Like Tree46Likes
 Old 04-03-2013, 09:40 PM   #1
Mikey's Avatar
Posts: 2,049   (View Stats)
Mikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the world
Groans: 104
Groaned at 45 Times in 36 Posts
Default Not another Build thread. :(
Well I did a compression test about a month ago and cylinder 2 was at 90 and 3 was at 110. So after doing some reading and talking with a couple people figured it was my ringlands. I was emptying my SSP OCC once a week.
Been driving the car very easy for the past month. Finally saved up enough cash for my parts, $2200 worth, and on the way home the car finally started to give out, smoking like Bob Marley and sputering like a little bitch. I am hoping it will get my to my mechanic tomorrow. Here is a video I made earlier tonight.
https://www.dropbox.com/s/8xg428s74j...2023.04.33.mp4
Here is a list of all the parts I ordered. I believe I got everything thanks to Alan at EdgeAutoSports.
Main Bearings 0.025" Oversize OEM
Rod Bearings 0.025" Oversize OEM
Thrust Bearing OEM
Rear Main Seal/Cover OEM
Injector Seals CPE
Thermal Gaskets JBR
PVC Plate Perm
Crank Pully Bolt OEM
Friction Washers (3) OEM
Gasket Set OEM
Flywheel Bolts (6) OEM
Rods K1
Piston WisecoPistons
Main studs APR
Head studs APR
Timing Chain OEM
Camshaft Washers (2) OEM
Oil Pump OEM
Oil Pan Baffle Kit/
BSD delete Kit JBR
VVT kit OEM
I have a friend that is going to take the engine out and take it to the machine shop and then re-install. I will try to get as many pics of the build as I can. Machine shop is also going to port and polish so I cannot wait.
Zdraveca likes this.
2007 Cosmic Blue
Built HTA 3076 Corn Fed with shot of Meth and Freektuned
Mikey is offline   Reply With Quote
The Following 6 Users Say Thank You to Mikey For This Useful Post:
ABolewski (04-04-2013), atvfreek (04-04-2013), derek13p (04-03-2013), jack_hammer (04-16-2013), Redline143 (04-12-2013), Zdraveca (04-15-2013)
 Old 04-03-2013, 10:09 PM   #2
derek13p's Avatar
Posts: 1,193   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
I gotta come up and see this when its done! Sucks that happened but its going to be killer after this. Good luck with everything!
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
The Following User Says Thank You to derek13p For This Useful Post:
Mikey (04-03-2013)
 Old 04-04-2013, 07:14 AM   #3
Eth Fiend
phate's Avatar
Posts: 6,849   (View Stats)
Ugh, you ordered bearings before you knew what size you needed? pistons, too, I assume. That FORCES you to have machine work performed when it may not be necessary. Did edge recommend going that way?
-06 MS6
-Corn fed 07 MS3 - Sold
atvfreek (04-04-2013), jracer (04-04-2013), LumberJack (10-23-2013), rfinkle2 (04-04-2013), silvapain (04-04-2013)
 Old 04-04-2013, 07:22 AM   #4
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
I think he wanted to reduce downtime. I would have cracked the motor open first.
Sent via stocked out for a while ...
Pickles Tune in progress
The Following 2 Users Say Thank You to himurax13 For This Useful Post:
Mikey (04-04-2013), phate (04-04-2013)
 Old 04-04-2013, 07:27 AM   #5
Eth Fiend
phate's Avatar
I agree, and I understand the dilemma with downtime. It's a different story if that's the case.
-06 MS6
Mikey (04-04-2013)
 Old 04-04-2013, 06:19 PM   #6
Mikey's Avatar
Groans: 104
Yea, its my daily driver and down time is very important. Besides, since the engine will be out and it already has 75k miles on it, I wanted everything just done at one time. I planned having machine work done on the block and cylinder head anyway so hopefully I don't have to worry about this shit for another 75-100 miles.
2007 Cosmic Blue
 Old 04-12-2013, 09:59 PM   #7
rolanblack's Avatar
Posts: 2,110   (View Stats)
rolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the world
Zzb I see within 50-100 miles.
rolanblack is offline   Reply With Quote
 Old 04-12-2013, 11:14 PM   #8
Mikey's Avatar
Groans: 104
Goodies are in and engine comes out next week.
@atvfreek
@Zdraveca
@TheFlash
@Redline143
@rolanblack
@SpeedEngineer
rolanblack and Smelson like this.
2007 Cosmic Blue
The Following 4 Users Say Thank You to Mikey For This Useful Post:
atvfreek (04-16-2013), Redline143 (04-13-2013), Smelson (04-13-2013), SpeedEngineer (05-07-2013)
 Old 04-12-2013, 11:21 PM   #9
rolanblack's Avatar
you can have my engine and ill just wait for the rebuilt.
 Old 04-12-2013, 11:23 PM   #10
Mikey's Avatar
Groans: 104
lol exactly. Now I dont have to worry. lol wanna buy my turbo....
2007 Cosmic Blue
 Old 04-12-2013, 11:45 PM   #11
rolanblack's Avatar
going BIGGER?
Naw, im Good. Hassle Z
 Old 04-13-2013, 07:28 AM   #12
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
@atvfreek
@Zdraveca
@TheFlash
@Redline143
@rolanblack
@SpeedEngineer
We're about to have a lot more quickness with our guys! With @Smelson going BT and @Mikey going forged while already having BT, ethanol and methanol, those cars at the Southlake meet better watch out!
Slow K04 on ethanol is slow... I need a BNR or better!
Redline143 is offline   Reply With Quote
 Old 04-13-2013, 03:26 PM   #13
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
Im aiming for king of the k04's so you guys dont have to worry about me for a while
Sent while putting train lengths on @Redline143 ;
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
 Old 04-13-2013, 04:27 PM   #14
Redline143's Avatar
Trying to regain your crown, eh? @TheFlash has been true to his name... Quite quick. How's the re-tuning coming along?
You know, to secure and keep the K04 crown, there's nothing like meth... since the K04's the limiting factor Apparently you can get close to 350whp with eth/meth on a K04.
 Old 04-13-2013, 05:17 PM   #15
Zdraveca's Avatar
Groans: 145
I want to do it without meth
GT2876r
E85 FREEKTUNE
 Old 04-13-2013, 06:35 PM   #16
Redline143's Avatar
Yeah, I hear ya. I don't like the feeling that I have another fuel tank I have to worry about filling up. It seems like it'd be pretty involved to remove if I ever have major issues and need to take it in on my 100,000 mile warranty too.
 Old 04-13-2013, 07:21 PM   #17
Mikey's Avatar
Groans: 104
You can buy mine..
Pussy
2007 Cosmic Blue
Last edited by Mikey; 04-13-2013 at 07:21 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-13-2013, 07:27 PM   #18
Zdraveca's Avatar
Groans: 145
You can buy mine..
Pussy
Bitch I bought mine first
GT2876r
E85 FREEKTUNE
 Old 04-13-2013, 08:18 PM   #19
Mikey's Avatar
Groans: 104
lmao i was telling Zach to by GT3071 and you are a pussy for no meth...
PUSSSSSSSSSSSSSSSSSSSSSSSSSSSSSYYYYYYYYYYYYYYYYYYY YYYYYYYYY
2007 Cosmic Blue
 Old 04-13-2013, 10:04 PM   #20
rolanblack's Avatar
I have been thinking about going MEH
 Old 04-13-2013, 10:04 PM   #21
Redline143's Avatar
Buy your GT3071? What you gonna do? Are you going even bigger?!?
 Old 04-13-2013, 10:07 PM   #22
Mikey's Avatar
Groans: 104
would like to go up to the gtx3071 since I will be built, if I can sell mine. If I dont I will just keep mine.
2007 Cosmic Blue
 Old 04-13-2013, 10:08 PM   #23
Redline143's Avatar
If you put your 3071 up on here, it'll be gone quick! "If" you can sell yours, you say--ha! That thing will be gone fast, I'll bet!
 Old 04-13-2013, 10:12 PM   #24
Mikey's Avatar
Groans: 104
I hope so but either way if it whoops Z's ass like it did when i first pu it on before my zzb then i will be happy
2007 Cosmic Blue
 Old 04-13-2013, 10:16 PM   #25
Redline143's Avatar
How many miles are on the turbo?
 Old 04-13-2013, 10:18 PM   #26
Mikey's Avatar
Groans: 104
between 2500-3,000
2007 Cosmic Blue
 Old 04-13-2013, 10:21 PM   #27
Redline143's Avatar
between 2500-3,000
Oh gosh, that thing's barely broken-in. When the build's all done you'll be pulling harder than ever, I'm sure. And if Atvfreek can get 417 on his BNR with eth and meth, I'm sure he can hit 450 with your 3071.
 Old 04-13-2013, 10:28 PM   #28
Mikey's Avatar
Groans: 104
and you can get 380-400 with mine.
2007 Cosmic Blue
 Old 04-13-2013, 10:37 PM   #29
Redline143's Avatar
For sure. I'd tune it for maybe 375 or so... Maybe daily driver it at 350...
 Old 04-13-2013, 11:50 PM   #30
Smelson's Avatar
Posts: 2,237   (View Stats)
Smelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the world
Weak...lol
Sent while losing to TheFlash
FreekTune
GT2871r- 402/402
Smelson is offline   Reply With Quote
 Old 04-14-2013, 08:14 AM   #31
Redline143's Avatar
Originally Posted by Smelson View Post
Weak...lol
What you call weak I'd call wise. Tuning for much more than that on stock engine internals turns the engine into a ticking time bomb! Despite what may have been thought or said, I tune for safety! Or, at least reliability...
 Old 04-14-2013, 09:10 AM   #32
Smelson's Avatar
We all know you're the wise one. Both of our cars are ticking time bombs now despite what you may think wise one.
FreekTune
GT2871r- 402/402
The Following User Says Thank You to Smelson For This Useful Post:
Zdraveca (04-14-2013)
 Old 04-14-2013, 09:25 AM   #33
Redline143's Avatar
Say it ain't so! I don't want any of our cars to blow up!
 Old 04-14-2013, 09:46 AM   #34
Smelson's Avatar
I don't need to explain it to you but we are running BT non built torque, some cases even more. To think our cars are safe is silly.
FreekTune
GT2871r- 402/402
 Old 04-14-2013, 10:35 AM   #35
rolanblack's Avatar
Throw some rods. Then rebuilt.
hahaha
 Old 04-14-2013, 11:01 AM   #36
Mikey's Avatar
Groans: 104
I thought you were going to throw some Rods and pistons in? Smelson
2007 Cosmic Blue
 Old 04-14-2013, 11:48 AM   #37
Zdraveca's Avatar
Groans: 145
I definitely don't think we're running "safe mode" tunes. But I also don't think it's merely a matter of time until Zoom Zoom Boom. My torque peak's at 4k! Now, if it were at 3k and I regularly went WOT at 2k, that would be much more foolish. I just try to keep things at about 21 or so psi no earlier than 3500rpms with 380 or less max torque at 4k. I get these numbers from the "safe" tunes of the pro-tuned folks in our group, like theflash, speedengineer, and Z. I follow their patterns, which I've confirmed lots of extra times through thread reading.
Torque down low is what to avoid. And rods don't generally bend or snap instantly. They fatigue and start bending progressively, which can be progressively observed as gradually lowering power and gradually increasing KR. Also, since bent rods aren't as short, a pumping compression test will likely show lower compression as the piston won't travel as high up. Since I log meticulously, I'd start seeing a trend, most likely. No such trend has appeared.
So, if you think your car's a ticking time bomb, are you relying on stocking out and getting an engine replacement under warranty? Surely, tuning is inherently risky. But I think all the guys in our group have done very well in minimizing risk and running tunes that have the backing of all the practical wisdom of this forum and really are "safe" rather than ticking-time-bomb tunes.
Dont spam the thread frodo
Redline143 likes this.
GT2876r
E85 FREEKTUNE
 Old 04-14-2013, 11:55 AM   #38
Smelson's Avatar
I wouldn't stock out at this point. Lets keep this out of mike's thread.
It's in the plans but I came across the turbo for cheap so I'll throw it on and do internals later.
Mikey likes this.
FreekTune
GT2871r- 402/402
Last edited by Smelson; 04-14-2013 at 11:55 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Smelson For This Useful Post:
Mikey (04-15-2013), Redline143 (04-14-2013)
 Old 04-16-2013, 07:31 AM   #39
SpeedEngineer's Avatar
Posts: 1,589   (View Stats)
SpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the worldSpeedEngineer is the leader of the world
Groaned at 20 Times in 19 Posts
Mik how much do you want to well it for?? Does it have oil all over it? How bout shaft play and bearings
How much are you selling for mike? I might be interested
2010 MS3 GenPu Blue Mica
ETS TMIC | ATP 3" Downpipe | OBX Catback | HTP 3" Intake | 3 Bar MAP Senosor | Cobb Accessport | CorkSport Battery Box | JBR Shift weight| JBR 88 duro RMM | JBR 88 duro TMM | JBR 80 duro PMM | JBR IM and TB TIGS | JBR Boost Tubes | Forge V1 | SSP Full EGR Delete | Balance Shaft Delete | Iridium one step colder sparkplugs | Autotech internals | Koni Yellow Shocks and Struts | Swift Springs | Defi Boost Guage | DDM 6000k 55W Headlights | 5000k 35W Fogs
4 GAL E85 CORN BY THE FREEK
Blue 2011 Triumph Daytona 675 Triple
Last edited by SpeedEngineer; 04-16-2013 at 07:31 AM. Reason: MSF Database - Automerged Doublepost
SpeedEngineer is offline   Reply With Quote
 Old 04-16-2013, 08:02 AM   #40
Zdraveca's Avatar
Groans: 145
turbo has less than 2k miles on it
GT2876r
E85 FREEKTUNE
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f541/not-another-build-thread-142040/
DFW Sunday installs - Page 142 - DFW Mazdas This thread Refback 04-27-2013 08:47 PM
Captain KR's build thread Captain KR Mazda MZR DISI Engine Builds (2006-2013) 28 04-17-2013 07:41 AM
Engine Build Thread EdgeAutosport.com EdgeAutosport.com 47 02-08-2013 02:34 PM
Stavros' build thread stavros Gen2 MS3 General Discussion 6 09-29-2011 11:08 AM
Page generated in 0.58752 seconds with 29 queries
