Like Tree3Likes
  • 1 Post By xtasy
  • 1 Post By xtasy
  • 1 Post By xtasy
 Old 11-23-2016, 08:01 PM   #1
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groans: 98
Groaned at 6 Times in 4 Posts
Neutral  +2 score
Default Xtasy's Sleeper build
Dyno video, 480awhp, 443awtq (Dynosheet on 2nd post)
https://www.youtube.com/watch?v=Nm8qbgFNx9c
Its been awhile since I've posted here. The last time I've posted here was probably many years ago when I had my Mazdaspeed3. Well long story short, I sold the Speed3 because of low compression on cylinder 3. Did not want to deal with it and I did not have the knowledge to deal with it at the time. Here's all the mods that's done to the sleeper speed6 and timeline of how it got there.
Performance Mods/fueling/Random mods:
Cobb Accessport, tuned by FREEKTUNE
Built bottom end, stock head
Manley rods, Wiseco piston. Engine put together by Matt Damond
3.5Inch HTP intake
Grimspeed Ported Intake Manifold
PTE 5858 .82AR
Custom Exhaust manifold
Tial 38mm EWG w/ custom dump pipe
CXRacing intercooler piping
Treadstone Tr8l intercooler
Custom Downpipe
White Widow Catback
6th Port injection w/ dual 800cc injectors
Autotech FP internals
DW65C Intank Fuel pump
Damond Motorsports vented OCC
Jbarone Windage Tray
3 Bar Map Sensor
Cobb EBCS
Southbend Stage 3 Endurance Clutch
Kosmic oil return/drain line
EGR Delete, coolant Bypass
JBR thermal insulating gaskets
Drivetrain/mounts:
Damond Motorsports SSP & Solid Shifter bushings
JBR Full motor mount kit
Corksport rear diff mount
Suspensions:
BC BR Coilovers (awaiting revalve + swift springs)
White line Rear sway bar Kit (will be installed with coils)
Brakes:
EBC Yellow stuff (front and rear)
Might consider Evo Brembos soon.
Free mods:
Weight reduction, stripped out about 220lb of stuff (balance shaft, and washer fluid tank deleted)
Still need to strip out carpets, and front seats for Corbeau 1 piece.
Also need to lose 40lb.
The car is currently sitting at 3380lb.
Future mods:
More weight stripping
Retune for 500+ AWHP
Power steering cooler
Oil cooler
Evo Brembos (front)
Carbotech rear brake pads & new rotors
Corbeau FX1 bucket seats
Looking for OEM style carbon hood
Install Coilovers
Fender flares (rear quarters are rusting, perfect excuse for wider wheels/tires)
Wrap car in Vinyl or liquid wrap using Autodip.
1 More vented catch can
Stainless Clutchline
Exterior Mods:
Not much exterior mods on the car, mainly for the sleeper look.
Bought a Sti Lip, failed to get it to work because the Front mount hangs too low.
The exterior received a 2 stage paint correction followed by Cquartz Paint coating.
Will be stripping off this coating and apply Gtechniq CSL + Exo V2 either on the paint or on top of the vinyl wrap or liquid wrap.
2013-2014
Fast forward a few years. I went from a Mazdaspeed3 to a Honda Fit (don't even ask, midlife crisis, hated that car.) Then 5 months after, bought an Audi B5 S4. Loved that car, but it was a pain to work on. There's also no legroom in the back, tiptronic trans slips when it is cold. End up selling it after the stupid waterpump exploded.
December 2014
After 1.5 months of having no car. I decided to go to a local dealership and check out an Evo 9 MR. I somehow almost ended up with a 2007 Subaru WRX STI. Luckily the bank wanted 20%+ APR. I ended up walking out, lucky I didn't get that car. I probably would've hated it. Went home and jumped on Craigslist. Low and behold, there was a Mazdaspeed6 with a blown motor (spun bearing) on craigslist. It was 8 hours fresh and I messaged the guy right away.
December 29 2014
Went and check it out the same day and end up purchasing it. He originally listed it for $3,500. The car had 129k miles on the Odometer, single owner, Grand Touring with GPS and Sunroof, Cobb AP, CAI, brand new brakes and clutch installed with less than 800 miles before the spun bearing. Ended up talking the price down to $2,300 and the $90 flatbed tow home. Cool guy, I still keep in contact with him.
The plan for the speed6 was to have the motor pulled, drive 100 miles to a known machinist that @phate recommended. Order gaskets, Vvt kit, forged Pistons and rods. And have @mattdamond put the motor together for me and make it on time for the dyno tune.
January 2015
On January, I ordered a full vvt and gasket rebuild kit as well as some misc stuff like HTP 3.5 intake, Grimspeed EBCS, Grimspeed Ported intake manifold. Full JBR high Duro motor mounts & Corksport Rear Diff mount, Autotech HPFP, EGR delete, Corksport injector seals, 3 bar map sensor. Probably a lot more that I forgot to list.
February 2015
There was a guy that was selling a complete turbo kit on one of the FS page on facebook. (EBCS, 3 inch JBR intake, Treadstone intercooler, custom pipings, PTE5858 w/ .82AR, custom Exhaust manifold, and Tial wastegate/dumppipe). I end up picking up this kit for $2,500. Sold the 3 inch JBR intake and the Grimspeed EBCS I originally purchased.
Because of the turbo kit, I realized that the stock clutch is not going to handle the power. The motor and trans was already out, so I might as well order a new clutch. Save money in the long run. Ended up ordering a Southbend Stage 3 Endurance clutch. I didn't know a stage 4 existed. But nonetheless, this is a great clutch and I don't regret my decision.
March 2015
The motor is finally pulled, I had about 3 months to get the motor machined, put back together, reinstall the motor AND break it in before Justin from Freektune flew in to dyno tune our cars. I dropped the motor off to the machinist on mid or late March, I was told that the motor will be ready in roughly 2 months.
April 2015
Received bad news from the Machinist, the damage to the crank was excessive and it needed a new crank. Lucky for the great community, someone sourced me a crank for $500. The crank was already measured and polished, but the machinist checked the measurement again anyways). The shipper was nice enough to have the crank shipped to the machinist. So I didn't need to drive that 200 miles round trip.
May 2015
Late May, I received a phone call from the machinist saying that he needs me to drop off something, I don't remember what it was exactly. I went there and dropped it off, in hopes that I can pick up the motor the same day. The machinist told me that it won't be ready for another few days. So we went ahead and eat around the area. About 75 miles back home, I received a phone call from the machinist, the motor is ready. We went back and picked it up. The next day, we dropped it off at Matt Damond's house. He assembled the motor within a few days.
Reserve + posting pics
Varomnia likes this.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
Last edited by xtasy; 11-23-2016 at 10:29 PM. Reason: MSF Database - Automerged Doublepost
xtasy is offline   Reply With Quote
The Following 4 Users Say Thank You to xtasy For This Useful Post:
Code Monkey (11-23-2016), Gerbilo (11-29-2016), Snyeed (11-23-2016), Varomnia (11-23-2016)
 Old 11-23-2016, 08:34 PM   #2
xtasy's Avatar
Groans: 98
May 28 2015
The motor is ready to be picked up on May 28th. Right after picking up the motor, I dropped it off at my mechanics. It took nearly a week to get the motor in, rear motor mount bolts were missing, shifter cable was stretched and broken, driveshaft boot ripped, had to grind off couple mm of metal from the block in order to clear the turbo. I also made a mistake of not checking if southbend provided a new throw out bearing. Luckily Mazda had one in stock.
I had exactly 2 days to break in the motor. I was only able to put 200 miles on it. The shifter cable issue took up a whole days worth of time. We ghetto fix the cable because putting in a new one requires the dash to be taken off. And that's a 10+ hour job. Ended up crimping the cable back together. It lasted roughly a rear before I decided to launch the car a little. Sourced another cable, my mechanic was able to somehow fish the cable in and get it done within 2 hours.
May 30 2015
It was time for the tune. The car felt really healthy and responsive. Because of the amount of time we had, we couldn't install the FMIC. Ended up dynoing the car with the stock top mount intercooler and stock bpv.
Dyno numbers were 322AWHP/337AWTQ. Sorry can't find the dyno sheet. Ran out of fuel. But the car pulls great.
Fast forward 1 year later (May of 2016)
The car pulls great. Had the following replaced/Added/removed:
New drive shaft boot
New rear Diff
New power steering pump/line
6th Port injection
DW65C In tank Fuel pump
Weight Reduction (everything behind driver seat is removed)
The car received another Dynotune from Justin @freektune. (Same dyno, roughly 1ish year later)
This time it made 480Awhp/443awtq. It maxed out the 3bar map sensor.
I made a mistake of not changing it out for a 3.5 bar map sensor. Deeply regret it, was hoping for 500awhp. Hopefully Justin will make another trip back and I'll get the 3.5bar in, as well as some other small stuff.
Shortly after the tune, I realize the stock brakes isn't keeping up to the task. Ended up switching the brakepads for EBC yellowstuff and stainless brakelines. Great brake pads, needed to be warm up a little before stomping on the brakes. Probably going to switch over to Evo brembos in the near future.
Code Monkey (11-23-2016), impossible (03-20-2017), Snyeed (11-23-2016), Varomnia (11-23-2016)
 Old 11-23-2016, 08:58 PM   #3
Varomnia's Avatar
Posts: 387   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
Originally Posted by xtasy View Post
May
WOW!
Thanks for posting this. Love your write up!
I was just about to buy the 3 bar until you said this. Now i'll just go futureproof myself and get the 3.5 bar instead. Thanks a million! *travesty avoided
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
The Following User Says Thank You to Varomnia For This Useful Post:
xtasy (11-23-2016)
 Old 11-23-2016, 09:12 PM   #4
xtasy's Avatar
Groans: 98
Originally Posted by Varomnia View Post
WOW!
Thanks, it was a simple mistake I overlooked. I completely forgot that the car had a 3 bar map sensor. Hopepfully the next dyno run will be at 550 awhp or somewhere close to that.
The Following User Says Thank You to xtasy For This Useful Post:
 Old 11-27-2016, 11:25 PM   #5
sj9ers's Avatar
Posts: 25   (View Stats)
sj9ers is an unknown quantity at this point
What parts did you use to replace the driveshaft boot? Mines torn right now and the only to fix it from what I can find online is to replace the whole shaft because the boot isn't sold separately
Sent from my SAMSUNG-SM-G920A using Tapatalk
sj9ers is offline   Reply With Quote
 Old 11-29-2016, 06:21 PM   #6
xtasy's Avatar
Groans: 98
MAZDASPEED 6 PROPELLER SHAFT CV BOOT
 Old 11-29-2016, 07:36 PM   #7
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
Looks like you've been busy. Thanks for sharing, keep up the good work. I'll have to keep an eye out around the city for the sleeper.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
 Old 03-20-2017, 12:07 PM   #8
Jrs7686's Avatar
Posts: 152   (View Stats)
Jrs7686 will become famous soon enoughJrs7686 will become famous soon enough
Groaned at 12 Times in 8 Posts
With those power and torque numbers, is there anything else you need to upgrade for the drive train? Transfer case, axes, mounts? Do you launch the car hard?
Jrs7686 is offline   Reply With Quote
 Old 03-20-2017, 08:56 PM   #9
impossible's Avatar
Posts: 723   (View Stats)
Groans: 30
Probably would want to do upgraded t-case bearing caps from White Widow or SP63 if you're gonna be launching often at this power along with DSS rear axles. That's all the upgrades that I'm aware of for the MS6 outside of upgraded diff + motor/trans mounts etc. Custom single-piece driveshaft wouldn't hurt if you're gonna really be dogging on this thing from 0mph often.
2009 Mazdaspeed 3 w/ Manley Forged, keyed and lightened crank, ported, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo setup underway. PD Tuned by Ryan Martin.
MS3 is a sleeper on OppositeLock jk_ms3 Mazdaspeed3/6 General Discussion 35 12-07-2013 07:42 PM
Page generated in 0.32430 seconds with 26 queries
