Like Tree8Likes
 Old 01-11-2017, 08:06 AM   #41
brandon3212's Avatar
Posts: 423   (View Stats)
So some things have changed
Some rear diffuser work, still in the early stages.
Hood vented radiator progress. Still a bunch of sheet metal work to do.
Custom exhaust manifold
Custom intake manifold stuff
Code Monkey likes this.
07 Speed 3
Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01
Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads
Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4
The Following User Says Thank You to brandon3212 For This Useful Post:
Code Monkey (01-16-2017)
 Old 01-14-2017, 08:23 PM   #42
Mattyhawk1's Avatar
Posts: 731   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
Ok, what is going on with the flares and tire/wheel combo? Must have missed you talking about that
Mattyhawk1 is offline   Reply With Quote
 Old 01-16-2017, 10:32 AM   #43
Never got posted up here. Went with 18X10.5" RPF1's with 1 +15 offset. I've got Nitto NT01s in 275/35 waiting to be installed.
07 Speed 3
The Following 2 Users Say Thank You to brandon3212 For This Useful Post:
Code Monkey (01-16-2017), Mattyhawk1 (01-17-2017)
 Old 01-16-2017, 12:01 PM   #44
Code Monkey's Avatar
Posts: 7,632   (View Stats)
^ Same as mine.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
MCS coilovers|Brembo BBK|6UL 17x9|Nitto NT01|ACE 350|Delicious tuned
2000 E39 M5
2001 MR2 2ZZ
 Old 01-17-2017, 10:36 AM   #45
Mattyhawk1's Avatar
Originally Posted by Code Monkey View Post
^ Same as mine.
You mean on your MS6?
What flares are you using?
Last edited by Mattyhawk1; 01-17-2017 at 10:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-17-2017, 10:59 AM   #46
Yes, same ones I use on my MS6.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
 Old 01-17-2017, 07:16 PM   #47
I'm using some fiberglass Ebay flares, I don't recommend fiberglass flares since they dont bend very well.
07 Speed 3
Mattyhawk1 (01-18-2017)
 Old 03-21-2017, 05:26 AM   #48
I have no idea what I'm doing
07 Speed 3
Code Monkey (03-21-2017), Mattyhawk1 (03-31-2017)
 Old 03-21-2017, 03:07 PM   #49
zenit's Avatar
Posts: 1,354   (View Stats)
Groans: 56
Groaned at 7 Times in 6 Posts
headlights are for suckers. @xfeejayx;
Also, welcome to team full-retard racecar.
-feejay
-wetzel
brandon3212 (03-22-2017)
 Old 03-22-2017, 05:51 AM   #50
I originally had it in between the rad and intercooler but it made the intercooler stick out past the bumper so I had to move it. Next thought was to put a fan behind it and vent it through the hood, that didn't fit either.
Just for kicks I stuck it in the headlight area and it actually fit really well. I'm getting a light from the wreckers to cut up.
07 Speed 3
zenit (03-22-2017)
 Old 03-27-2017, 09:32 AM   #51
Diffuser pretty much done, just needs a bit of work on the top side
07 Speed 3
Code Monkey (03-27-2017), Mattyhawk1 (04-03-2017)
 Old 03-30-2017, 01:47 PM   #52
07 Speed 3
 Old 03-30-2017, 03:11 PM   #53
zenit's Avatar
Groans: 56
Is there a reason the tubes are so long?
Are you bracing the turbo?
-feejay
-wetzel
 Old 03-31-2017, 07:26 AM   #54
I did a bit of research and it led me to believe that longer runners are better for top end. I'm sure there's more to it than this but I figured I'd see what I could fit in the space I had available. This also fit well with my exhaust and dump tube placement.
The turbo is still pretty much stock placement so I plan on using the existing brace
07 Speed 3
zenit (03-31-2017)
 Old 03-31-2017, 08:36 AM   #55
Mattyhawk1's Avatar
I am curious how much weight you have added to the car
 Old 03-31-2017, 09:57 AM   #56
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 267
Probs added over 9000grams?
Sent from my Pixel XL
 Old 03-31-2017, 12:59 PM   #57
Diffuser is about 25lb or so, I haven't actually weighed it.
But I've removed all the rear interior, carpets and insulation, front crashbar is also way lighter than OEM. Exhaust, heater core and rear crashbar are also coming out. I'm going to make aluminum under body bracing so that will also save weight.
At the end of the day I should still come out way ahead of what the car weighed stock.
07 Speed 3
 Old 04-03-2017, 12:08 PM   #58
Manifold and turbo are in, needs heat shields.
07 Speed 3
Code Monkey (04-03-2017)
 Old 04-04-2017, 06:17 AM   #59
Mazdazilla6's Avatar
Posts: 3,655   (View Stats)
Always cool to see custom shit. What's with the banjos on the valve cover?
Also, if making a custom manifold, why stick with the shitty stock flange? That's the perfect time to move to something that gives you better options.
And how are you running your hot side charge pipe?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
brandon3212 (04-06-2017)
 Old 04-05-2017, 08:31 AM   #60
They replaced the vent on the back of the valve cover as it didn't clear the manifold.
I have a BNR S3 currently am sticking with it probably until I get a built motor. Cutting off the flange really isn't a big deal for me at all if I decide to swap turbos.
The turbo is clocked and I'll be making an under the motor pipe.
07 Speed 3
Mazdazilla6 (04-05-2017)
 Old 04-06-2017, 07:03 AM   #61
Intercooler is back from welding. Now I can make crash bar mounts and really start getting some progress made on the charge piping.
Getting a new bumper to replace this disaster.
But I now realize I'm still going to need to trim the bottom out of it at the very least to get flow to my entire core. Undecided about trimming the top off the new bumper also. To do it right I really need to add some ducting so it's more than just a giant hole...
The infinite struggle
07 Speed 3
Code Monkey (04-06-2017)
 Old 04-07-2017, 05:41 AM   #62
So I got some slick little brackets made up for my Intercooler. They also have slots that I'll use to mount braces for the splitter.
I've got most of the cold pipe all welded up, still need another bend up top once I get the intake manifold completed. I wish I could make it out of aluminum but I don't have the equipment to weld it.
07 Speed 3
Code Monkey (04-07-2017), jtday (04-08-2017)
 Old 04-11-2017, 08:32 AM   #63
Cold side intercooloer pipe with meth injection completed
Got various things installed or at least fitted.
07 Speed 3
Code Monkey (04-11-2017)
 Old 04-11-2017, 08:33 PM   #64
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 267
 Old 04-12-2017, 05:28 AM   #65
07 Speed 3
Code Monkey (04-12-2017)
 Old 04-12-2017, 11:51 AM   #66
What made you decide on such large piping?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 04-12-2017, 12:39 PM   #67
It's only 2.5" on the hot side, cold side is 3". I copied Corksport, they claim that having a 3" cold side increases throttle response due to the larger air volume in front of the throttle body.
It makes sense, but no idea how effective it really is.
07 Speed 3
Mazdazilla6 (04-12-2017)
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Not another Build thread. :( Mikey MazdaSpeed 3/6 - Build Diaries 606 04-30-2015 12:39 PM
Days On Lot: What cars are moving the quickest and slowest out of showrooms? Haltech Automotive News 0 06-08-2011 03:10 PM
Page generated in 0.47484 seconds with 25 queries
