Notices
Like Tree14Likes
 Old 07-17-2012, 07:43 AM   #121
Speeeeeed
06Speed6's Avatar
Posts: 5,755   (View Stats)
Finally got a call from DCR about the vvt, core will be sent in today.
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
06Speed6 is online now   Reply With Quote
Boosten Ya(josh) (07-17-2012)
 Old 07-17-2012, 09:35 AM   #122
Captain
djuosnteisn's Avatar
Posts: 11,191   (View Stats)
Groans: 79
Did you ever find any conclusive data on why 5 layer gaskets are better?
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
djuosnteisn is online now   Reply With Quote
 Old 07-17-2012, 09:44 AM   #123
Posts: 8,030   (View Stats)
Groans: 34
because 2 more layers = bigger...bigger=better.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
 Old 07-17-2012, 10:11 AM   #124
Ziggo's Avatar
Posts: 3,090   (View Stats)
My completely unresearched, off the cuff guess.
It's like lumber or metals; the tighter the grain the stiffer the wood/metal (heh). The layers give it strength.
Zigatapatalka
Ask Me About My:
Ziggo is online now   Reply With Quote
 Old 07-17-2012, 10:22 AM   #125
Captain
Groans: 79
Do head gaskets see flex? I know with wire, stranded core will hold up much better to abuse before it breaks compared to solid core. The more strands, the better is handles strain.
www.permtuning.com
 Old 07-17-2012, 10:31 AM   #126
Ziggo's Avatar
That something different and due to stress/strain. The thinner the material the more it can bend (strain) before it reaches a given stress. With a thicker material (solid core) it generates more stress in the material for a given deflection, which makes it more prone to fatigue failures.
Zigatapatalka
Ask Me About My:
djuosnteisn (07-17-2012)
 Old 07-17-2012, 01:33 PM   #127
Captain
Groans: 79
Right, that's why i was asking if head gaskets ever see flex. Didn't think they did, but was just throwing out the idea.
Perhaps more layers handle thermal conditions better, helping distribute heat loads more effectively. No clue. Now i'm interested in why more would be better on layer count, assuming same thickness, lol.
www.permtuning.com
 Old 07-17-2012, 01:40 PM   #128
Captain
Groans: 79
I think the gaskets are simply "embossed" or stamped with ridges... to provide a spring like seal.
Look at the side views on the first page in this pdf:
http://www.cometic.com/catalogs/AutoDomestic.pdf
So more layers probably = more sealing bosses = better seal.
Dunno... have to work... will read later... unless ziggo posts answers before hand
www.permtuning.com
PapaSmurf (07-17-2012)
 Old 07-18-2012, 02:51 PM   #129
Speeeeeed
06Speed6's Avatar
From everything that I can find that actually looks reputeable, more layers simply means a thicker HG. The standard 3 layer is standard thickness and the 5 layer is thicker for a compression drop or to take up room for lost metal after the block/head surface has been machined, this is to prevent a misstimed engine from reduced crank/cam distance and added compression. I have seen nothing about a 5 layer out sealing a 3 layer if the head and block are machined properly, it seems debateable to me but if the engine/head is prone to warpage the 5 layer seems to be the way to go.
I dropped the torque plate off at the machine shop, they finished balancing the crank and just have the machining on the block and head left.
I also dropped off the timing cover and valve cover to get chrome plated, they are going to look like a mirror after they get done with them. It was $185 for the timing cover and $250 for the valve cover. They are copper plated twice, then polished, then nickel plated twice, and then chrome plated. This is an actual old school car show level chrome plate process. They mostly do bike parts and bike/auto wheels, but they can handle refridgerator doors and stovetops too lol. This is the first time I have ever had a car part chrome plated so we will see how it goes, hopefully ill be able to read a book off of my valve cover.
2006 Mazdaspeed 6
djuosnteisn (07-19-2012)
 Old 07-18-2012, 02:56 PM   #130
Eth Fiend
phate's Avatar
Posts: 4,270   (View Stats)
phate has disabled reputation
Why doesn't someone just call cometic?
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
 Old 07-18-2012, 06:01 PM   #131
Posts: 10,144   (View Stats)
Groans: 98
yah but now you will be able to see yourself doing this everytime the wrench slips and you bust your knuckles!
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
06Speed6 (07-18-2012)
 Old 07-18-2012, 09:44 PM   #132
Speeeeeed
06Speed6's Avatar
Thats way too easy
2006 Mazdaspeed 6
phate (07-18-2012)
 Old 07-19-2012, 12:10 PM   #133
Captain
Groans: 79
Thats way too easy
+1
We need more mspaint drawings in order to solve this riddle.
www.permtuning.com
06Speed6 (07-19-2012), Monotonous ONE (07-19-2012), phate (07-19-2012)
 Old 07-19-2012, 12:16 PM   #134
Groans: 34
I know a guy.....
PERM
The Following 5 Users Say Thank You to Dano For This Useful Post:
06Speed6 (07-19-2012), djuosnteisn (07-19-2012), Monotonous ONE (07-19-2012), phate (07-19-2012), superskaterxes (07-20-2012)
 Old 07-19-2012, 03:56 PM   #135
Speeeeeed
06Speed6's Avatar
Finally got through to south bend clutch, they can reline my full face disc to feramic for $270 and it should hold north of 700ftlb without issue.
2006 Mazdaspeed 6
Don06speed6 (07-19-2012)
 Old 07-19-2012, 06:56 PM   #136
psn boostenya
Boosten Ya(josh)'s Avatar
Posts: 3,943   (View Stats)
Boosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the world
Groans: 40
Groaned at 15 Times in 13 Posts
Stock disk?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosten Ya(josh) is offline   Reply With Quote
 Old 07-20-2012, 01:06 PM   #137
Eth Fiend
phate's Avatar
So I just called Cometic and asked about 3 vs 5 layer gaskets. I asked specifically about sealing capacity and was told there is "no difference, not at all". They only alter thickness, lol.
06Speed6 (07-20-2012), Dano (07-21-2012), djuosnteisn (07-24-2012), Tomas (07-20-2012), Ziggo (07-20-2012)
 Old 07-20-2012, 02:26 PM   #138
Speeeeeed
06Speed6's Avatar
Ain't that some shit
2006 Mazdaspeed 6
 Old 07-20-2012, 07:13 PM   #139
Speeeeeed
06Speed6's Avatar
I degreased the engine area, you would really be surprised at how much shit can build up over 147k miles. I used an industrial degreaser and a scrub brush and and had to scrub for a while to get through it. Shit looks as close to new as its going to get.
I am going to paint it black this weekend. Should look nice with the chrome.
2006 Mazdaspeed 6
 Old 07-20-2012, 07:41 PM   #140
socks's Avatar
Groans: 124
pics of that too, lol.
1994 Mazda RX-7
 Old 07-21-2012, 03:10 AM   #141
Speeeeeed
06Speed6's Avatar
Thats already black...
2006 Mazdaspeed 6
 Old 07-21-2012, 12:49 PM   #142
Groans: 34
so they are purely to alter compression ratio then?
PERM
 Old 07-21-2012, 01:20 PM   #143
Eth Fiend
phate's Avatar
compression ratio, quench, yeah. However you want to look at it, it sounded like the # of layers had no effect on sealing.
06Speed6 (07-22-2012), Dano (07-23-2012), djuosnteisn (07-24-2012)
 Old 07-23-2012, 04:42 PM   #144
Speeeeeed
06Speed6's Avatar
Got new TT fmm bushing in today and its urethane not rubber. Now I need to press it in, wonder if I can fit it all in my vice...
Still havent painted my engine bay, I might start it tonight... maybe, its flipping hot as fuck.
2006 Mazdaspeed 6
 Old 07-23-2012, 05:49 PM   #145
Groans: 98
picts of new and old bushing side by side please
WWW.SONICTUNING.COM
 Old 07-23-2012, 06:23 PM   #146
Speeeeeed
06Speed6's Avatar
Alright, the new one is red, old is black
2006 Mazdaspeed 6
 Old 07-24-2012, 12:14 PM   #147
Captain
Groans: 79
You must have had a really old one then, lol.
www.permtuning.com
06Speed6 (07-25-2012)
 Old 07-25-2012, 12:42 AM   #148
Speeeeeed
06Speed6's Avatar
The bushing swap was cake! I got lotsa pics too.
The Arp flywheel bolts are perfect and I think they should be manditory for alum flywheels. The bolt head on them is at least twice as wide so they distribute clamping force more evenly and shouldnt deform the flywheel so much. Lotsa pics of that too.
The Arp crank bolt is a monster! It looks like it fits perfect also but I need my crank so that I can do a test fit.
The best news of the day is that I completely grenaded my tcase without breaking the case. I didnt open it up but the driveshaft flange just spins freely. I have a spare tcase that I thought was from a cx-7 but its identical to my tcase in every way so I think that it is actually a ms6 tcase. I test fitted it and that bitch bolted up perfectly. I installed the upgraded tcase bearing caps and torqued it all down, preped the sealing surfaces and sealed it up and bolted it back together so its ready to go now. Got lotsa pics of that too.
Ill post pics prolly tomorrow.
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
Boosten Ya(josh) (07-25-2012), djuosnteisn (07-30-2012), Easter Bunny (07-30-2012)
 Old 07-25-2012, 03:10 AM   #149
Speeeeeed
06Speed6's Avatar
ARP stuff
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
Boosten Ya(josh) (07-25-2012), Code Monkey (07-27-2012), djuosnteisn (07-30-2012), Menace1 (02-08-2013)
 Old 07-25-2012, 03:13 AM   #150
Speeeeeed
06Speed6's Avatar
Tcase #1 pic set
2006 Mazdaspeed 6
Boosten Ya(josh) (07-25-2012), djuosnteisn (07-30-2012), Menace1 (02-08-2013)
 Old 07-25-2012, 03:17 AM   #151
Speeeeeed
06Speed6's Avatar
Tcase #2 pic set
2006 Mazdaspeed 6
 Old 07-25-2012, 03:20 AM   #152
Speeeeeed
06Speed6's Avatar
TT FMM bushing replacement #1 Pic set
2006 Mazdaspeed 6
Boosten Ya(josh) (07-25-2012), djuosnteisn (07-30-2012), Menace1 (02-08-2013), Tomas (07-27-2012)
 Old 07-25-2012, 03:35 AM   #153
Speeeeeed
06Speed6's Avatar
TT FMM bushing replacement #2 pic set
2006 Mazdaspeed 6
 Old 07-26-2012, 08:21 PM   #154
Speeeeeed
06Speed6's Avatar
Dont need no stinkin $50 hex key bitches! Thats a 3/4" nylon lock nut from Lowes that cost 88 cents!
The other part is off of the trans, you have to take that plug out to tear it down.
2006 Mazdaspeed 6
 Old 07-26-2012, 09:00 PM   #155
Speeeeeed
06Speed6's Avatar
ACL rod bearings also on order today along with a third throw out bearing, a timken pilot bearing, and something else that I cant remember
2006 Mazdaspeed 6
 Old 07-27-2012, 08:15 PM   #156
Speeeeeed
06Speed6's Avatar
Tonight I walnut blasted my IM and several brackets, man that shit is easy to do and the gun is $30 from harbor freight. Im just glad that I have a fairly big air compressor, even so I was still waiting around some because it doesnt work as well under 100psi because the hopper is on the bottom and it uses a venturi tube to pull the media through.
2006 Mazdaspeed 6
Tomas (07-27-2012)
 Old 07-27-2012, 08:55 PM   #157
Groans: 34
FWIW I got the top feed hopper and it doesn't use nearly as much air. its actually the compressor tank more than the HP/CFM rating that dictates how much air it can supply to a device. I would also say it takes much less air to blast into the head than something in an open area.
I have like 30LBS of left over walnut media from my valve cleaning......thinking I'll blast anything in sight from now on to clean it.
PERM
06Speed6 (07-28-2012), Tomas (07-27-2012)
 Old 07-27-2012, 11:35 PM   #158
Veblen Goods
Tomas's Avatar
Posts: 2,293   (View Stats)
Just mounted the pauter rods and wisecos up and compaired them to the stockers and holy fuck there has to be at least twice the metal in the pauter rods
Originally Posted by Empurfektion View Post
When mine popped I went with k1's. After doing a lot of research I figured they were pretty good for the price and they still help up really well for all that I need. They still had twice the metal as the stockers too. It was crazy to me to see how thin the stock ones really are.
Are you going with Pauter rods because you think the material is better or because you like the design better?
Not an expert on chroming but I remember for best results you should have a copper layer anodized underneath the chrome. Not sure if that's for steel only or if that also applies to aluminum.
Is that with the stock PP? Dood, if so, that is highly unlikely. Spec's 3+ ferramic disc with the stock PP can only hold 470 lbs. IIRC the stock pp has a clamping load of 1950 lbs when new increasing to about 2100 lbs after ratcheting down all the way. With a 2500 lbs pp you can get about 120-150 lbs more down. That still only gets you to 620 lbs under the best conditions. Suspect the SB numbers are a lil exaggerated. I am running a ferramic / kevlar discon stock PP and I can tell you it does not hold more than 400 lbs.
ARP stuff
That ARP crank bolt is a sexy beast. I'd like to see at what torque the threads on the crank snout give out.
I would also look into the bolts of the cams. I think most people only look at the washers and crank bolt as the cause of jumping timing but IMO it is much more likely the sprockets on the EX cam or the VVT are slipping. You have somewhere around a 3 times bigger diameter of the sprockets on the cams than the sprockets on the crank. Unless I am mistaken that also means there is about 3 times more leverage on the cam sprockets resulting in much higher torsion / shear load there.
Nice baller build!
GHEY THUNDER
06Speed6 (07-28-2012), Dano (07-28-2012)
 Old 07-28-2012, 12:29 AM   #159
Speeeeeed
06Speed6's Avatar
Nice baller build!
Thanks man
I went with the Pauter rods because they are the heaviest rod available and the quality of the material and machine work is good. To me more metal is more strength.
The chrome plate that I am getting has two copper layers, then two nickel layers, and a chrome layer. The way it was explained to me, and I researched this online, its actually the nickel layer that you mainly see and the chrome simply protects it from corrosion. The chrome itself is supposed to me largely see through because its so thin. Maybe I understood it wrong, but it does have a copper layer.
I have a 2500lb pp and SBs feramic is actually supposed to be a large percentage graphite or something so it has more grip than other feramics at a cost of wearing out slightly faster.
Yeah that ARP crank bolt gets torqued to something like 180'lb, I had to buy a new torque ratchet because mine stopped at 175'lb lol.
Here is the first coat on a few parts, more to get painted later.
2006 Mazdaspeed 6
djuosnteisn (07-30-2012), Tomas (07-28-2012)
 Old 07-28-2012, 05:36 AM   #160
Veblen Goods
Tomas's Avatar
What's the weight on the Pauters? I am not on in the camp that says more weight > more strength but the Pauter rods look like a good product.
I'll leave this here as a reference for you. From lightest to heaviest. K1--> Eagle--> Stock.
And Genpoo piston with gudgeon pin and rings.
GHEY THUNDER
The Following 4 Users Say Thank You to Tomas For This Useful Post:
06Speed6 (07-28-2012), Boosten Ya(josh) (07-28-2012), chimmike (07-30-2012), djuosnteisn (07-30-2012)
long awaited turbo manifold is out!!! Grumpyjap Custom Performance Engineering (cp-e.com) 146 05-13-2012 05:05 AM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 06:20 AM
Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup Haltech Automotive News 0 03-22-2010 09:10 PM
Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 Haltech Automotive News 0 04-01-2008 04:20 PM
Page generated in 0.59509 seconds with 29 queries
