-   -   2012 factory freaks? (http://www.mazdaspeedforums.org/forum/f544/2012-factory-freaks-109318/)
melbaro 03-29-2012 03:01 PM
@phate thanks for the interesting info regarding the 2012's you've worked on.
There seems to be a trend noticed by our PERM magicians that the 2012's are showing amazing numbers in comparisson to previous model years.
Have any of you got VD or logs of cars with similar mileage and mods that we can take a look at to see if Mazda is up to something here?
@Bucker
@rfinkle2
@atvfreek
@Lex
SofaKingAwesome 03-29-2012 03:02 PM
because skyactiv yo.
abiezerf 03-29-2012 03:05 PM
I just bought a 2012, it is completely stock. I can do a few pulls and see what the logs show. I can report back this weekend.
melbaro 03-29-2012 03:06 PM
From what I hear, the skyactiv's run a ridiculously high compression ratio and on 87 octane...apparently they come with a fuel pump that pushes out astronomical psi. I was under the impression that a high compression ratio need premium, but this fuel pump negates that. I may be in way over my head, but please let me know if this is something we can look into?
SofaKingAwesome 03-29-2012 03:07 PM
I was definitely kidding, but am interested to see if anyone finds some differences like the piston heads from 2010/2011
phate 03-29-2012 03:08 PM
Thanks for posting. I'll have a look through my files for older model years results.
Noodlesincup 03-29-2012 03:09 PM
Originally Posted by IAM (Post 1334444)
From what I've hear the skyactiv's run a ridiculously high compression ratio and on 87 octane...apparently they come with a fuel pump that pushes out astronomical psi. I was under the impression that a high compression ratio need premium, but this fuel pump negates that. I may be in way over my head, but please let me know if this is something we can look into?
Wait your talking about sky active not mazdaspeed 3 making awesome hp?
I drive a 2012
melbaro 03-29-2012 03:13 PM
I drive a 2012
Topic derailed a little there. Definitley talking about the Speeds (not sure if some form of Skyactiv technology is being implemented in 2012's though).
abiezerf 03-29-2012 03:13 PM
I drive a 2012
No man! This is a Mazdaspeed forum not SkyActiv. He is saying that 2012 Speeds are pushing higher numbers with the same setup as previous years.
SofaKingAwesome 03-29-2012 03:20 PM
I drive a 2012
Please go away.
UnknownSuperhero 03-29-2012 03:23 PM
http://www.animated-gifs.eu/leisure-...egger/0005.gif
Because 2012
Noodlesincup 03-29-2012 03:23 PM
Originally Posted by SofaKingAwesome (Post 1334482)
Please go away.
Hehe I remember you always hating me lol
Ahhhh I see
How much higher are we talking about here?
Lmk if I can help with anything
StayBroke 03-29-2012 03:30 PM
Girl cruze runs on 87 and i dont no how it does it. 30 in the city 38 on highway
Lex 03-29-2012 03:45 PM
Give them a chance to get a few miles on the cars. We already know there are improvements from gen1 to gen2 (pistons, ECU/tune etc) but generally as valve deposits accumulate, the turbos get some wear, etc. things start to level out power wise.
The gen1s and ms6s also had a nasty habit of losing compression over time. Whether it was carbon deposits on the rings seizing them or worn cylinder walls due to fuel spray - hard to say. The piston upgrade for the 2010+ cars I think addressed some of these issues.
Do any of you gen2-ers with higher mileage cars test compression? (http://www.mazdaspeedforums.org/foru...95/index8.html)
makjur 03-29-2012 03:47 PM
I thought the DISI motor has been thr same since the first speeds in 06 (or 07, brain forgets numbers) and skyactive is only available on 2012 mazda 3 in the 2 liter motor...
Probably wrong tho
Voltwings 03-29-2012 03:52 PM
i have a 2010, my neighbor has an 11, and our friend has a 12. Of the 3 of us with generally the same mods (in sig) the 2012 holds noticeably more boost than our 11/12. Now the 11 and i are able to run more timing (all tuned by same guy) so this may explain the 12 not being able to get away from us in a race, but then again it may just be his car / driver mod at that point.
zpele 03-29-2012 03:52 PM
This thread fails so fucking hard.
http://www.failfunnies.com/38/images...reath-fail.jpg
kritz 03-29-2012 03:55 PM
Because Pu? lol
abiezerf 03-29-2012 04:19 PM
Originally Posted by zpele (Post 1334542)
I cant groan you cuz I'm on mobile, but screw you man.
Sent from my PG86100 using Tapatalk 2 Beta-4
VitViper 03-29-2012 04:31 PM
GenPu 4tw?
@Lex, we'll see how my 2012 ages. I had a previous DI car (08 GTI) that never showed any signs of "aging" after 27.5k miles. But apples to oranges in that case...
Bucker 03-29-2012 04:49 PM
Wrong.
The late production 2011s/ some 2012s seem to hold more boost with lower WGDC. I think they may have modified/ changed producers for the Wastegate setup during this timeframe.
Voltwings 03-29-2012 04:58 PM
Originally Posted by Bucker (Post 1334671)
Wrong.
@ms3_150 this may explain Jeffs badass boost haha
MSFer87 03-29-2012 05:02 PM
Def. interested in this more.
Proshop 03-29-2012 07:42 PM
In before engine swap of wife's Skyactiv into my Pu for awesome MPG's and pretty blue engine cover (all i got for an engine cover was this ugly silver metal thing). I have logs of 2012 Pu if needed.
fortressofcomfort 03-29-2012 11:57 PM
Well track season isn't too far away and that should help us learn a bit more. This will be the first time we get some 2012s out there right?
Has anyone considered that maybe Cobb, not Mazda, is changing things? :naughty:
VitViper 03-30-2012 12:07 AM
I already went out once, OEM down to the tires aside from my Intake/internals/tune... 14.0 @ 108 (well, 107.83 but who doesn't round that shit up?). This is at PIR, which is completely unprepped, so it pretty much blows.
breakfstincluded 03-30-2012 12:40 AM
We're talking about genpus??
well... fuck.
dhsieh911018 03-30-2012 12:46 AM
hmm i actually remember a thread talking about an improvement on the shape of the cylinder head...
phate 03-30-2012 06:50 AM
I'm gonna call mazda motorsports, then. Those lazy fucks don't open til like 10am western time.
Edit: The piston design changed in the second gen's, of that I'm sure. Hadn't heard anything about the head, though.
SlickDevil 03-30-2012 10:47 AM
i just got my 2012 speed 3 and im subed into this thread wondering what the outcome is
Holy Beach Balls Aquaman It's Tapatalk
chintastic 03-30-2012 05:17 PM
interesting....
dhsieh911018 03-30-2012 05:34 PM
oh i mean piston... lol
86AmishMs3 03-30-2012 08:53 PM
Jesus! did you land a 2.6+ 60ft??
MS3-a(sore)ASS-rex 03-30-2012 09:07 PM
This thread is a cluster fuck. Half of you know what you're saying and the other half doesn't even know what the topic is.
I've discussed this discovery with @Bucker before and I think we ended at a new style of wastegate or possibly even boost control as the reason. A change in piston head design wouldn't alter how the turbo holds boost.
Edit: another viable option (and this one actually makes the most sense to me in retrospect), would be that the exhaust side on the turbo for those production years is a bit larger.
VitViper 03-30-2012 09:25 PM
2.49, not a whole lot better lol
Werm 03-30-2012 09:53 PM
dont think anyone would believe; but look at my sig for pow'a #'s. Completely stock numbers
VitViper 03-30-2012 10:20 PM
I'm not surprised... Mine where always like 270-280 on straight pump with intake & tune.
G26 03-31-2012 06:41 AM
fuckin 2012's. Although I have tuned a 2011 and 2012 with my same mods, and they both need more wastegate to hit the same boost as me. Of course i have a grim speed, but it is in 2 port.
3rd gear wgdc goes from 40-30-80
4th gear 30-30-30-60
5th- 20-20-20-40
If it was different boost control than that would explain a difference with the oem tune, but once you do a custom tune, and you see higher numbers with the same mods than it is either because the car is newer, or there is something mechanically different.
VitViper 04-01-2012 02:20 AM
Of all the cars I've owned I've never had one make more power than the others like it. Sure maybe a 3-5hp variance from the "norm", but nothing like this, whether the motor had 1k or 50k on it... I'm inclined to believe the difference is something mechanical. But I'm not inclined to take my motor apart to find out what, so I guess we'll know when a 2012 spits out it's guts... heh
fortressofcomfort 04-01-2012 02:22 PM
True, plus the likelihood of getting a 'ringer' as they call it nowadays is even less, what with all the precision robotics and quality assurance programs modern cars go through.
Manufacturers change parts and suppliers all the time. With a modern car having around 15,000 parts, there are bound to be significant changes even mid-year.
Page generated in 0.20577 seconds with 11 queries
