014)
 Old 07-12-2014, 08:36 PM   #682
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
I'd actually only run the 7163 to hold the boost out further up the rev band, and potentially faster spool. The increase in map efficiency would also lend quite nicely to slower heatsoaking of the TMIC, thus making WMI more effective post-intercooler.
Keep in mind that the bigger turbo you run, the less boost you need to flow the same air (relatively speaking; this isn't entirely accurate due to the number of variables in play, but you get the idea).
Enki is offline
Code Monkey (07-12-2014), Easter Bunny (07-13-2014), Mauro_Penguin (07-13-2014), ST_Fan (07-13-2014), wolly6973 (07-13-2014)
 Old 07-12-2014, 09:08 PM   #683
ST_Fan's Avatar
Thanks for the response. From what I understand of the 7163 should have similar spool to the 6758 which is crazy.
Yeah 7163 < hairdryer..
6758 > hairdryer..
At least for the ST, the 7163 may be my go to once Kosmic releases a 5th port and I'll be able to run E30 on the bigger turbo.
Filling the meth tank has been annoying, I've ran it out of the washer tank for the past year with the pump almost maxed out on the D06. 1 Cruz night and 2 fill-ups sucks. Just don't want to give up my hatch room to a bigger tank.
Anyway subbed..
You guys got some cool shit goin on here
ST_Fan is offline
The Following 3 Users Say Thank You to ST_Fan For This Useful Post:
Easter Bunny (07-13-2014), Mauro_Penguin (07-13-2014), wolly6973 (07-13-2014)
 Old 07-13-2014, 01:03 AM   #684
Enki's Avatar
Groans: 189
The 6758 running 23 psi @ 6500 RPM sees about the same rise in boost temps as a K04 @ 16 PSI @ 6k RPM.
As for giving up hatch room, you don't have to. You saw my sleeper meth setup, yes?
Enki is offline
 Old 07-13-2014, 10:43 AM   #685
ST_Fan's Avatar
Yeah, definitely sleeper. Very clean.
Where'd you obtain that nice tank?
Pic of my pump mounted on the frame under the airbox. Cut a hole in the airbox so I can make quick adjustments at the track. Just need a flowmeter failsafe and a tank like u have and GTG..
Custom cold side with bung welded in:
ST_Fan is offline
 Old 07-13-2014, 01:46 PM   #686
Enki's Avatar
Groans: 189
This is the tank in question:
Water Alcohol Methanol Ethanol Injection Systems
Though mine was a bit less because I had them ship it with the hose setup rather than a fill cap setup like pictured.
Enki is offline
Mauro_Penguin (07-14-2014)
 Old 07-13-2014, 05:53 PM   #687
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Not at all familiar with the location of the throttle body etc on the st but I would think it wouldn't be that hard to adapt a MS3 5th port kit to work on the focus
I hugged rfinkle2
Easter Bunny is offline
 Old 07-13-2014, 06:19 PM   #688
ST_Fan's Avatar
The throttle body is vertical and centered on the manifold. The MS3 5th port from Kosmic should work with a little fanagling from a hard parts perspective. The problem is the ST is MAP based, no MAF. The only way to command the correct fuel would be off a boost reference. This is also how the meth system works.
I may end up building my own system if they don't do something soon. We are out of fuel like you guys were which is partly why I'm here.
If someone knows where I could get a 5th port boost reference controller would be very helpful..
ST_Fan is offline
The Following User Says Thank You to ST_Fan For This Useful Post:
 Old 07-13-2014, 06:44 PM   #689
Raider is mah Homie
Groans: 2,978
That does complicate things a little.
I hugged rfinkle2
 Old 07-13-2014, 07:30 PM   #690
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Probably easier just to integrate a denso type maf sensor into the system with a treadstone like adapter. I'll take maf tuning over speed density any day of the week.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
Enki (07-13-2014), Mauro_Penguin (07-14-2014), ST_Fan (07-13-2014), wolly6973 (07-13-2014)
 Old 07-13-2014, 08:25 PM   #691
ST_Fan's Avatar
I was actually thinking about this for the first time today. It would be a funky hybrid system. May end up being my best DIY option.
ST_Fan is offline
 Old 07-13-2014, 08:41 PM   #692
Ziggo's Avatar
Posts: 3,843   (View Stats)
The AIC can be done speed density based as well. It's just a simple RPM vs Voltage table. With a MAF based voltage source you can mostly ignore the rpm axis and just set pulsewidth by voltage, scaling linearly along the rpm axis. If you were using a map based voltage source you will have to be a little more careful since it would be speed density, but the same controller would work and it would save you the trouble of integrating another sensor.
Ask Me About My:
Ziggo is offline
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
Easter Bunny (07-14-2014), Mauro_Penguin (07-14-2014), ST_Fan (07-13-2014), wolly6973 (07-14-2014)
 Old 08-04-2014, 11:43 AM   #693
Enki's Avatar
Groans: 189
Progress. Logs to follow later today.
Enki is offline
btstarcher (08-04-2014), Code Monkey (08-04-2014), Mauro_Penguin (08-07-2014)
 Old 08-04-2014, 02:51 PM   #694
Enki's Avatar
Groans: 189
Bats are looking great, but I should probably up the nozzle size by a touch. I forget what I'm running now but it's probably a 7.
Power/torque is low as I'm only running 15 degrees timing @ 6k and 18 @ 6500. Map does have VVT and peak boost is ~21 PSI up top.
I still need to swap out my primary O2 sensor (this weekend) and ditch the secondary.
Enki is offline
btstarcher (08-04-2014), Code Monkey (08-04-2014), Dimenus (08-04-2014), JgamB (08-07-2014), Mauro_Penguin (08-07-2014)
 Old 08-07-2014, 03:17 PM   #695
Enki's Avatar
Groans: 189
Swapped to the 8 GPH nozzle, and I'm liking it a bit better. Feels good, though now I'm down on power, probably due to timing, which will be added after I fix the o2 sensor(s) on Saturday.
Also, I finished the stealth install; pictures are below.
Enki is offline
ItsNox (08-08-2014), magicka (08-07-2014), Mauro_Penguin (08-07-2014), wolly6973 (08-07-2014)
 Old 08-07-2014, 03:21 PM   #696
ST_Fan's Avatar
Nice, I just swapped in a D09 today. It's unbelievable how much spray comes out. I was surprised when I tested it. Unfortunately it didn't seem to help my fueling issues up top though still working on it.
ST_Fan is offline
ItsNox (08-08-2014)
 Old 08-07-2014, 03:32 PM   #697
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
TiAL just realeased hotsides for efr turbo.
I may have to invest in one when I get bored with the gtx3067 I haven't even gotten running yet.
Jackis and Mauro_Penguin like this.
"Exclusivity" - CP-enis
Demodded.
The Seals
Tokay444 is offline
ItsNox (08-08-2014), Mauro_Penguin (08-07-2014)
 Old 08-07-2014, 03:44 PM   #698
Enki's Avatar
Groans: 189
The factory EFR hotsides are REALLY fucking good though...Are they just flanged differently or what?
Enki is offline
 Old 08-07-2014, 04:01 PM   #699
Tokay444's Avatar
Groans: 793
Cast stainless and TiAL flanges. I have a TiAL flanged cpe mani.
Demodded.
The Seals
Tokay444 is offline
Easter Bunny (08-08-2014), magicka (08-07-2014), Mauro_Penguin (08-07-2014)
 Old 08-08-2014, 04:30 PM   #700
Enki's Avatar
Groans: 189
Upped timing to 18 @ 6k and 20 @ 6500. There's room for at least 2 degrees more at both RPMs.
60-100 is 5.038 seconds with 100 degree ambient.
40-130 is 13.42 seconds granny (full lift) shifting.
Enki is offline
The Following 6 Users Say Thank You to Enki For This Useful Post:
btstarcher (08-09-2014), Dimenus (08-10-2014), ItsNox (08-08-2014), JgamB (08-08-2014), Mauro_Penguin (08-10-2014), SarcasticOne (08-08-2014)
 Old 08-10-2014, 01:38 PM   #701
Dimenus's Avatar
Posts: 2,825   (View Stats)
Dimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the worldDimenus is the leader of the world
Groans: 33
Ugh. Fuck AZ heat. Your car would rip so hard if it was at either sea level OR in normal temps. Just for shits n giggles, you should temp correct that graph.
2012 Velocity Red Mica
Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC
Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps
Dimenus is offline
 Old 08-10-2014, 03:26 PM   #702
Enki's Avatar
Groans: 189
It doesn't seem to make that much of a difference. Right now I think not having good crankcase evac is hurting me a bit power wise, as are dirty valves.
Enki is offline
Mauro_Penguin (08-13-2014)
 Old 08-10-2014, 04:46 PM   #703
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
What's your catch can setup at this point?
Realgib3 is offline
The Following User Says Thank You to Realgib3 For This Useful Post:
 Old 08-10-2014, 05:17 PM   #704
Enki's Avatar
Groans: 189
Vent to air. CC and VC are teed and there's a hose ziptied to my undertray.
Enki is offline
Code Monkey (08-10-2014)
 Old 08-11-2014, 07:20 AM   #705
Realgib3's Avatar
Groans: 52
Gotcha. Well I have an almost as simple and definitely effective setup, proven at very high boost levels that you could give a shot. Just the stand catch can kit from CC to IM, then two hoses from VC to undertray.
I'll be switching shortly to one large, vented can, just so I'm a little better on environment, but otherwise that setup has worked great for me.
Realgib3 is offline
 Old 08-11-2014, 12:00 PM   #706
Enki's Avatar
Groans: 189
I'm actually contemplating a completely sealed catch can setup that would provide for full vacuum at idle and under boost, but it won't allow fresh air through the crankcase so not sure it's a good idea.
Enki is offline
 Old 09-14-2014, 02:01 AM   #707
Enki's Avatar
Groans: 189
Hit the track today...
Lots of fail.
Some backstory:
Last time I ran at the track, I ran a mid 14 something at 104 ish MPH. Fourth and final run that day got me to 13.8 @ 108. This was on about a 320 whp tune with a 20-25% detune in first and second.
Tonight, I ran a 340 WHP tune, with WMI, and no detune in 1-2. This tune hits 4.25 volts on a custom 3.5" intake.
First pass: Tons of wheelhop. 14.6 @ 104. Bit of a bummer.
I go home real quick to get the laptop to detune first and second, flash a map while I'm there and get back in time for the second run (there was a shutdown due to a dude going through the nets after the sandbox which provided an hour of downtime).
Get up about 5-6 cars from the second run, and see car is running at 11.x AFR at idle with -25% STFT. Fuck. Run aborted. Get back to the pits, check everything and find that the car stumbled when I touched the MAF connector. It wasn't loose or anything, but apparently had a shitty connection. A bit worrisome, but not that big of a deal.
Third run.
Wheel hop from hell, shifting failures (couldn't find second or third). 15.x @ 100.
Multiple ABS codes now, with a TPMS code.
Need to do some diagnostics tomorrow.
Enki is offline
Code Monkey (09-14-2014), Easter Bunny (09-14-2014), Mauro_Penguin (09-20-2014)
 Old 09-14-2014, 08:18 AM   #708
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Violent wheel hop triggers abs, tpms, stability, etc to come on.
You might have a broken wire to the MAF connector.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline
The Following 5 Users Say Thank You to udntknw For This Useful Post:
Easter Bunny (09-14-2014), Enki (09-14-2014), himurax13 (09-14-2014), Mauro_Penguin (09-20-2014), phate (09-14-2014)
 Old 09-14-2014, 12:12 PM   #709
Raider is mah Homie
Groans: 2,978
What side mounts are you running?
I hugged rfinkle2
 Old 09-14-2014, 12:27 PM   #710
udntknw's Avatar
He is running JBR trilogy if I remember correctly.
**Old Motor**
**New Motor**
udntknw is offline
 Old 09-14-2014, 06:06 PM   #711
Enki's Avatar
Groans: 189
JBR 70 pass/trans with chromoly rear.
Enki is offline
 Old 09-14-2014, 07:46 PM   #712
Enki's Avatar
Groans: 189
Failure 1:
Failure 2 (20% detune 1 and 2):
EDIT:
In a spot of good news, my street test runs of fourth gear showed 4.25 peak volts @ 20 PSI in 100 degree ambient temps with >3,000 foot elevation. Intake is a custom 3.5" with Treadstone housing.
Also, my pops (who was running tech) said that quite a few people were rather unhappy with their 60' times, so track prep might have been an issue.
Last edited by Enki; 09-14-2014 at 07:50 PM. Reason: MSF Database - Automerged Doublepost
Enki is offline
littleloogy (09-18-2014), Mauro_Penguin (09-20-2014)
 Old 09-20-2014, 12:43 PM   #713
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
What tires are you running? Airing down the fronts to ~30psi might help with the hop, the Conti DW's I have definitely respond well to that. Once you start hopping it seems next to impossible to get in a clean pass with these cars.
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline
The Following User Says Thank You to twenty5psi For This Useful Post:
 Old 09-20-2014, 07:04 PM   #714
Enki's Avatar
Groans: 189
Ventus V12 Evo, they were at 35 PSI, but thats about the same pressure they were at last time I went and put down a 13.8 @ 108 with driver fail.
Enki is offline
 Old 10-03-2014, 06:40 PM   #715
Enki's Avatar
Groans: 189
Ringlands might be done, not 100% sure. Warm start, and lots of pulsing air/exhaust out the VC breather (crank case and valve cover both go to T connection, then vent to air). Should probably do a hot compression test to be sure.
I'm under the impression that any volume of gas reliably exiting via the valve cover is no bueno, confirm/deny?
Enki is offline
Mauro_Penguin (10-03-2014)
 Old 10-03-2014, 08:02 PM   #716
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
Damn bro I'm sorry to hear this
If it's confirmed, do you plan to build?
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline
 Old 10-03-2014, 08:06 PM   #717
Enki's Avatar
Groans: 189
Yes, and sleeper status will be no more. Full on unique destroked build. Gonna go buy a compression/leakdown tester tomorrow and see whats up. Hopefully, I won't have to build and that money can go towards the new house/Falcon racecar build.
Enki is offline
ItsNox (10-03-2014), littleloogy (10-03-2014), Mauro_Penguin (10-03-2014), Roddiy (10-05-2014)
 Old 10-03-2014, 08:12 PM   #718
radbrad's Avatar
Posts: 538   (View Stats)
radbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the world
Could it be a bad valve seal?
07Speed3
TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. ||
radbrad is offline
 Old 10-03-2014, 08:41 PM   #719
Enki's Avatar
Groans: 189
Unlikely, since the gasses are coming from the valve cover, and my entire crankcase evac setup is vent to air.
Enki is offline
 Old 10-03-2014, 08:46 PM   #720
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
No gas/pressure out of the crankcase hose?
A noticeable amount of blowby at idle would def concern me too... at WOT it's going to happen. On my miater dyno video you can see smokey/oily mist out of mine when you go WOT.
+1 on comp test or leakdown... get some real data and go from there.
Last edited by aaronc7; 10-03-2014 at 08:46 PM. Reason: MSF Database - Automerged Doublepost
aaronc7 is offline
The Following User Says Thank You to aaronc7 For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f541/enki-s-efr-ordeal-157429/
borgwener turbos ? Mazda MPS Owners Club This thread Refback 04-13-2015 04:01 PM
turbo fitment ? Mazda MPS Owners Club This thread Refback 02-14-2015 02:19 PM
Turbo ? Mazda MPS Owners Club This thread Refback 02-12-2015 08:41 AM
BT path help This thread Refback 12-27-2013 05:04 PM
Video: Washington State bridge collapse victim talks about his ordeal Haltech Automotive News 2 05-24-2013 10:00 AM
Report: Good Samaritan motorists box in man driving with girlfriend on hood, end ordeal safely Haltech Automotive News 0 09-26-2012 06:20 AM
Page generated in 0.60088 seconds with 33 queries
