 Old 01-05-2019, 01:40 PM   #1
PuhtenPants's Avatar
Posts: 6   (View Stats)
PuhtenPants is an unknown quantity at this point
Default 2013 Mazdaspeed 3 groaning noise at a low rpm
My 2913 Mazdaspeed 3 has a ETS top mount, a Cobb SRI a Cobb TIP, high pressure fuel pump internals, a Cobb Downpipe and a tune. I've been having this groaning noise for the past couple of weeks and it doesn't matter what gear I'm in and I'm iddling it will make it at a low rpm. It's not very consistent, it comes and goes about every 3 to 4 times of me getting range from 1300 to 2500 rpms. The noise is coming from the right side of the engine bay it sounds. But I cannot pinpoint the exact location. I've searched everywhere and I cannot find someone with a similar problem. Please help.
PuhtenPants is offline   Reply With Quote
 Old 01-07-2019, 12:41 PM   #2
crankshaft's Avatar
Posts: 567   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
Hard to hear in the video. Sounds like a loose heat shield - thin metal vibrating.
2012 MS3, CWP
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 01-07-2019, 01:13 PM   #3
Ya it was the heat shield on my exhaust I tightened that down after the video, but did you hear the sound at the very end of the video?
 Old 01-08-2019, 01:19 PM   #4
crankshaft's Avatar
whistling noise?
2012 MS3, CWP
 Old 01-08-2019, 02:10 PM   #5
Quazz236's Avatar
Posts: 10   (View Stats)
Quazz236 is an unknown quantity at this point
The sound in the end is very close to worn out brake pads sound, but you're obviously stationary. At first I thought it was that whine type sound I hear when I press the brakes at lower rpm to stop(I think its from the trans components winding down). But it's definitely different. Way closer to the worn pad sound. Sorry if this isn't useful. I've owned my MS3 for only few month so I'm still mostly learning.
Quazz236 is offline   Reply With Quote
 Old 01-08-2019, 02:34 PM   #6
Ya listen at the very end if the video, turn up your volume all the way up it sounds like a whine or metal on metal. I'll take another video when I get home
 Old 01-08-2019, 06:04 PM   #7
crankshaft's Avatar
does it make the same noise if you hold the clutch in? (rule out clutch/gearbox)
2012 MS3, CWP
 Old 01-09-2019, 03:31 PM   #8
It does still make the noise when the clutch is put in. It makes it no matter what gear the car is in, if its in idle, or if the clutch is out or not. Thanks again for your help. If I just let the RPM's drop in neutral the RPM's will stop moving completely until the noise stops, and then continue to drop like normal. The car accelerates just fine as well.
 Old 01-10-2019, 12:34 PM   #9
Jeff23spl's Avatar
Posts: 1,746   (View Stats)
A/C bearing / clutch ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 01-10-2019, 02:16 PM   #10
I'll take it apart on Monday and see if it needs reolaced. I'll keep you posted. Thanks for the inout
Groaning noise when going slow - ideas? hypercar Gen2 MS3 General Discussion 74 06-08-2013 03:11 AM
Front end groaning/warranty work cesaros Gen2 MS3 General Discussion 21 03-27-2012 05:09 AM
Page generated in 0.29066 seconds with 24 queries
