 Old 10-16-2019, 03:47 PM   #1
CombatVet89's Avatar
Posts: 16   (View Stats)
CombatVet89 has a spectacular aura aboutCombatVet89 has a spectacular aura aboutCombatVet89 has a spectacular aura about
Default 2012 MS3 brake light bulb
So I was trying to replace one of my brake light's bulb and not sure if you have to remove the assembly in order to remove it. Usually you just turn and pull, and it should come off. But earlier, I tried twisting it and it just wont come off. I didn't want to twist it hard and end up breaking the socket. I posted the picture below, the one with the harness off is the brake light. Also, what the hell is that yellow thing ( the sponge-looking thing)?
CombatVet89 is offline   Reply With Quote
 Old 10-16-2019, 04:11 PM   #2
Also, the manual says:
Due to the complexity and difficulty ofthe procedure, the LED bulbs should bereplaced by an Authorized Mazda Dealer. LED bulb replacement is not possible. Therear combination component must be replaced.
Looks like this bulb is built-in
 Old 10-17-2019, 09:26 AM   #3
manu's Avatar
Posts: 79   (View Stats)
manu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of light
Groaned at 7 Times in 5 Posts
Exactly u d have to buy the whole thing unfortunately
Sent from my SM-G955U using Tapatalk
manu is offline   Reply With Quote
 Old 10-17-2019, 10:07 AM   #4
tegxsi's Avatar
Posts: 1,251   (View Stats)
Groans: 87
If you have the tech package with LED tails then the brake light isn't serviceable. The turn signals can be replaced.
Is it common for the red LEDs to fail? I know they sell aftermarket replacements.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 10-17-2019, 02:18 PM   #5
Didn't fail, I was going to replace it with something 'brighter'.
Fog Light Bulb Size PapaSmurf Exterior 16 05-03-2019 11:20 PM
e-brake light, abs light, dsc light, and traction control light DarrenMon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-27-2016 08:44 PM
light bulb warranty jlsspeed4 Gen2 MS3 General Discussion 13 11-07-2011 06:52 PM
Page generated in 0.25794 seconds with 23 queries
