 Old 07-10-2019, 10:46 PM   #1
NickW253's Avatar
Posts: 3   (View Stats)
NickW253 is an unknown quantity at this point
Default 2011 Speed3 Headlight issue
I'm gonna start this off with saying hi, I'm new to the forum, this is my first post. I've searched the forum before posting this, I've scoured the internet for answers to no avail so I am posting to forums much like this one in hopes someone has an answer.
With that said, let's get started.
I just bought my 2011 used a couple of months ago, tech package with adaptive bi-xenon headlights, no DRLs. My passenger side light went out, I bought a cheap pair off of Amazon in hopes it wasn't the ballast (I know this is stupid, but in the heat of the moment I didn't think to just pop in the driver's side bulb to see if that would work). Luckily, it wasn't the ballast.
However, through doing this I encountered another issue. The plastic POS that holds down the retention spring bars (whatever you would like to call them) for holding in the bulb/igniter busted off, and now my headlight no longer stays in and inevitably gets vibrated out of the igniter. Naturally, I tried super glue, but obviously I knew this would not be a permanent fix.
My hopes are that is it possible to just buy the halogen pigtail harnesses and a set of halogen headlamp assemblies to replace these as I don't want the potential (expensive) issues and upkeep that come with having HID headlights. That, or a suggestion for a replacement that doesn't cost me 700-800 bucks. I've looked, but it's hard to find these specific headlights. Any help at all is appreciated.
NickW253 is offline   Reply With Quote
 Old 07-11-2019, 05:17 AM   #2
Jeff23spl's Avatar
Posts: 1,941   (View Stats)
Just get a used one, you may also get it from high end gt model maybe if you compare part numbers...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-11-2019, 06:42 AM   #3
NickW253's Avatar
That's still at least 600ish bucks. I did find one that was 300,but it didn't have the adaptive lighting and I'm not sure if that would cause a problem
 Old 07-11-2019, 07:26 AM   #4
Jeff23spl's Avatar
make sure the non adaptative isn,t a standard halogene...
but keep searching, i would definitely won't pay 600$ for a used headlight....it still worth 2-300$ but 600 is expensive.....Look a personal people with blown speed that part it out instead of repairing it.
Wife drive 2010 CX7
 Old 07-11-2019, 02:42 PM   #5
Chigga311's Avatar
Posts: 42   (View Stats)
Chigga311 is a splendid one to beholdChigga311 is a splendid one to beholdChigga311 is a splendid one to beholdChigga311 is a splendid one to beholdChigga311 is a splendid one to beholdChigga311 is a splendid one to beholdChigga311 is a splendid one to beholdChigga311 is a splendid one to behold
Groaned at 6 Times in 2 Posts
Take a picture of it.
I've been searching for the same headlight and they're stupid expensive.
Used or Aftermarket.
There is something called Quick-Steel which is a Putty Epoxy which is SUPER EASY to use.
All you do is knead if for about 30sec to a min, then form it on the broken piece.
It dries quickly about 3 Min I would guess.
Chigga311 is offline   Reply With Quote
 Old 07-11-2019, 09:04 PM   #6
NickW253's Avatar
I think I will try the putty. Definitely better than either option.. I appreciate the advice, both of you.
 Old 07-12-2019, 06:07 AM   #7
Jeff23spl's Avatar
you can give it a try, it cannot be worse anyway.
take a picture of the broken part...just in case it could be a standard part that you could take out from a cheaper or older light assembly....
Wife drive 2010 CX7
OEM HID Headlight Issue Duey1083 Gen2 MS3 General Discussion 3 10-20-2016 07:18 PM
2011 speed3 sport headlamp adjustment issue dirtybeef 2010 MS3 - Troubleshoot/Diagnostics 11 10-11-2016 04:03 PM
2011 MS3 Headlight Issue..Need Input I_Heart_Haters 2010 MS3 - Troubleshoot/Diagnostics 22 02-27-2014 09:06 AM
Headlight Issue--Please Help! maz612 MazdaSpeed 3/6 - Car Audio & Electronics 7 09-07-2013 05:21 PM
Porsche recalls 2011-2012 Cayenne SUVs over headlight issue Haltech Automotive News 0 02-27-2012 07:50 AM
Page generated in 0.28002 seconds with 22 queries
