 Old 07-16-2011, 07:03 PM   #1
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Default 2011 Deleted Resonator..Impressions and story
So I wanted to delete my resonator on my 2011 to gain some additional sound...that was the plan. I take it to the shop and they say ok $65 because we have to take off the plate that connects the frame to get to the resonator and use 2.5" pipe....i'm like really 8 bolts increase the price...whatever. I wanted it done so I agreed. I wait 20 minutes and the car is lowering on the rack. They start it and rev it up...um did I ask you to rev out my engine???...again whatever. I say ok thank but can you lift the car so I can see the work and the welds, and they say sure. They raise the car and the welds look great...nice job...then I look at the pipe. It looks smaller than my factory pipe except for the ends which are 2.5" flared. I say hmmm, that appears to be 2.25" pipe....the exhaust guy says noooooo its 2.5". He looks at the part number on the pipe and guess what, 2.25 fucking inches....total idiots. I reply to this saying this is not going to do, I am not going to have 2 different pipe diameters disrupting my flow path because you failed to follow instructions. Take it off and start again. So the idiots do it all over again and I wait more. At the end of the ordeal the resonator is off and the 2.5" is on...but holy shit how hard is it to follow instructions.
Impressions of mod....both my cats are in place, stock downpipe as well. Only thing changed is the resonator is removed. Car is 100 percent stock other than that. The sound difference is extremely minimal at best. Im hoping that when I go to a race pipe I'll get some increased sound from the combo, but for those looking to increase exhaust sound on the cheap I will have to say that the single resonator delete on the 2011 Genpu will NOT get whatever sound you are looking for, it will continue to give you stock like sound. Take care!!!!
Mike
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 3 Users Say Thank You to mrmonk7663 For This Useful Post:
CrKeKi_13 (07-27-2012), DingoDave (07-17-2011), thanox2 (07-17-2011)
The Following User Says NO Thank You to mrmonk7663 For This Un-useful Post:
sellers (08-24-2011)
 Old 07-16-2011, 07:06 PM   #2
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
Cool
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
The Following 2 Users Say Thank You to Mchart For This Useful Post:
Monotonous ONE (07-16-2011), sellers (08-24-2011)
 Old 07-16-2011, 07:07 PM   #3
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
Was going to do this, and I am not now lol.
Sent from my HTC Vision using Tapatalk
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 07-16-2011, 07:37 PM   #4
mrmonk7663's Avatar
If you want to do this mod to gain exhaust sound, and this is the only thing you will do to your exhaust....I would say don't do it. The racepipe may change things up, I will have to wait and see how the 2 mods combine together later after I figure out what my options for race pipes are. I need to find who makes downpipes AND racepipes...where I can do the mods one at a time. I would do a racepipe now, but I won't touch a downpipe until I upgrade the fuel pump. Are racepipes for the gen1 and gen2 the exact same or not? OBX sells one for like $80 but its listed as a gen 1. The authorized vendors told me I can try it out and if it works great, if not return it...but I don't have time to "try the fitment out" and just cross my fingers.
 Old 07-16-2011, 07:40 PM   #5
manelscout4life's Avatar
Posts: 1,781   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
Neutral  -1 score
get real mods
manelscout4life is offline   Reply With Quote
The Following 9 Users Say Thank You to manelscout4life For This Useful Post:
BigJimMs3 (07-16-2011), faeker (07-17-2011), KusteLokal (10-22-2011), Pendarus (10-21-2011), predapio (07-17-2011), sellers (08-24-2011), TexasSpeed3 (07-18-2011), thehead (10-25-2011), WAHBAM (10-22-2011)
 Old 07-16-2011, 07:43 PM   #6
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
Sounds ricey to go through all that just for sound. For $100 you could have bought a test pipe, done the mod yourself, and actually got some real gains.
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
Originally Posted by Monotonous ONE View Post
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
The Following 8 Users Say Thank You to emag remrofni For This Useful Post:
BigJimMs3 (07-16-2011), DingoDave (07-17-2011), faeker (07-17-2011), manelscout4life (07-16-2011), Pendarus (10-21-2011), predapio (07-17-2011), sellers (08-24-2011), TexasSpeed3 (07-18-2011)
 Old 07-16-2011, 07:52 PM   #7
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
hmmmmmmm......i have my resonator removed but also my exhaust cut off and replaced with straight pipe and a test pipe....sounds like a beast now
surebOOst is offline   Reply With Quote
The Following 3 Users Say Thank You to surebOOst For This Useful Post:
BigJimMs3 (07-16-2011), kyzomo (07-16-2011), reckywind (07-17-2011)
 Old 07-16-2011, 08:05 PM   #8
mrmonk7663's Avatar
Ricey, I am anything but ricey. (and even if this is considered a "ricey mod" the mod did almost nothing so the rice is hidden haha) I come from domestic supercharged custom built v-8 mustangs running 10's...this is my daily driver and first 4cyl car in my life. I want to get a racepipe, I plan on it, just not sure of my options. I am not sure because I want a racepipe that I can later add a Downpipe with that has a cat. Im not sure what the options are for that setup. Some companies offer it as a one piece downpipe (not what I want) some piece offer separate downpipe/racepipes for good prices, but no cat on the dp, and yet some companies offer downpipes/racepipes listed as Gen1 cars...not gen 2, so I need assistance in this area for product fitment. As for doing the mod myself, I have a welder...but if I would try to weld the top of the pipe that close to the floor I would have 100% burned a hole into the interior of my car.
At the end of the day, the mod is done, and is NOT worth the time or money. "REAL" mods are already on order.
 Old 07-16-2011, 08:07 PM   #9
Mchart's Avatar
Groans: 54
Not even worth messing with the exhaust until you fix the downpipe and cats. Not to mention the stock exhaust note on the Gen2 is actually pretty decent for being stock compared to a lot of other cars.
 Old 07-16-2011, 08:20 PM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Originally Posted by surebOOst View Post
hmmmmmmm......i have my resonator delete removed but also my exhaust cut off and replaced with straight pipe and a test pipe....sounds like a beast now
Resonator delete removed?
So you have a resonator now that you had once deleted?
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
JS + MS3 (07-16-2011), kyzomo (07-16-2011), ms3speeed (07-17-2011), predapio (07-17-2011), Pu Manchu (07-16-2011), Teethkikr (07-17-2011), TexasSpeed3 (07-18-2011)
 Old 07-16-2011, 08:29 PM   #11
Jake5713's Avatar
Posts: 1,775   (View Stats)
Corksport sells downpipe/ raveling separate
Jake5713 is offline   Reply With Quote
 Old 07-16-2011, 08:30 PM   #12
Jake5713's Avatar
Edit racepipe stupid iPhone
The Following User Says Thank You to Jake5713 For This Useful Post:
 Old 07-16-2011, 08:33 PM   #13
Tokay444's Avatar
Groans: 793
You know, you can just edit the original post, rite?
Demodded.
The Seals
 Old 07-16-2011, 09:00 PM   #14
surebOOst's Avatar
exactly....i put in a highly modified resonator after i removed the resonator deleted gone not there anymore powhhhh just like that.
 Old 07-16-2011, 09:04 PM   #15
Tokay444's Avatar
Groans: 793
Now you're just talking crazy talk.
Demodded.
The Seals
breakfasteatre (05-20-2012)
 Old 07-16-2011, 09:11 PM   #16
mrmonk7663's Avatar
Yes corksport has them separate but they don't offer a carted dp as far as I could see.
 Old 07-16-2011, 09:12 PM   #17
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
You can just do what i did for a total of like $280 Custom testpipe/res. delete/ straight pipes
reckywind likes this.
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
 Old 07-16-2011, 09:19 PM   #18
surebOOst's Avatar
&#x202a2010 Mazdaspeed 3 exhaust 5&#x202c&rlm; - YouTube
damn you payed $280? I payed $180 for tp, ans straight pipe all the way back.
always wondered how it sounded outside the car though! Nice
 Old 07-16-2011, 09:25 PM   #19
BigJimMs3's Avatar
Groans: 76
Yea i think the tips cost like $20 each lol fuck it.... it looks nice lol
2006 Mazdaspeed 6
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
Stock
 Old 07-16-2011, 09:26 PM   #20
mrmonk7663's Avatar
But even if I did what you all did who sells a catted dp that would work for later? Cpe is one piece. Cnt is one piece. ATP is non catted. Corksport is non catted.
 Old 07-16-2011, 09:30 PM   #21
surebOOst's Avatar
I payed like 50 for my exhaust tip but i had it as an single exit exhaust! Its loud as shit and im happy with it. I always get compliments on it after i race someone!
 Old 07-16-2011, 09:31 PM   #22
327whp's Avatar
Posts: 231   (View Stats)
327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute
Groaned at 7 Times in 5 Posts
This is a good reminder to those to not cheap out and do do things properly. Hope you get what you want in the end.
2010 Red MazdaSpeed 3 (281whp) - Traded in
2008 Crystal Red C6 Corvette (402whp)
Still have stock MS3 wheels with Blizzaks
327whp is offline   Reply With Quote
The Following User Says NO Thank You to 327whp For This Un-useful Post:
sheldonross (10-24-2011)
 Old 07-16-2011, 09:34 PM   #23
surebOOst's Avatar
Neutral  -1 score
Originally Posted by mrmonk7663 View Post
But even if I did what you all did who sells a catted dp that would work for later? Coe is one piece. Cnt is one piece. ATP is non catted. Corksport is non catted.
Custom DP??? Ebay and craigslist? Just trying to help!
Ive always felt straight pipe FTW! Its less restrictive and sounds mean as shit!
Last edited by surebOOst; 07-16-2011 at 09:34 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-16-2011, 10:28 PM   #24
mrmonk7663's Avatar
I wasn't trying to "cheap out" I was simply removing a piece of hardware (resonator) from my car that was 100% not needed. I replaced it with a superior piece...the 2.5" pipe. Did I get the result I was looking for....nope....was I suprised at the result...nope. I posted on here to tell others that for the gen2 the mod isn't going to get you any real change in sound, and moreso than that, the story about the mod and the shop I found comical and wanted to share :-) I read through a ton of resonator delete threads on the gen1 cars so I figured since my "real mods" are in the mail, and its Saturday and i'm bored, i'll give this a try. And still, i'm thinking once the race pipe is on the combination of the 2 pieces being removed might actually give me an exhaust tone i'm happy with. We shall see!!!
The Following User Says Thank You to mrmonk7663 For This Useful Post:
NOreasonY (07-19-2011)
 Old 07-16-2011, 10:53 PM   #25
mrmonk7663's Avatar
Ok, I found a company that makes the 2 pieces I'm looking at...catted downpipe and separate test pipe. Ultimate Racing is the company. I just did a search and have also found that this company had an original design with the o2 bung in a bad spot that made the CEL trigger....and later they had a revised design that put the bung in the exhaust stream on the 3" pipe. So this should work for me. I don't know much about this company other than what I just read on this forum and their website, but I like their dyno graphs...the graph shows that the peak HP with their test pipe is only 1.5hp more than stock...it then shows that below max the gain is at times up to 10hp....the point being they aren't saying the pipe adds 10hp above and beyond what you have, just that it adds horsepower and at some points in the curve up to 10hp greater than stock.....I guess i'm saying I like that they aren't trying to market the pipe based on a peak horsepower number....anyway, this thread has gotten off topic (my fault). Take care yall.
 Old 07-16-2011, 11:10 PM   #26
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
Im actually glad you did this. I have been considering this for a while, but have been leaning more towards straight pipe all the way back.
To answer your question earlier, race pipe is the same between gen1 and gen2
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
 Old 07-16-2011, 11:21 PM   #27
mrmonk7663's Avatar
Well then i'm glad my experiment helped someone save some time and money. Also thank you for the racepipe info, its appreciated. When I do the racepipe I will update this thread and report how the sound changes.
 Old 07-17-2011, 07:09 AM   #28
Tokay444's Avatar
Groans: 793
Cnt makes a catted dp.
Demodded.
The Seals
 Old 07-17-2011, 07:37 AM   #29
Teethkikr's Avatar
Posts: 677   (View Stats)
Teethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the worldTeethkikr is the leader of the world
Groans: 50
If you arent happy with just the res delete.. Absolutely do delete the 2nd cat.. I can run stage 2 on AP and it sounds mean..
2012 CWP Tech Package:
Powdercoated Rx-8 Wheels//35% Tint//Cobb SRI//COBB TIP//CS LED Kit//UR Test Pipe//Autotech Internals//TRZ RMM//Painted Front Grille//Painted Emblems//
Teethkikr is offline   Reply With Quote
 Old 07-17-2011, 09:27 AM   #30
Jake5713's Avatar
Yeah going to put on a UR test pipe and downpipe on to my corksport cbe when I have a AP and the CPE fuel pump UR's products look great plus corksport's dp throws a CEL
 Old 07-17-2011, 09:36 AM   #31
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
Can u post some pics
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 07-17-2011, 10:08 AM   #32
Aetherfury's Avatar
Posts: 1,227   (View Stats)
Aetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the world
Go look for my thread on this from like a year ago. There is a video of the res delete + test pipe. It makes a huge difference to have the test pipe.
I drive a white car with a HUGE spoiler
Cobb Accessport Stage 1 + Cobb SF Intake
Aetherfury is offline   Reply With Quote
 Old 07-17-2011, 10:27 AM   #33
surebOOst's Avatar
Yea np. I will take some i a little later when i go out.
The Following User Says Thank You to surebOOst For This Useful Post:
2011speed (07-17-2011)
 Old 07-17-2011, 11:13 AM   #34
thanox2's Avatar
Posts: 1,236   (View Stats)
thanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the world
Groans: 639
Groaned at 39 Times in 29 Posts
Resonator delete always yields better sound from these cars...
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." Most people would have just called it "wrong-wheel drive."
thanox2 is offline   Reply With Quote
 Old 07-17-2011, 11:42 AM   #35
mrmonk7663's Avatar
Maybe its better driving...but I'd have to be outside listening. As far as reving the motor up and being outside of the car....the difference is miniscule on my car, imho.
 Old 07-17-2011, 01:23 PM   #36
Toymachinespeed's Avatar
Posts: 244   (View Stats)
Toymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the world
Groaned at 7 Times in 3 Posts
I am wondering on what you guys do exactly when you say you straight pipe your exhaust. Like after the first cat you just put straight pipes all the way? Just trying to clear things up cause I don't want to spend the money on an exhaust system ATM and if this is an option it sounds like a good idea.
2011 Black Mica Mazdaspeed3 w/ Tech Package
CorkSport SRI/TIP Combo: COBB AP Custom Tune @20psi: Autotech Internals: OBX Racing Cat Back: CNT Catless Long DP: CPe TMIC: Forge V1 BPV:
JBR 80 duro RMM: JBR SSP+Knob+Bushings: H&R Springs: Rota G-Force 18x8.5 +48 Continental Extreme Contact DW 235/40/18:
Toymachinespeed is offline   Reply With Quote
 Old 07-18-2011, 08:35 PM   #37
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
It could just be me and my old age, but straight pipes annoy the fuck out of me. I'd much rather get a nice sounding exhaust.
Mods: stock
The Following 3 Users Say Thank You to faeker For This Useful Post:
Broxer (10-25-2011), nick779 (07-20-2011), Tokay444 (07-19-2011)
 Old 07-19-2011, 02:07 AM   #38
surebOOst's Avatar
I have pics i just gotta post up later. Straight pipe for me is straight pipe from the testpipe back. Once i get a full catless dp it will ve a complete straight pipe turbo back. Its loud as hell now and sounds mean as shit boosting but thats what i like. Something i can piss of muscle car guys with and just FFS all the time.
 Old 07-19-2011, 08:36 PM   #39
turbomzr's Avatar
Posts: 21   (View Stats)
turbomzr can only hope to improve
Groaned at 17 Times in 7 Posts
Cool thanks
turbomzr is offline   Reply With Quote
 Old 07-20-2011, 02:44 AM   #40
ShadowHunter117's Avatar
Posts: 55   (View Stats)
ShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to beholdShadowHunter117 is a splendid one to behold
I too have gotten the res delete on my 2011 and I was admittedly a little disappointed as well. There is a small difference in tone and loudness (it sounds a little deeper), but it probably isn't worth the 50 or so dollars it cost.
As for the place I got it done, I thankfully did not have any of the problems the OP had, or other horror stories I have read about.
ShadowHunter117 is offline   Reply With Quote
Deleted balance shaft meeker13 MazdaSpeed 6 - Engine, Transmission & Driveline 18 02-22-2013 06:37 PM
Did my thread get deleted? 06Speed6 Website Help/Feedback 4 10-03-2008 05:03 PM
Muffler deleted! speed3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 03-20-2008 09:29 AM
Page generated in 0.57915 seconds with 38 queries
