> 2010 MS3 - Build Diaries
2010 MS3 - Build Diaries Genpu - General Build Threads/Diaries.
Like Tree7Likes
 Old 11-10-2017, 08:58 PM   #41
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
You already thanked Bexar 3 days ago...Velocity's mod journal
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
Bexar (11-17-2017)
 Old 11-10-2017, 11:41 PM   #42
Velocity_Speed_83's Avatar
Posts: 88   (View Stats)
Velocity_Speed_83 is a splendid one to beholdVelocity_Speed_83 is a splendid one to beholdVelocity_Speed_83 is a splendid one to beholdVelocity_Speed_83 is a splendid one to beholdVelocity_Speed_83 is a splendid one to beholdVelocity_Speed_83 is a splendid one to beholdVelocity_Speed_83 is a splendid one to behold
i didn't get a chance to actually reply back because i was at work so Relax buddy
COBB AP V3 || Autotech Hpfp Internals || NGK Iridium One Step Colder || CP-E RMM || JBR Solid Shifter Bushings ||Damond SSP || JBR Shift Knob || HTP 3" Intake || HKS SSQV V4 3P kit || Corksport Test Pipe|| 51r Battery & JBR ||Stop Tech Full Brake Kit || Battery Tray || ETS TMIC || CP-E Triton Cat Back Exhaust || Purple Drank Tuned 91 oct 276whp / 330wtq @21 || 329whp / 378wtq @ 21psi E30 MIX ||
Velocity_Speed_83 is offline   Reply With Quote
 Old 11-23-2017, 12:58 PM   #43
11/23/17 update
looks like my black friday shopping came early today i bought a used Cp-e triton cat back exhaust from a fellow speed owner that's trading his car in to get something newer so i couldnt pass this opportunity up got a really good deal on it
 Old 11-23-2017, 02:00 PM   #44
krimsonviper's Avatar
Posts: 61   (View Stats)
krimsonviper has a spectacular aura aboutkrimsonviper has a spectacular aura aboutkrimsonviper has a spectacular aura about
Groaned at 4 Times in 2 Posts
Not sure if you know this, but that’s suppose to be installed underneath the car. I’m scared to know how you installed it there
krimsonviper is offline   Reply With Quote
 Old 11-23-2017, 02:25 PM   #45
Fstrnyou's Avatar
Stealth mod. It's much quieter outside the car.
krimsonviper likes this.
Other rides:
History:
 Old 11-23-2017, 08:00 PM   #46
Originally Posted by krimsonviper View Post
Not sure if you know this, but thatís suppose to be installed underneath the car. Iím scared to know how you installed it there
lol WTF 😆
 Old 11-23-2017, 08:13 PM   #47
need to either borrow or buy two jack stands i have two at home but the guy i bought it from said it will be much easier with four to get under the car to unbolt everything and get the car as high off the ground. i need a impact gun also so i can do my install to make it go fast and smoothly he also mention it was a pain without one the bolts were super hard to take off
 Old 11-23-2017, 10:42 PM   #48
Originally Posted by Velocity_Speed_83 View Post
lol WTF 😆
Velocity_Speed_83 likes this.
 Old 12-07-2017, 02:14 PM   #49
update 12/7/17
switching from my NGR type S to HKS ssqv v4 . i purchase the bov on black friday since it was a pretty good deal . i originally purchase the Cp-e hks kit but it turns out they ran out of the kit and they wouldnt receive the cp-e up to 4 to 5 weeks i was told so i got a call from edge and they offer me to get another kit so i end up getting the 3P performance kit with the recirculated fitting and vent to atmosphere plug . the only difference between the Cp-e version is it came with a by pass recirculated hose and the flange is polished and the 3P is black and comes with a vta plug . now i been reading about vta and i know it's bad for our cars and any car in general but i kinda want to experience it for myself since i have the plug to vta just for a week to see how it feels and switch back to recirculated fitting
 Old 01-20-2018, 01:28 AM   #50
so haven't updated in awhile a lot has happen last month the first thing i want to talk about is the 3p performance flange i got didn't line up correctly with the cold pipe the bolts didn't line up correctly either so i contacted edge autosports to see if i can get a exchange it here is some pictures.
edge exchange the flange out for me it took a couple weeks due to they had to warranty it out through 3p performance and i had to provide proof . the fitment sucks with this flange and found out from another person on Instagram they had the same issue after i got my new replacement. i wish edge had the Cp-e flange in stock so i wouldn't had go through the headache
 Old 01-20-2018, 01:54 AM   #51
update 12-9-17 installed my exhaust finally came out pretty good the sound of the triton is amazing only thing i needed to buy new exhaust hangers because i was getting exhaust rattle and vibration against the subframe and my AP was picking up false knock since it was moving around so i decided to order new hangers when i got paid pictures below
 Old 01-20-2018, 01:19 PM   #52
update 12-11-17
i was on my way to work and i was merging on to the free way and i do my normal thing check all my mirrors before i get into a lane i was clear and i was driving in the middle lane for about 2 to 3 mins then i get hit from my drivers side by a gmc sierra truck the guy side swipe me and i bounce and hit another car but the person to the right side of me took off and left the scene. I'm guessing they didnt have insurance ? the guy that hit me try to blame the whole accident on me saying i hit him which is crazy ! long story short i had my car in the shop for three weeks and they repaired it and i won my case and got a check for $500 since i didnt use my rental car insurance it paid itself out and i got reimbursed the deductible
pictures below
 Old 01-22-2018, 10:04 AM   #53
Glad you’re ok!
Invest in a dash cam. I want one, but my GoPro is working it for right now. People are fucking crazy
If Iím asking a question:
1. I searched and my question is a little unique to my situation.
2. My search-fu is weak.
3. The answer might have gone over my head and I need clarification.
Not modding just to mod. If something in maintenance comes up and aftermarket offers me something Iíll probably take it.
The Following User Says Thank You to krimsonviper For This Useful Post:
Velocity_Speed_83 (01-22-2018)
 Old 01-22-2018, 04:14 PM   #54
Glad youíre ok!
Thanks man ! yeah I'm thinking about investing in a dash cam my mother in law mentioned i should buy one also . i have a friend that has one and he told me he would help install it if i need help
 Old 01-22-2018, 04:25 PM   #55
update 1-5-18
i got my car back ! only thing my fenders and bumper is a shade darker then the oem oh well i guess it'll never be perfect since the accident
 Old 01-22-2018, 04:27 PM   #56
Fstrnyou's Avatar
On my 6, the front and rear bumper appear a bit darker in most lighting scenarios. Bugs the shit out of me.
Other rides:
History:
 Old 01-22-2018, 04:30 PM   #57
yeah this kind of bugs me too ! everyone can tell it's been repainted now
 Old 01-22-2018, 04:44 PM   #58
update 1-6-18
i finally got my flange replacement from 3p performance and my oem hks o-ring and snap ring replacement i forgot to mention that the original o-ring and snap ring popped off when i was testing it out once i hit 5psi lol i end up losing it on the street somewhere so i had to order another one
 Old 01-23-2018, 01:29 PM   #59
update 1-5-18
Iíve always thought about this: why not find another vehicle with the body part you need in perfect and replace it that? That way you donít have to deal with mismatched paint. The body shop I use has always been immaculate in paint matching, but if they ever leave, this is the route I was going to take. I donít know much about body panels.
 Old 02-16-2018, 08:37 AM   #60
update 1/13/18
I finally got the hks on the car with the new flange and gasket and snap ring
The car holds boost really good haven't had any issues so far . Recirculated the hks is quiet to me and I actually like it that way compare to my NGR Type S was really Loud but sounded really cool
The Following User Says Thank You to Velocity_Speed_83 For This Useful Post:
sagrav (12-01-2018)
 Old 02-16-2018, 08:49 AM   #61
update 1/17/ 18
I order some cobb exhaust hangers man these things are solid !!!! I'm glad I order the new hangers I got tired of my exhaust moving around vibrating . also I had a exhaust leak and finally got around to fixing it the car was super loud with the leak lol. I guess the oem hangers where moving too much and cause one of my clamps on the exhaust to come loose . The new hangers also made my exhaust tips pushed in little more I felt like they stuck out too much
krimsonviper (02-17-2018)
 Old 02-16-2018, 09:03 AM   #62
1/19/18 91 map 2/8/18 E30 mix map
decided to go with purple drank for my full custom tune as a early birthday gift to myself lol . the tune is amazing ! the car pulls hard !!!! I finished my 91 map couple weeks ago and already started my E30 MIX Map !
 Old 02-16-2018, 09:12 AM   #63
painted the ETS Plate black looks so much better
File Type: png Screenshot_SmartSelect_2018-02-16-08-04-57.png (1.59 MB, 3 views)
 Old 02-16-2018, 09:31 AM   #64
The same week I painted my plate for the ETS I put 4 Gallons of E85 to start my E30 mix the car feels so much faster and powerful on E30 it's insane !!!! a lot more torque steer lol I think at this point I'm either close to 300whp or a little over 300whp I want to dyno it once I'm done with my E30 mix so I can find out how much power I'm making with both of my maps 91/ E30 ! Will & Ryan are amazing tuners I'm glad I got a full custom tune with them !
 Old 02-16-2018, 09:36 PM   #65
virtual dyno graph not sure how accurate this is but i should be close to the numbers . i sent my data logs in this morning waiting on my 2nd revision map
 Old 02-17-2018, 05:38 AM   #66
Benis's Avatar
Posts: 413   (View Stats)
Benis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the worldBenis is the leader of the world
2-10-18
Nice! Looks great!
2013 MS3 BM
Cobb AP, SRI, TIH
OBX Test Pipe
JBR RMM
Autotechs
E85 Freektune
Benis is offline   Reply With Quote
The Following User Says Thank You to Benis For This Useful Post:
Velocity_Speed_83 (02-17-2018)
 Old 02-22-2018, 08:54 AM   #67
my 2nd revision map i made some really good power on E30 for the ko4 !
 Old 02-23-2018, 11:54 AM   #68
update 2/23/18
I got my last revision map for E30 2/21/18 from Will i flashed the car this morning and did a couple data logs the car feels so smooth and the way it delivers power ! Will Dawson is a amazing tuner hands down ! i was curious to see how much power i was making now so i did another virtual dyno pull from my data logs from this morning this is 4th gear traction control turn off . i made 329whp 378wtq on the ko4 very impressive numbers and that was my goal for the stock turbo i made it finally .I'm pretty happy for now but still plan on doing more mods for the car Cp-e full downpipe , bigger turbo bnr s3 or corksport 18g , ebcs and 3 bar map sensor retune the car new wheels and tires and suspension next goal is 350 - 370whp !
File Type: jpg PD - E30 Final map 329whp - 378lbft.jpg (91.8 KB, 10 views)
Last edited by Velocity_Speed_83; 03-27-2018 at 06:38 AM. Reason: left somethings out
krimsonviper (02-25-2018)
 Old 04-21-2018, 12:32 AM   #69
update 4-3-18
i wanted to do some updating i got a bonus check from work and decided to buy the stop tech full brake kit with slotted rotors front and back . i got the kit from edge auto because of the tax season promo was going on couldn't pass up the opportunity
Db09ms3 (04-21-2018)
 Old 04-21-2018, 12:36 AM   #70
update 3-29 -18
i bought a damond SSP it feels perfect ! not too short just in between a good medium only took five mins to install
 Old 04-21-2018, 12:42 AM   #71
update 4-19-18
finally got a 3 bar map sensor from jbr for $60 i sold my old apexi air fuel controller form my old dsm got $75 for it which was cool and a good opportunity to get a map sensor in exchange now i just need is a ebcs next on the list
 Old 12-01-2018, 12:51 AM   #72
sagrav's Avatar
Posts: 1   (View Stats)
sagrav is an unknown quantity at this point
Any updates on this good work car came along great!
sagrav is offline   Reply With Quote
 Old 12-01-2018, 11:00 AM   #73
I'll update Soon I still plan on getting the corksport turbo, corksport ebcs, cp-e catted downpipe and also a retune with will dawson and a few other small things I will update 2019 forsure thanks for asking man
sagrav likes this.
Scored cam journal Motorheaddad MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-20-2017 08:41 PM
2013 LSM Photo Journal R3V 2010 MS3 - Build Diaries 8 07-09-2014 04:48 AM
how long do Journal Bearing turbo's last ? jracer MazdaSpeed 3/6 - Big Turbo Builds 16 03-09-2011 12:16 PM
U.S. to hire adviser for GM stock offering, Journal says Haltech Automotive News 0 05-16-2010 10:10 PM
Precision 5557 Impressions (journal bearing) cageyvet MazdaSpeed 3/6 - Turbo Induction 9 02-28-2010 12:11 AM
©Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.56040 seconds with 25 queries
